Page 188 of 245 FirstFirst ... 88138178183184185186187188189190191192193198238 ... LastLast
Results 2,806 to 2,820 of 3668
  1. #2806
    Feb 2021
    the long coding is not working I tried adding and subtracting 00. Whenever
    message: Coding rejected. Request out of range.
    please help.
  2. #2807
    Feb 2014
    Hello pls. need long code for this ABS/ESP Model
    Control Module Part Number: 1K0 907 379 CD
    Component and/or Version: ESP MK60EC1 H35 0120
    Software Coding: 0000000000000000000000000000000000000
    ESP On/Off Button: YES
    Engine Code: BSE
    vin WVWZZZ1KZ9P022418
    GOLF 5 1.6mpi
  3. #2808
    Feb 2021
    Hi.
    TMBHS61Z392019995
    1K0 901 379 BJ
    Thanks.
  4. #2809
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by SonyPS3 View Post
    Engine Code: BSE
    GOLF 5 1.6mpi
    Joined in 2014 ( 8 years ago ) and only 38 posts
    JUST LOOKING AND WATCHING !!!! ??
  5. The Following 3 Users Say Thank You to vagva For This Useful Post:
    Kalivox (26th February, 2021), rafal (16th February, 2021), SonyPS3 (20th February, 2021)
  6. #2810
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by szwanczeps View Post
    Hi.
    TMBHS61Z392019995
    1K0 901 379 BJ
    Thanks.
    Car type and model ?
    its Skoda but what type of Skoda ?
  7. The Following 2 Users Say Thank You to vagva For This Useful Post:
    Kalivox (26th February, 2021), szwanczeps (17th February, 2021)
  8. #2811
    Feb 2021
    Quote Originally Posted by vagva View Post
    Skoda Octavia 2
    1.9tdi BXE
    2009R.
  9. #2812
    Jan 2018
    Hi. Please I need long coding for abs
    Jetta gli mk5
    Abs 1k0907379ap
    Vin: 3VWXJ71K27M082628
    Mk60ec1
    Lhd
  10. #2813
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by RYPCOL View Post
    Jetta gli mk5
    Abs 1k0907379ap
    Mk60ec1
    Lhd
    empty your inbox
  11. The Following 2 Users Say Thank You to vagva For This Useful Post:
    Kalivox (26th February, 2021), RYPCOL (16th February, 2021)
  12. #2814
    Jan 2018
    Ready... Sorry
  13. #2815
    vagva's Avatar
    Apr 2016
    Jetta gli mk5
    Abs 1k0907379ap
    Mk60ec1
    Lhd
    one of tehse should be your long coding , you maybe need to remove or add 00 at the end
    A13B20F8092A00FC851104E6902104121100
    A43B40F8112A00FC251102E68821004021100
    A14B400C492A00FC851102E692210041A1180
  14. #2816
    Feb 2021
    2011 Volkswagen Jetta LHD MK60EC1
    1k0907379bc abs module
    vin= 3vw2k7aj8bm314642
    using a ross-tech hex-net scanner
    I been stuck at this for a while, please help me
  15. #2817
    vagva's Avatar
    Apr 2016
    Hi.
    TMBHS61Z392019995
    1K0 901 379 BJ
    Thanks.
    here is your long coding
    113B201C09230003881404ED901E0041340000
  16. #2818
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by kingofeast View Post
    Here is your long coding :
    243B400D092300FE241102E8901B0040300000
    you maybe need to add or remove 00 from the end
  17. The Following User Says Thank You to vagva For This Useful Post:
    Saf91 (19th February, 2021)
  18. #2819
    Nov 2018
    hi everyone
    hope everyone is well today
    please can someone help me with abs long coding for vw polo 6r
    Vin :AAVZZZ6RZFU036564
    ABS :BPA
    :6C0 907 379
    6R0 907 379 BA
    0002
    H03
    Info for abs provided is as per sticker on abs pump.
    any help would be appreciated
    thanx
  19. #2820
    Aug 2018
    Hi could i please get thenlong coding for this A3, i tried everything and connot get it
    audi a3 1.9tdi bls engine code
    vin wauzzz8p39a026180
    brakes
    1kd 1zf
    No stop and start
    esp butoon yes
    advance id of abs
    Thursday,18,February,2021,14:59:59:39744
    VCDS Version: Release 17.1.3
    Address 03: ABS Brakes
    Control Module Part Number: 1K0 907 379 AD
    Component and/or Version: ESP MK60EC1 H35 0104
    Work Shop Code: WSC 06314
    VCID: 74E00792D7206FE1FD-8020
    Advanced Identification
    Identification: TT1-000
    Revision: 00H35001
    Date: 13.07.08
    Manufacturer number: 0101
    Test stand number: 07B3
    Flash Status
    Programming Attempts(application): 0
    Successful Attempts(application): 0
    Programming Status: 00000000
    Flash Date: 2008.08.04
    Flash Tool Code: 00000 000 00000
    Misc.
    Hardware number: 1K0 907 379 AD
    Workshop System Name: -----
    VCDS Info:
    Labels: 1K0-907-379-60EC1F.clb
    fault codes
    Thursday,18,February,2021,15:06:36:39744
    VCDS Version: Release 17.1.3 Running on Windows 8.1 x64
    www.Ross-Tech.com
    Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
    Control Module Part Number: 1K0 907 379 AD HW: 1K0 907 379 AD
    Work Shop Code: WSC 06314 000 00000
    5 Faults Found:
    01486 - System Function Test Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 190303 km
    Time Indication: 0
    Date: 2021.02.14
    Time: 20:23:59
    Freeze Frame:
    Count: 7
    Count: 2
    Count: 12288
    Count: 320
    Count: 43520
    Count: 0
    Count: 0
    Count: 0
    01435 - Brake Pressure Sensor 1 (G201)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 190303 km
    Time Indication: 0
    Date: 2021.02.14
    Time: 20:23:59
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 190303 km
    Time Indication: 0
    Date: 2021.02.14
    Time: 20:18:29
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12288
    Count: 270
    Count: 43520
    Count: 0
    Count: 0
    Count: 0
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 190303 km
    Time Indication: 0
    Date: 2021.02.14
    Time: 20:18:29
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 190303 km
    Time Indication: 0
    Date: 2021.02.14
    Time: 20:18:29
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12288
    Count: 291
    Count: 43520
    Count: 0
    Count: 0
    Count: 0
    thank you
