Page 183 of 245 FirstFirst ... 83133173178179180181182183184185186187188193233 ... LastLast
Results 2,731 to 2,745 of 3668
  1. #2731
    Dec 2020
    Defecto
    Hola y feliz navidad a todos
    , necesito una codificación larga para este automóvil:
    golf mk5 1.9tdi bxe
    Módulo de control Número de pieza: 1K0 907379 AN
    Componente y / o versión: ESP MK60EC1 H45 0107
    VW Golf V 1.9TDI
    Código de motor BXE
    Año 2008
    VIN: wvwzzz1kz9P003664
    Caja de cambios manual
    LHD
    FWD
    Tiene el botón de apagado ESP
  2. #2732
    Jan 2021
    Can someone help me to coding my abs i change it old one was 1k0907379ad with 1k0907379cd software now is 1k0907379ad with 1k0907379ad software
    VIN wvwzzz1kz9w401334
    Vw Golf 6 2.0 tdi 110ps 2008
    ESP MK60EC1 H35 0109
    143B600D212200FB280E06E7841D0040B100 Thanks First one is accept but now i have problem i don’t have hill holder control G251 but the abs is searching for it and some vacuum. Two of them was deleted but G251 and the vacuum stay
  3. #2733
    kwansterp's Avatar
    Hi freinds.
    I replaced the ABS pump with another used 1K0 907 379 AT, the previous one was 1K0 907 379 CD
    I have coding problems. Please i need help for long coding ABS for a VW golf mk6.
    Car : golf mkVI
    Vin : WVWZZZ1KZ9P489177
    Abs : 1K0 907 379 AT
    engine : BSE
    LHD Manual trans
    Tires : 195/65/r15
    In the attachment there is a sticker from the trunk
    Thank you in advance.
  4. #2734
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by kwansterp View Post
    Hi freinds.
    Car : golf mkVI
    engine : BSE
    LHD Manual trans
    Tires : 195/65/r15
    Usaully I need vin from instrument
    if vin is the same then one of these should be your long coding :
    143B600D212A0003280C06EB84200040B100
    A13B20F8092A0003850CF0EBC92000041A50800
    143B400D112A0003280C02EB88200040310000
  5. The Following 2 Users Say Thank You to vagva For This Useful Post:
    kwansterp (9th January, 2021), red69 (13th January, 2021)
  6. #2735
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by litllevill View Post
    Serial
    Here is your long coding :
    843D601609220002210B06E4901A00423500
    863D601609220002610B06E4901A00813400
  7. The Following 2 Users Say Thank You to vagva For This Useful Post:
    hampster (13th January, 2021), litllevill (6th January, 2021)
  8. #2736
    PierreTheron's Avatar
    Centurion,South Africa
    I think some clever people figured this out already with brain exe ... as you helped plenty off them ,,,.
  9. #2737
    UK
    Can you please help with the following
    Glof Mk6 1.4TSI petrol , automatic , RHD
    MK60EC1
    1K0 907 379 BL
    WVWZZZ1KZDP033228
  10. #2738
    UK
    done my self
  11. #2739
    United Kingdom
    Hi i wonder if you can help,
    i changed the ECU & dash and have now all 00 in long coding.
    i have the old code but the dash and ECU have a new different VIN number so it will not accept it.
    The Old VIN:- WVWZZZ1KZAW363101
    The New VIN:- WVWZZZ1KZCW136309
    The Old MK60 Code.
    this is from the last scan that was done .
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
    Component: ESP MK60EC1 H30 0107
    Revision: 00H30001
    Coding: 133B200D092800FDC80C04E4901A0081310000
    Shop #: WSC 01357 011 00200
    VCID: 7AFB44E9F5DF5E9A9B-802E
  12. #2740
    sbakovi's Avatar
    Dec 2010
    EU
    Hi ,Please i need help for long coding ABS for a Seat leon.Thanks
    VIN: VSSZZZ1PZ8R014099 License Plate:
    Mileage: 147070km-91385mi Repair Order:
    Chassis Type: 1P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: VSSZZZ1PZ8R014099 Mileage: 147070km-91385miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Sporadic communication error 1000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 1010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Cannot be reached 1100
    Address 01: Engine Labels: 03G-906-021-BLS.clb
    Part No SW: 03G 906 056 AA HW: 03G 906 021 AB
    Component: R4 1,9L EDC 000SG 2898
    Revision: --H08--- Serial number: XXXXXXXXXXXXXX
    Coding: 0050071
    Shop #: WSC 00011 888 06946
    VCID: 66C3039F5167C47F0B-8032
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0104
    Revision: 00H35001
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 04941 000 00000
    VCID: 74E769D7D7BB26EF85-8020
    5 Faults Found:
    03306 - Coding Not Valid
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 7
    Mileage: 147077 km
    Time Indication: 0
    Freeze Frame:
    Count: 3
    Count: 0
    Count: 12288
    Count: 4161
    Count: 47616
    Count: 0
    Count: 0
    Count: 0
    01435 - Brake Pressure Sensor 1 (G201)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 7
    Mileage: 147077 km
    Time Indication: 0
    Freeze Frame:
    Count: 3
    Count: 0
    Count: 12288
    Count: 279
    Count: 47616
    Count: 0
    Count: 0
    Count: 0
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 7
    Mileage: 147077 km
    Time Indication: 0
    Freeze Frame:
    Count: 3
    Count: 0
    Count: 12288
    Count: 270
    Count: 47616
    Count: 0
    Count: 0
    Count: 0
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 7
    Mileage: 147077 km
    Time Indication: 0
    Freeze Frame:
    Count: 7
    Count: 0
    Count: 12288
    Count: 195
    Count: 48128
    Count: 0
    Count: 0
    Count: 0
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 7
    Mileage: 147077 km
    Time Indication: 0
    Freeze Frame:
    Count: 3
    Count: 0
    Count: 12288
    Count: 291
    Count: 47616
    Count: 0
    Count: 0
    Count: 0
  13. #2741
    Jan 2019
    France
    Hello friend,
    can you please help me, i replaced ABS pump on a golf 5 1.9 TDI 2008 year.
    VIN: WVWZZZ1KZ9W030598
    LHD, Manual Transmission
    ESP: 1K0 907 379 AJ
    Tires: 205/55 R16
    Thank You
  14. #2742
    i_shot_the_sheriff's Avatar
    Nov 2008
    Default Skoda Octavia
    Hi there ,,
    I've been struggling with coding this damn ABS from a Skoda Octavia . Vin number is TMBCT21Z6D2094778
    Can someone please help ? I've paid to make it online coding with ODIS ,,, but i'm getting error ERP0617E all the time and won't code the module ! So can someone calculate please so i can code it?
    Thanks in advance
  15. #2743
    Oct 2018
    Hello ,please calculate coding for abs
    Skoda Octavia FL 2011y ,
    2.0tdi
    LHD
    TMBHE61Z0C2035568
    ESP MK60EC1
    1K0907379BJ
  16. #2744
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by hampster View Post
    The Old MK60 Code.
    Revision: 00H30001
    Here is your Long coding :
    133B200D09250000C80E04E490220081310000
  17. The Following 4 Users Say Thank You to vagva For This Useful Post:
    hampster (13th January, 2021), i_shot_the_sheriff (14th January, 2021), Mikle1 (13th January, 2021), red69 (14th January, 2021)
  18. #2745
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by Mikle1 View Post
    2.0tdi
    LHD
    TMBHE61Z0C2035568
    ESP MK60EC1
    1K0907379BJ
    here is your ABS Long coding :
    113B201C092500FF881004EA90210041340000
  19. The Following 2 Users Say Thank You to vagva For This Useful Post:
