Page 148 of 245 FirstFirst ... 4898138143144145146147148149150151152153158198 ... LastLast
Results 2,206 to 2,220 of 3668
  1. #2206
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by zcataide View Post
    Hi VAG, i canīt program with this codes. The ABS System generate this error: "Coding Reject: ERROR 12: Sub-function not supported or invalid format".
    Follow the advanced ID:
    Tuesday,07,January,2020,10:25:03:00007
    VCDS Version: Release 18.9.0 (x64)
    Address 03: ABS Brakes
    Control Module Part Number:
    Component and/or Version:
    Software Coding:
    Work Shop Code:
    VCID: 55A13755BC0151E2D6-8000
    Advanced Identification
    Identification: TT1-000
    Revision: 00H31001
    Date: 19.12.10
    Manufacturer number: 0104
    Test stand number: 0601
    Flash Status
    Programming Attempts(application): 1
    Successful Attempts(application): 1
    Programming Status: 00000000
    Flash Date: 2000.00.00
    Flash Tool Code: 36705 933 20200
    VCDS Info:
    VCID: 7BF541EDEAE5679280-802E
    Labels: 1K0-907-379-60EC1F.clb
    you can add 00 or delete 00 from the end
  2. #2207
    Jan 2019
    Quote Originally Posted by vagva View Post
    This code is accepted: A43B40F811288000250D02E988190140211000
    But generated this erros:
    Tuesday,07,January,2020,21:19:43:00007
    VCDS Version: Release 18.9.0 (x64) Running on Windows 10 x64
    www.Ross-Tech.com
    Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
    Control Module Part Number: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component and/or Version: ESP MK60EC1 H31 0121
    Software Coding: A43B40F811288000250D02E988190140211000
    Work Shop Code: WSC 00066 123 12345
    VCID: 7BF541EDFAE5679280-802E
    2 Faults Found:
    03366 - Vacuuum Sensor
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 18
    Mileage: 130963 km
    Time Indication: 0
    Date: 2033.14.30
    Time: 21:18:55
    Freeze Frame:
    Count: 3
    Count: 14
    Count: 28672
    Count: 213
    Count: 44288
    Count: 0
    Count: 253
    Count: 11
    03197 - Stopping Distance Reduction 2 in ADR Control Module (J428)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 18
    Mileage: 130963 km
    Time Indication: 0
    Date: 2033.14.30
    Time: 21:18:55
    Freeze Frame:
    Count: 3
    Count: 14
    Count: 28672
    Count: 8244
    Count: 44288
    Count: 0
    Count: 253
    Count: 11
  3. #2208
    kinketotua's Avatar
    Apr 2016
    Europe
    Hi friends! someone can help me with these long coding?
  4. #2209
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by kinketotua View Post
    CAR TYPE ?
  5. The Following User Says Thank You to vagva For This Useful Post:
    kinketotua (8th January, 2020)
  6. #2210
    kinketotua's Avatar
    Apr 2016
    Europe
    Ohh sorry yes is Seat Leon 1.9tdi
  7. #2211
    Jan 2019
    Can you help me VAGVA?
  8. #2212
    vagva's Avatar
    Apr 2016
    Here is your Long coding :
    143B801209220803281401E4901F1041350800
    If you find that my Post was Helpful, please Press Thanks and Rep
  9. The Following User Says Thank You to vagva For This Useful Post:
  10. #2213
    Jan 2020
    Malaysia
    Hi I having problem long coding my ABS ESP MK60 EC1 H31 0121 (RHD)
    Volkwagen Beetle 2012 1.2 TSI
    Error details: Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 00000000000000000000000000000000000000
    Shop #: WSC 00066 123 12345
    VIN: WVWZZZ16ZCM645935 Mileage: 71430km-44384miles
    Note: ABS module was replaced by previous owner (original information provided by VW Service: 5C0614517BBEF)
    Thanking in advance
  11. #2214
    Mar 2017
    Hi, I changed ECU, Dash, keys then coding missing. I try figuret this by mysefl. But maybe I'm not so clever . Could anybody help my here.
    New VIN form Dash and ECU: WVWZZZ1KZCW125492
    2012 Golf VI, 1.6 diesel, LH, 1k0907379BJ
    Am i close?
    213B400D092400FF240E02EE901B0041310000
  12. #2215
    Jan 2020
    Malaysia
    Hi, VAGVA, I new to this forum, hope you can help with my ABS long coding. The coding lost after repair was carried on the instrument panel .
    1. ABS module part number (the part number which is labelled on the ECU part, not the motor part number) >1K0 907 379 BJ
    2. VIN > WVWZZZ16ZCM645935
    3. Exact model of the car > 2012 Volkswagen Beetle > 1.2 TSI
    4. Left hand drive (LHD) or right hand drive (RHD) model > RHD
    5. Engine type (gas or diesel), power output and displacement. Engine code can be provided instead if known. > Gasoline
    6. 4Motion/4WD version or FWD > FWD
    7. Is there any start/stop ("eco"/"bluemotion"/etc) system installed in the car? > NO
    8. Is there any kind of TPMS? If yes, then what kind of TPMS - indirect ABS based (no sensors in each wheel) or direct system which uses sensors inside the wheels? > NO
    9. Does the car have ASR/ESP off buttons (in the center console)? > NO
    10. "Hill hold" function. Do you want it to be activated if possible?> NO
    Volkswagen Beetle 1.2 TSI
    VAG number 1K0 907 379 BJ
    Thanking in advance for you help.
  13. #2216
    Jul 2016
    Vilnius
    Check your PM
    * MK100
  14. #2217
    Jan 2020
    Malaysia
    Dear Vagva, can you help me abs long code, details as below: Thanks
  15. #2218
    Mar 2011
    Romania
    Quote Originally Posted by Sival View Post
    try this
    f43b20f8092600ff2f1404e7901e0081200000
  16. #2219
    rm23's Avatar
    UK
    hello
    can anyone help with abs coding? Audi A3 2008 all details in pictures, coding on the picture is wrong abs saying wrong coding. thank you !!!
  17. #2220
    May 2019
    could someone help me with my long coding for my seat ibiza
    VIN: VSSSK46J99R116900 License Plate:
    Chassis Type: 6J-SE25 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 2E 44 4B 56 77
    VIN: VSSSK46J99R116900 Mileage: 182770km-113568miles
    Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
    Part No SW: 6R0 937 087 A HW: 6R0 937 087 A
    Component: PQ25 BCM H07 0012
    Revision: BE007001 Serial number: 9424B033090193
    Coding: 7D882BA4887326000A300400740B1CC80040400F608C000020 00
    Shop #: WSC 64564 324 38760
    VCID: 3B740F70BA65A19E9F-806E
    Subsystem 1 - Part No SW: 6R0 959 801 A HW: 6R0 959 801 A Labels: 6R0-959-801.CLB
    Component: J386__TSG_FT 001 0238
    Serial number: --------------------
    Coding: 020000
    Subsystem 3 - Part No SW: 6R0 959 591 HW: 6R0 959 591
    Component: J245/J878 H04 0054
    Serial number: 849200043345
    Coding: 000003
    Subsystem 4 - Part No: 1K8 951 171 A
    Component: DWA-Sensor 001 0103
    Coding: 000000
    Subsystem 5 - Part No SW: 6R0 959 811 HW: 6R0 959 811
    Component: J388__TSG_HL 001 0245
    Coding: 000000
    Subsystem 6 - Part No SW: 6R0 959 812 HW: 6R0 959 812
    Component: J389__TSG_HR 001 0246
    Coding: 000000
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 182770 km
    Time Indication: 0
    Date: 2014.06.01
    Time: 22:14:58
