Page 21 of 35 FirstFirst ... 11161718192021222324252631 ... LastLast
Results 301 to 315 of 514
  1. #301
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by Jimmy07 View Post
    What is Best Buy for programming keys Can ECU tool or Renolink ?
    ecu too have much better virginise options.. HFM, ecu, immo...etc, Simply qick GUI.. Key lerning is extremely fail proof, far better hw. I have both and ecu tool is always my first choice.
  2. The Following User Says Thank You to jodge For This Useful Post:
    Jimmy07 (7th October, 2019)
  3. #302
    Oct 2018
    Romania
    I programmed chinese cards with PCF 7941 and PCF 7952 on some Megane 3. I will try Clio4 with PCF7953.
  4. #303
    Top Poster admiralx's Avatar
    Apr 2012
    news for update ???????
    2.88 from 5-6/2019
  5. #304
    Dec 2016
    Quote Originally Posted by admiralx View Post
    2.88 from 5-6/2019
    it's free since beginning of tool , relax , for £600
    Rest of update available for this tool Twingo 3 Trafic 3 coming soon ..... & the END ( no tag key tool no can doing Megane 4 system )
  6. #305
    Feb 2009
    Hello.and for duster Ph3?
    Sent from my SM-N950F using Tapatalk
  7. #306
    Oct 2018
    can renolink write a remap dpf off file? i have file ready i just need to write. i used clone kess to read but not able to write through protocol sid 305 but read ok. or would anyone know what i can buy to write this file please, preferably the cheapest option
  8. #307
    RIMKACHIP's Avatar
    Feb 2012
    Here is Renault ecu tool not renolink but I think renolink can not write flash on sid305 ( I think). Renault ecu tool not possible.
    Envoyé de mon iPhone en utilisant Tapatalk
  9. #308
    tek2dk's Avatar
    Oct 2012
    under the sea
    Read & Write a lot of SID 305 with kess!
  10. #309
    Mar 2019
    Moldova
    Hello! who knows why a sim card is installed on the board?
  11. #310
    Dec 2016
    Quote Originally Posted by tankist83 View Post
    I/O terminal HW , activated by SIM card !
  12. The Following User Says Thank You to TERMINATOR1000 For This Useful Post:
    tankist83 (11th October, 2019)
  13. #311
    sdnatlst's Avatar
    Aug 2011
    England
    Today had espace IV 2005
    all keys lost,, they order card from dealer.
    Renault ECU tool connect OK - SECURITY login error , cannot go any further.
    Also tried lonsdor, Autel,, all gave pin password pull error or security access validation failed.
    So obviously problem car side,,, but any ideas ?? Car battery was dead, and had brand new battery fitted same morning. Just wondering what could cause it.
    Only DTC error code found was Start button fault, but igniton was OFF which is what ECU tool said was required.
    Tools owned -
  14. #312
    scotland clydebank
    being a Renault wiring fuses earth the list is endless is the car being sitting for a while also check card reader very common on these
    vehicles can just try a second hand one.
  15. The Following User Says Thank You to godfathertre For This Useful Post:
    sdnatlst (18th October, 2019)
  16. #313
    sdnatlst's Avatar
    Aug 2011
    England
    All tools said no card should be inserted, and ignition should be OFF
    so i cant see a card reader fault being anything to do with not pulling the pin code, or security access problem?
    it was the PRE 2005 model according to ECU tool, (white light near reader) which was correct when i checked the light.
    but yes, car had been sitting for a while, just thought strange all tools connect fine, just cannot get the security/pin
    Tools owned -
  17. #314
    Apr 2014
    clear all codes in ecu and uch battery at 13v and leave side lights on as akl
  18. #315
    Oct 2015
    yesterday tried add new card clio 4 from 2014. old card repreogrammed normal, new recognised as unknown blank card and of course not accepted by car. some device recognise booth original and new(original also) cards 4A. tango recognise booth cards as manchester regular card unknown. tried renewed card with A2C53419439 stamp at board and same. are there trick, my cards are wrong or renault can tool can't do it?
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  19. The Following User Says Thank You to rokibar For This Useful Post:
    bocaje (24th October, 2019)
