Page 185 of 245 FirstFirst ... 85135175180181182183184185186187188189190195235 ... LastLast
Results 2,761 to 2,775 of 3668
  1. #2761
    Coding accepted but have errors01279 03366 and 02085
  2. #2762
    Nov 2015
    [QUOTE=vagva;4044794]Hi
    first of all we nee vin from dashboard not from sticker or glass
    by the way , your inbox is full ,try to delete some
    i checked dashboard has the same vin
  3. #2763
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by real898 View Post
    Attachment 778359Attachment 778346hello freind i need long code golf 6 2.0 tdi cbcc vin wvwzzz1kzap070882 abs 1k0907379an
    one othese will be your Long coding:
    143B600D212900FA281306EC841B0040B100
    A13B20F8092900FA8513F0ECC91B00041A50800
  4. The Following User Says Thank You to vagva For This Useful Post:
    Zadleer (30th January, 2021)
  5. #2764
    mkii's Avatar
    Oct 2008
    hello i need help
    Car : scirocco
    Vin : WVWZZZ13Z9V001232
    Abs : 1K0 907 379 CE
    engine : CAW
    LHD AUTO TRANS
    Tires : 235/40/18
    PR-CODES:B0A C9T G1A HV3 J1D D2L V0A 1AT 1G9 2FP 5RG 5SL 3U1 QG1 8AY 8GU 1LJ 3FA 0GG 4UF4X3 4R4 4K3 N1A 8RM 2JC E0A 1D0 A8I 8BG U5A 1N3 3L3 4A3 8N4
    THANKS IN ADVANCE
  6. #2765
    Nov 2015
    Quote Originally Posted by vagva View Post
    Thanks for the work, the correct encoding 113B200D092900FA881304EC901B00412800 helped the brain file
  7. #2766
    Jan 2021
    Hi I apreciate if You can give me long coding for
    2015 VW JETTA US Version AT VIN 3VW1K7AJFM352686
  8. #2767
    g5n14's Avatar
    Aug 2018
    Hey guys! I have the calculator software, but for some reason still cant get it to work.
    Car is Golf V 2009, 1.4TSI
    ABS 1K0907379BJ
    VIN: WVWZZZ1KZ9M272292
    TPMS installed
    PLA not installed
    Brakes 288-253
    FWD
    LHD
    Coding 114B400C112900FC880D02ED881B0041050000 did not work.
  9. #2768
    Car Skoda octavia 1.2 TSI
    Hardware part number:
    3Q0907379C
    Part number:
    3Q0907379P
    VIN: TMBAB7NE3G0125113
    Engine CYDB
    FWD
    LHD
    thanks in advanced
  10. #2769
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by naelraddad View Post
    3Q0907379C
    Part number:
    3Q0907379P
    Engine CYDB
    FWD
    LHD
    thanks in advanced
    Here is your Long coding :
    113B201C092400FF880C04E5901C0040340000
    you maybe need to remove or add 00 from the end
  11. The Following 2 Users Say Thank You to vagva For This Useful Post:
    kospoz (29th January, 2021), naelraddad (27th January, 2021)
  12. #2770
    EUROPE
    I have done a huge mistake.I tried another cluster and did not copy the coding from abs and now all values are 00.
    abs is 1k0907379 BK ESP MK60EC1 H31 0152
    VIN-->TMBCT61ZXD2028094
    Can someone calculate coding?Car is Octavia 1.6 tdi cayc 2011 model left hand
  13. #2771
    Feb 2013
    North of the South, Venezuela, self-exiled in D.R.
    I change the Abs Pump from VW Jetta 2010 and Abs coding is lost
    VIN: 3VWRAZAJXAM036505
    Jetta 2.0 TDI LHD ESP Button Chassis Type AJ-VW36 (1K0)
    ABS Old 1k0 907 309 AH MC60EC1 old Coding 114B600C49250000881006E4921E0041300800
    New Abs installed "1K0 907 309 CC" MK60EC1
    i test codes 114B600C49250000881006E4921E004130080000 02 21 22 72 .... but not work
    Please help to generate new coding
  14. #2772
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by kospoz View Post
    Here is your long coding:
    113B201C09240002880B04ED901D0041340000
  15. The Following 2 Users Say Thank You to vagva For This Useful Post:
    builderis (29th January, 2021), kospoz (29th January, 2021)
  16. #2773
    Member builderis's Avatar
    Nov 2012
    Lithuania
    Please help with long coding ABS/ESP
    SUPERB 2014
    ESP MK60EC1
    1K0907379BL
    TMBLF73T5E9008432
    engine : CFGB
    LHD
  17. #2774
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by builderis View Post
    SUPERB 2014
    ESP MK60EC1
    1K0907379BL
    TMBLF73T5E9008432
    engine : CFGB
    LHD
    One of these shouid be your long coding :
    843D601609220002210F06E7901B00423500
    863D601609220002610F06E7901B00813400
  18. The Following 2 Users Say Thank You to vagva For This Useful Post:
    aquilesy (29th January, 2021), builderis (29th January, 2021)
  19. #2775
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by aquilesy View Post
    one of these should be your exact long coding :
    A13B20F809250000851004E4901E004121100
    A14B400C49250000851002E4921E0041A1100
    B14B400C492500008D1002E4921E004221000
