Page 102 of 245 FirstFirst ... 25292979899100101102103104105106107112152202 ... LastLast
Results 1,516 to 1,530 of 3668
  1. #1516
    Nov 2018
    villa alberdi
    Hello friends! I need help with the long code of a VW, who suffered decoding when trying another dashboard on the vehicle. From already thank you very much! regards!
    ECU:
    HW: 0261S04612
    SW: 1037399540
    VIN: 3VWRG61K08AM036990
    ABS: 1K0614517BD
    MODEL:
    JETTA 2.5L
    YEAR 2010
    Hello friends! I need help with the long code of a VW, who suffered decoding when trying another dashboard on the vehicle. From already thank you very much! regards!ECU:HW: 0261S04612SW: 1037399540VIN: 3VWRG61K08AM036990ABS: 1K0614517BDMODEL:JETTA 2.5LYEAR 2010
  2. #1517
    Aug 2015
    Netherlands
    Default Long coding help
    1: Control Module Part Number: 1K0 907 379 AP
    2: car VIN -WVWZZZ1KZAW160332
    3: model : 5K1
    4: LHD
    5: 1.4 TSI
    6: FWD
    7: no start stop
    8: no TPMS
    9: yes ESP button
    10: no Hill hold
    Can you help me for Long Code
  3. #1518
    Jul 2018
    GOLF 6
    LHD
    2.0 TDI 81 KW
    VIN
    WVWZZZ1KZ9P475951
    ABSMODUL
    ESP MK60EC1
    1K0907379AD
    tpms
    somebady help
  4. #1519
    Jul 2018
    3: model : 5K1
    4: LHD
    5: 1.4 TSI
    6: FWD
    7: no start stop
    8: no TPMS
    9: yes ESP button
    10: no Hill hold
    113B200D092800FA880E04E7901B0040300000
    TRY THIS AND REPORT .
  5. #1520
    Nov 2016
    Hi.
    Please help .
    VW golf VI 2010r
    1,4 tsi
    ABS 1K0 907 379 AH ESP MK60EC1
    solved calculated the coding
    Last edited by kowalskidebno; 16th December, 2018 at 07:10 PM. Reason: solved calculated the coding
  6. #1521
    mobileworks's Avatar
    Buenos Aires
    hI ,PLEASE HELP FOR LONG CODING
    AUDI A3 2006
    MOTOR 2.0 FSI BVZ
    VIN WAUHS38P36A218353
    ABS 1K0614517AC CTA ESP
  7. #1522
    Nov 2016
    There is a short ABS coding in your Audi A3 !!!
    ABS/EDS/ASR/ESP (MK60)
    • Model:
      • +0000000 = Audi A3 (8P) / Seat Leon (1P) / VW Golf/Jetta (1K) / Skoda Octavia (1Z)
      • +0000064 = VW Touran (1T)
      • +0000080 = VW Caddy (2K)
      • +0000096 = VW Eos (1F)
      • +0000112 = Seat Altea/Toledo (5P) / VW Golf Plus (5M)
    • Frontbrakes (Sensor Cluster OLD):
      • +0000005 = FS III 54 15" (PR-1ZF/1ZM/1ZC)
      • +0000006 = FN III 54 15"/16" (PR-1ZE/1LJ/1ZP/1ZD/1LL)
      • +0000009 = FRNG 57 17" (PR-1LK)
    • Frontbrakes (Sensor Cluster NEW):
      • +0000001 = FS III 54 15" (PR-1ZF/1ZM/1ZC)
      • +0000002 = FN III 54 15"/16" (PR-1ZE/1LJ/1ZP/1ZD/1LL)
      • +0000008 = FRNG 57 17" (PR-1LK)
    • Suspension:
      • +0000640 = Standard/Sport Suspension (PR-2UA/2UC OR PR-UA0/UA1/UA9)
      • +0001152 = Rough Road/Comfort Suspension (PR-2UB/2UD OR PR-UA2)
    • Engine:
      • +0002048 = 1.4l / 1.6l & 1.6l FSI
      • +0004096 = 1.9l TDI PD / 2.0l FSI / 2.0l SDI PD & All with Automatic Transmission
      • +0006144 = 2.0l TDI PD
    • Tire Pressure Monitoring (TPMS):
      • +0000000 = with ABS based Tire Pressure Monitoring (PR-7K1/7K6)
      • +0016384 = without ABS based Tire Pressure Monitoring (PR-7K0/7K4/7K8)
    Notes: See production codes on car data plate. Coding is the sum of the individual options.
    Sensor Cluster OLD: Installed behind glove compartment (ONLY VW Caddy (2K) & VW Touran (1T) & Audi A3 (8P) <MY2005).
    Sensor Cluster NEW: Installed under passenger seat (All Others & Audi A3 (8P) MY2006>).
    Special Notes: When replacing 1K0-907-379-D with 1K0-907-379-K or newer, the original Coding CANNOT be transferred to the new Control Module. Instead you need to build a new Coding using the Table above.
  8. #1523
    Nov 2016
    pleas write coding
    0021206
  9. #1524
    borysgo2's Avatar
    Can some one help me with gearbox conversion from 7 spd DSG to 5spd manual:
    VW Caddy 2013
    Engine 1.6tdi
    FWD, RHD
    ABS: 1K0 907 379 BL ESPMK60EC1
    Ori codding - DSG gearvox: 633C400D092A03FFC60C02E5901FC081310000
    I need to get rid of DSG and putt 5 speed manual gearbox into the coding please.
    Big thanks
  10. #1525
    Jul 2016
    Vilnius
    The ABS coding in fact has nothing to do with the fault you are getting, seriously....
    You need to reflash your Engine ECU with a flash/sgo for manual trans and all will be fine
    * MK100
  11. The Following User Says Thank You to hid3 For This Useful Post:
    borysgo2 (4th January, 2019)
  12. #1526
    Oct 2018
    Hello friends I have big problem with my Golf VI ABS MK60EC1. I have changed the whole unit because old one was damaged. Before that I have read the original coding : 1462401A094A00222833020C904100403000. After replacing the unit I tried to code it with my original coding but it is rejected ... I tried few more codings but nothing works. Can you give me a helpful hand ?
    My car is :
    VW Golf VI 1.4 tsi, fwd, LHD
    vin : WVWZZZ1KZ9P465580 ; ABS pump : 1K0907379AD
    Greetings
  13. #1527
    Sep 2011
    please help with the following
    VOLKSVAGEN JETTA 2011 1.6 TDİ
    MK60EC1
    1K0907379BE
    LHD
    DSG
    WVWZZZ1KZBM043319
  14. #1528
    Sep 2011
    MK60EC1
    1K0907379BE
    LHD
    DSG
    WVWZZZ1KZBM043319
  15. #1529
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by emrahdamar View Post
    MK60EC1
    1K0907379BE
    LHD
    DSG
    WVWZZZ1KZBM043319
    one of these should be your Long Coding :
    A13B20F8092600FD850E04E59022004121100
    A43B40F8112600FD250E02E588220040211000
    A14B400C492600FD850E02E592220041A11800
    if My Post was useful Press Thanks and Rep Buttons
  16. The Following User Says Thank You to vagva For This Useful Post:
    kamolsfss (11th September, 2019)
  17. #1530
    Sep 2011
    Quote Originally Posted by vagva View Post
    Thank you so much I will try and let you know
