Page 210 of 245 FirstFirst ... 110160200205206207208209210211212213214215220 ... LastLast
Results 3,136 to 3,150 of 3668
  1. #3136
    Sep 2021
    Cześć. Potrzebuję dług Coding vw golf plus. WVWZZZ1KZ9W844282.
  2. #3137
    Apr 2021
    Hello guys, in case you wonder about no reaction by anyone I can only remind you of this message here. If any other than that is posted (like: this is the VIN, I need coding), you cannot expect a working answer for free ever.
    In any other urgent case you should contact someone directly, as I doubt people are observing this thread constantly.
    Regards, and I hope everyone gets his problem fixed.
  3. #3138
    Apr 2020
    Balarus
    Hi, I needyour help with Long coding of 1K0907379BL
    VIN WVGZZZ1TZDW103466
    ABS 1K0907379BL H31 0152
    LHD
    Engine PETROL 1.4 TSI CTHC 103kW
    DSG
    Hill Control YES
    Tire Pressure Monitoring YES
    Engine start-stop NO
    Thanksin advance
  4. #3139
    Dec 2015
    Germany
    Hello. I need abs long coding
    - VIN from scan WVWZZZ1KZ9M308291
    - ABS software part number from scan 1K0 907 379 AP
    - LHD
    - Engine type 1.4 TSI CAXA
    - Transmission type DSG
    THANK YOU FOR HELP
  5. #3140
    Apr 2021
    Quote Originally Posted by pifulete View Post
    - LHD
    THANK YOU FOR HELP
    Incomplete request.
    - No information about TPMS. Yes or no?
    - What kind of a car is this? Regular golf or golf plus?
  6. #3141
    Feb 2019
    hi can you help me with this abs coding?
    CAR vw polo from 2009
    VIN wvwzzz6rzay040780
    ABS 6R0907379R
    LHD
  7. #3142
    Nov 2016
    italy
    è possibile codificare Abs
    HepGiovedì,07,OTTOBRE,2021,11:27:22:57661VCDS -- Emulatore di VAG/VAS basato in Windows Esecuzione su Windows 7 x86
    Versione del VCDS: ITT 21.3.0.0
    Versione di dati: 20210508 DS325.0
    www.vag-com-italiano.com
    Nome del Concessionario/Officina: Ags-Automotive
    VIN: WAUZZZ8P39A124450 Matricola:
    Chilometraggio: 231520km Ordine di Lavoro:
    Tipo di Telaio 1K0)
    Centraline 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WAUZZZ8P39A124450 Chilometraggio: 231520km
    01-Motore -- stato: Guasto 0010
    03-Freni ABS -- stato: Guasto 0010
    04-Angolo Sterzata -- stato: Corretto 0000
    08-Climatizzatore -- stato: Corretto 0000
    09-Centrale elettr. -- stato: Corretto 0000
    10-Assist. Parchegg. -- stato: Corretto 0000
    15-Airbags -- stato: Corretto 0000
    16-Volante -- stato: Corretto 0000
    17-Cruscotto -- stato: Guasto 0010
    19-Gateway CAN -- stato: Guasto 0010
    25-Immobilizzatore -- stato: Guasto 0010
    42-Porta Conducente -- stato: Corretto 0000
    44-Servosterzo -- stato: Guasto 0010
    46-Sistema Comfort -- stato: Corretto 0000
    52-Porta ant. des. -- stato: Corretto 0000
    56-Radio -- stato: Non si può accedere 1100
    62-Porta post. sin. -- stato: Guasto 0010
    72-Porta post. des. -- stato: Corretto 0000
    Indirizzo 01: Motore (CBA) Etichette: ITT\03L-906-022-CBA.clb
    N°. di Ricambio SW: 03L 906 022 LS HW: 03L 906 022 BQ
    Componente: R4 2,0L EDC 0000SG 3610
    Versione: 13H01--- N° di Serie: AUX7Z0I2FN60E4
    Codifica: 0000072
    Nº Officina: WSC 83968 024 534663
    VCID: 010D784658E83783CC-8054
    1 Guasto/i riconosciuto/i:
    008213 - Sensore posizione farfalla del collettore di aspirazione segnale inammissibile
    P2015 - 000 - - Spia di Guasti accesa
    Dati congelati:
    Stato dei Guasti: 11100000
    Priorità dei Guasti: 2
    Frequenza dei Guasti: 1
    Azzeramenti del Contatore: 255
    Chilometraggio: 231522 km
    Indicazione di Tempo: 0
    Data: 2021.10.06
    Tempo: 13:49:55
    Dati congelati:
    RPM: 0 /min
    Velocità: 0.0 km/h
    Carico: 0.0 %
    Lambda: -11.8 %
    Lambda: -11.0 %
    Tensione: 3.800 V
    Bits bin.: 10001110
    Readiness: 1 1 0 0 1
    Indirizzo 03: Freni ABS (-----) Etichette:. ITT\1K0-907-379-60EC1F.clb
    N°. di Ricambio SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Componente: ESP MK60EC1 H35 0106
    Versione: 00H35001
    Codifica: 000000000000000000000000000000000000
    Nº Officina: WSC 06314 000 00000
    VCID: 74E32192D75A122BD7-8020
    2 Guasti riconosciuti:
    01042 - Centralina non è codificata
    000 - -
    Dati congelati:
    Stato dei Guasti: 01100000
    Azzeramenti del Contatore: 19
    Data: 2021.10.06
    Tempo: 16:05:16
    Dati congelati:
    Conto: 7
    Conto: 0
    Conto: 4096
    Conto: 195
    Conto: 44032
    Conto: 0
    Conto: 0
    Conto: 0
    00778 - Sensore per angolo di sterzo (G85)
    005 - Adattamento/registrazione di base assente o errata
    Dati congelati:
    Stato dei Guasti: 01100101
    Data: 2021.10.06
    Tempo: 16:02:35
    Dati congelati:
    Conto: 3
    Conto: 0
    Conto: 4096
    Conto: 291
    Conto: 44032
    Conto: 0
    Conto: 0
    Conto: 0
    Indirizzo 08: Climatizzatore Etichette: ITT\8P0-820-043.clb
    N°. di Ricambio SW: 8P0 820 043 BH HW: 8P0 820 043 BH
    Componente: KlimavollautomatH09 0100
    Versione: 000020 N° di Serie: 8P0820043BH
    Nº Officina: WSC 00000 000 00000
    VCID: 73E1228E12541513CE-8026
    Nessun Guasto riconosciuto
    Indirizzo 09: Centrale elettr. Etichette:. ITT\8P0-907-279-30-H.clb
    N°. di Ricambio SW: 8P0 907 279 N HW: 8P0 907 279 N
    Componente: Bordnetz-SG H54 2801
    Versione: 00H54000 N° di Serie: 00000009449890
    Codifica: F1A83F8190141380EF00001C0000000000094E056401040300 A800000000
    Nº Officina: WSC 06314 000 08192
    VCID: 489BA5623B52C6CB4B-801C
    Subsistema 1 - N°. di Ricambio: 8P1 955 119 F Etichette: ITT\1KX-955-119.CLB
    Componente: Wischer AU350 H10 0040
    Codifica: 00056595
    Subsistema 2 - N°. di Ricambio: 8K0 910 557 Etichette: ITT\8K0-955-559.CLB
    Componente: REGENLICHTSENSORH04 0003
    Codifica: 00150573
    Indirizzo 10: Assist. Parchegg. (J446) Etichette:. ITT\8P0-919-475-7X1.clb
    N°. di Ricambio SW: 8P0 919 475 F HW: 8P0 919 475
    Componente: PARKHILFE 4K H06 0102
    Versione: 11001001 N° di Serie: 52340906101487
    Codifica: 000003
    VCID: 418DB846D868F7838C-8014
    Indirizzo 15: Airbags (J234) Etichette:| ITT\8P0-959-655-10.clb
    N°. di Ricambio SW: 8P0 959 655 J HW: 8P0 959 655 J
    Componente: Airbag AU1042 H06 0090
    Versione: -------- N° di Serie: 003CA005J1Z%
    Codifica: 303142383038303030354A55304C38503053
    Dati ASAM: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4_AU35.rod
    VCID: 499DA066E8583FC354-801C
    Sensore d'impatto dell'airbag laterale anteriore lato guida:
    N° di Serie: 3572DRB4000089CC816%
    Sensore impatto airbag laterale anteriore lato passeggero:
    N° di Serie: 3582DRB4000089E122AX
    Sensore d'impatto dell'airbag laterale posteriore lato guida:
    N° di Serie: 35128RB400004BD9F6B1
    Sensore d'impatto dell'airbag laterale post. lato passeggero:
    N° di Serie: 35228RB400004B6AA4BW
    Sensore d'impatto dell'airbag frontale lato guida:
    N° di Serie: 35547RB400004B6CA09W
    Sensore d'impatto dell'airbag frontale lato passeggero:
    N° di Serie: 35647RB400004B6C9FD8
    Indirizzo 16: Volante Etichette: ITT\1K0-953-549-MY8.clb
    N°. di Ricambio SW: 1K0 953 549 AH HW: 1K0 953 549 AH
    Componente: J0527 036 0070
    Codifica: 0000012
    VCID: 78FB15A20B32764BFB-802C
    Indirizzo 17: Cruscotto Etichette: ITT\8P0-920-xxx-17-MY8.clb
    N°. di Ricambio SW: 8P0 920 931 S HW: 8P0 920 931 S
    Componente: KOMBIINSTR. VDO H19 0860
    Versione: D0H19007 N° di Serie: 2242I007079643
    Codifica: 0004028
    Nº Officina: WSC 00001 001 00001
    VCID: 4381B24E0274E5939E-8016
    00003 - Centralina
    014 - Difettoso/a/i/e
    Dati congelati:
    Stato dei Guasti: 01101110
    Priorità dei Guasti: 1
    Chilometraggio: 170144 km
    Data: 2017.02.10
    Tempo: 10:59:34
    Indirizzo 19: Gateway CAN Etichette:. ITT\1K0-907-530-V4.clb
    N°. di Ricambio SW: 1K0 907 530 S HW: 1K0 907 951
    Componente: J533__Gateway H16 0210
    Versione: H16 N° di Serie: 3400K093100624
    Codifica: E9A07F06000202002102
    VCID: 3779D69E46ACB93332-8062
    3 Guasti riconosciuti:
    01305 - Bus dati infotainment
    004 - Senza segnale/comunicazione
    Dati congelati:
    Stato dei Guasti: 01100100
    Frequenza dei Guasti: 19
    Data: 2021.10.06
    Tempo: 13:31:05
    00470 - Gruppo -bus dati comfort, funzionamento unifilare
    011 - Interruzione
    Dati congelati:
    Stato dei Guasti: 01101011
    Priorità dei Guasti: 3
    Data: 2021.10.06
    Tempo: 13:31:05
    01304 - Radio
    Dati congelati:
    Data: 2021.10.06
    Tempo: 13:31:08
    Indirizzo 25: Immobilizzatore Etichette: ITT\1K0-920-xxx-25.clb
    Versione: D0H19007 N° di Serie: AUX7Z0I2FN60E4
    16346 - Centralina
    Indirizzo 42: Porta Conducente Etichette: ITT\8P0-959-801-MIN3.clb
    N°. di Ricambio SW: 8P0 959 801 K HW: 8P0 959 801 K
    Componente: Tuer-SG H03 0060
    Codifica: 0000148
    Indirizzo 44: Servosterzo Etichette: ITT\1K0-909-14x-GEN3.clb
    N°. di Ricambio: 1K0 909 144 E
    Componente: EPS_ZFLS Kl. 232 2501
    Versione: 00H15000
    Nº Officina: WSC 02069 000 90108
    VCID: 2C53F9F28FEA0AEB4F-8078
    005 - Adattamento/registrazione di base assente o errata - Spia di Guasti accesa
    Dati congelati:
    Stato dei Guasti: 11100101
    Data: 2021.10.06
    Tempo: 13:31:04
    Dati congelati:
    Volts Batteria: 12.2 V
    DD
    Temperatura: 28.0°C
    Conto: 2
    Angolo Sterzo: 0.00°
    Conto: 0
    SenzInizAngSter
    Indirizzo 46: Sistema Comfort Etichette: ITT\8P0-959-433.clb
    N°. di Ricambio: 8P0 959 433 L
    Componente: KSG H11 0080
    Codifica: 1880200002186D0985054C8F0167
    VCID: 4585AC560C40DBA3B0-8010
    Subsistema 1 - Componente: Sounder n.mounted
    Subsistema 2 - Componente: NGS n.mounted
    Subsistema 3 - Componente: IRUE n.mounted
    Indirizzo 52: Porta ant. des. Etichette:. ITT\1K0-959-702-MIN3.clb
    N°. di Ricambio SW: 8P0 959 802 K HW: 8P0 959 802 K
    Codifica: 0000148
    VCID: 4483B152077AE2ABA7-8010
    Indirizzo 56: Radio
    Non si può accedere
    Indirizzo 62: Porta post. sin. Etichette: ITT\8P4-959-801.clb
    N°. di Ricambio SW: 8P4 959 801 E HW: 8P4 959 801 E
    Componente: Tuer-SG H04 0040
    Codifica: 0000144
    Nº Officina: WSC 06314 000 1012544
    VCID: 418DB8461868F7838C-8014
    00934 - Motore per alzacristallo posteriore sinistro (V26)
    005 - Adattamento/registrazione di base assente o errata - Sporadico
    Indirizzo 72: Porta post. des. Etichette: ITT\8P4-959-802.clb
    N°. di Ricambio SW: 8P4 959 802 E HW: 8P4 959 802 E
    Codifica: 0000144
    VCID: 428FB74A1D6EEC9B95-8016
    Fine-----------------------(Tempo trascorso: 0
  8. #3143
    Sep 2008
    I have a Scirocco. someone convert it before me with TT BWA dsg engine. The car was 1.4 TSi Rline.
    now i have abs fault no communication with ECU. This fault only on ABS. Immo on ECU was already off but I corrected Vin on eeprom
    ABS 1K0907379AJ Coding now : 763B60F5612500FD6EC861D0081350800
    VIN : WVWZZZ13ZAV433084
    ECU : 8J0907115N Coding : 011300031C070160
    Can we find coding for this??
    I believe must install VW ECU or change flash and Eeprom to VW one?
  9. #3144
    Jul 2011
    Hello, I need a lot of help, thank you:
    LHD
    VIN WAUZZZ8P89B006520
    ENGINE 2.0 TDI CBAB
    MANUAL
    TPMS:YES? IM NOT SURE
    HILL CONTROL: NOT
    START-STOP: NOT
    ABS: 1K0907379AN (BEFORE BROKEN 1K0 907 379 AD)
    HW: H45
    Thank you so much!
  10. #3145
    Apr 2021
    Quote Originally Posted by DreamLand69 View Post
    Well if you are not sure how shall anyone else here be? Little hint: check for the reset button. It's only available when tpms is available, too.
  11. The Following User Says Thank You to r4nd0mize For This Useful Post:
    DreamLand69 (13th October, 2021)
  12. #3146
    Jul 2011
    Quote Originally Posted by r4nd0mize View Post
    Tpms not available, sorry.
  13. #3147
    Oct 2021
    hi looking for the long coding for my 2009 vw scirocco 2.0 tsi gt
    VIN number is WVWZZZ13Z9V003351
  14. #3148
    Sep 2021
    Hi im look for long coding MK60 EC1
    VIN WAUZZZ8P5AA049609
    ABS 1K0907379AP
    LHD
    Engine PETROL 2.0 TFSI
    DSG
    thanks in advance
  15. #3149
    Sep 2008
    Attached a VCDS full scan
  16. The Following User Says Thank You to RallyeCAV606 For This Useful Post:
    Davidmaina (22nd December, 2023)
  17. #3150
    kimodiag's Avatar
    Jan 2016
    ALGERIA
    Default codage long abs seat leon 2014
    VSSZZZ5FZER036937
