seat ibiza 2011 1.2 TDI
VSSZZZ6JZCR024179
6R 907 379AD
ABS8.2 front H03 0001
VSSZZZ6JZCR024179
6R 907 379AD
Try this:
A63B40F8092500FC650F02E8901F0081211000
lush29 (22nd September, 2016)
Seems that the coding is not valid.
a couple of questions:
Does your car have automatic distance control/braking system? Adaptive cruise control?
Does your car have the SET button in center console or glove box? (This is used for TPMS reset)
Could you please post a sticker with PR numbers of your car? A few memebers have posted it before.
* MK100;
Hi hid3 thanks for coming back to me. For sure car not have the SET button. I dond think she has automatic distance control or adaptive cruise control( how can i check) and i attached pic with pr sticker. Thank you.20160923_141154.jpg
Sent from my SM-G925F using Tapatalk
J428 seems to be like Adaptive cruise module... Look at the front grill. VW logo, or lower grille. Is there any sensor in the center of the car?Based on your PR numbers, the coding might be slightly amended:
With front disk brake diameter (280 mm), 2 stage ESP-off switch and Adaptive Cruise Control:
A63B20F8092580FC650F02E8901F0181011000
With fron disk brake diameter (280 mm ) and 2 stage ESP-off switch:
A63B20F8092580FC650F02E8901F0181211000
With proper front disk brake diameter (280 mm):
A63B20F8092500FC650F02E8901F0081211000
Give it a try from the top one, down to lowest. Be sure to adapt ALL the sensors in one ignition cycle. Do the adaptation on flat ground (ideally empty parking space).
* MK100;
Hi hid3 again all codes rejected. I can not adapt any sensors because is telling wrong coding. And i cant see any sensor on the grill or under. And is only sterring angle sensor light on and traction control light. Abs light and hand brake light are gone with the smokey codding. Thanks hid3 again for your hard work and not giving up.
Okay, now let's stick with working coding:
Are you able to adapt all the sensors which ar emissing adaptation? Note that you will need to use "Login" function for each adaptation. All should be done in one ignition cycle.
After all is adapted, is the fault code 'incorrect coding' still present?
* MK100;
Try these:
A63B20F8092500FC650F04E8901F0081210000
A33B20F8092500FC650F04E8901F0081210000
lush29 (27th September, 2016)
magicworx, Try this:
133B200D092900FAC80F04E8901F0080310000
today I swap instrunemt cluster (only in scientific expertise reasons) but if I put old inst. cluster back
this long coding:
11 50 60 0F 49 23 00 FC 88 13 06 E4 92 21 00 41 39 08 00 no match
My question is WHY??? if was nothing change in car configuration. What decide of matching long coding???
oudside temp.?
level of tank,
atmosferic pressure,
frequ. in radio ...
=== my ABS/ESP control unit!
it's me...
impossible is nothing...
Short answer would be "hell knows".
Long answer - are you swapping US region to EU region cluster or vice versa?
* MK100;
