Results 1 to 7 of 7
    Jun 2009
    Default BMW X3 SYNCHRO ECU
    hi freind's, please i need help for a bmw X3, 2007, original ecu is broken and i buy used one, please can someone help me to virginise the eeprom dump, or matching EWS and ecu, i have read eeprom ecu 95640, and EWS4 dump, i post them here and hope someone can help me, thank's a lot in advance.
    ecu BOSCH 0281 013 251
    DDE 7 801 711
    Thank's a lot
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    EWS4 dump is not ok
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
  3. The Following User Says Thank You to lupu_sandu For This Useful Post:
    aeroyas (11th April, 2016)
    Jun 2009
    thank s freind, i have read it with abritus, i try again and send new dump; thank's a lot in advnce
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    Read with AVDI?!?!?! Mate you need to read with 9s12 programmer.
  6. The Following User Says Thank You to lupu_sandu For This Useful Post:
    MV auto (11th April, 2016)
  7. #5
    Feb 2010
    Germany
    I?m not sure. You can try this dump. But maybe ISN is in flash. It?s worth a try. If not work, post full bdm dump.
    Good luck.
    Greetings MR...
  8. #6
    Feb 2010
    Germany
    I did a little research. I was on the right way. ISN in this ecu is in eeprom. I set ISN to 0000 with correct checksum. Maybe so you can align the ecu. You must make a sync with launch or whatever. If not work read ews4 eeprom, so we can set ISN from ews to ecu eeprom. This must work...
    Greetings MR...
  9. #7
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Try to send messege to "OMINIMICU", he will give 100% solution!
