Page 164 of 245 FirstFirst ... 64114154159160161162163164165166167168169174214 ... LastLast
Results 2,446 to 2,460 of 3668
  1. #2446
    Quote Originally Posted by vagva View Post
    car type ????
    The car is a 2015 VW Beetle 1.8T. The ECU is a 2008 Audi A3 3.2 Quattro.
    Thank you.
  2. #2447
    Hi. I need help for long coding for ABS. It is VW Jetta 2013 TDI 2.0L Diesel Left hand driver....ABS part is 1k0907379BL Vin# 3VWPL7AJ0DM663364
  3. #2448
    neksus's Avatar
    Jun 2013
    Quote Originally Posted by goga969 View Post
    Try and rapport...
    00000000092800FD000E00EA901D0000000000
    PRESS THANK + REPUTATION
  4. #2449
    Thanks a lot. Tommorow i will try and let you know.
  5. #2450
  6. #2451
    Mar 2011
    Romania
    try this and rep
    a13b400d092800fd850e02ea901d0044200000
  7. #2452
    Mar 2011
    Romania
    Quote Originally Posted by hybrid_r View Post
    Thank you.
    For coding you need vin stored on dashboard and abs module nr .
  8. #2453
    Quote Originally Posted by mike870 View Post
    The VIN on thes modules is 3VWS07AT3GM625037. Thank you for everyone's help so far.
  9. #2454
    I will do...
  10. #2455
    try this and rep
    it is reject...any others code??
  11. #2456
    Jul 2015
    São Paulo, Brasil
    Default HELP
    HI, I NEED LONG CODE FOR VW VOYAGE 1.6L 2019
    VIN:9BWDB45U0LT083498
    VAG NUMBER: 5U0614117M
    ABS TRW
  12. #2457
    Feb 2019
    I need ABS code for Amarok swap from diesel to petrol engine.
    Old code is
    C07324B69196039D24AB89AA6F5410
    VIN
    WV1ZZZ2HZB8028974
    Sent from my SM-G935F using Tapatalk
  13. #2458
    I need your help with ABS MK60 long coding for VW Golf V.
    Long coding is completetly 00000.... Don´t know history but I think someone just erased this.
    VW part number: 1K0907379CD
    Software Version 0120
    Hardware Part Number: 1K0907379AD
    Hardware version: H35
    Code Workshop: Imp: 001 WSC 38714
    Front wheel drive
    EPS OFF button ; LHD
    ECO system NO ; TPMS system NO ; Manual transmission
    Front brake I think its 280mm aproximately
    VIN: WVWZZZ1KZ9W035253
    Model: VW Golf V year 2008
    Engine: 1.9 TDI code BLU
    Next photo I think you can check extras.
    Many thanks for your help.
  14. #2459
    I used now an online service to get the long coding for this Golf V abs.
    It gave me long code 113B200D092500FF880D04E9901C00423000
    When I program on vehicle it doesn´t reject this code. The system accepts the coding.
    However after 1 minute of entering coding, the ECU will have again coding 00 00 00 00 .....
    What could be the problem ? I don´t understand why the system accepts the code, then after some time it write again 00 00 00 00
    Someone can help ? Thank you
  15. #2460
    May 2020
    Hello, Can you help me with long coding for my vehicle..for the abs unit
    2011 vw jetta
    vin 3vwlx7aj1bm358410
    thanks in advance...
