Page 156 of 245 FirstFirst ... 56106146151152153154155156157158159160161166206 ... LastLast
Results 2,326 to 2,340 of 3668
  1. #2326
    Jun 2019
    Hi. New member here. I own a 2013 VW Jetta 1.4 TSi. CDXA single turbo, 7 speed DSG
    I am currently driving without noticeable problems except for the 3 fault light on the speedometre. ABS, ESP and brakes. Lights goes off only when I step on the brake pedal when I start the car, and lights will come back on immediately with brake servo fault message on the MFD when I release the brake padel.
    My VIN : WVWZZZ16ZDM042442
    Current long code: A63B40F8112600FC650F02E8881B0080201000
    Last action done using VCDS was to turn off hill assist.
    Would appreciate anyone here who could help generate a long code base on the provided VIN, and attached scan result.
    Monday,10,February,2020,17:30:43:00007
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.9.0.2 (x64)
    Data version: 20180927 DS296.0
    www.Ross-Tech.com
    VIN: WVWZZZ16ZDM042442 License Plate: SFT000
    Mileage: 108960km-67704mi Repair Order: 001
    Chassis Type: 16-VW32 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ16ZDM042442 Mileage: 108960km-67704miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: Sporadic communication error 1000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CAXA) Labels:. 03C-906-016-CAX2.clb
    Part No SW: 03C 906 016 BT HW: 03C 907 309 F
    Component: MED17.5.5 H13 3498
    Revision: LCH13--- Serial number: 00000000000000
    Coding: 00250012002400000000
    Shop #: WSC 00066 000 00086
    ASAM Dataset: EV_ECM14TFS01103C906016BT 001008
    ROD: EV_ECM14TFS01103C906016BT.rod
    VCID: 72EB6CC9A5AF26DAD3-8026
    No fault code found.
    Readiness: 1110 0101
    Address 02: Auto Trans Labels: 0AM-927-769.clb
    Part No SW: 0AM 300 054 A HW: 0AM 927 769 D
    Component: GSG DSG AG7 431 3640
    Revision: 00043014 Serial number: CU501209216219
    Coding: 0000020
    Shop #: WSC 00066 000 00000
    VCID: 2B55B1AD8A05371250-807E
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
    Component: ESP MK60EC1 H31 0152
    Revision: 00H31001
    Coding: A63B40F8112600FC650F02E8881B0080201000
    Shop #: WSC 00066 790 00185
    VCID: 7DF14FF5E4F169A2BE-8028
    1 Fault Found:
    01486 - System Function Test Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 217
    Mileage: 108961 km
    Time Indication: 0
    Date: 2014.07.03
    Time: 01:02:01
    Freeze Frame:
    Count: 7
    Count: 14
    Count: 12288
    Count: 320
    Count: 48640
    Count: 64512
    Count: 512
    Count: 62
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 3AA 907 044 AF HW: 3AA 907 044 AF
    Component: Climatronic H03 0303
    Revision: 00001K02
    Coding: 0010002002
    Shop #: WSC 00066 000 00119
    ASAM Dataset: EV_Climatronic A01010
    ROD: EV_ClimaAutoBasis_VW32.rod
    VCID: 74E76AD1DFBB28EAC1-8020
    Address 09: Cent. Elect. Labels: None
    VCID: 55A13755BC0151E2D6-FFFE
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
    Component: AirbagVW10 013 0613
    Serial number: 003G6M06XBS$
    Coding: 00003241
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
    ROD: EV_AirbaVW10SMEVW360.rod
    VCID: 326BACC9652F66DA13-8066
    Crash sensor for side airbag: driver side:
    Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H02 ----
    Serial number: 3572MSME556D5174ZZZ$
    Crash sensor for side airbag: front passenger side:
    Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Beif.V H02 ----
    Serial number: 3582MSME636E5174ZZZ/
    Crash sensor for side airbag: rear: driver side:
    Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
    Component: S.Sens.Fahr.H H02 ----
    Serial number: 3516KSME4E261B1FZZZ0
    Crash sensor for side airbag: rear: passenger side:
    Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
    Component: S.Sens.Beif.H H02 ----
    Serial number: 3526KSME2715331FZZZR
    Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
    Part No SW: 1K5 953 507 T HW: 5K0 953 549 B
    Component: Lenks.Modul 008 0080
    Revision: -------- Serial number: 90422LIN0006J
    Coding: 0892140000
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_A05.rod
    VCID: 428BFC09D58FD65A83-8016
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H08 0010
    Serial number: 0314858
    Coding: 830000
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 5C6 920 872 HW: 5C6 920 872
    Component: KOMBI H07 0705
    Coding: 171B01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
    VCID: 6ADB74A98D7FEE1A6B-803E
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF
    Component: J533 Gateway H52 1634
    Revision: H52 Serial number: 04111203270123
    Coding: 351003
    VCID: 74E76AD1D7BB28EAC1-8020
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H07 0705
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
    ROD: EV_Immo_UDS_VDD_RM09.rod
    Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
    Part No SW: 561 959 701 A HW: 3C0 959 793 C
    Component: TUER-SG FT 002 0515
    Revision: 12110009 Serial number: 0005688881
    Coding: 0012B7
    Shop #: WSC 01383 790 50316
    ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
    ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
    VCID: 1C37627117ABC0AA29-8048
    Slave Driver:
    Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
    Component: J389__TSG-HR 008 1508
    Serial number: 00000007233377
    Coding: 000290
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 P
    Component: EPS_ZFLS Kl. 68 3305
    Revision: 00H22000
    Shop #: WSC 02069 000 90108
    VCID: 377D9DDD464D83F224-8062
    Address 46: Central Conv.
    Cannot be reached
    Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
    Part No SW: 561 959 702 A HW: 3C0 959 792 C
    Component: TUER-SG BT 002 0515
    Revision: 14110009 Serial number: 0005633244
    Coding: 0013B6
    ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
    ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
    VCID: 1D316F750CB1C9A2DE-8048
    Slave Passenger:
    Subsystem 1 - Part No SW: 3C0 959 703 B HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
    Component: J388__TSG-HL 008 1508
    Serial number: 00000007199835
    Coding: 000290
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
    Component: Radio RCD310 042 0082
    Revision: 00000001 Serial number: VWZ1Z2M4470031
    Coding: 0D000400040000
    VCID: 72EB6CC9ADAF26DAD3-8026
    End-------------------------(Elapsed Time: 03:56)--------------------------
  2. #2327
    right here right now
    I would really appreciate some help with long coding for this vw caddy,it is RHD and here is my scan as follows
    Log-15 CADDY-WV2ZZZ2KZFX048117-56010km-34803mi-GERRY M.txt
  3. #2328
    DK Veteran magdex's Avatar
    POLAND
    Please Help ! I need ABS Long coding Skoda Yeti 2010
    VIN :TMBJF95L386017899
    After change Dashbord ABS coding is 000000000000000000
    Regards !
  4. #2329
    srt8's Avatar
    Nov 2017
    hi guys, need a help with a abs coding. posting the logs for it
  5. #2330
    srt8's Avatar
    Nov 2017
    here is the photo of the abs module sceenshot
  6. #2331
    Dec 2019
    Hi!
    I would like to say thank you people for helping me & Please can you give me a coding for this ABS:
    my old abs (1k0 907 379 bk) I replace it with (1K0 907 379 BL)
    Volkswagen Passat Sedan 2014 New Passat (HIGHLINE)
    Thursday,20,February,2020,15:14:30:14601
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
    VCDS Version: 19.6.2.0 HEX-NET CB: 0.4508.4
    Data version: 20190930 DS308.0
    www.Ross-Tech.com
    VIN: WVWCR7A37EC000894 License Plate:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 1C 25 2B 2E 42 46 47 4F 52 56
    62 72 77
    VIN: WVWCR7A37EC000894 Mileage: 104330km-64827miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    1C-Position Sensing -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
    Part No SW: 07K 906 055 CB HW: 07K 907 309 B
    Component: 2,5L 125KW G01 1202
    Revision: T4H06--- Serial number:
    Coding: 0000075
    Shop #: WSC 09003 957 00200
    VCID: 70ACF6C7639A1ACF57-8024
    1 Fault Found:
    001393 - Brake Switch (F)
    P0571 - 000 - Implausible Signal - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 104337 km
    Time Indication: 0
    Date: 2014.07.05
    Time: 16:18:34
    Freeze Frame:
    RPM: 790 /min
    Load: 33.7 %
    Speed: 7.0 km/h
    Temperature: 56.0°C
    Temperature: 24.0°C
    Absolute Pres.: 1020.0 mbar
    Readiness: 0010 0001
    Address 02: Auto Trans Labels: 09G-927-750.clb
    Part No SW: 09G 927 750 NH HW: 09G 927 750 NH
    Component: AQ 250 6F 2244
    Revision: 00H97000 Serial number:
    Coding: 0000328
    VCID: 0444AA174722166F83-8050
    Revision: 00H31001
    Coding: 00000000000000000000000000000000000000
    Shop #: WSC 00028 028 00001
    VCID: 7DB2DFF3E4C867A7CC-8028
    5 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 125
    Mileage: 104338 km
    Time Indication: 0
    Date: 2014.07.05
    Time: 17:01:54
    Freeze Frame:
    Count: 3
    Count: 14
    Count: 29184
    Count: 320
    Count: 48640
    Count: 10496
    Count: 0
    Count: 8704
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 125
    Mileage: 104338 km
    Time Indication: 0
    Date: 2014.07.05
    Time: 17:01:56
    Freeze Frame:
    Count: 7
    Count: 14
    Count: 29184
    Count: 195
    Count: 48640
    Count: 10496
    Count: 65280
    Count: 8704
    01435 - Brake Pressure Sensor 1 (G201)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 125
    Mileage: 104338 km
    Time Indication: 0
    Date: 2014.07.05
    Time: 17:01:54
    Freeze Frame:
    Count: 3
    Count: 14
    Count: 29184
    Count: 279
    Count: 48640
    Count: 10496
    Count: 0
    Count: 8704
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 125
    Mileage: 104338 km
    Time Indication: 0
    Date: 2014.07.05
    Time: 17:01:54
    Freeze Frame:
    Count: 3
    Count: 14
    Count: 29184
    Count: 295
    Count: 48640
    Count: 10496
    Count: 0
    Count: 8704
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 125
    Mileage: 104338 km
    Time Indication: 0
    Date: 2014.07.05
    Time: 17:01:54
    Freeze Frame:
    Count: 3
    Count: 14
    Count: 29184
    Count: 270
    Count: 48640
    Count: 10496
    Count: 0
    Count: 8704
    Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
    Part No SW: 5K0 959 434 B HW: 5K0 959 434
    Component: VWKESSYPQ35GP 086 1101
    Revision: 00086000 Serial number: 0199297623
    Coding: 030C0C
    ASAM Dataset: EV_KESSYPQ35G A02013
    ROD: EV_KESSYPQ35G_A02_VW31.rod
    VCID: 34243AD79F0266EF73-8060
    Part No SW: 561 907 044 R HW: 561 907 044 R
    Component: Climatronic H03 0405
    Revision: 00001K01
    Coding: 0010001002
    ASAM Dataset: EV_ACClimaBHBVW411 A01001
    ROD: EV_ACClimaBHBVW411_VW41.rod
    VCID: 2600D09F59DE047FFD-8072
    Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
    Part No SW: 5K0 937 086 P HW: 5K0 937 086 P
    Component: BCM PQ35 M+ 021 0068
    Revision: BD021001
    Coding: 68200E3B802908D400080000340081E00371008645A00DF064 806000AC70
    VCID: 41CA6303D8B0C347E8-8014
    Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 050213 05 54 0403
    Coding: 02300A
    1 Fault Found:
    01496 - Bulb for Fog-Lamps; Left (L22)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 124
    Mileage: 104337 km
    Time Indication: 0
    Date: 2014.07.05
    Time: 16:07:16
    Freeze Frame:
    Term 15 On
    Voltage: 11.95 V
    ON
    ON
    OFF
    OFF
    OFF
    Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
    Component: AirbagVW10G 014 0851
    Serial number: 003MWM01FAJ
    Coding: 00005033
    ASAM Dataset: EV_AirbaVW10SMEVW360 001026
    VCID: 75A2C7D3D4F83FE784-8020
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
    Component: BF-Gewichtss. H10 0046
    Serial number: 6940000Y130000SJJ20$
    Coding: 303046
    Serial number: 3572MSME71266578ZZZZ
    Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Serial number: 3582MSME7E6F1478ZZZD
    Serial number: 3516KSME46746822ZZZS
    Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
    Serial number: 3526KSME632A3F22ZZZX
    Crash sensor for front airbag: driver side:
    Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
    Component: F.Sens.Fahr H02 ----
    Serial number: 3556LSME28703921ZZZQ
    Crash sensor for front airbag: front passenger side:
    Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
    Component: F.Sens.Beif H02 ----
    Serial number: 3566LSME724C3921ZZZZ
    1 Fault Found:
    9439771 - Front Passenger's Side Airbag Igniter
    B100A 1B [137] - Resistance Too High
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 104337 km
    Date: 2020.02.12
    Time: 16:06:13
    Part No SW: 1K5 953 501 S HW: 5K0 953 569 L
    Component: LENKS.MODUL 014 0140
    Revision: FF010041 Serial number: 20121125100110
    Coding: 010A140000
    ASAM Dataset: EV_VW360SteerWheelUDS A03004
    ROD: EV_VW360SteerWheelUDS.rod
    VCID: 3B3611EBB25CA997B2-806E
    Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
    Component: E221__MFL-YVJ H07 0022
    Coding: E20000
    Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
    Part No SW: 561 920 870 B HW: 561 920 870 B
    Coding: 631E01
    VCID: 187CEE67E3AAA28F7F-804C
    Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
    Component: J533 Gateway H50 1634
    Revision: H50 Serial number: 02041303290542
    Coding: 461000
    Shop #: WSC 12345 123 61029
    VCID: 76A0C0DFC1FE34FF8D-8022
    Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 561 919 965 HW: 561 919 965
    Component: Kompass 002 0001
    Revision: 00002000 Serial number: 1829227R44D406
    Coding: 0000002
    VCID: 6386898BA26CB157DA-8036
    Serial number:
    Coding: 000007
    VCID: 6A98E4AF8D46E01F19-803E
    Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
    Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
    Component: ELV-PQ35 H21 0240
    Revision: 00000000 Serial number: 13000003861002
    Coding: 4900000000000000
    ASAM Dataset: EV_ELVMarquMPVW36X A01001
    ROD: EV_ELVMarquMPVW36X.rod
    VCID: 302C36C76B1A5ACF17-8064
    Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
    Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
    Component: SG EXT.PLAYER H19 0550
    Revision: A1001003 Serial number: 7664509691
    Coding: 010100
    VCID: 2A1824AF45C6201FD9-807E
    Part No SW: 561 959 701 HW: 3C0 959 793 B
    Component: TUER-SG FT 002 0525
    Revision: 13110009 Serial number: 0006474867
    Coding: 0404FD
    ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
    ROD: EV_TSGFPQ25BRFVW46X.rod
    VCID: 5BF6B16B521C899792-800E
    Slave Driver:
    Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
    Component: J388__TSG_HL 006 5470
    Serial number: 14202630130410104818
    Coding: 800000
    1 Fault Found:
    131584 - Motor for Rear Window Regulator
    B11EE 54 [008] - Missing Calibration / Basic Setting
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 165
    Mileage: 104337 km
    Date: 2020.02.12
    Time: 16:06:15
    Address 47: Sound System (R12) Labels: 5K0-035-456.clb
    Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
    Component: KonzernAmp10K H07 6813
    Revision: -------- Serial number: EAA098A0034290
    ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
    ROD: EV_AudioVerst10KanalSTT3.rod
    Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
    Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
    Component: EZE_2 H50 1634
    Coding: 01030108
    VCID: 6FAEF5BBBEA405374E-803A
    Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
    Component: J245 P05 FFD7 H07 0004
    Serial number: 53388786011232400873
    Coding: 181100
    Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
    Component: Analoguhr 008 0005
    Part No SW: 561 959 702 HW: 3C0 959 792 B
    Component: TUER-SG BT 002 0525
    Revision: 15110009 Serial number: 0006500806
    Coding: 0404FC
    ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
    ROD: EV_TSGBPQ25BRFVW46X.rod
    VCID: 5CF4B27757128EAF9B-8008
    Slave Passenger:
    Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
    Component: J389__TSG_HR 006 5470
    Serial number: 14202631130409180554
    Coding: 800000
    2 Faults Found:
    67074 - Motors for Central Locking
    B122B 01 [009] - Electrical Failure
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 125
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 165
    Mileage: 104337 km
    Date: 2020.02.12
    Time: 16:06:18
    Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
    Component: Radio RCD510 051 0213
    Revision: 00000001 Serial number: VWZ1Z3M8406516
    Coding: 0102004001000B
    VCID: 2306C98B22ECF1579A-8076
    Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
    Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
    Component: TELEFON H15 3200
    Revision: 1B001001 Serial number: 00007664291009
    Coding: 0A00000000010110
    ASAM Dataset: EV_UHVNA 002720
    ROD: EV_UHVNA_002.rod
    VCID: 3A3814EFBD66909FA9-806E
    End----(Elapsed Time: 01:19, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
    please can somebody help with abs codig for my car
    thank you
  7. #2332
    Tefocm's Avatar
    Sep 2013
    Planet Earth...Take me to your leader.
    Quote Originally Posted by sinemora08 View Post
    www.Ross-Tech.com
    Coding: 0000020
    Revision: 00H31001
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 217
    Mileage: 108961 km
    Time Indication: 0
    Date: 2014.07.03
    Time: 01:02:01
    Freeze Frame:
    Count: 7
    Count: 14
    Count: 12288
    Count: 320
    Count: 48640
    Count: 64512
    Count: 512
    Count: 62
    Revision: 00001K02
    Coding: 0010002002
    No Faults Found
    Coding: 00003241
    Coding: 0892140000
    Coding: 830000
    Coding: 171B01
    Coding: 351003
    Serial number:
    Coding: 000000
    Coding: 0012B7
    Slave Driver:
    Coding: 000290
    Revision: 00H22000
    Cannot be reached
    Coding: 0013B6
    Slave Passenger:
    Coding: 000290
    That is not all that true mate. The last thing you did was activated function test. Just deactivate it, it has nothing to do with the fact that you deactivated hill hold.
    Buy every pirate China has to offer for cheap...and WIN!
    Buy everything the original manufacturer has to SHOW YOUR SUPPORT!
  8. #2333
    Tefocm's Avatar
    Sep 2013
    www.Ross-Tech.com
    Coding: 0000020
    Revision: 00H31001
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 217
    Mileage: 108961 km
    Time Indication: 0
    Date: 2014.07.03
    Time: 01:02:01
    Freeze Frame:
    Count: 7
    Count: 14
    Count: 12288
    Count: 320
    Count: 48640
    Count: 64512
    Count: 512
    Count: 62
    Revision: 00001K02
    Coding: 0010002002
    No Faults Found
    Coding: 00003241
    Coding: 0892140000
    Coding: 830000
    Coding: 171B01
    Coding: 351003
    Serial number:
    Coding: 000000
    Coding: 0012B7
    Slave Driver:
    Coding: 000290
    Revision: 00H22000
    Cannot be reached
    Coding: 0013B6
    Slave Passenger:
    Coding: 000290
  9. The Following 2 Users Say Thank You to Tefocm For This Useful Post:
    sinemora08 (13th February, 2020), srt8 (14th February, 2020)
  10. #2334
    Jun 2019
    Hi @Tefocm, thanks for the input, to clarify. Last function before any lights appears on the speedometer.. As for the attached scan result. This was done after I have cleared the ABS fault code, and the moment the execute the function test. The 01130 error comes back, sometime with function test intermittent..
    When doing the function test. The error will trigger the moment I turn my steering. Going straight the lights is still flashing during the test, but once I turn the steering, error lights will stay on.
    Doing another scan, I sometime get 1 error 01130, or 2 error, 1 being the 01130, and the other 14xx can't remember, which is something like function test intermittent..
    Quote Originally Posted by Tefocm View Post
  11. #2335
    Jun 2019
    Any member here can help me decipher the language and what options are these.
    As described in my post #2326. I am trying to at least clarify it's not the codes messing up my ABS which now have a 01130 fault before replacing it.
    Have tried enabling the 2 option in the long code, where when I use google translate, is pointing to new generation ABS. When enabled. I get rear left/right sensor incorrect signal fault.
  12. #2336
    Jul 2016
    Vilnius
    Mate, I think you've already got plenty of info on your issue. And you know what to do. Doing some random bullsheet which you don't have a clue you're doing will not solve your problem.
    Oh, and this inaccurate "caulculator" isn't worth anything - just forget it.
    * MK100
  13. #2337
    Default NEED long coding for golf6
    hi
    i NEED long coding for golf6 2011
    VIN WVWZZZ1KZCW008792
    FULL SCAN in attachemants
    And thanx
  14. #2338
    Jan 2011
    Italy
    AUDI A3 8P
    VIN WAUZZZ8P1AA058761
    ACAYCF1 FM5A4051R8P607MGEM1
    Year 2009
    Component ESP MK60EC1 H45 0109
    VaG number of module : 1K0907379 BA
    Engine: 1.6 TDI
    LHD
    with tyre pressure sensor
    without hill assist
    with ESP/ASR button
    Long coding
  15. #2339
    Top Poster vankoal's Avatar
    Bulgaria
    Please Help ! I need ABS Long coding GOLF 6 2010 .
  16. #2340
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    hi
    i need correct long coding after abs pump replaced.... HW: 1K0 907 379 AH
    full scan via vcds
    Thank you...
    Log-WVWZZZ1KZAP095539-160370km-99649mi.zip
