Page 196 of 245 FirstFirst ... 96146186191192193194195196197198199200201206 ... LastLast
Results 2,926 to 2,940 of 3668
  1. #2926
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by georgeMKO View Post
    Hello guys,
    I need some help with the long conding for ESP
    Golf 5 GT LHD 2.0TDI FWD manual
    WVWZZZ1KZ8W085705
    1k0 907 379 BJ
    312/282 brakes
    I tried to put the one below but it doesn't work and I can't figure it out. Any help it's apreciated.
    114B600C092A00FF881206E4901E0042002000
    Thank you in advance!
    one of these should be your long coding :
    143B600D212A00FF281206E4841E0040B100
    A13B20F8092A00FF8512F0E4C91E00041A50800
    113B200D092A00FF881204E4901E00412800
    you maybe need to remove or add 00 from the end
  2. The Following User Says Thank You to vagva For This Useful Post:
    Fec001 (7th April, 2021)
  3. #2927
    Montenegro
    Hello guys, please help,I need ABS / ESP long coding
    Audi A3, BLS 1.9TDI, LHD, FWD, Manual trans, Brakes 280mm
    WAUZZZ8P09B000730
    1K0 907 379 CD
    ESP MK60EC1 H35 0120
    I tried Long Code Calculator Helper v2, but no success
  4. #2928
    May 2015
    Default A3 abs coding
    Hello if is possible i need abs coding please.
  5. #2929
    Montenegro
    I coded using this tutorial:
    Byte 0 - it specifies the model, the diameter of the master brake cylinder, the location of the steering wheel (the byte value is the mirror value of byte 8):
    11 - VW Golf Mk5 (1K) / Golf Mk6 (5K) / Jetta Mk5 (1K) / Jetta (Vento) Mk6 Variant USA (AJ) / Seat Leon Mk2 (1P) / Audi A3 Mk2 (8P) / Skoda Octavia A5 (1Z) left hand drive (LHD), GTZ 22 mm (byte 8 = 88)
    13 - VW Golf Mk5 (1K) / Golf Mk6 (5K) / Jetta Mk5 (1K) / Seat Leon Mk2 (1P) / Audi A3 Mk2 (8P) / Skoda Octavia A5 (1Z) right hand drive (RHD), GTZ 22 mm (byte 8 = C8)
    14 - VW Golf Mk5 and Golf Mk6 GTI / GTD / R (1K, 5K) / Jetta Mk5 GLI / GTI (1K) / Seat Leon FR / Cupra Mk2 (1P) / Audi A3 / S3 Mk2 (8P) / Skoda Octavia A5 RS ( 1Z) left hand drive (LHD), GTZ 23 mm (byte 8 = 28)
    16 - VW Golf Mk5 and Golf Mk6 GTI / GTD / R (1K, 5K) / Jetta Mk5 GLI / GTI (1K) / Seat Leon FR / Cupra Mk2 (1P) / Audi A3 / S3 Mk2 (8P) / Skoda Octavia A5 RS (1Z) right hand drive (RHD), GTZ 23 mm (byte 8 = 68)
    21 - VW Golf Plus (5M) / Seat Altea (5P) / Toledo Mk3 (5P) (byte 8 = 84)
    24 - VW Golf Plus FL (52) / Seat Altea Freetrack (5P) left hand drive (LHD) (byte 8 = 24)
    26 - VW Golf Plus FL (52) / Seat Altea Freetrack (5P) right hand drive (RHD) (byte 8 = 64)
    32 - VW Touran Mk1 (1T) left hand drive (LHD) (byte 8 = 4C)
    33 - VW Touran Mk1 (1T) right hand drive (RHD) (byte 8 = CC)
    42 - VW Caddy Mk3 (2K, 2C) left hand drive ( LHD) (byte 8 = 42)
    43 - VW Caddy Mk3 (2K, 2C) right hand drive (RHD) (byte 8 = C2)
    51 - VW Eos USA (1F) (byte 8 = 8A)
    54 - VW Eos EU (1F) left hand drive (LHD) (byte 8 = 2A)
    56 - VW Eos EU (1F) right hand drive (RHD) (byte 8 = 6A)
    62 - VW Caddy Maxi Mk3 (2K, 2C) left handlebar (LHD) (byte 8 = 46)
    63 - VW Caddy Maxi Mk3 (2K, 2C) right hand drive (RHD) (byte 8 = C6)
    74 - VW Scirocco Mk3 (13) left hand drive (LHD) (byte 8 = 2E )
    76 - VW Scirocco Mk3 (13) right hand drive (RHD) (byte 8 = 6E)
    84 - Skoda Superb Mk2 (3T) left hand drive (LHD) (byte 8 = 21)
    86 - Skoda Superb Mk2 (3T) right hand drive ( RHD) (byte 8 = 61)
    91 - Skoda Yeti (5L)? GTZ 22 mm? left hand drive (LHD) (byte 8 = 89)
    93 - Skoda Yeti (5L)? GTZ 22 mm? right hand drive (RHD) (byte 8 = C9)
    94 - Skoda Yeti (5L)? GTZ 23mm left hand drive (LHD)? (byte 8 = 29)
    96 - Skoda Yeti (5L)? GTZ 23mm Right Hand Drive (RHD)? (byte 8 = 69)
    A1 - VW Jetta Mk6 USA? TSI? (16) (byte 8 = 85)
    A4 - VW Jetta Mk6 EU (16, AV) left hand drive (LHD) (byte 8 = 25)
    A6 - VW Jetta Mk6 EU (16) right hand drive (RHD) (byte 8 = 65 )
    B1 - VW Jetta Mk6 USA? Atmosphere? (16) (byte 8 = 8D)
    E4 - VW Beetle Mk2 EU (5C) (byte 8 = 27)
    F4 - VW Jetta Mk6? Hybrid? (16) (byte 8 = 2F)
    F1 - VW Beetle Mk2 USA (5C) (byte 8 = 8F)
    C5 - VW Passat NMS USA (A3) (byte 8 = A3)
    Please note that the American Jetta station wagon (Vento) in the AJ body is coded in the same way as Golf 5, Golf 6, etc., while for other Jetta 6th generation the values ​​are different and unique.
    Byte 1 - this byte specifies the region and / or car model:
    3B - VAG, other regions (Volkswagen, Skoda Octavia A5 (1Z), Seat Leon Mk2)
    3C - Volkswagen Caddy Mk3 (2K, 2C)
    3D - Skoda Superb Mk2 ( 3T)
    3F - Skoda Yeti (5L), Seat Altea (5P), Toledo Mk3 (5P)
    42 - Audi Europe
    4B - VW USA
    50 - Audi USA
    Byte 2 - diameter of brake discs (byte value is the mirror value of byte 10):
    20 - diameter of front brake discs 280 mm, rear 253 mm (byte 10 = 04)
    40 - diameter of front brake discs 288 mm, rear 253 mm (byte 10 = 02)
    44 - front brake disc diameter 288 mm, rear drum brakes (byte 10 = 22)
    60 - front brake disc diameter 312 mm, rear 253 mm (byte 10 = 06)
    80 - front brake disc diameter 345 mm, rear 310 mm (byte 10 = 01)
    C0 - front brake disc diameter 312 mm, rear 272 mm (byte 10 = 03)
    Byte 3 - Model:
    1C - Skoda Octavia A5 (1Z)
    16 - Skoda Superb Mk2 (3T) / VW Touran Mk1 (1T) / VW Beetle Mk2 USA (5C)
    0E - Skoda Yeti (5L)
    12 - Seat Leon Mk2 (1P) ) / Altea (5P) / Toledo Mk3 (5P) / Audi A3 Mk2 (8P)
    0C - VW Golf Mk6 USA (5K) / Jetta Mk6 USA (16)
    0D - VW Golf Mk5 (1K) / Golf Mk6 (5K) / Golf Plus (5M) and Golf Plus FL (52) / Jetta Mk5 (1K) / Caddy Mk2 (2K, 2C)
    0A - VW Eos USA (1F)
    08 - VW Eos EU (1F)
    0F - Audi A3 Mk2 USA (8P) )
    F5 - VW Scirocco Mk3 (13) / Passat NMS USA (A3)
    F8 - VW Jetta Mk6 (16, AV), VW Beetle Mk2 EU (5C)
    Byte 4 - type of suspension, brake system features (byte value is the mirror value of byte 12):
    09 - standard / sports suspension ("Euro", ie "Eurostock" or "Eurosport") (byte 12 = 90)
    0A - Comfort suspension with a package for bad roads (PPD) (byte 12 = 50)
    11 - brake system with vacuum sensor G608 in the vacuum booster (1K0906207, manufacturer of ATE sensor, ATE number: 10.0522-9971.1) (byte 12 = 88)
    12 - ? (byte 12 = 48)
    19 -? Skoda Superb Mk2 (3T) with block 3T0? (byte 12 = 98) (in all Superb encodings with such a block that I have come across, there was just such a value)
    21 - semi-comfortable suspension ("almost PPD", VW Golf Mk5 GT DSG6) (byte 12 = 84)
    22 - comfort suspension (PPD, VW Golf Mk5 GT Sport DSG6) (byte 12 = 44)
    49 - VW / Audi USA, VW Scirocco Mk3 (13) (byte 12 = 92)
    51 - brake system with vacuum sensor G608 in the vacuum line (sensor manufacturer Bosch) (byte 12 = 8A)
    89 - VW Golf GTI up to MY 2011 (byte 12 = 91)
    Byte 5 - the 13th character of the VIN number (check the VIN on the car and in the electronic blocks: dashboard, immobilizer, engine! If the VIN in the blocks differs from the one printed on the body - use it to compose the coding):
    22 - 13 -th character of VIN-number = 0
    23 - 13th character of VIN-number = 1
    24 - 13th character of VIN-number = 2
    25 - 13th character of VIN-number = 3
    26 - 13th character of VIN-number = 4
    27 - 13th digit of VIN = 5
    28 - 13th digit of VIN = 6
    29 - 13th digit of VIN = 7
    2A - 13th digit of VIN = 8
    2B - 13- th character of VIN number = 9
    Byte 6 - model, complete disable ESP on blocks up to BM with firmware 0120 and newer (byte value is the mirror value of byte 14):
    Bit value 0-3:
    00 - other models (byte 14 = 00)
    01 - Skoda Yeti (5L) until 2011 (byte 14 = 80)
    03 - VW Caddy Mk3 (2K, 2C) (byte 14 = C0)
    05 - Skoda Yeti (5L) since 2011. (byte 14 = A0)
    08 - some VW Passat NMS USA (A3), Jetta Mk6 USA (16) (byte 14 = 10)
    0E - VW Touran Mk1 (1T) (byte 14 = 70)
    Bit 7: completely disable ESP ( ESP Off, DO NOT CHANGE for TDI 2012 onwards! Blocks with firmware 0120+ to BM, for BM + see 19 bytes)
    Byte 7 - the 14th character of the VIN number (check the VIN on the car and in the electronic blocks: dashboard, immobilizer, engine! If the VIN in the blocks differs from the one printed on the body - use it to compose the coding):
    FA - 14 -th character of the VIN-number = 0
    FB - 14th character of the VIN-number = 1
    FC - 14th character of the VIN-number = 2
    FD - 14th character of the VIN-number = 3
    FE - 14th character of the VIN-number = 4
    FF - 14th character of VIN number = 5
    00 - 14th character of VIN number = 6
    01 - 14th character of VIN number = 7
    02 - 14th character of VIN number = 8
    03 - 14- th character of VIN number = 9
    Byte 8 - model, brake master cylinder diameter, steering wheel location (byte value is the mirror value of byte 0):
    88 - VW Golf Mk5 (1K) / Golf Mk6 (5K) / Jetta Mk5 (1K) / Jetta (Vento) Mk6 Variant USA (AJ) / Seat Leon Mk2 (1P) / Audi A3 Mk2 (8P) / Skoda Octavia A5 (1Z) left hand drive (LHD), GTZ 22 mm (byte 0 = 11)
    C8 - VW Golf Mk5 (1K) / Golf Mk6 (5K) / Jetta Mk5 (1K) / Seat Leon Mk2 (1P) / Audi A3 Mk2 (8P) / Skoda Octavia A5 (1Z) right hand drive (RHD), GTZ 22 mm (byte 0 = 13)
    28 - VW Golf Mk5 and Golf Mk6 GTI / GTD / R (1K, 5K) / Jetta Mk5 GLI / GTI (1K) / Seat Leon FR / Cupra Mk2 (1P) / Audi A3 / S3 Mk2 (8P) / Skoda Octavia A5 RS (1Z) left steering wheel (LHD), GTZ 22 mm (byte 0 = 14)
    68 - VW Golf Mk5 and Golf Mk6 GTI / GTD / R (1K, 5K) / Jetta Mk5 GLI / GTI (1K) / Seat Leon FR / Cupra Mk2 (1P) / Audi A3 / S3 Mk2 (8P) / Skoda Octavia A5 RS (1Z) right hand drive (RHD), GTZ 23 mm (byte 8 = 16)
    84 - VW Golf Plus (5M) / Seat Altea (5P) / Toledo Mk3 (5P) (byte 0 = 21)
    24 - VW Golf Plus FL (52) / Seat Altea Freetrack (5P) left hand drive (LHD) (byte 0 = 24)
    64 - VW Golf Plus FL (52) / Seat Altea Freetrack (5P) right hand drive (RHD) (byte 0 = 26)
    4C - VW Touran Mk1 (1T) left hand drive (LHD) (byte 0 = 32)
    CC - VW Touran Mk1 (1T) right hand drive (RHD) (byte 0 = 33)
    42 - VW Caddy Mk3 (2K, 2C) left hand drive ( LHD) (byte 0 = 42)
    С2 - VW Caddy Mk3 (2K, 2C) right hand drive (RHD) (byte 0 = 43)
    8A - VW Eos USA (1F) (byte 0 = 51)
    2A - VW Eos EU (1F) left hand drive (LHD) (byte 0 = 54)
    6A - VW Eos EU (1F) right hand drive (RHD) (byte 0 = 56)
    46 - VW Caddy Maxi Mk3 (2K, 2C) left steering wheel (LHD) (byte 0 = 62)
    C6 - VW Caddy Maxi Mk3 (2K, 2C) right hand drive (RHD) (byte 0 = 63)
    2E - VW Scirocco Mk3 (13) left hand drive (LHD) (byte 0 = 74 )
    6E - VW Scirocco Mk3 (13) right hand drive (RHD) (byte 0 = 76)
    21 - Skoda Superb Mk2 (3T) left hand drive (LHD) (byte 0 = 84)
    61 - Skoda Superb Mk2 (3T) right hand drive ( RHD) (byte 0 = 86)
    89 - Skoda Yeti (5L)? GTZ 22 mm? left hand drive (LHD) (byte 0 = 91)
    C9 - Skoda Yeti (5L)? GTZ 22 mm? right hand drive (RHD) (byte 0 = 93)
    29 - Skoda Yeti (5L)? GTZ 23 mm left hand drive (LHD)? (byte 0 = 94)
    69 - Skoda Yeti (5L)? GTZ 23mm Right Hand Drive (RHD)? (byte 0 = 96)
    85 - VW Jetta Mk6 USA? TSI? (16) (byte 0 = A1)
    25 - VW Jetta Mk6 EU (16, AV) left hand drive (LHD) (byte 0 = A4)
    65 - VW Jetta Mk6 EU (16) right hand drive (RHD) (byte 0 = A6 )
    8D - VW Jetta Mk6 USA? Atmosphere? (16) (byte 0 = B1)
    27 - VW Beetle Mk2 EU (5C) (byte 8 = E4)
    2F - VW Jetta Mk6? Hybrid? (16) (byte 0 = F4)
    8F - VW Beetle Mk2 USA (5C) (byte 0 = F1)
    A3 - VW Passat NMS USA (A3) (byte 0 = C5)
    Byte 9 - the 15th character of the VIN number (check the VIN on the car and in the electronic blocks: dashboard, immobilizer, engine! If the VIN in the blocks differs from the one printed on the body - use it to compose the coding):
    0B - 15 -th character of VIN-number = 0
    0C - 15th character of VIN-number = 1
    0D - 15th character of VIN-number = 2
    0E - 15th character of VIN-number = 3
    0F - 15th character of VIN-number = 4
    10 - 15th character of the VIN number = 5
    11 - 15th character of the VIN number = 6
    12 - 15th character of the VIN number = 7
    13 - 15th character of the VIN number = 8
    14 - 15- th character of VIN number = 9
    Byte 10 - diameter of brake discs (byte value is the mirror value of byte 2):
    04 - diameter of front brake discs 280 mm, rear 253 mm (byte 2 = 20)
    02 - diameter of front brake discs 288 mm, rear 253 mm (byte 2 = 40)
    22 - front brake disc diameter 288 mm, rear drum brakes (byte 2 = 44)
    06 - front brake disc diameter 312 mm, rear 253 mm (byte 2 = 60)
    01 - front brake disc diameter 345 mm, rear 310 mm (byte 2 = 80)
    03 - front brake disc diameter 312 mm, rear 272 mm (byte 2 = C0)
    Byte 11 - the 16th character of the VIN number (check the VIN on the car and in the electronic blocks: dashboard, immobilizer, engine! If the VIN in the blocks differs from the one printed on the body - use it to compose the coding):
    E4 - 16 -th character of VIN-number = 0
    E5 - 16th-character of VIN-number = 1
    E6 - 16th-character of VIN-number = 2
    E7 - 16th-character of VIN-number = 3
    E8 - 16th-character of VIN-number = 4
    E9 - 16th digit of VIN = 5
    EA - 16th digit of VIN = 6
    EB - 16th digit of VIN = 7
    EC - 16th digit of VIN = 8
    ED - 16- th character of VIN number = 9
    Byte 12 - type of suspension, features of the brake system (the value of the byte is the mirror value of byte 4):
    90 - standard / sports suspension ("Euro", ie "Euro", "Eurosport") (byte 4 = 09)
    50 - Comfort suspension with bad road package (RAP) (byte 4 = 0A)
    88 - brake system with vacuum sensor G608 in the vacuum booster (1K0906207, ATE sensor manufacturer, ATE number: 10.0522-9971.1) (byte 4 = 11)
    48 - ? (byte 4 = 12)
    98 -? Skoda Superb Mk2 (3T) with block 3T0? (byte 4 = 19) (in all Superb encodings with such a block that I have come across, there was just such a value)
    84 - semi-comfortable suspension ("almost PPD", VW Golf Mk5 GT DSG6) (byte 4 = 21)
    44 - comfortable suspension (PPD,
    92 - VW / Audi USA, VW Scirocco Mk3 (13) (byte 4 = 49)
    8A - brake system with vacuum sensor G608 (sensor manufacturer Bosch) (byte 4 = 51)
    91 - VW Golf GTI up to 2011 m. g. (byte 4 = 89)
    Byte 13 - 17th character of the VIN number (check the VIN on the car and in electronic blocks: dashboard, immobilizer, engine! If the VIN in the blocks differs from the one printed on the body - use it to compose the coding):
    19 - 17 -th character of the VIN-number = 0
    1A - 17th character of the VIN-number = 1
    1B - 17th character of the VIN-number = 2
    1C - 17th character of the VIN-number = 3
    1D - 17th character of the VIN-number = 4
    1E - 17th character of VIN = 5
    1F - 17th character of VIN = 6
    20 - 17th character of VIN = 7
    21 - 17th character of VIN = 8
    22 - 17- th character of VIN number = 9
    Byte 14 - model, complete ESP off on blocks up to BM with firmware 0120 and higher (the value is the mirrored value of byte 6):
    Bit 0: ESP completely disabled (ESP Off, DO NOT CHANGE for TDI 2012 onwards! Blocks with firmware 0120+ to BM, for BM + see 19 bytes)
    The meaning of bits 3-7:
    00 - other models (byte 6 = 00)
    80 - Skoda Yeti (5L) until 2011 (byte 6 = 01)
    C0 - VW Caddy Mk3 (2K, 2C) (byte 6 = 03)
    A0 - Skoda Yeti (5L) since 2011 (byte 6 = 05)
    10 - some VW Passat NMS USA (A3), Jetta Mk6 USA (16) (byte 6 = 08)
    70 - VW Touran Mk1 (1T) (byte 6 = 0E)
    Byte 15 - engine type, start-stop, Off-Road mode, DSR, steering position:
    Bit 0, value 0: Engine type: 1.2 TSI / 1.4 MPI / 1.4 TSI / 1.6 MPI /? 2.0 TDI (PD, unit injectors )?
    Bit 0, value 1: Engine type: 1.8 TSI / 2.0 FSI / 2.0 TSI / 3.6 FSI / 1.6 TDI / 1.9 TDI
    Bit 1: Engine type: 2.0 TDI (? Common-Rail?)
    Bit 2: Start / stop system installed ( PR code 7L6, for some cars (? Blocks?), If it does not work - see bit 4)
    Bit 3: Off-Road mode switch is installed (Skoda Yeti 4x4, PR code 8LG)
    Bit 4: Start / stop system is installed (PR code 7L6, for some cars (? Blocks?), If not working - see bit 2)
    Bit 5: Driver Steering Recommendation (DSR) inactive
    Bit 6: Left hand drive (LHD)
    Bit 7: Right Hand Drive (RHD)
    Byte 16 - Additional functions:
    Bit 0: Hill Hold Control (HHC, PR codes UG1 / UG4) active (for units with longitudinal acceleration sensor G251)
    Bit 1: TPMS virtual button II (RKA +) in the MFA + / Maxidot dashboard (blocks up to 1K0907379 BM , for BM + see 19 bytes), in BM + blocks - an electronic hand brake (EPB) is installed; for Skoda Superb Mk2 with block 3T0 this bit is always active
    Bit 2: indirect tire pressure monitoring system TPMS (RKA, PR code 7K6) is active (for BM + blocks see also 19 bytes)
    Bit 3: complete ESP off for units with firmware lower than 0120 (AD / AE / AM, possibly some others)? Other units before BM - 2-level ESP off indication on dashboard inactive (ASR Off-ESP Off)?
    Bit 4:? Often checked?
    Bit 5: Adaptive cruise control (ACC) not set
    Bit 6:? Sometimes checked?
    Bit 7:? Sometimes checked? It is not known for sure
    If you have a problem with the fact that the block does not accept the encoding, although you have checked everything and set the correct encoding for sure, then I give a list of the basic encodings of this byte that I have come across:
    11, 25, 28, 30, 38, 68, 70 , A0, A8, B0, B2, B8
    Perhaps, in some early blocks, one or more of the bits of this byte are responsible for setting up a complete disable ESP.
    Byte 17 - Additional Functions:
    Bit 0: Parking assist PLA 2.0 (PR-code 7X5 / 7X6)
    Bit 1:?
    Bit 2: indirect tire pressure monitoring system TPMS II (RKA +) via the instrument cluster MFA + / Maxidot (virtual block 4C, 2012+)
    Bit 3: extended electronic differential lock XDS (PR codes UG3 / UG4) active ( except AD / AE / AN / AP units)
    Bit 4:? Stopping distance reduction 2 (Front Assist) in the adaptive cruise control control unit (ADR, J428)?
    Bit 5:? Stopping distance reduction 2 (Front Assist) in the control unit for the adaptive cruise control (ADR, J428)?
    Bit 6:? Stopping distance reduction 2 (Front Assist) in the control unit for the adaptive cruise control (ADR, J428)?
    Bit 7:? Stopping distance reduction 2 (Front Assist) in the control unit for the adaptive cruise control (ADR, J428)?
    It is reliably known that in the absence of adaptive cruise control and activation of 4-7 bits in this byte, an error appears in the ABS unit that looks like this:
    03197 - Reducing the stopping distance 2 in the ADR control unit (J428)
    004 - no signal / communication
    Hence the conclusion that these bits are directly related to the adaptive cruise control.
    Byte 18 - type of ABS sensors, type of rear steering knuckles:
    Bit 0:?
    Bit 1:?
    Bit 2:?
    Bit 3:?
    Bit values ​​4-7:
    00 - standard rear ABS
    50 sensors installed - new generation rear ABS sensors installed (for parking autopilot PLA 2.0), steel steering knuckles
    F0 - new generation rear ABS sensors installed (for parking autopilot PLA 2.0), aluminum rotary fists
    Byte 19 - basic value, additional functions:
    Bit 0: virtual button for the indirect tire pressure monitoring system TPMS II (RKA +) in the MFA + / Maxidot dashboard (for 1K0907379 BM / BR / BS / CA / CB / CC units )
    Bit 1: indirect tire pressure monitoring system TPMS (RKA, PR code 7K6) active (for 1K0907379 BM / BR / BS / CA / CB / CC units )
    Bit 2:?
    Bit 3: Blind Spot Assist (BSD) installed,? PLA 3.0 ?,? Lane Change Assist?
    Bit values ​​4-7:
    10 - disable only ASR, no disable ESP (often checked,? Base value?)
    20 -? Base value?
    50 -? Base value?
    80 -? Base value?
    70 - completely disable ESP (ESP Off)
    90 - Partial ESP Disable (ESP Sport)
    Bit 4: ASR Disabled Only, No ESP Disabled (often checked,? Basic value?)
    Bit 5:? ESP Complete Disabled (ESP Off)?
    Bit 6: ESP off completely (ESP Off)
    Bit 7: ESP partially off (ESP Sport)
  6. The Following 3 Users Say Thank You to dusan.stevovic For This Useful Post:
    ASCM (6th April, 2021), Berubeg (6th April, 2021), keturi (29th March, 2023)
  7. #2930
    ASCM's Avatar
    Oct 2018
    Does it worked-with that tutorial can you share your vcds log scan to understand compatible bytes related to specific car
    Sent from my 5033F using Tapatalk
  8. #2931
    Jul 2016
    Vilnius
    Much wrong info there. This has been floating around since probably the start of this thread times.
    I especially like the "base value" and "sometimes checked" explanations in safety-critical system - brakes
    * MK100
  9. #2932
    Fec001's Avatar
    Hi!
    Please give coding for this modul:
    ESP MK60EC1 H30 0107
    1K0 907 379 AJ
    WVWZZZ1KZAM687372
    VIN in IC: WVWZZZ1KZBW135343
    Engine CBZA 1.2 TSI
    Front disc diameter: 280mm
    Rear disc diameter: 272mm
  10. #2933
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by Fec001 View Post
    Hi!
    1K0 907 379 AJ
    WVWZZZ1KZAM687372
    Engine CBZA 1.2 TSI
    One of these codes should be your ABS long coding :
    143B600D212500FF280E06E8841C0040B100
    A13B20F8092500FF850EF0E8C91C00041A50800
    113B200D092500FF880E04E8901C00412800
    you maybe need to add or remove 00 from the end
  11. The Following User Says Thank You to vagva For This Useful Post:
  12. #2934
    Fec001's Avatar
    Quote Originally Posted by vagva View Post
    Third string is ok/accepted. Only thing is that the ESP off switch is not working. If I check in actual values, switch is ok/working when pressing it.
    Could be coding problem?
  13. #2935
    Jan 2018
    Hi all can someone give me a help with long coding for abs esp pump.Audi s3 2009 2.0 tfsi CDLA engine.RHD,4WD,hill control
    1K0907379AD
    ESP MK60EC1
    H35 0106
    WCS06314
    WAUZZZ8P99A102498
    Front discs 345 mm
    Rear disks 310 mm
    Code given before by one of members was incorrect.
  14. #2936
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Need long code for AUDI A3, 1.9 PD, 2008
    VIN from cluster - WAUZZZ8P39A069983
    Hope you will help me!
  15. #2937
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by bobolin4o View Post
    One of these going to be your Long coding :
    1142401209280003881402EC901C0423800
    1162401A49280003881302EC921C00403900
    if was useful , press Thanks and Reputation
  16. The Following 2 Users Say Thank You to vagva For This Useful Post:
    bobolin4o (10th April, 2021), Tkeso (12th April, 2021)
  17. #2938
    bobolin4o's Avatar
    Second is rejected, first is with wrong length... adding, removing not helps.
    The right code is 1142401209280003881402EC901C00423800
    Thank you!!!
  18. #2939
    Dec 2016
    PL-GB
    Hi, some can help me with long code WV Golf VI 2009 1.6 TDi RHD
    ESP MK60EC1 1K0 907 379 AN
    WVWZZZ1KZAW133368
    It’s correct?
    Calculator give me:
    13 4B 00 0C 09 25 00 FD 00 0E 00 EA 90 21 00 00 00 00 i think its complete wrong
    I make code from list but dont know bytes 15(17) 16 17
    13 3B 20 0D 09 25 00 FD C8 0E 04 EA 90 21 00 .. .. ..
  19. #2940
    Apr 2021
    I have problem with my ABS/ESP controller on my Volkswagen Scirocco 2009. I bought a new unit, due old being completely shot. New appears to be 18bit and old was 17bit, so old coding does not match.
    Can You help?
    Car Vin:
    WVWZZZ13Z9V008985
    Controller number:
    1K0907379CC
    Hydraulic unit:
    1K0614517EJ
    Thanks!
