Page 101 of 245 FirstFirst ... 519196979899100101102103104105106111151201 ... LastLast
Results 1,501 to 1,515 of 3668
  1. #1501
    Jan 2013
    This coding fits 11422012092200FD881240E4901C00423800 , but I have a error - inplausible signal from J500
  2. #1502
    Quote Originally Posted by HARYHARY View Post
    I have made mistake in byte10, this is correct:
    11424012092200FD881202E4901C00423800
    What steering assist you have, check adaptation channel of DSR function in it
  3. The Following User Says Thank You to 1 6 D For This Useful Post:
    HARYHARY (29th November, 2018)
  4. #1503
    Quote Originally Posted by rafal View Post
    audi A3 8P
    can somebody calculating coding please?
    vin:
    WAUZZZ8P59B024098
    ABS:
    1K0907379 CD
    LHD
    without start stop
    2.0 tfsi
    Original was other engine, check this:
    11424012092400FE880B02ED902100413800
  5. The Following User Says Thank You to 1 6 D For This Useful Post:
    rafal (29th November, 2018)
  6. #1504
    Quote Originally Posted by borysgo2 View Post
    Can someone help me with coding of caddy 2015 abs:
    WV1ZZZ2KZFX094405
    1K0 907 379 BS
    ESPMK60EC1 H46
    1.6TDI
    RHD
    MANUAL TRANSMISSION
    THANKS
    Maybe need some cosmetic changes:
    433C200D092B03FEC20F04E4901EC081A1040021
  7. The Following User Says Thank You to 1 6 D For This Useful Post:
    borysgo2 (29th November, 2018)
  8. #1505
    borysgo2's Avatar
    16D
    It worked like a charm.
    Thanks a lot !!!!
  9. #1506
    rafal's Avatar
    UK - PL
    all working well. thank you
    need help
    now my goal is to buy xp-005
    who will help?
  10. #1507
    Jan 2013
    11424012092200FD881202E4901C00423800 does not fit
    11424012092200FD881204E4901C00423800 does not fit
    11422012092200FD881204E4901C00423800 fit a J500 error has been detected but after setting the G80 G200 G201 and driving the ABS and ESP lights out. Thanks 16D.
  11. #1508
    Sep 2013
    VIN: WVWJ11607CT011448
    Car: VW Polo India
    Engine: 1.2 CFWA
    ABS: 6RF907379A H03 S0001
    Please help with ABS long coding
  12. #1509
    borysgo2's Avatar
    I have another caddy, 2013:
    1.6tdi
    conversion from DSG to manual gearbox
    Codding:
    633C400D092A03FFC60C02E5901FC081310000
    Can someone change coddig from lovley non problematic automatic DSG gearbox to manual please ?
    Big thanks.
  13. #1510
    What pump number?
  14. #1511
    borysgo2's Avatar
    Pump no
    1K0 907 379 BL
    ESPMK60EC1
    THANKS
  15. #1512
    Bulgaria
    hello need long coding for VW Polo 6r
    abs part number 6R0907379AS ESP9.0i
    1.2 Disesel engine manual transmition
    hatchback CFWA engine code
    vin is WVWZZZ6RZEY235383
    LHR , TPMS , ESP button
  16. #1513
    World
  17. #1514
    South Africa
    hi there any idea why coding gets rejected. i use original long coding copied to secondhand unit. coding rejected error 12. any idea dear friends. keep well.
    original info from faulty abs pump.
    Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
    Control Module Part Number: 1K0 907 379 CE HW: 1K0 907 379 AE
    Component and/or Version: ESP MK60EC1 H35 0120
    Software Coding: 13424012492A0000C80C02E5922200813900
    Work Shop Code: WSC 22708 003 1048576
    VCID: 77FD8DEAC68F76FEA0-8022
    1 Fault Found:
    01130 - ABS Operation
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 66
    Mileage: 205477 km
    Time Indication: 0
    Date: 2018.11.20
    Time: 17:15:04
    Freeze Frame:
    Count: 0
    Count: 0
    Count: 4608
    Count: 125
    Count: 48143
    Count: 2833
    Count: 0
    Count: 0
    secondhand unit info currently fitted to vehicle.
    Thursday,06,December,2018,14:32:51:16946
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
    VCDS Version: 17.8.1.0
    Data version: 20171130 DS276.6
    www.Ross-Tech.com
    Control Module Part Number: 1K0 907 379 CB HW: 1K0 907 379 CB
    Component and/or Version: ESP MK60EC1 H46 0174
    Software Coding: 0000000000000000000000000000000000000000
    Work Shop Code: WSC 00066 000 00000
    VCID: 74E7BAE6D7F91DE685-8020
    1 Fault Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 68
    Time Indication: 0
    Date: 2018.11.20
    Time: 07:00:33
    Freeze Frame:
    Count: 3
    Count: 12
    Count: 20992
    Count: 195
    Count: 45056
    Count: 8704
    Count: 0
    Count: 0
  18. #1515
    Jun 2016
    Hello
    i need long coding for
    W Jetta
    Vin WVWZZZ16ZDM006389
    ORIGINAL ABS 1K0 907 379 BL
    changed to 1K0 907 379 BK
    is possible to code BK for this car? with original coding is stored
    02085 - incorrect control module installed
  19. The Following User Says Thank You to Nezakabude For This Useful Post:
    rocken606 (16th March, 2022)
