Getting correct ABS coding is simple:
1. Get a photo of the sticker with PR codes from the trunk spare wheel or decode VIN https://carinfo.kiev.ua/vin
2. Get VCDS scan
3. Post the info above on the forum and please also describe where steering wheel is located (LHD/RHD), presence of Start-Stop system, buttons: TPMS/RKA, ESC/TCS/ASR off
Good to know: without option's list/current car scan/details about driving side etc, the proper coding is not possible in 99% of cases!
Jonatanfunes91 (20th June, 2022)
Calculation for LHD, front brakes 288mm, rear 232mm, standard suspension, manual transmission, CAXA 1.4TSI, Start-Stop, Hill Hold Control, XDS:
310448E9217500BB8C2712EA84D800510D00
without Start-Stop it would be 310448E9217500BB8C2712EA84D800410D00
Let's play with Tire Pressure Monitoring options later if one of these codings is accepted? I wonder if the car has a sticker with PR-Codes in the trunk near spare wheel.
2. Get VCDS scan
thank you very very much. I'm going to fix the label on Wednesday to see if it brings it. Thanks a lot
:wink
Hey, Im new hear and i have a problem,
I have an MK60 EC1 and he lost the long coding
pls help me.
Audi S3 8P 09.2008
WAUZZZ8P59A034586
2,0 TFSI
1K0 907 379 AP
ESP MK60 EC1 H450109
lprot (20th June, 2022)
As there is no scan I guess that car is RHD? If there was AE block from the stock and it was not reflashed to CE then try:
16428012092500FE681001EC901F00813800
If AE was officially reflashed to CE and now you instlled AP then:
16428012492500FE681001EC921F00813800
Don't forget to do basic settings http://wiki.ross-tech.com/wiki/index...1)#Replacement
And after that you can additionaly turn on Hill Hold Control in bit0 of byte 16.
Don't forget to give feedback which coding worked. Good luck!
2. Get VCDS scan
Mert93 (20th June, 2022)
it is a LHD. I don't change the ABS block, it was always an AP. He only lost the coding because the battery voltage was too low. The only thing we did is flash the version of H45 0107 to the latest version H45 0109. Here is a picture before flashing the software.Thanks in advance
Attachment 895119
2. Get VCDS scan
ok thanks, i will test it
2. Get VCDS scan
Mert93 (21st June, 2022)
Need ABS coding.
THANKS !!!!
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 06314 123 12345
VCID: 74E769D7D7BB262955-8020
If my solution helped You - do not forget to THANKS !!!
gege974 (24th June, 2022)
salut
voici votre codage
11422012092700fb881404e8902100423800
Small circumstances produce great events : 02.47-tranquillité:
number7hd (24th June, 2022)
