Hello
Sorry to Make sad update 2 megane III from 2014 month june fail tested more than 10 cards virgin, maybe too expensive tool for This fail.
Please help if i do anything wrong
Enviado do meu iPhone usando o Tapatalk
Hello
bocaje (26th September, 2018), whiskeyman (25th September, 2018)
Hey. To program the card, you need to take a pin-code somewhere, or does the program do everything yourself?
It will find pin automatically,
About the Koleos key cards that are sold like megane 3 cards.The spacing in the card holder is made to hold nsn14.
So there is to much play to hold the va2 blade in place.
Pulling the card out, is almost impossible, the blade always comes loose.
NSN14 blade 8.7mm width
Va2 blade 7.3mm with
So i am looking for better cards, with logo.
MVVL (26th September, 2018)
To bind a map using Renault CAN/K-line ECU Tool you need to have a pin code or the program itself finds or does not require a pin code?
Not require a pin code. Program card/key without PIN code.
Yes, on the megane 3, used the latest V2.70 version.
Worked fine.
doctore (27th September, 2018)
Update .... clio 2015 /11 not possible key learning with key available. Even with pin bypass.
Bigining to wish never purchase it
Hello
What is the problem during procedure ?
Post an video
bocaje (2nd December, 2018)
As your picture not quite iqual as i use version 2.7 but no info or change in latest software só no diference in This function, so after that nothing hapens... just close and wait for comands
If i did something wrong please help
did you have a booster pack on the car i myself i am very impressed just done a clio 2000 with sagem ecu that could only be done before by eeprom now can be done by obd by this tool the developer is trying
hard version 275 now i have nothing but good about this tool just buy the equivalent tool from arbitrates or truecode and see the difference in price alone this tool covers 90 percent of renault vehicles .
Clio IV 2017 AKL - read reader dump (Upa-S), load dump, add HitagAES OK.
Still wait for EDC16 read option :/.
I have the tool and I am very happy with it, no complaints for today.
a question, it is possible to read eep of a megane UCH UCBIC 68h05b16 of the first with infrared key, can clone in another unit? Once I tried, I could not, I do not know if I was doing it correctly, any comments about this work?
excuse my English, is the best.
