Page 104 of 245 FirstFirst ... 4549499100101102103104105106107108109114154204 ... LastLast
Results 1,546 to 1,560 of 3668
  1. #1546
    HR
    Hello!
    I need help with coding .
    abs 8.2
    6r0907379ae
    wvwzzz6rzbu000090
    polo cross
    lhd
    1.6tdi caya
    fwd
    no start stop
    indirect tpms
    no esp
    hill hold no
    edit ; solved
  2. #1547
    Jan 2019
    Hello!
    Can someone help with this?
    1. 1k0 907 379CC
    2. WAUZZZ8P39A011341
    3. Audi A3 8P 2008
    4. LHD
    5. 1,6 MPI (don't know BSE, BSF or other)
    6. FWD
    7. no start stop
    8. no TPMS
    9. Does the car have ASR/ESP off buttons (in the center console)? - Yes, it have
    10. "Hill hold" function. Do you want it to be activated if possible?" -Yes
    I try my old code from 1k0 907 379 AE:
    11 42 20 12 12 23 00 FB 88 0E 04 E8 48 1A 00 41 B9 00, but 1k0 907 379 CC have 19 bytes and
    11 42 20 12 12 23 00 FB 88 0E 04 E8 48 1A 00 41 B9 00 00 83 don't works
  3. #1548
    Jul 2016
    Vilnius
    Why did you decide to add 0083?
    * MK100
  4. #1549
    Jan 2019
    Hi I wondered if you could provide an ABS long code for my car, it’s lost it after a mega flat battery.
    1. Exact model of the car: VW scirocco gt
    2. Year of the car: 2009
    3. VIN in cluster: WVWZZZ13Z9V027446
    4. Right Hand Drive
    5. Engine type: 2.0tfsi
    6. FWD, Manual Gearbox
    7. Stock brakes:ABS pump is MK60EC1. H35 0120: 1K0 907 379 CD
    8. No Start-Stop
    9. Has ESP button
    Tia
  5. #1550
    Dec 2018
    Hi guys I’ll try again with more info
    looking for abs long code
    1. Exact model of the car: AUDI Q3
    2. Year of the car: 2014
    3. VIN in cluster:WAUZZZ8U2ER100139
    4. Right Hand Drive
    6. 4wd auto
    7. ABS pump is 5NO614109ba
    8. Has Start-Stop
    9. Has ESP button
    10. Has hill hold
    Last edited by Ylwgtr; 11th January, 2019 at 02:00 PM. Reason: Additional information
  6. #1551
    Jul 2016
    Vilnius
    Mate, I think nobody will be able to make your Q3 coding... Your best option now it official Audi dealership
    * MK100
  7. #1552
    Jan 2019
    Quote Originally Posted by hid3 View Post
    Just tried 0083 and 0012 and 0000 and other
  8. #1553
    Aug 2010
    hI,I amlooking for abs long coding
    1. 1K0 907 379 BL
    2. WV1ZZZ2KZDX054888
    3. VW Caddy 2012
    4. RHD
    5. 1,6 TDI - motor code CAYE
    6. FWD
    7. start stop - YES
    8. no TPMS
    9. NO ASR/ESP off buttons (in the center console)
    10. "Hill hold" function -NO
  9. #1554
    Hello ,
    I also have a VW Golf 2011 1.6 TDI , WVWZZZ1KZBP039304 , 1K0 907 379 AT MK60EC1 unit , coding lost due to test exchange of instrument cluster .
    The car does have an ESP off button , no TPMS (7k0), with hill hold (UG1) , without start/stop (7L3) , front brakes 1ZF 280 mm , rear brakes 1KD 253mm .
    Can you help with the coding ?
    Thank you.
  10. #1555
    I get an error 02186 in abs for adr interface. I believe someone has input bad or wrong coding in abs module.
    Can you help me get the proper coding?
    2011 VW Jetta Sportwagen
    2.0L TDI
    DSG automatic transmission
    Front wheel drive
    Left hand drive
    Tpms: disabled
    Esp button: yes
    Hill hold: yes
  11. #1556
    Jul 2018
    Hi can someone help, abs unit was replaced after failure and I am unable to read long coding from old unit the following is a scan by vcds, car has esp button on console
    VIN: WVWZZZ1KZ9W054758 License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 76
    VIN: WVWZZZ1KZ9W054758 Mileage: 180520km-112169miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 1010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: Cannot be reached 1100
    56-Radio -- Status: OK 0000
    76-Park Assist -- Status: Malfunction 0010
    Address 01: Engine Labels: 06F-907-115-AXX.clb
    Part No SW: 1K0 907 115 T HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0010
    Revision: 5BH16--- Serial number: VWX7Z0H53NA8QE
    Coding: 040300031C070060
    Shop #: WSC 00248 210 83408
    VCID: 377CA8DF462198F918-8062
    1 Fault Found:
    049441 - No Communication with ABS Brake Control Module
    U0121 - 008 - - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 180524 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 02:46:31
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 40.0°C
    Temperature: 24.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 12.192 V
    Readiness: 0110 0100
    Address 02: Auto Trans Labels: 02E-927-770.clb
    Part No SW: 02E 300 051 H HW: 02E 927 770 AJ
    Component: GSG DSG AG6 431 1802
    Revision: 04843012 Serial number: 00000806181279
    Coding: 0000020
    Shop #: WSC 01279 785 00200
    VCID: 183E4B632BFFB78131-804C
    1 Fault Found:
    18259 - Powertrain Data Bus
    P1851 - 000 - Missing Message from ABS Controller -
    Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 255
    Reset counter: 40
    Mileage: 180524 km
    Time Indication: 0
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
    Component: ESP MK60EC1 H45 0107
    Revision: 00H45001
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 39315 001 1048576
    VCID: 000E0303936F1F41E9-8054
    4 Faults Found:
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 180524 km
    Time Indication: 0
    Freeze Frame:
    Count: 16391
    Count: 12
    Count: 0
    Count: 88
    Count: 42752
    Count: 0
    Count: 0
    Count: 0
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 180524 km
    Time Indication: 0
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 180524 km
    Time Indication: 0
    Freeze Frame:
    Count: 16391
    Count: 12
    Count: 0
    Count: 56
    Count: 42752
    Count: 0
    Count: 0
    Count: 0
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 180524 km
    Time Indication: 0
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE
    Component: ClimatronicPQ35 130 1213
    Revision: 00130023 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 6DD04AB774FDE22932-8038
    1 Fault Found:
    01316 - ABS Control Module
    004 - No Signal/Communication
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 00000008600913
    Coding:
    E78F8F270004151E471400001400000000087F075C00010000 0000000000
    Shop #: WSC 07975 795 00500
    VCID: 33649CCF525974D924-8066
    Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 210608 021 0501
    Coding: 00038805
    Shop #: WSC 07975
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 040708 054 0402
    Coding: 00209069
    Shop #: WSC 07975
    No fault code found.
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: 38 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PC1SDDK.
    Coding: 0013112
    Shop #: WSC 01357 011 00200
    VCID: 3D70BAF7641DB2A9C2-8068
    Subsystem 1 - Serial number: 6332MSME3B3323354
    Subsystem 2 - Serial number: 6342MSME3D745267J
    Subsystem 3 - Serial number: 6352QSME7A1410516
    Subsystem 4 - Serial number: 6362QSME6B6B2377V
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
    Component: J0527 051 0101
    Coding: 0012102
    VCID: 04060F1347770361CD-8050
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K6 920 974 HW: 1K6 920 974
    Component: KOMBIINSTRUMENT VDD 2416
    Revision: V0002000 Serial number: VWX7Z0H53NA8QE
    Coding: 0007403
    Shop #: WSC 07975 067 57207
    VCID: 71E856C768C506C916-8024
    2 Faults Found:
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Ign. Timing: 4.5 °BTDC
    Raw, Form. N/A: 000 000 000
    01771 - Control Module for Headlight Range (J431)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 107
    Mileage: 180524 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 02:56:49
    Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533 Gateway H07 0062
    Revision: H07 01 Serial number: 300608F1000826
    Coding: ED811F0E0002020001
    VCID: 3560A2D75C2D6AE90A-8060
    2 Faults Found:
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 147
    Mileage: 180524 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 02:56:50
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 180524 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 02:56:50
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 2416
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
    Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
    Component: Tuer-SG 006 1208
    Coding: 0000564
    VCID: 3978AEE770358E89EE-806C
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 74 2301
    Revision: 00H15000
    VCID: 2A5A81AB8593351197-807E
    1 Fault Found:
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 157
    Mileage: 180524 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 02:56:48
    Freeze Frame:
    Voltage: 11.88 V
    DU
    Temperature: 15.0°C
    RPM: 0 /min
    Speed: 50.0 km/h
    Speed: 50.0 km/h
    Count: 0
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0204
    Revision: 00020000 Serial number: 00000000000000
    Coding: 819002085103087F2D040F0F7008DAC690BC00
    Shop #: WSC 01287 785 00200
    VCID: 03040C0F42790459F4-8056
    Subsystem 1 - Part No: 1K0 951 605 D
    Component: LIN BACKUP HORN H08 9001
    Subsystem 2 - Part No: 1K0 951 178 A
    Component: Neigungssensor 003 0203
    Subsystem 3 - Part No: 1K0 951 178 A
    Component: Innenraumueberw.003 0203
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
    Coding: 0000820
    VCID: 3A7AB1EB75338591E7-806E
    Address 55: Headlight Range
    Cannot be reached
    Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 3C8 035 195 HW: 3C8 035 195
    Component: Radio RCD510 036 0130
    Revision: 00000001 Serial number: VWZ1Z3I4232883
    Coding: 0200040004
    Shop #: WSC 05314 000 00000
    VCID: 65C032976C0DDA697A-8030
    1 Fault Found:
    00856 - Radio Antenna
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 180524 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 03:09:23
    Address 76: Park Assist Labels: 1K0-919-283.lbl
    Part No: 1K0 919 283 A
    Component: 22 Einparkhilfe 0101
    VCID: 2D508AB7B47D222972-8078
    End-------------------------(Elapsed Time:
    02:07)--------------------------
  12. #1557
    kazoula55's Avatar
    Sep 2012
    Default long codage vw polo 2010
    hi all
    i need long codage
    for vw polo 2010
    vin:WVWZZZ6RZAY085105
    THANK'S ADVENCE
  13. #1558
    Dec 2018
    Turkey
    Hello!
    abs 8.2
    Vag Number : 6R0 907 379 AE
    Hardware number: 6R0 907 379 AC
    Workshop System Name: J104
    Chassis Number: WVWZZZ6RZDY216516
    Engine code: CAYB
    1.6 tdı Polo 2013
    LHD
    FWD
    No start stop
    indirect tpms
    no esp
    hill hold no
  14. #1559
    Jul 2018
    Hello
    I need help with coding please.
    1. 1K0 907 379 AE ESP MK60EC1 H35 0106
    2. VIN : WVWZZZ1KZ9W121830
    3. VW GOLF 5 GTI Pirelli Edition
    4. RHD
    5. BYD 2.0 TFSi
    6. FWD
    7. No
    8. Yes , car has TPMS in the centre console , not sure what system
    9. Yes
    10. if possible, yes
  15. #1560
    Dec 2018
    Turkey
    Quote Originally Posted by mertcanozmen View Post
    Hello!
    abs 8.2
    Engine code: CAYB
    1.6 tdı Polo 2013
    LHD
    FWD
    No start stop
    indirect tpms
    no esp
    hill hold no
    200228E3016E00B8042A14E380D700000200
    Thanks to me
