Results 1 to 4 of 4
Thread: X5 Channel List
    Sep 2013
    Default X5 Channel List
    Hi, does cwaites or aj's channel list work on the x5 box? Is it the same install procedure as the f5, v8s, etc?
    DK Veteran mini's Avatar
    Apr 2008
    W Yorkshire
    No they are not compatible, X5 file is .bin format
    the other boxes are .dbs
    but the procedure is the same.
    1 ... Unzip the file and save the DB(00000004).bin file to a USB Stick.
    2 ... Insert the USB Stick into the front USB port on the OpenBox X5.
    3 ... Press Menu -> Edit Channels -> Load DB and load the DB(00000004).bin file
    Sep 2013
    Cheers mate, but where will i find the channel list?
    P&D's Avatar
    Hi here you go but they are Aj's list dated 4-8-14
