Page 140 of 245 FirstFirst ... 4090130135136137138139140141142143144145150190240 ... LastLast
Results 2,086 to 2,100 of 3668
  1. #2086
    Port Elizabeth
    Hi can you help with long coding for Golf6 GTI vin WVWZZZ1KZBW053556 MK60 abs unit
    Cheers
    Shane
  2. #2087
    May 2017
    London United Kingdom
    Hi guys. I have Audi A3 that has new cluster and ecu from donor car same model. I need abs coding please. info below
    1. ABS module part number - 1K0 907379AT MK60EC1
    2. VIN - WAUZZZ8P4BA143966
    3. Audi A3 2.0 S line
    4. Right hand drive (RHD) model
    5.Engine code is CFFB
    6.Front wheel drive
    7. Car has start/stop
    8. car has ASR/ESP off button
    Attached VCDS error codes.
  3. #2088
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by conbee70 View Post
    6.Front wheel drive
    One of these going to be your Long coding :
    11424012092600FD881402EA901F0423800
    1162401A492600FD881402EA921F00403900
    Please Press Thanks and Reputation
  4. The Following User Says Thank You to vagva For This Useful Post:
    conbee70 (6th November, 2019)
  5. #2089
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by shanektm450 View Post
    Cheers
    Shane
    Here is your Long coding :
    113B200D092700FD881004E9901F0040350000
  6. The Following User Says Thank You to vagva For This Useful Post:
    shanektm450 (6th November, 2019)
  7. #2090
    Feb 2018
    Push,
    Can somebody help?
    Can someone check if my coding is correct?
    Current coding: 1442601209290003280F06E6902100413900
    ABS Partnumber: 1K0 907 379 CE
    VIN: WAUZZZ8P39A079428
    Motor Nr: CCZA 006649, A3 Spb FSI q2.0 R4147 DSG,
    Start/Stop: no
    4Wheel drive: yes
    Transmission: DSG
    Blue Motion: no
    ESP Switch: Yes
    Hill hold assistance: Yes
    Fault codes: 02085 incorrect control module installed
    and
    Longitudinal Acceleration Sensor (G251)
    Wenn I follow following procedure, I can not see any values in field 4
    The Longitudinal Acceleration Sensor (G251) is only present cars with All Wheel Drive (AWD) and/or Hill Hold Control (HHC)
    Prerequisites:
    System voltage at least 12.0 V.
    [Select]
    [03 - Brake Electronics]
    [Measuring Blocks - 08]
    Group 006
    [Go!]
    Check field 4, the value has to be between -1.5 and +1.5 m/s².
    [Done, Go Back]
    [Security Access - 16]
    Enter 40168, to enable the basic setting.
    [Do it!]
    [Basic Settings - 04]
    Group 069
    [Go!]
    After a successful basic setting, field 2 should say "OK".
    [Done, Go Back]
    To make sure the basic setting was successful, check the sensor again.
    Group 006
    [Go!]
    Check field 1, the value has to be between -1.5 and +1.5 m/s².
    [Done, Go Back]
    [Close Controller, Go Back - 06]
  8. #2091
    VW GOLF 6+ 2011
    ABS MODULE ESP MK60EC1
    1K0907379BE
    ENGINE 2.0 TDI
    ENGINE CODE CFHC
    LEFT HAND DRIVE (LHD)
    VIN:WVWZZZ1KZBW579757
    BEST REGARDS
  9. #2092
    Port Elizabeth
    Quote Originally Posted by vagva View Post
    Hi thanks for coding but coding string to long not exepting the coding to many 0000 after 5 I tried to code by taking away 000 but not working coding rejected
    Here is full log file with vcds
    Cheers
    Shane
  10. #2093
    May 2017
    Hi Vagva thank you for getting back to me. Can you please double check the first code starting with 1142.... seems like a byte is missing
  11. #2094
    Nov 2019
    hello help please
    skoda octavia
    porta datos.pdf
    ECU 1K0907379AS
  12. #2095
    right here right now
    please help me with abs long coding for this one as follows
    WVWZZZ1KZBW284038
    MK60EC1
    1K0 907 379 BE
    Golf 1.6 tdi
    right hand drive
    much appreciated
  13. #2096
    Dec 2016
    Hello, can you help with long coding
    VSSZZZ1PZ6R099544
    MK60
    1K0 907 379 BM
    Left hand drive
    Engine 1.9 TDI
    Engine code is BXE
    Seat Leon MK2
    Car has ASR/ESP Off button
    Front wheel drive
  14. #2097
    Ireland
    Quote Originally Posted by yarowsc View Post
    give part number ABS module
    Hi sorry for late
    The abs number is 1k0907379BJ
    Thanks for your help
  15. #2098
    Oct 2014
    hello hope someone can help me with this one
    WVWZZZ1KZP470520 EU GOLF MK6 GTD
    MK60
    1K0907379AD 18 bytes
    LHD
    ENGINE 2.0TDI CBBB 170ps
    Brakes front 1KD 288mm rear 253mm
    No tpms i think
  16. #2099
    kiszka's Avatar
    Quote Originally Posted by hansdevogel89 View Post
    MK60
    LHD
    No tpms i think
    143B400C092700FC4C0B02E6901900420000
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  17. #2100
    EU
    HI please help long coding ABS
    Škoda Superb TMBJE93T5C9008899
    ABS 1K0907379BH
    2.0TDI 103KW CFFB
    LHD
    NO TPMS
    THX
    Problem solved
