Page 242 of 245 FirstFirst ... 142192232237238239240241242243244245 LastLast
Results 3,616 to 3,630 of 3668
  1. #3616
    Jun 2018
    VW Golf V , 1,6 FSI , 1K1
    1. Driving side LHD
    2. Engine type 1,6 FSI , BLF
    3. Transmission Auto or Manual : Automatic
    4. Suspension: Standart or Sport : Standart
    5. Start-Stop : NO
    6. TPMS button or monitoring : NO
    VIN Number : WVWZZZ1KZ6W151949
    please i need ABS code
  2. #3617
    Oct 2017
    99problems
    You have the short coding abs module. You have to calculate the code from the floating message appearing by holding the mouse on the "0000000" line on coding menu.
    Edit: From my searching, it should be 0019073.
    If I helped you, please don't forget to hit :
  3. #3618
    Jun 2018
    thnak you , i have tried but always i have DTCs
    01487 System Function Test ,
    01486 System Function Test Activated ,
    i have many codes tried but not work
  4. #3619
    Sep 2012
    AOW
    Hi guys!
    I need ABS 5N0614109BD - short coding for VW Tiguan -2010 vin: WVGZZZ5NZAW099891
    ... old ABS was 5N0614109M - with coding 11567 (maybe it helps...)
  5. #3620
    Nov 2017
    Hi i really hope someone can help me. I have a VW Amarok here thats been all around the town and every workshop has tried to fix it. The original problem was that the ECU had water damage, so the customer took it to a well known bulls**ter against everyone's warnings. Now it has a second hand ECU in and starts at least. I then reset all the learnt values and put in the injector codes. Now my problem is the ABS coding. I dont know what the other guy did to the vehicle but the ABS says 'control module not coded'. Please can some one help me with the long code.
    Also the vehicle's original VIN is "WV1ZZZ2HZB8053945" is there any way to change the VIN back to the origial.
    Monday,25,July,2022,17:11:35:00009
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 21.3.0.0
    Data version: 20210226 DS325.0
    www.Ross-Tech.com
    VIN: WV1ZZZ2HZB8076257 License Plate:
    Mileage: 170890km-106186mi Repair Order:
    Chassis Type: 2H-VN81 (6N0)
    Scan: 01 03 08 09 15 17 19 22 25 32 69
    VIN: WV1ZZZ2HZB8076257 Mileage: 170890km-106186miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    32-Differential Locks -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    Address 01: Engine (J623-CDCA) Labels:. 03L-906-022-CAA.clb
    Part No SW: 03L 906 019 EL HW: 03L 907 309 K
    Component: R4 2,0L EDC H41 1238
    Revision: 26H41--- Serial number: 00000000000000
    Coding: 01190012232400080000
    Shop #: WSC 07456 790 50316
    ASAM Dataset: EV_ECM20BTD01103L906019EL 002005
    ROD: EV_ECM20BTD01103L906019EL_002.rod
    VCID: 79F958E3F8D95B4384-802C
    1 Fault Found:
    4978 - Glow Plug Module 1; Glow Plug Circuit
    P0670 00 [047] - Electrical Malfunction
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 170896 km
    Date: 2022.07.25
    Time: 18:50:33
    Engine RPM: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 39 °C
    Intake air temperature: 22 °C
    Ambient air pressure: 900 mbar
    Voltage terminal 30: 12.080 V
    Unlearning counter according OBD: 40
    Electric auxiliary heater: shut-off conditions-Bits 0-7: 00000000
    Electric auxiliary heater: relay activation-Bits 0-7: 00000000
    Pre-glow time: 0 ms
    Glow status-Bits 0-7: 00000000
    Glow cycles above temperature threshold-Bits 0-7: 00000000
    Glow cycles above temperature threshold-Bits 0-7: 00001100
    Glow cycles below temperature threshold-Bits 0-7: 00000000
    Glow cycles below temperature threshold-Bits 0-7: 00010001
    Outside temperature: 17.0 °C
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (-----) Labels: 2H0-907-37x-ESP.clb
    Part No SW: 2H0 907 379 G HW: 2H0 907 379 D
    Component: ESP MK25A XT H44 0106
    Revision: 00H44001
    Coding: C07324B69299039824AB49A7AF5510
    Shop #: WSC 07456 790 49164
    VCID: 3467A9D7973B662B17-8060
    4 Faults Found:
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 191
    Mileage: 170896 km
    Time Indication: 0
    Date: 2016.12.15
    Time: 20:22:31
    Freeze Frame:
    Count: 16512
    Count: 257
    Count: 4198
    Count: 516
    03306 - Coding Not Valid
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 191
    Mileage: 170896 km
    Time Indication: 0
    Date: 2016.12.15
    Time: 20:43:32
    Freeze Frame:
    Count: 16384
    Count: 513
    Count: 4161
    Count: 516
    01044 - Control Module Incorrectly Coded
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 191
    Mileage: 170896 km
    Time Indication: 0
    Date: 2016.12.15
    Time: 19:36:53
    Freeze Frame:
    Count: 16512
    Count: 4865
    Count: 4163
    Count: 514
    003 - Mechanical Failure
    Freeze Frame:
    Fault Status: 01100011
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 191
    Mileage: 170896 km
    Time Indication: 0
    Date: 2016.12.15
    Time: 19:39:15
    Freeze Frame:
    Count: 16384
    Count: 257
    Count: 83
    Count: 766
    Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
    Part No SW: 2H0 907 040 D HW: 2H0 907 040 D
    Component: ClimatronicT5 H11 0304
    Revision: 00002001
    Coding: 0000000002
    Shop #: WSC 07446 790 50316
    ASAM Dataset: EV_ClimatronicT5 A01003
    ROD: EV_ClimaAutoT5Basis.rod
    VCID: 224B5F8F35CFF89BF5-8076
    No fault code found.
    Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
    Part No SW: 6R7 937 087 H HW: 6R7 937 087 H
    Component: PQ25 BCM H12 0022
    Revision: -1------ Serial number: 1002480801
    Coding: 3C0002380C41040080300000240A04C40080412E6000000030 00
    Shop #: WSC 80093 222 69422
    VCID: 4999E823E0B90BC354-801C
    Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
    Component: J386__TSG_FT 002 3321
    Serial number: --------------------
    Coding: 110000
    Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
    Component: J387__TSG_BT 002 3321
    Coding: 110000
    Subsystem 3 - Part No: 1K8 951 605 A
    Component: LIN BACKUP HORN H11 H11 9004
    Subsystem 4 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
    Component: J388__TSG_HL 002 3321
    Coding: 100000
    Subsystem 5 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
    Component: J389__TSG_HR 002 3321
    Coding: 100000
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
    Component: VW10Airbag00M H06 0013
    Revision: -------- Serial number: 003HN001Y6FD
    Coding: 00000000000000000000000000000000304D
    ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
    ROD: EV_AirbaVW10BPAVN750_VN75.rod
    VCID: 3365AACB9A3561130E-8066
    Crash sensor for side airbag: driver side:
    Serial number: 3495RRB40656VQ8AIHBD
    Front Passenger's Side Airbag Crash Sensor:
    Serial number: 3505RRB40516Q5D66GGA
    Crash sensor for front airbag: driver side:
    Serial number: 3555YRB4057042AEC10K
    Crash sensor for front airbag: front passenger side:
    Serial number: 3565YRB405B04M78B1VN
    Part No SW: 2H0 920 853 A HW: 2H0 920 853 A
    Component: KOMBI H04 0304
    Coding: 150A00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
    VCID: 2643439F59E704BB99-8072
    Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R7 937 087 H
    Component: GW-K-CAN TP20 0022
    Revision: -1------
    Coding: 742300
    VCID: 70EF65C7A3A31A0B33-8024
    Address 22: AWD Labels: None
    Part No SW: 2H0 927 755 B HW: 2H0 927 755 B
    Component: SG offroad VTG 0153
    Revision: 00H06000 Serial number: T1IRB0220BW2UJ
    Coding: 0000013
    Shop #: WSC 131071 1023 2097151
    VCID: 2F6DA6BBBE1D45F36A-807A
    1 Fault Found:
    00625 - Vehicle Speed Signal
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 39
    Mileage: 170896 km
    Time Indication: 0
    Date: 2016.12.15
    Time: 19:39:15
    Freeze Frame:
    Battery Volts: 14.0 V
    Current: 0.0 A
    Voltage: 4.00 V
    RPM: 1938 /min
    Speed: 92.0 km/h
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H04 0304
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
    VCID: 6ADB77AF8D7FE0DB7D-803E
    Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
    Part No SW: 2H0 927 771 HW: 2H0 927 771
    Component: Quersperre H04 0014
    Revision: 11001001 Serial number: 4DG 15.09.10 00
    Coding: 000001
    ASAM Dataset: EV_QuersUDSAAMVN817 A01005
    ROD: EV_QuersUDSAAMVN817.rod
    VCID: 6BD572AB8285F9D306-803E
    Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
    Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
    Component: Anhaenger H09 0100
    Revision: 3A001001 Serial number: 00000140408066
    Coding: 0100000100000000
    VCID: 306FA5C763235A0B73-8064
    End-------------------------(Elapsed Time: 01:53)--------------------------
    Controller Software Versions:
    ECU 1 = Engine 1238
    ECU 2 = ABS Brakes 0106
    ECU 3 = Auto HVAC 0304
    ECU 4 = Cent. Elect. 0022
    Sub ECU 4 > 1 = Cent. Elect. 3321
    Sub ECU 4 > 2 = Cent. Elect. 3321
    Sub ECU 4 > 3 = Cent. Elect. 9004
    Sub ECU 4 > 4 = Cent. Elect. 3321
    Sub ECU 4 > 5 = Cent. Elect. 3321
    ECU 5 = Airbags 0013
    ECU 6 = Instruments 0304
    ECU 7 = CAN Gateway 0022
    ECU 8 = AWD 0153
    ECU 9 = Immobilizer 0304
    ECU 10 = Differential Locks 0014
    ECU 11 = Trailer 0100
  6. #3621
    Jun 2016
    Hi can you help me with ABS coding
    1K0 907 379 AN ESP MK60EC1 H45 0107
    TMBHT61Z2A2043089
    thx
    EDIT: Solved
  7. #3622
    Aug 2022
    Caddy 2012 1.6 tdi cayd motor
    Vin : WV1ZZZ2KZCX078710
    ABS CODE
  8. #3623
    Dec 2010
    Earth
    Quote Originally Posted by Saka1 View Post
    ABS CODE
    433C200D09290302C21204E59019C081300000
    Getting correct ABS coding is simple:
    1. Get a photo of the sticker with PR codes from the trunk spare wheel or decode VIN https://carinfo.kiev.ua/vin
    2. Get VCDS scan
    3. Post the info above on the forum and please also describe where steering wheel is located (LHD/RHD), presence of Start-Stop system, buttons: TPMS/RKA, ESC/TCS/ASR off
    Good to know: without option's list/current car scan/details about driving side etc, the proper coding is not possible in 99% of cases!
  9. #3624
    Jun 2017
    please help with the following
    MK60EC1
    1K0 907 379 BJ
    3VWDP7AJ4CM348329
    VW JETA
    thanks.
    1. Driving side LHD
    2. Engine type 2.5 CBU
    5. Start-Stop : NO
  10. #3625
    Dec 2010
    Earth
    Quote Originally Posted by doordie40 View Post
    MK60EC1
    1K0 907 379 BJ
    3VWDP7AJ4CM348329
    VW JETA
    thanks.
    1. Driving side LHD
    5. Start-Stop : NO
    B14B400C492608028D0E02E692221061A70000
    2. Get VCDS scan
  11. #3626
    Jul 2022
    Skoda Octavia 1.4tsi 1K0907379AN TMBDJ21Z2AC005613. THANK YOU VERY MUCH
  12. #3627
    Apr 2021
    Quote Originally Posted by hid3 View Post
    Wow, it seems our Ukrainian friend got finally banned... How that happened? Did his fake reputation contribute to that or the fact that he was getting political and writing in russian in his every post?
    In either case, thanks to all who have reported that guy. Let's keep this place clean, friendly and peaceful!
    He is back. Unbanned.
  13. #3628
    May 2022
    Ukraine
    Wrote in russian my browser translates automatically. I give him a translation, and he automatically flips the text. And I can't see in what language I saved it. To check, you need to look in another browser or from another computer or phone.
    On the positive side, I finished the MQB calculator and almost finished AO.
    FSI/GDI/Piezo injector test and cleaning stands are fully operational. If anyone is interested, I can show the old developments https://www.youtube.com/watch?v=OoKkmB3WcJY
  14. #3629
    cheero's Avatar
    Czech Republic
    SKODA OCTAVIA 1.9 TDi 77kW 2009
    VIN : TMBBS61Z2A2051282
    1K0 907 379 AN
    1. Driving side LHD
    2. Engine type 1.9 TDi 77kW
    3. Transmission Auto or Manual : Manual
    5. Start-Stop : NO
    7. ESP : YES
    very thxy
    ++++ GOOD WORK ? + ++++
    FIAT EMEA 7inch, Ford Sanyo, DELPHI Chrysler Jeep Dodge, DELPHI Volvo GMC Renault, Ford FIC, Fiat Turkey, Ford V Series Calc, Fiat Continental VP1 VP2 Calc, Opel Delco CDR500 & CDR2005 Calc, Mercedes Alpine Calc, Jaguar Alpine Calc, Fiat Daiichi Calc, Delphi Famar Fueguina Calc, Renault Calc, Dacia Calc, Grundig oldtimer Calc, Chrysler Jeep Dodge Panasonic Harman Becker Alpine Continental Calc, Blaupunkt Calc, Philips oldtimer Calc, Audi Aisin RNS-E Calc ....
  15. #3630
    cheero's Avatar
    Czech Republic
