Page 233 of 245 FirstFirst ... 133183223228229230231232233234235236237238243 ... LastLast
Results 3,481 to 3,495 of 3668
  1. #3481
    May 2022
    Ukraine
    C54B000000000000000000000000000000000000
    C54BC0F549240000000000000000000000000000
    C54BC0F549240003A30000000000000000000000
    C54BC0F549240003A31403E8001E000000000000
    C54BC0F549240003A31403E8001E0041A0100012
    without a log, the brain turned on. Check. I'll correct the little things .. but I think I was not mistaken.
    Слава Украине!
  2. #3482
    May 2022
    Ukraine
    Quote Originally Posted by viytik1 View Post
    My log ESP.
    А почему лог на руцком языке?
    Are you by any chance from katsapstan? For katsapiv all encodings are closed, sanctions.
    I did this one, but the next time the katsaps go towards the moscow ship that sank.
  3. The Following User Says Thank You to Fibiana For This Useful Post:
    viytik1 (25th May, 2022)
  4. #3483
    Dec 2016
    Дякую.Перевірю вже завтра.Лог на москальский бо в VCDS здаеться немае вибору мови.
  5. #3484
    May 2022
    Ukraine
    For the future, this does not concern katsaps, you need to shoot the entire log. I explain, it shows block 01, its power and type of motor, block two ..... (yes-no). block 03 - what software and number. Encoding length. Block 17, block 44, block 5F. This is important in modern cars to consider. We'll do yours with our eyes closed.
    Твою сделаем даже не сомневайся. главное путенхуйло и кацапы не могут калькулировать блоки, им капец))).
  6. #3485
    DK Veteran zeljolaki's Avatar
    In my garage
    Hi! I need help for ABS long code, car is VW Golf V,
    VIN: WVWZZZ1KZ9W151220
    Engine : BUD , 59 kw,1390 ccm
    LHD
    ABS is : 1K0 907 379 CD
    ESP MK60EC1 H35 0120
    Thanks !
  7. #3486
    May 2022
    Ukraine
    Quote Originally Posted by zeljolaki View Post
    LHD
    Thanks !
    Do you really not understand or do you do it on purpose? What for do I have a software number ??? Can I see the block number or do I have to guess? Is the log difficult to remove???? I'll write the same for Austria... In about twenty minutes.
    If someone wants to help Ukraine and its soldiers for my work, you can transfer one Euro for the work.
    113B200D092700FB880D04E6901900400000
    мне проще жирафа или крокодила обучить. чем пояснять клиентам как надо сдавать анализы.
    This is a draft, I will correct it later when there is a diagnostic log, and not scribbles and photographs of labels.
    No thanks, you can just help Ukraine by transferring 1 Euro
  8. #3487
    In my garage
    Quote Originally Posted by Fibiana View Post
    Thanks !!!!
  9. #3488
    May 2022
    Ukraine
    113B200D092700FB880D04E690190040 30 00
  10. The Following User Says Thank You to Fibiana For This Useful Post:
    zeljolaki (27th May, 2022)
  11. #3489
    May 2022
    Someone help me with the code…
    1K0 907 379AD
    Seat Leon mk2 1p1
    VSSZZZ1PZ9R026827
    Left Hand drive!
    Thanks !
    Disc 312/272
    Engine BMN
  12. #3490
    In my garage
    Quote Originally Posted by karhune View Post
    1K0 907 379AD
    Seat Leon mk2 1p1
    VSSZZZ1PZ9R026827
    Left Hand drive!
    Thanks !
    Disc 312/272
    Engine BMN
    Please make VCDS log file and Fibiana will help you ...
  13. #3491
    May 2022
    Saturday,28,May,2022,11:46:28:00009
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 19.6.1.0 (x64)
    Data version: 20190529 DS308.0
    www.Ross-Tech.com
    VIN: VSSZZZ1PZ9R026827 License Plate:
    Mileage: 282130km-175307mi Repair Order:
    Address 03: ABS Brakes (1K0 907 379 AD)
    11:46:17 Group 001: Current Wheel Speed
    0.0 km/h Speed Sensor Front Left (G47)
    0.0 km/h Speed Sensor Front Right (G45)
    0.0 km/h Speed Sensor Rear Left (G46)
    0.0 km/h Speed Sensor Rear Right (G44)
    11:46:17 Group 002: Switches and Warning Lights I
    Activated Parking Brake
    11:46:17 Group 003: Switches and Warning Lights II
    Not Oper. Brake Light Switch (F)
    ON Brake System Warning L. (K118)
    ON ABS Warning L. (K47)
    ON ASR/ESP Warning L. (K155)
    Saturday,28,May,2022,11:59:19:00009
    www.Ross-Tech.com
    Chassis Type: 1P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 77
    VIN: VSSZZZ1PZ9R026827 Mileage: 282130km-175307miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Part No SW: 03G 906 018 GP HW: 03G 906 018 GP
    Component: R4 2.0l PPD1.2 G 2281
    Revision: --H52--- Serial number: SEX7Z0H631T03M
    Coding: 0050072
    Shop #: WSC 66565 257 00032
    VCID: 79F3B02630D95B87DE-802C
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0106
    Revision: 00H35001
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 01357 011 00200
    VCID: 74ED8112D7BB26EF8D-8020
    4 Faults Found:
    01435 - Brake Pressure Sensor 1 (G201)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 73
    Mileage: 282133 km
    Time Indication: 0
    Freeze Frame:
    Count: 7
    Count: 2
    Count: 12800
    Count: 279
    Count: 43264
    Count: 768
    Count: 0
    Count: 0
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 73
    Mileage: 282133 km
    Time Indication: 0
    Freeze Frame:
    Count: 7
    Count: 2
    Count: 12800
    Count: 295
    Count: 43264
    Count: 768
    Count: 0
    Count: 0
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 73
    Mileage: 282133 km
    Time Indication: 0
    Freeze Frame:
    Count: 7
    Count: 2
    Count: 12800
    Count: 270
    Count: 43264
    Count: 768
    Count: 0
    Count: 0
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 73
    Mileage: 282133 km
    Time Indication: 0
    Freeze Frame:
    Count: 7
    Count: 2
    Count: 12800
    Count: 195
    Count: 43264
    Count: 768
    Count: 0
    Count: 0
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No: 1P0 907 044 E
    Component: ClimatronicPQ35 011 0702
    Shop #: WSC 00000 000 00000
    VCID: 2E59537AB9174C3F3B-807A
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
    Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 00000005861497
    Coding: EB8A8E2F00040100431D00000000008000017F075C40000C00 0000000000
    Shop #: WSC 00012 123 12345
    VCID: 336F420E523561D754-8066
    Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer 120608 022 0601
    Coding: 00056208
    Shop #: WSC 00012
    Subsystem 2 - Part No: 1P0 955 559 Labels: 1P0-955-559.CLB
    Component: REGENLICHTSENSORH04 0090
    Coding: 00152622
    Shop #: WSC 00012
    1 Fault Found:
    01800 - Light Switch (E1)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 73
    Mileage: 282133 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 12.10 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
    Component: J234__A02 VW10 HI 1815
    Revision: 19013000 Serial number: 0039DPDRMX9P
    Coding: 0012338
    Shop #: WSC 06402 785 00200
    VCID: 3B7F6A2E7A65A9978C-806E
    Subsystem 1 - Serial number: 6333FTS601051788
    Subsystem 2 - Serial number: 6343FTS661331788
    Subsystem 3 - Serial number: 6353ETS6FQ9OTVNH
    Subsystem 4 - Serial number: 6363ETS6CF4TTVNH
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
    Component: J0527 752 0101
    Coding: 0002042
    VCID: 78F5B5220BD3428FA1-802C
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 001 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1P0 920 847 C
    Component: KOMBIINSTRUMENT VO3 0750
    Coding: 0004101
    Shop #: WSC 00011 888 06946
    VCID: 3261470AAD2F68DF5F-8066
    Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533__Gateway H16 0202
    Revision: H16 Serial number: 2700K0871008B9
    Coding: E9817F060006020202
    VCID: 356B7C165C417FE77A-8060
    1 Fault Found:
    01304 - Radio
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 73
    Mileage: 282133 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:54:55
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VO3 0750
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
    Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
    Component: J386 TUER-SG FT 1517
    Revision: 71009005 Serial number: 00000766288607
    Coding: 0004272
    VCID: 40851DC21383CA4FD9-8014
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
    Part No: 1K1 909 144 M
    Component: EPS_ZFLS Kl.142 H08 1901
    Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0204
    Revision: 00020000 Serial number: 00000000000000
    Coding: 888008005283CC7F7F060F0D60084F00207C00
    VCID: 030FD2CE4215115784-8056
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
    Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
    Component: J387 TUER-SG BT 1517
    Revision: 71009005 Serial number: 00000151788602
    Coding: 0004272
    VCID: 418318C61889C347D6-8014
    Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
    Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
    Component: AFS-Steuergeraet 0133
    Revision: 00H04000 Serial number:
    Coding: 2556933
    Shop #: WSC 00000 785 00200
    VCID: 346D4112573B66EF4D-8060
    Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
    Component: AFS-Lst.-Modul l 0004
    Coding: 00000039
    Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
    Component: AFS-Lst.-Modul r 0004
    Coding: 00000039
    Address 56: Radio
    Cannot be reached
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
    Component: J388 TUER-SG HL 1401
    Revision: 11006001 Serial number: 00000003317524
    Coding: 0000144
    VCID: 74ED811217BB26EF8D-8020
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
    Component: J389 TUER-SG HR 1401
    Revision: 11006001 Serial number: 00000003301806
    Coding: 0000144
    VCID: 75EBBC161CC13FE7BA-8020
    Address 77: Telephone Labels: 5P0-862-335.lbl
    Part No SW: 5P0 862 335 B HW: 5P0 862 335 B
    Component: FSE_2P5x H26 0110
    Revision: 00000001 Serial number: 00000005035092
    Coding: 0000555
    1 Fault Found:
    01304 - Radio
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 73
    Mileage: 282133 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:54:51
    End-------------------------(Elapsed Time: 01:48)--------------------------
  14. #3492
    May 2022
    Ukraine
    Слава Украине!
    113B60120000000000000000000000000000
    113B60120924000088000000000000000000
    113B601209240000881306E6900000000000
    113B601209240000881306E6902000420000
    113B601209240000881306E6902000423000
    113B601209240000881306E6902000423000 готово
    Должно быть так
    Revision: 00H35001
    Coding: Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
    Revision: 00H35001
    Coding: 113B601209240000881306E6902000423000
    Shop #: WSC putin is_ huilo
  15. #3493
    May 2022
    [QUOTE=Fibiana;4348382]Слава Украине!
    Problem with esp, esp is on all the time and no brake pressure fault. and it accept this code 113B601209240000881306E6902000423000but dont wanna keep it in.
  16. #3494
    May 2022
    Ukraine
    Пишу с телефона, но компьютер буду позже. Мне нужен срок, почему слетела кодировка, и журнал блока 03. Я подправлю, но некоторые блоки будут принимать крдинг, когда путин-хуйло.)))).
    Подробно опишите, что меняли в автомобиле.
  17. #3495
    May 2022
    Only abs box and hydraulic pump.replaced with same number.
