Well, puuuh, again,... this is in first case definetely a basic settings problem. In the (second) video they are using a super old VCDS version and it is absolutely freaky what they are doing at all.
Usually it only needs brake pressure sensor basic settings, acceleration cluster (lateral, longitudinal, yaw rate, in some cases only yaw and lateral). Doing valves is very rare and only necessary if hydraulic was disconnected from electronic. Which is like never the case as only superfreaks disconnect them for repair purposes.
But what do you mean with "the address"? The abs has to be mounted correctly and the car has to stand flat - otherwise forget about doing basic settings. And even if it accepts not being correctly mounted, you have wrong basic values.
aolvera (7th February, 2022)
1K0 907 379 AD
LHD
STANDARD
No start stop
No hill control
disk size not sure
Merhaba arkadaşlar,
ABS ünitem sadece 000000 kod gösteriyor. Ayrıca sistemde hata kodları mevcut. Yeniden kod girmem gerekiyor. Yardımcı olur musun?
Araçla ilgili detaylar:
Skoda Octavia 2012
1.6TDI CAY Motor
Manuel Şanzıman
SET düğmesi mevcut
ASR düğme mevcut
PLA 2.0 mevcut
Yokuş Kalkış Mevcut
Sol taraf sürücü
VIN: TMBBT61Z4D2011724
Parça no.: 1k0 907 379 BL
Hello
need also long coding
Golf v 1.9 tdi
LHD
No Start Stop
1K0907379 AD
ESP MK60EC1
WVWZZZ1KZ9M293211
Thks
113B200D09230003880D04E7902000413000
You forgot to mention TPMS. So I turned it off.
After your cluster change, make sure you adapted it to the original VIN that is in you picture. Otherwise this coding will not work because you have to provide the VIN from scan, not from sticker in booklet or chassis.
zuco1989 (6th February, 2022)
Apart from not using english (board language), this is a very good request. Everything important mentionend. Especially the fact, that you mentioned PLA 2.0 because that makes special settings. But what you forgot is engine start stop, so I turned it off.
113B201C092300FB881204E6901D0041350150
Very important: because of PLA 2.0 this car should also have bidirectional wheel speed sensors at the rear axle. I took care of it. But please make sure after coding there is no electrical failure regarding wheel speed sensors when you read error codes. And also, very important, make sure in measurements, that when you drive forwards they also show forwards and not the other way round. If any of that is not ok, tell me so I can fix it.
denizoto62 (5th February, 2022)
I'm sorry for my bad english. I am very grateful for your help. My car has no start-stop. I'm sorry I forgot to say this.
r4nd0mize (6th February, 2022)
It's just fine. As I said, you request all in all was very good. Start stop was not very common in this vehicles back in the days so chance was high I am correct turning it offSo then you can use the coding I gave you above. But once again, after it's written to the unit, to the basic settings and then check if the wheel speed sensor direction is correct in measurements when you are driving. Cause that will cause problems if it is the other way round when driving.
Could you provide me some help for long coding. Here the car details.
1. 1K0907379CC
2. WVWZZZ1KZ6P016813
3. Golf MK5 GTI
4. LHD
5. 2.0 TFSI AXX engine (147Kw). DSG gearbox
6. Front Wheel Drive
7. No start/stop installed
8. indirect TPMS
9. ESP OFF button
10. No "Hill hold" function
11. 312 mm front discs / 288mm rear discs.
The old MK60 block fitted on the car was 1K0907379Q
Thanks a lot for your time.
Uff, your case is special. That CC units have an additional byte, that I did not get through yet, completely. And old block number ending with Q is not a software number. It's probably the pump number.
Anyways, your request is really very detailed (very good) so heres your coding with the minimum accepted stuff for the last byte. And if you had a different unit mounted before without that, it in the end doesnt matter what is in there as it does not affect your car originally.
143B600D09230000281306E5901C004134000012
In case this is not accepted, try the last byte instead of 12 to be:
- 02
- 10
- 1A
- 22
- 72
These are known, valid values.
Sorry to go this way, but as I said this software is kinda rare, and that additional byte contains some lane assist stuff and so on. But I can tell you all the rest is perfect for your car. And if accepted with one of the possibilities for the last byte and no problems appear no matter what you use as last byte, you are fine.
Murderous972 (6th February, 2022)
Thank for your time.
The part number is 1K0907379Q. I just checked right now with VCDS. It"s an old MK60 block. The pump number is 1K0614517N.
I know the CC revision is rare. I took it because i have in mind to add all these assistant stuff on my old MK5.
Thank you again for your time! I appreciate a lot.
