Hi!
I would like to say thank you people for helping me & Please can you give me a coding for this ABS:
my old abs (1k0 907 379 bk) I replace it with (1K0 907 379 BL)
Volkswagen Passat Sedan 2014 New Passat (HIGHLINE)
Thursday,20,February,2020,15:14:30:14601
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 19.6.2.0 HEX-NET CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVWCR7A37EC000894 License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 1C 25 2B 2E 42 46 47 4F 52 56
62 72 77
VIN: WVWCR7A37EC000894 Mileage: 104330km-64827miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 CB HW: 07K 907 309 B
Component: 2,5L 125KW G01 1202
Revision: T4H06--- Serial number:
Coding: 0000075
Shop #: WSC 09003 957 00200
VCID: 70ACF6C7639A1ACF57-8024
1 Fault Found:
001393 - Brake Switch (F)
P0571 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 104337 km
Time Indication: 0
Date: 2014.07.05
Time: 16:18:34
Freeze Frame:
RPM: 790 /min
Load: 33.7 %
Speed: 7.0 km/h
Temperature: 56.0°C
Temperature: 24.0°C
Absolute Pres.: 1020.0 mbar
Readiness: 0010 0001
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09G 927 750 NH HW: 09G 927 750 NH
Component: AQ 250 6F 2244
Revision: 00H97000 Serial number:
Coding: 0000328
VCID: 0444AA174722166F83-8050
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 00000000000000000000000000000000000000
Shop #: WSC 00028 028 00001
VCID: 7DB2DFF3E4C867A7CC-8028
5 Faults Found:
01486 - System Function Test Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 125
Mileage: 104338 km
Time Indication: 0
Date: 2014.07.05
Time: 17:01:54
Freeze Frame:
Count: 3
Count: 14
Count: 29184
Count: 320
Count: 48640
Count: 10496
Count: 0
Count: 8704
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 125
Mileage: 104338 km
Time Indication: 0
Date: 2014.07.05
Time: 17:01:56
Freeze Frame:
Count: 7
Count: 14
Count: 29184
Count: 195
Count: 48640
Count: 10496
Count: 65280
Count: 8704
01435 - Brake Pressure Sensor 1 (G201)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 125
Mileage: 104338 km
Time Indication: 0
Date: 2014.07.05
Time: 17:01:54
Freeze Frame:
Count: 3
Count: 14
Count: 29184
Count: 279
Count: 48640
Count: 10496
Count: 0
Count: 8704
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 125
Mileage: 104338 km
Time Indication: 0
Date: 2014.07.05
Time: 17:01:54
Freeze Frame:
Count: 3
Count: 14
Count: 29184
Count: 295
Count: 48640
Count: 10496
Count: 0
Count: 8704
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 125
Mileage: 104338 km
Time Indication: 0
Date: 2014.07.05
Time: 17:01:54
Freeze Frame:
Count: 3
Count: 14
Count: 29184
Count: 270
Count: 48640
Count: 10496
Count: 0
Count: 8704
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0199297623
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G_A02_VW31.rod
VCID: 34243AD79F0266EF73-8060
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 561 907 044 R HW: 561 907 044 R
Component: Climatronic H03 0405
Revision: 00001K01
Coding: 0010001002
ASAM Dataset: EV_ACClimaBHBVW411 A01001
ROD: EV_ACClimaBHBVW411_VW41.rod
VCID: 2600D09F59DE047FFD-8072
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 P HW: 5K0 937 086 P
Component: BCM PQ35 M+ 021 0068
Revision: BD021001
Coding: 68200E3B802908D400080000340081E00371008645A00DF064 806000AC70
VCID: 41CA6303D8B0C347E8-8014
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 050213 05 54 0403
Coding: 02300A
1 Fault Found:
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 124
Mileage: 104337 km
Time Indication: 0
Date: 2014.07.05
Time: 16:07:16
Freeze Frame:
Term 15 On
Voltage: 11.95 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM01FAJ
Coding: 00005033
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 75A2C7D3D4F83FE784-8020
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y130000SJJ20$
Coding: 303046
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME71266578ZZZZ
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME7E6F1478ZZZD
Crash sensor for side airbag: rear: driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME46746822ZZZS
Crash sensor for side airbag: rear: passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME632A3F22ZZZX
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME28703921ZZZQ
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME724C3921ZZZZ
1 Fault Found:
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 104337 km
Date: 2020.02.12
Time: 16:06:13
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 1K5 953 501 S HW: 5K0 953 569 L
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20121125100110
Coding: 010A140000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 3B3611EBB25CA997B2-806E
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-YVJ H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 870 B HW: 561 920 870 B
Component: KOMBI H07 0705
Serial number: 00000000000000
Coding: 631E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 187CEE67E3AAA28F7F-804C
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 02041303290542
Coding: 461000
Shop #: WSC 12345 123 61029
VCID: 76A0C0DFC1FE34FF8D-8022
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 561 919 965 HW: 561 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 1829227R44D406
Coding: 0000002
VCID: 6386898BA26CB157DA-8036
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0705
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A98E4AF8D46E01F19-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000003861002
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 302C36C76B1A5ACF17-8064
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664509691
Coding: 010100
VCID: 2A1824AF45C6201FD9-807E
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0006474867
Coding: 0404FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BF6B16B521C899792-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14202630130410104818
Coding: 800000
1 Fault Found:
131584 - Motor for Rear Window Regulator
B11EE 54 [008] - Missing Calibration / Basic Setting
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 165
Mileage: 104337 km
Date: 2020.02.12
Time: 16:06:15
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0034290
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3.rod
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2 H50 1634
Coding: 01030108
VCID: 6FAEF5BBBEA405374E-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011232400873
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0006500806
Coding: 0404FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CF4B27757128EAF9B-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14202631130409180554
Coding: 800000
2 Faults Found:
67074 - Motors for Central Locking
B122B 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 125
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 165
Mileage: 104337 km
Date: 2020.02.12
Time: 16:06:18
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
Component: Radio RCD510 051 0213
Revision: 00000001 Serial number: VWZ1Z3M8406516
Coding: 0102004001000B
VCID: 2306C98B22ECF1579A-8076
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664291009
Coding: 0A00000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A3814EFBD66909FA9-806E
End----(Elapsed Time: 01:19, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
please can somebody help with abs codig for my car
thank you
