Page 166 of 245 FirstFirst ... 66116156161162163164165166167168169170171176216 ... LastLast
Results 2,476 to 2,490 of 3668
  1. #2476
    Mar 2011
    Romania
    Quote Originally Posted by Ninacivic View Post
    hello, i exchanged the abs unit. now the coding doesn't fit anymore. I hope you can help me.
    old coding: 11424012492A0002880E02E4922100413800 on hardware 1k0907379AD.
    new hardware: 1k0907379BJ the coding is completely set to 00000000000 ...
    Fin wauzzz8p59a088308
    in addition, the vehicle was converted to automatic dsg gearbox 2 years ago.
    gearbox auto
    gasoline 1.8 tfsi cdaa
    Tpms no
    LHD
    front wheel
    rear parking sensors only
    no hill
    hear are the pr numbers
    WAUZZZ8P59A088308
    Audi A3 Sportback model
    1.8 FSI
    A3
    Production date 12/10/2008
    Model year 2009
    Sales type 8PAC6C
    Engine code CDAA
    Starting aid UG0 Without hill start / departure aid / comfort
    driving aid
    Towbar 1D0 Without towbar
    1X0 front-wheel drive
    Rear brake version 1KD rear disc brakes
    Front brake design 1ZE front disc brakes (Geomet D)
    Brake systems 1AT electronic stabilization program
    (ESP)
    Rear suspension damping UA0 Rear damping
    Front suspension damping G37 Front damping
    without preparation for VTS (Vehicle Tracing System)
    Vehicle specifications F0A None
    Weight class rear axle 0YF weight range 6
    Weight class front axle L34 spring area 34
    only installation control none
    Demand forecast
    Basic engine TE6 4 cylinder petrol engine 1.8L Ag. 06J.3
    Cruise control system 8T2 cruise control system (GRA)
    Tire pressure monitor 7K0 without tire pressure monitor
    thank you for your jop
    11424012092a0002880e02e490210042380000
  2. The Following User Says Thank You to mike870 For This Useful Post:
    zk001 (13th June, 2020)
  3. #2477
    Mar 2011
    Romania
    Quote Originally Posted by seenomore View Post
    Hi , I need ABS Long Coding For Skoda Octavia, tahnk you in advance .
    ABS/ESP MK60EC1
    1K0 907 379 AN
    TMBDS21Z782239291
    113b401c09250003880d02ed901a0042e800
  4. #2478
    Mar 2011
    Romania
    Quote Originally Posted by Wonsu View Post
    Can you help me with my one?
    Octavia II 2009
    ABS
    Part number: 1K0 907 379 AP
    MK60EC1 H45
    VIN: TMBKK61Z5A2009978
    1.8 TFSI
    4x4
    LHD
    Brake discs 288/253
    113b401c09220003881402eb902100423000
  5. #2479
    Jun 2020
    I am looking for an ABS long code for a 2011 Golf VIN WVWZZZ1KZBW039043. Can anybody help?
    Thanks in advance
    Monday,08,June,2020,09:10:34:06726
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 20.4.1.0 (x64)
    Data version: 20200331 DS317.0
    www.Ross-Tech.com
    VIN: WVWZZZ1KZBW039043 License Plate:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZBW039043 Mileage: 119510km-74260miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
    Part No SW: 5K0 907 115 HW: 1K0 907 115 AA
    Component: 2.0l R4/4V TFSI 0040
    Revision: AAH17--- Serial number:
    Coding: 0403000C18070060
    Shop #: WSC 01357 011 00200
    VCID: 67D65AB6567792BEAA-8032
    No fault code found.
    Readiness: 0110 0001
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
    Component: ESP MK60EC1 H30 0105
    Revision: 00H30001
    Coding: 00000000000000000000000000000000000000
    VCID: 040C6D3A870159A62F-8050
    4 Faults Found:
    03306 - Coding Not Valid
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 103
    Mileage: 119512 km
    Time Indication: 0
    Date: 2014.10.27
    Time: 14:49:18
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12288
    Count: 4161
    Count: 53504
    Count: 0
    Count: 256
    Count: 0
    01486 - System Function Test Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 103
    Time Indication: 0
    Date: 2014.10.27
    Time: 17:32:10
    Freeze Frame:
    Count: 7
    Count: 2
    Count: 12288
    Count: 320
    Count: 43776
    Count: 0
    Count: 256
    Count: 0
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 103
    Mileage: 119512 km
    Time Indication: 0
    Date: 2014.10.27
    Time: 14:42:47
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12288
    Count: 338
    Count: 53504
    Count: 0
    Count: 256
    Count: 0
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 103
    Time Indication: 0
    Date: 2014.10.27
    Time: 17:32:10
    Freeze Frame:
    Count: 7
    Count: 2
    Count: 12288
    Count: 195
    Count: 43776
    Count: 0
    Count: 256
    Count: 0
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
    Component: Climatronic H15 1012
    Revision: 00003001
    Coding: 0000001002
    Shop #: WSC 12345 123 12345
    ASAM Dataset: EV_Climatronic A01010
    ROD: EV_ClimaAutoBasis_VW36.rod
    VCID: 7DFA18DEECEB286E60-8028
    Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
    Part No SW: 1K0 937 086 H HW: 1K0 937 086 H
    Component: BCM PQ35 M 103 0615
    Revision: 00103 AD
    Coding: 40180A3A8025F1C040080080340001E443510088536D896064 8000200040
    VCID: 356AC0FE9C5B302EE8-8060
    Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer 16061 21 0512
    Coding: 009795
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 230610 05 54 0403
    Coding: 0330AD
    Subsystem 3 - Part No: 1K8 951 171
    Component: DWA-Sensor 00 001 0104
    Subsystem 4 - Part No: 1K8 951 605 A
    Component: LIN BACKUP HO H11 9004
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
    Component: AirbagVW10 037 0606
    Serial number: 003FKRA9GPMI
    Coding: 00003135
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
    ROD: EV_AirbaVW10SMEVW360.rod
    VCID: 3B7ED6C6B27FE65E1E-806E
    Crash sensor for side airbag: driver side:
    Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME62207054ZZZJ
    Crash sensor for side airbag: front passenger side:
    Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME51544454ZZZQ
    Crash sensor for side airbag: rear: driver side:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3512QSME1617575BZZZY
    Crash sensor for side airbag: rear: passenger side:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3522QSME2E136467ZZZZ
    Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
    Part No SW: 5K0 953 507 BB HW: 5K0 953 549 D
    Component: Lenks.Modul 007 0080
    Revision: -------- Serial number: 90440JFF0009I
    Coding: 1082040000
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_A05.rod
    VCID: 71E234EEA0B35C0EF4-8024
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H05 0010
    Serial number: 0002835
    Coding: 820000
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 5K6 920 971 HW: 5K6 920 971
    Component: KOMBI H04 0406
    Serial number: 00000000000000
    Coding: 470B00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
    VCID: 72E03BE2A5B567160D-8026
    Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
    Part No SW: 7N0 907 530 HW: 1K0 907 951
    Component: J533 Gateway H27 0602
    Revision: H27 Serial number: 220610F2001111
    Coding: E9807F0600021200000003
    VCID: 6DDA289E748BB8EED0-8038
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H04 0406
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
    VCID: 6AD023828D65AFD6B5-803E
    Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
    Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
    Component: SG EXT.PLAYER H13 0111
    Revision: A1001003 Serial number: 7668212580
    Coding: 010000
    VCID: 27561AB656F752BE6A-8072
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
    Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
    Component: Tuer-SG 009 2140
    Coding: 0000692
    VCID: 336EFEE6522F2E1EC6-8066
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 74 3001
    Revision: 00H17000
    VCID: 3162F4EEA8331C0EB4-8064
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
    Component: Tuer-SG 009 2114
    Coding: 0000692
    VCID: 3260FBE2AD352716CD-8066
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
    Component: Radio RCD310 042 0082
    Revision: 01000001 Serial number: VWZ1Z2N1317238
    Coding: 01000000000000
    Shop #: WSC 01286 386 08256
    VCID: 72E03BE2ADB567160D-8026
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
    Component: Tuer-SG 007 2101
    Coding: 0000144
    Shop #: WSC 01357 011 1012552
    VCID: 346CFDFA57212926DF-8060
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
    Coding: 0000144
    VCID: 356AC0FE5C5B302EE8-8060
    End-------------------------(Elapsed Time: 02:35)--------------------------
  6. #2480
    Sep 2012
    AOW
    Please Help with ABS coding VW Golf Vl 2011 Mk60EC1 1K0907379BE
    I attach PR label of the car
    Thank you all!
  7. #2481
    Aug 2019
    hello i would like to know how i can turn off system function test without drive test
  8. #2482
    Apr 2016
    Hello.
    Please help with ABS long coding.
    VW caddy 2012 1.6tdi CAYC, DSG
    VIN: WV1ZZZ2KZDX042218
    ABS: ESP MK60EC1
    Vag nr: 1K0907379BL
    SW ver: 0152
    HW ver: H31
    Thanks in advance.
  9. #2483
    pedjica's Avatar
    Sep 2015
    Serbia
    Please code abs module audi a3 2011.
    Friday,12,June,2020,12:43:00:64546
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 20.4.1.0 HEX-NET CB: 0.4513.4
    www.Ross-Tech.com
    VIN: WAUZZZ8P6CA012538 License Plate: A3 2011 S.MITROVICA
    Mileage: 280160km-174083mi Repair Order:
    Chassis Type: 8P-AU35 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 47 52 56 61 62
    72 77
    VIN: WAUZZZ8P6CA012538 Mileage: 280160km-174083miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 AG HW: 03L 906 018 AG
    Component: R4 2.0l TDI H24 9978
    Revision: 41H24--- Serial number: AUX7Z0K5FNF0WR
    Coding: 001D0032042401080000
    Shop #: WSC 32967 001 1048576
    ASAM Dataset: EV_ECM20TDI01103L906018AG 003013
    ROD: EV_ECM20TDI01103L906018AG.rod
    VCID: 6FAED5DDB6612EFEE2-803A
    1 Fault Found:
    5523 - Engine Start Blocked by Immobilizer
    P1570 00 [167] - -
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 280166 km
    Date: 2019.08.28
    Time: 20:37:03
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 83 °C
    Intake air temperature: 48 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 12.340 V
    Unlearning counter according OBD: 40
    Immobilizer snapshot A-Sia Error Snap A: 2B AB 15
    Immobilizer snapshot B-Sia Error Snap B: 0A 00 00
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-927-770.clb
    Part No SW: 02E 300 057 A HW: 02E 927 770 AL
    Component: GSG DSG AG6 511 2706
    Revision: 05351113 Serial number: 00001105280043
    Coding: 0000020
    Shop #: WSC 06314 000 00000
    VCID: 177ECD3D2671863EDA-8042
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    VCID: 7BB6F18DFA19425E5E-802E
    4 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 87
    Mileage: 280166 km
    Time Indication: 0
    Date: 2019.08.28
    Time: 20:35:55
    Freeze Frame:
    Count: 7
    Count: 12
    Count: 20480
    Count: 195
    Count: 44288
    Count: 0
    Count: 0
    Count: 0
    01435 - Brake Pressure Sensor 1 (G201)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 87
    Mileage: 280166 km
    Time Indication: 0
    Date: 2019.08.28
    Time: 20:35:55
    Freeze Frame:
    Count: 2
    Count: 0
    Count: 20480
    Count: 279
    Count: 44288
    Count: 0
    Count: 256
    Count: 0
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 87
    Mileage: 280166 km
    Time Indication: 0
    Date: 2019.08.28
    Time: 20:35:55
    Freeze Frame:
    Count: 2
    Count: 0
    Count: 20480
    Count: 295
    Count: 44288
    Count: 0
    Count: 256
    Count: 0
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 87
    Mileage: 280166 km
    Time Indication: 0
    Date: 2019.08.28
    Time: 20:35:55
    Freeze Frame:
    Count: 2
    Count: 0
    Count: 20480
    Count: 270
    Count: 44288
    Count: 0
    Count: 256
    Count: 0
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
    Component: KlimavollautomatH09 0170
    Revision: 000227 Serial number: 8P0820043BM
    VCID: 78BCEE810B2F694633-802C
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 126
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    ON
    Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
    Part No SW: 8P0 907 063 N HW: 8P0 907 063 N
    Component: BCM PQ35 M 110 0653
    Revision: 00110 AF
    Coding: 46000A2FA0051AC0207040E00000015C421A29AA004DC12AE4 008F800041
    VCID: 3FCE459DAE819E7E32-806A
    Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H11 0050
    Coding: 00DD13
    Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
    Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
    Component: PARKHILFE 4K H01 0140
    Revision: 11001001 Serial number: 36891114699057
    Coding: 000103
    VCID: 48DC5E41FB4FD9C683-801C
    Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
    Component: Airbag AU1042 H09 0250
    Revision: -------- Serial number: 003JU002JN5F
    Coding: 30314238303830303035554A304C38503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 52E87C2905136316ED-8006
    Serial number: 3572DRB40000DA3901AW
    Serial number: 3582DRB40000DA3549D1
    Serial number: 35128RB40000630B43AC
    Serial number: 35228RB40000630A27BF
    Crash sensor for front airbag: driver side:
    Serial number: 35547RB40000642DEED3
    Crash sensor for front airbag: front passenger side:
    Serial number: 35647RB40000642E0EAV
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
    Component: J0527 H37 0070
    Coding: 0014142
    VCID: 46C05079315BCFB671-8012
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0100
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 932 C HW: 8P0 920 932 C
    Component: KOMBIINSTR. VDO H02 0980
    Revision: D0H02002 Serial number: 2246I002017874
    Coding: 0004028
    Shop #: WSC 11111 111 11111
    VCID: 34241AB157C74D26DF-8060
    1 Fault Found:
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 280116 km
    Time Indication: 0
    Date: 2019.08.28
    Time: 21:25:22
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 J HW: 1K0 907 951
    Component: J533 Gateway H43 1620
    Revision: H43 Serial number: 020611F1000246
    Coding: 352102
    VCID: 373E2DBD86B1A63EFA-8062
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H02002 Serial number: AUX7Z0I6FNF09Q
    2 Faults Found:
    02241 - Engine Control Module; Immobilizer Data not Adapted
    000 - -
    01176 - Key
    Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H06 0200
    Revision: 0000012S Serial number: AUZBZ7LD210380
    Coding: 0205755
    Shop #: WSC 00126 223 178895
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
    Component: Tuer-SG H04 0101
    Coding: 0131252
    VCID: 49DA5B45204520CE9C-801C
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 233 3201
    Revision: 00H20000
    Shop #: WSC 02069 000 90108
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
    Component: AB2 SUBWOOFERBOXH07 0180
    Revision: 00006 Serial number: 92158120790903
    VCID: 362020B941BB5F36E1-8062
    Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
    Coding: 0131252
    VCID: 4AD8644925432BD695-801E
    Address 56: Radio Labels: 8E0-035-192-RNSE.clb
    Coding: 0205755
    Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H43 1620
    Coding: F30B185A
    VCID: 71AAD3A5A855380EF4-8024
    Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
    Component: J367-BDM H07 0150
    Serial number: 00000000009370558083
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
    Component: Tuer-SG H04 0050
    Coding: 0131216
    Shop #: WSC 06314 000 1012544
    VCID: 42C84C691D73F3965D-8016
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
    Coding: 0131216
    VCID: 43C6496D0269FA9E56-8016
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P1 862 335 A HW: 8P1 862 335
    Component: FSE_256x BT H44 0660
    Revision: 00000000 Serial number: 00000005401611
    Coding: 0011491
    VCID: 352227B55CBD542EE8-8060
    End----------(Elapsed Time: 01:22, VBatt start/end: 12.2V/12.2V)-----------
  10. #2484
    Nov 2017
    Uk
    HI guys i hope you are able to help . I've got a 2010 vw polo tdi that had a faulty ecu, found another donor car which was a 2012, took the key, ecu, and cluster from it, everything is ok so far but the abs module comes up with no long code. could you please help me with the coding . see the scan bellow:
    Friday,12,June,2020,15:48:38:00009
    VCDS Version: 19.6.0.2 (x64)
    Data version: 20190529 DS308.0
    www.Ross-Tech.com
    VIN: WVWZZZ6RZBU071464 License Plate: --------
    Mileage: 148450km-92242mi Repair Order: ABS module issue
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
    VIN: WVWZZZ6RZBU071464 Mileage: 148450km-92242miles
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: Not registered 0011
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
    Part No SW: 03P 906 021 A HW: 03P 907 425 A
    Component: R3 1.2l TDI H06 9978
    Revision: 11002001 Serial number:
    Coding: 00114010000500080000
    Shop #: WSC 31414 790 50316
    ASAM Dataset: EV_ECM12TDI03103P906021A 001023
    ROD: EV_ECM12TDI03103P906021.rod
    VCID: 2643439F59E7047FCB-8072
    Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
    Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
    Component: ESP8.2i front H05 0001
    Revision: --------
    Shop #: WSC 31414 790 31414
    VCID: 071D2E1BB22D3D77D0-8052
    4 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 10
    Reset counter: 120
    Mileage: 148451 km
    Time Indication: 0
    Date: 2014.10.10
    Time: 02:05:11
    Freeze Frame:
    Hex Value: 0x0007
    Hex Value: 0x0000
    Hex Value: 0x1013
    Hex Value: 0x1484
    Hex Value: 0x00FF
    Hex Value: 0x7F7F
    Hex Value: 0x7F00
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 21
    Reset counter: 120
    Mileage: 148451 km
    Time Indication: 0
    Date: 2014.10.08
    Time: 00:05:34
    Freeze Frame:
    Hex Value: 0x0007
    Hex Value: 0x0000
    Hex Value: 0x3251
    Hex Value: 0x1BB3
    Hex Value: 0x00FF
    Hex Value: 0x7F7F
    Hex Value: 0x7F00
    00493 - ESP-Sensor Unit (G419)
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 148451 km
    Time Indication: 0
    Date: 2014.11.03
    Time: 00:00:17
    Freeze Frame:
    Hex Value: 0x0007
    Hex Value: 0x0000
    Hex Value: 0x12E1
    Hex Value: 0x2098
    Hex Value: 0x00FF
    Hex Value: 0x7F7F
    Hex Value: 0x7F00
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 46
    Reset counter: 160
    Mileage: 148451 km
    Time Indication: 0
    Date: 2014.10.08
    Time: 00:11:15
    Freeze Frame:
    Hex Value: 0x0002
    Hex Value: 0x0000
    Hex Value: 0x32E7
    Hex Value: 0x25B2
    Hex Value: 0x00FF
    Hex Value: 0x7F7F
    Hex Value: 0x7FF8
    Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
    Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
    Component: Man AC 02 0101
    Revision: 0002S 02
    VCID: 326BAFCF6D2F68DF57-8066
    2 Faults Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 159
    Mileage: 148451 km
    Time Indication: 0
    Date: 2011.12.19
    Time: 23:32:44
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 159
    Mileage: 148451 km
    Time Indication: 0
    Date: 2011.12.19
    Time: 23:32:44
    Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R0 937 086
    Component: GW-K-CAN TP20 0230
    Coding: 002300
    VCID: 70EF65C7A3A31ACF61-8024
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 19
    Reset counter: 255
    Mileage: 148450 km
    Time Indication: 0
    Date: 2014.10.08
    Time: 02:36:18
    Component: IMMO H05 0304
    Serial number:
    Coding: 000000
    ROD: EV_Immo_UDS_VDD_RM09.rod
    VCID: 6ADB77AF8D7FE01F2F-803E
  11. #2485
    Jul 2013
    zagreb
    Hi mate
    can you help me with abs coding for Golf mk6 2.0 tdi, 4motionVIN: WVWZZZ1KZAW348460
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
    Component: ESP MK60EC1 H30 0107
    Revision: 00H30001
    VCID: 7AFB1463F52A82CEDA7-802F
  12. #2486
    wti's Avatar
    Dec 2017
    America do Sul
    hello friend, could you help me with the long code, I didn't forget the thanks buttons.
    VW SAVEIRO 2019
    left steering wheel
    ABS 1S0 614 117 S
    VIN 9BWKB45U4HP042587
  13. #2487
    Jun 2020
    Good Day Digital Kaos family, I hope everyone is well, please may i request the long code for the abs module
    Vehicle details as follows
    2020 Mk6 GTI manual
    vin WVWZZZ1KZAW1799977
    right hand drive
    any assistance will be greatly appreciated, thank you
  14. #2488
    Dec 2012
    Default CODING LOST ABS VW GOLF 6 2011
    Hi pleas i need coding abs 1K0 907 379 BE MK60EC1
  15. #2489
    borysgo2's Avatar
    Hi. I would be gratefull if someone help me to code 2009 MK6 VW Golf :
    1K0907379CD
    ESP MK60EC1 H35 0120
    WVWZZZ1KZ9P440789
    ENGINE 1.4MPI PETROL CGG
    RHD
    3 door
    no TMPS
    Manual gearbox
    THANKS
  16. #2490
    May 2016
    Hungary
    Default Audi A3 abs long code
    Hi Guys!
    Please help me the long coding for ABS. The ABS was swapped.
    1. ABS module part number: old 1k0 907 379 AD (not readable), new 1k0 907 379 BJ
    2. WAUZZZ8P89A076024
    3. Audi A3 8p 2008
    4. Left hand drive (LHD)
    5. 1,6 petrol, BSE
    6. FWD, manual gearbox
    7. no start/stop
    8. TPMS yes
    9. ESP off buttons (in the center console)
    10. no "Hill hold" function.
    Thanks for your work.
