Page 9 of 35 FirstFirst ... 456789101112131419 ... LastLast
Results 121 to 135 of 514
  1. #121
    Dec 2016
    Quote Originally Posted by Catalizator View Post
    follow the requirements.
    It's not an AKL situation , just additional card on 2015+ car
  2. The Following User Says Thank You to TERMINATOR1000 For This Useful Post:
    doctore (17th December, 2018)
  3. #122
    Apr 2016
    Quote Originally Posted by jodge View Post
    and did you pushed that button? Right bottom corner "enable read pin (2015+)"
    Yes yes. The inf is the car software do not Need This after 2015 enable...
    Enviado do meu iPhone usando o Tapatalk
  4. #123
    Apr 2016
    Quote Originally Posted by TERMINATOR1000 View Post
    no ! you see any log of this command ???
    Of corse i did ... is says This car does not need no plus 2015 software car
  5. #124
    Dec 2016
    Quote Originally Posted by bocaje View Post
    made an video , i understand nothing of your stories !
  6. #125
    castin's Avatar
    Oct 2015
    After 2015 need one working card OR need read HFM and load dump. Its simple and easy - working 100%.
  7. The Following User Says Thank You to castin For This Useful Post:
    bocaje (18th December, 2018)
  8. #126
    Apr 2016
    Quote Originally Posted by castin View Post
    Ok thanks for the help.
    For terrminator No video needed mate i think you understand what i told im not stupid and i try all the options....
    Conclusion not all the clios IV possible via obd still if card available….im also contacted the seller if any inf ill tell.
    thanks for the helpers
  9. #127
    Nov 2010
    I have exactly the same issue. 2015 Captur. Tried to add card using v2.75. Same issue. Reading isk FAILED. Tried all options. Not lost Card. Only wanted to add card.....
  10. The Following User Says Thank You to ponty For This Useful Post:
  11. #128
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Quote Originally Posted by ponty View Post
    Did you update to 2.77 and test again?
    Greetings,
  12. #129
    castin's Avatar
    Oct 2015
    ClioIV FL/Captur its the same system. After 2015 AKL (all key lost) must hawe dump from HFM. Its cleary info on product site and software info. Meybe next update or after add Megane IV/Espace V option.
    If add card captur after 2015 not work, then must wait for update .
  13. #130
    Apr 2016
    Correcting you clio 2015 one working key ... no Isk read even with enable pin.
  14. #131
    jodge's Avatar
    Mar 2017
    It seems it's something new sw and the ecu too doesn't support yet. Contact the support or dump the HFM or wait for update or leave it.
  15. #132
    Dec 2016
    all is OK , add an supplementary card not possible
    before push button "key programming" , need RESET PIN CODE PROTECTION with push button "enable read PIN code 2015 +" , if you don't do it always same issue ISK failed ....
    Or simply use ORANGE 5 to read NEC 70f3633 and sell card 50€ upper price
  16. #133
    Dec 2016
    Not possible , need online procedure ( fvdi & zedfull ) + make dealer key !!!!
    no server available and no tag key tool exist , this is the limit of Renault EcuTool , just an immo bypass by OBD2 is possible to theft the cars
  17. #134
    castin's Avatar
    Oct 2015
    Meybe yes, meybe no - im wait. Abrites hawe new update fir meg iv, scenic v.
  18. #135
    Dec 2016
    IS IMPOSSIBLE , NEED AN DEALER KEY & tag key to pré-code ISK + ONLINE CONNECTION to calculate ISK ....
    maybe ( sure ! ) AES keys for trafic 3 , sandero 2 , twingo 3
