Page 186 of 245 FirstFirst ... 86136176181182183184185186187188189190191196236 ... LastLast
Results 2,776 to 2,790 of 3668
  1. #2776
    Jan 2021
    Hi I apreciate if You can give me long coding for
    2015 VW JETTA US Version AT VIN 3VW1K7AJFM352686
  2. #2777
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by Zadleer View Post
    jetta 2015 has MK60 abs ?
    If its so , then your ABS Long coding should be one of these coding:
    A14B400C492700FC851102EC921F0041A1100
    B14B400C492700FC8D1102EC921F004221000
    A43B600D492700FC281106EC921F0041B100
    A13B20F8092700FC851104EC901F004121100
  3. The Following 2 Users Say Thank You to vagva For This Useful Post:
    g5n14 (2nd February, 2021), nrg128 (4th February, 2021)
  4. #2778
    Jan 2021
    Hi thanks but anyone works
    ESP MK60EC1
  5. #2779
    Jan 2021
    Hi, after the instrument cluster died on my 2009 audi s3 8p i replaced the whole kit but now i get fault vacuum sender-g608 electrical fault in circuit.
    Software part number:1k0907379AP
    Esp mk60EC1
    Current coding is 1640110068028800803100
    Car vin:WAUZZZ8PX9A052761
    dash vin:WAUZZZ8P29A070557
    Also the car now has hill assist which it didn't before. If anyone could help me with the correct coding also without hill asist. I would much appreciate it, thanks
  6. #2780
    Fec001's Avatar
    SOLVED!!!!!
  7. #2781
    Feb 2013
    North of the South, Venezuela, self-exiled in D.R.
    Unhappy
    Quote Originally Posted by vagva View Post
    one of these should be your exact long coding :
    A13B20F809250000851004E4901E004121100
    A14B400C49250000851002E4921E0041A1100
    B14B400C492500008D1002E4921E004221000
    Not Work!! coding refused
  8. #2782
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by g5n14 View Post
    Hey guys! I have the calculator software, but for some reason still cant get it to work.
    Car is Golf V 2009, 1.4TSI
    ABS 1K0907379BJ
    VIN: WVWZZZ1KZ9M272292
    TPMS installed
    PLA not installed
    Brakes 288-253
    FWD
    LHD
    Coding 114B400C112900FC880D02ED881B0041050000 did not work.
    OK
    ONE OF THESE SHOULD BE YOUR EXACT CODING :
    143B600D212900FC280D06ED841B0040B100
    A13B20F8092900FC850DF0EDC91B00041A50800
    113B200D092900FC880D04ED901B00412800
    YOU MAYBE NEED TO ADD OR REMOVE 00 FROM THE END
  9. The Following User Says Thank You to vagva For This Useful Post:
  10. #2783
    Hi friends, can anyone help me please?, with a coding of Touran from 2014?, i change battery and ABS ESP is blinking,loose CODING now is "0000000..", the touran have Start stop, tpms, and have sterring button on the center of console,is 2.0 TDI CFH engine Automatic, the abs number is 1K0 907 379 BM, AND VIN WVGZZZ1TZFW011317, thanks in advnce!
  11. #2784
    Jan 2021
    Hi all coding rejected
  12. #2785
    Jan 2021
    HI NOT WORK CODING REJECTED
  13. #2786
    Jan 2021
    Quote Originally Posted by Aiden1993 View Post
    Esp mk60EC1
    Still need help if anyone can do it?
  14. #2787
    mkii's Avatar
    Oct 2008
    Quote Originally Posted by mkii View Post
    hello i need help
    Car : scirocco
    Vin : WVWZZZ13Z9V001232
    Abs : 1K0 907 379 CE
    engine : CAW
    LHD AUTO TRANS
    Tires : 235/40/18
    PR-CODES:B0A C9T G1A HV3 J1D D2L V0A 1AT 1G9 2FP 5RG 5SL 3U1 QG1 8AY 8GU 1LJ 3FA 0GG 4UF4X3 4R4 4K3 N1A 8RM 2JC E0A 1D0 A8I 8BG U5A 1N3 3L3 4A3 8N4
    THANKS IN ADVANCE
    SOLVE !!! by myself
    THANKS TO ALL
  15. #2788
    Oct 2014
    Rome
    Hello, need help with long coding of this used abs.. don thave the old coding. greatz
    VW Golf plus - 11/2009
    1968 - 103 kw - CBD
    VIN : WVWZZZ1KZAW529600
    ABS CODE : 1K0 907 379 AP
    ESP MK60EC1 H45 0107
    i will apprecied the help.. tnx
  16. #2789
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by nrg128 View Post
    1968 - 103 kw - CBD
    one of these should be your abs long coding :
    143B600D212400032811060B84190040B100
    A13B20F8092400038511F00BC91900041A50800
    113B200D092400038811040B901900412800
    you maybe need to add or remove 00 from the end
  17. The Following User Says Thank You to vagva For This Useful Post:
  18. #2790
    Jan 2021
    Still need help please
