Page 12 of 245 FirstFirst ... 278910111213141516172262112 ... LastLast
Results 166 to 180 of 3668
  1. #166
    Jul 2016
    Vilnius
    please try this coding:
    133B400D09290002C81202E490220082310000
    * MK100
  2. The Following User Says Thank You to hid3 For This Useful Post:
    smokey08 (30th September, 2016)
  3. #167
    smokey08's Avatar
    Essex, UK
    Quote Originally Posted by doctorelectrical View Post
    Has the car got a tyre pressure button?
    If no then use this:
    143B400D09290002281202E4902200423100
  4. #168
    Jul 2016
    Vilnius
    doctorelectrical, somkey, so is this left hand drive or right hand drive?? I'm confused.
    * MK100
  5. #169
    smokey08's Avatar
    Essex, UK
    Quote Originally Posted by hid3 View Post
    Left I assume as Portugal is listed as his location. I haven’t checked it by the VIN.
  6. #170
    donkez's Avatar
    Mayo, Ireland
    WAUZZZ8P0BA102685
    Please help me with this Audi A3, shes driving me nuts...
    Its a right hand drive, 2.0TDI
    Thanks in advance
  7. #171
    Jul 2016
    Vilnius
    What is the module part number?
    Also, could you take a picture of the white sticker under the trunk carpet?
    * MK100
  8. #172
    donkez's Avatar
    Mayo, Ireland
    the ABS control module part number is 1K0907379BE
    And the lable:
  9. #173
    Jul 2016
    Vilnius
    donkez, please try this coding:
    13426012092200FCC81106EC901E0082380800
    P.S.: ignore the coding I've sent you via PM, it is for smaller disc brake diameter than your car has...
    * MK100
  10. The Following 2 Users Say Thank You to hid3 For This Useful Post:
    donkez (5th October, 2016), wojciech300 (5th October, 2016)
  11. #174
    donkez's Avatar
    Mayo, Ireland
    CODING ACCEPTED, THANKS A LOT
  12. #175
    Jul 2016
    Vilnius
    Glad it worked. Make sure to adapt all the sensors in one ignition cycle, othervise the coding will revert back to zeroes and you will need to start over.
    For best results, do the adaptations on ideally flat surface. Be very careful when adapting steering angle sensor. If you make at least one degree mistake, it might cause car pulling to one side (don't ask me how I know....).
    * MK100
  13. #176
    donkez's Avatar
    Mayo, Ireland
    Actually car has auto start stop, do I have to change coding for that?
  14. #177
    Jul 2016
    Vilnius
    Use this coding for start/stop function to be available:
    13426012092200FCC81106EC901E0092380800
    * MK100
  15. #178
    Oct 2016
    Hi, can you please help me with the coding of the MK60EC1 1K0-907-379BA
    Audi A3 WAUZZZ8P0AA024312
    1.6CR CAYC TDI
    RHD
    Start Stop
    without TPMS
    EOA 7AO 4UF 6XD 5SJ 5RU
    1KD J2D 1ZF 1AT
    3FA UAO G17 5MC 7X0 4R4
    F0A 8GU 0YF L34
    TF3 3NZ 8BD U1B X2B 1N3
    2ZQ 8Q1 9Q2 8Z5 D38
    7Q0 C3L 7K0 4X3
    3L3 4KC 3Y0 4K4 5D1
    1SA UG0 7MG QG1 4GQ
  16. #179
    smokey08's Avatar
    Essex, UK
    Quote Originally Posted by R2medyk View Post
    1.6CR CAYC TDI
    RHD
    Start Stop
    without TPMS
    1KD J2D 1ZF 1AT
    F0A 8GU 0YF L34
    2ZQ 8Q1 9Q2 8Z5 D38
    7Q0 C3L 7K0 4X3
    3L3 4KC 3Y0 4K4 5D1
    1SA UG0 7MG QG1 4GQ
    Here is your coding from information you have given:
    13422012092400FEC80E04E5901B00913808
  17. The Following User Says Thank You to smokey08 For This Useful Post:
    R2medyk (7th October, 2016)
  18. #180
    Oct 2016
    Thank you code correct.
    All done and dusted.
