Hello can anyone help with long coding. My car is a 2012 Jetta 2.5 SE
VIN: 3VWDP7AJ3CM329657
after I changed the ABS from 1K0907375BJ to 1K0907379BM
Saturday,22,May,2021,18:24:32:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: 3VWDP7AJ3CM329657 License Plate: GM 7227 14
Mileage: 109300km-67915mi Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 37 56
VIN: 3VWDP7AJ3CM329657 Mileage: 109300km-67915miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Not registered 0001
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
56-Radio -- Status: OK 0000
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 CJ HW: 07K 907 309 B
Component: 2,5l R5/4V G01 1156
Revision: T4H06--- Serial number:
Coding: 0000075
Shop #: WSC 00066 000 00000
VCID: 78FF5DE70BD3424BFB-802C
No fault code found.
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09G 927 750 LF HW: 09G 927 750 LF
Component: AQ 250 6F 2041
Revision: 00H97000 Serial number:
Coding: 0000072
VCID: 000F350753030A8BC3-8054
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: 0000000000000000000000000000000000000000
Shop #: WSC 09003 957 00200
VCID: 7EF34BFFE9F77C7BB1-802A
5 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 109303 km
Time Indication: 0
Date: 2015.10.13
Time: 09:16:18
Freeze Frame:
Count: 7
Count: 2
Count: 28672
Count: 195
Count: 35328
Count: 55808
Count: 254
Count: 0
01279 - Longitudinal Acceleration Sensor (G251)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 109303 km
Time Indication: 0
Date: 2015.10.13
Time: 09:16:18
Freeze Frame:
Count: 2
Count: 2
Count: 24576
Count: 212
Count: 35072
Count: 55808
Count: 0
Count: 0
01435 - Brake Pressure Sensor 1 (G201)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 109303 km
Time Indication: 0
Date: 2015.10.13
Time: 09:16:18
Freeze Frame:
Count: 2
Count: 2
Count: 24576
Count: 279
Count: 35072
Count: 55808
Count: 0
Count: 0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 109303 km
Time Indication: 0
Date: 2015.10.13
Time: 09:16:18
Freeze Frame:
Count: 2
Count: 2
Count: 24576
Count: 295
Count: 35072
Count: 55808
Count: 0
Count: 0
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 109303 km
Time Indication: 0
Date: 2015.10.13
Time: 09:16:18
Freeze Frame:
Count: 2
Count: 2
Count: 24576
Count: 270
Count: 35072
Count: 55808
Count: 0
Count: 0
