1999 renault clio
Think uses id33
Customer had all keys lost. Is this able to do by OBD
1999 renault clio
Think uses id33
Tools owned -
clio 2000 year, sagem bmt does not even connect to uch
auto Clio, ecm safir, uch sagem-RET not connected!
RET maybe but as it turned out not everything
i use it all days , never fail in listed key function , Clio 2018 = 1 minute = Clio 1998
Catalizator (17th August, 2019), p1et (17th August, 2019)
RET may not work? How can I find out what's wrong?
Hello
Another good experience two megane 3
Two cars programing card fail maybe wrong China card, but after abs fault on the two.
I think maybe dangeours tool...
Any help with procedure and bad cards?
Enviado do meu iPhone usando o Tapatalk
I think ABS fault will dissappear after car will be driven for some short distance. And always use original card, you can buy used for good price and renew.
bocaje (17th August, 2019)
erase immo in ecm and cut immo line.
