Page 22 of 35 FirstFirst ... 12171819202122232425262732 ... LastLast
Results 316 to 330 of 514
  1. #316
    sdnatlst's Avatar
    Aug 2011
    England
    can this do DACIA LOGAN 2016 all keys lost? think its HITAG 3 key
    Tools owned -
  2. #317
    POLAND
    Quote Originally Posted by rokibar View Post
    yesterday tried add new card clio 4 from 2014. old card repreogrammed normal, new recognised as unknown blank card and of course not accepted by car. some device recognise booth original and new(original also) cards 4A. tango recognise booth cards as manchester regular card unknown. tried renewed card with A2C53419439 stamp at board and same. are there trick, my cards are wrong or renault can tool can't do it?
    I did Clio 4 2014 year without problems Renault Ecu tool.
  3. The Following 2 Users Say Thank You to voltec For This Useful Post:
    RIMKACHIP (24th October, 2019), rokibar (24th October, 2019)
  4. #318
    Oct 2015
    Quote Originally Posted by voltec View Post
    i am sure no tool problem but my new card is original for clio4 and renewed card has marked proper numbers for this car. no goes.
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  5. The Following User Says Thank You to rokibar For This Useful Post:
    alclot (24th October, 2019)
  6. #319
    sdnatlst's Avatar
    Aug 2011
    England
    Dacia logan 2016. All key lost hitag3.
    Didn't work. Pulled pin and isk OK
    Went to program new key. Says TP authorisation fail
    I think it needs working key first?
    Can anyone confirm
    Tools owned -
  7. #320
    RIMKACHIP's Avatar
    Feb 2012
    Default Renault CAN/K-line ECU Tool
    What did you use ? Pcf7939 or remote key ? Status of your key by ecu tool : programmed not virgin. I think there is problem with your key or precode of your key.
    Update to 2.88 and test.
    Envoyé de mon iPhone en utilisant Tapatalk
  8. #321
    sdnatlst's Avatar
    Aug 2011
    England
    I used a remote key. Virgin.
    Are we sure it can do AKL on these ? Who has tested.
    Tools owned -
  9. #322
    Jan 2016
    In my case I can not add key in logan2 via Renault ECU tool-(((
  10. #323
    sdnatlst's Avatar
    Aug 2011
    England
    Did you get same error?
    Tools owned -
  11. #324
    RIMKACHIP's Avatar
    Feb 2012
    If you can read isk and pincode you can add key !! ( I think). AKL not working in case you can not read isk and pincode or maybe precode of key is not good.
  12. The Following User Says Thank You to RIMKACHIP For This Useful Post:
    sdnatlst (24th October, 2019)
  13. #325
    Dec 2016
    tested on AKL 2012 > 2018 DACIA , work fine with last 30 key !
    your key is bad quality ...
    you have PIN & ISK , job is done , just need to bought an decent key
  14. The Following 6 Users Say Thank You to TERMINATOR1000 For This Useful Post:
    godfathertre (24th October, 2019), looking77 (25th October, 2019), PocketHero (25th October, 2019), RIMKACHIP (24th October, 2019), sdnatlst (24th October, 2019), Team dz (5th November, 2019)
  15. #326
    Oct 2015
    i tried with latest version 2.88. who did it can remember which version used? maybe bug inthe latest software?
    anyone?
  16. #327
    jodge's Avatar
    Mar 2017
    anyone?
    keep the older versions of sw every tool when the downgrading is possible. like vvdi prog, ecu tool etc... If you have problem with the latest version you can roll back to the older and tested.
  17. The Following User Says Thank You to jodge For This Useful Post:
    rokibar (25th October, 2019)
  18. #328
    RIMKACHIP's Avatar
    Feb 2012
    Quote Originally Posted by sdnatlst View Post
    AES key ? Key must be 4A look like clio 3 but not id46.
  19. #329
    Jan 2016
    2 version of UCH are installed in Logan2 - Visteon & Continental, as i know
    Visteon is unreacheable in curent(2.88) version
    EU cars equipped by Continental UCH
    RU cars equipped by Visteon UCH
  20. #330
    Dec 2016
    STOP fake news , ISK & PIN code are reading by tool , 100% work 2.88 .
    I tested all functions of this tool every days , is simply de best & safe tool for Renault / Dacia cars
    tool says problem with key = problem with key
  21. The Following 3 Users Say Thank You to TERMINATOR1000 For This Useful Post:
    bocaje (25th October, 2019), PocketHero (25th October, 2019), rokibar (25th October, 2019)
