Page 25 of 245 FirstFirst ... 1520212223242526272829303575125 ... LastLast
Results 361 to 375 of 3668
  1. #361
    Jul 2016
    Vilnius
    Well, assumint the module is 1K0 907 379 AD, those codings should be just about right.
    What software are you using to code?
    Are yo uable to provide full car's autoscan?
    * MK100
  2. #362
    Jul 2016
    Vilnius
    Quote Originally Posted by fogducker View Post
    I'll try to change them, they appear to be stuck at 00001 001 001 and greyed out
    I'd suggest setting them to this:
    00028 028 001
    If using VCDS, they're in your VCDS cfg file, in the folder.
    * MK100
  3. #363
    Sep 2016
    UK
    Quote Originally Posted by hid3 View Post
    00028 028 001
    I deleted the config file and reset them to zero. I'll use those codes in the long coding screen and see what happens. For now I've to go pick up the troops from school and work! Thanks for your help so far.
  4. #364
    Jul 2016
    Vilnius
    Well, I've been thinking for a few hours and couldn't think anything better than this:
    1342201209260000C80F04ED90200080300000
    or this:
    1342201209260000C80F04ED90200080380000
    * MK100
  5. #365
    Sep 2016
    UK
    or this:
    good news! The first code worked! The only difference I made hardware wise was that I used my old original speedo cluster. Last night I discovered a problem with the VIN number in a new cluster I had already fitted. The VIN appears to be stored in two places and only one place was correct. The other is stored as YYYYYYYYYYYYYYYYY for some reason. Maybe a long code based on that "Y" VIN would work on my new cluster?
  6. #366
    Jul 2016
    Vilnius
    Okay, so seems that this one is correct for the module:
    Unfortunately, it is impossible to encode letters in ABS coding. It uses only digits from VIN...
    Are you able to change the VIN in the cluster?
    * MK100
  7. #367
    Sep 2016
    UK
    Ah, I see. At this point, I can't change that VIN in the cluster. I'm waiting on a reply from Carprog to see if they can help. I did the initial swap with their hardware/software. The VIN is correct in one area but not the other it seems. I bet it stored in the Fujitsu MCU. Do you happen to know the security code for the steering assist module (44)? I need to adapt the DSR in there to eliminate a power steering comms fault.
  8. #368
    Jul 2016
    Vilnius
    I doubt I have but feel free to provide the autoscan block of Steer. Assist (44)...
    Firstly I'd suggest figuring out with ABS module (and the cluster, of course). As you will need to adapt lots of sensors, including steering angle sensor.
    * MK100
  9. #369
    Sep 2016
    UK
    I'll see what Carprog say about the cluster issue and go from there. It's the notorious Fujitsu MCU with 93C86 version that was made around 2005. I might just get a newer one with Micronas, at least I can program that fully.
    Adapting the ABS module sensors will be easy enough, I've done it so many times now I think I could do it in my sleep!!
  10. #370
    BRASIL / SUL
    Default HELP ABS LONG CODE
    tks , good tks.
  11. #371
    Mar 2017
    is it posible to find long code for this one:retro fitted touran.
    MK60EC1 H31 0152 1K0 907 379 BL
    TOURAN 2005
    BKD 2,0TDI
    FWD
    START/STOP SYSTEM NO
    TPMS NO
    LEFT HAND DRIVE
    WVGZZZ1TZ5W046432
  12. #372
    Jul 2016
    Vilnius
    Quote Originally Posted by wendelbo View Post
    TOURAN 2005
    BKD 2,0TDI
    FWD
    TPMS NO
    LEFT HAND DRIVE
    WVGZZZ1TZ5W046432
    retrofits are usually a pain...
    Try this code:
    323B401609260E004C0F02E7901B7042300000
    If it works, a few coins donation would be nice...
    * MK100
  13. #373
    Sep 2015
    POLAND
    Hi i need help for long coding:
    1. Exact model of the car: Golf VI
    2. Year of the car: 2011
    3. VIN in cluster: WVWZZZ1KZCW186151
    4. LHD
    5. Engine type: 1,6 TDI
    6. FWD
    7. stock brakes: 280 front / 253 back, ABS pump is mk60ec1: 1K0 907 379 BJ
    8. START/STOP SYSTEM and TPMS I don't know
    9. Manual transmision
    Hopefully this is enough info for you. Thank You !!
  14. #374
    Jul 2016
    Vilnius
    Jak sie masz?
    Try this coding:
    113B200D092A8000880C04E9901A0141310000
    Bonus bonus, with it you get a full ESP disable option. If the coding is accepted, (and you adapt all the sensors on level ground) just hold the Anti-slip button on the center console near the ash tray longer and it will deactivate ESP too. It will display the info in MFD.
    If the coding does not work, please look up if:
    - you have a start/stop system (bluemotion), which shuts the engine off once standing on traffic lights, etc
    - there is a TPMS system. In glove box, where the owner's manual should be, on the left side there might be a button with "SET" written on it. If it is, then you have, if there is a dummy blanking plate then there is not. Look from the passenger's side and use a torch, as it's a bit hard to see
    * MK100
  15. The Following User Says Thank You to hid3 For This Useful Post:
    canontronic (15th March, 2017)
  16. #375
    Sep 2015
    POLAND
    Thanks a lot Mate, I will check it tomorrow and i let You know
