Page 30 of 245 FirstFirst ... 2025262728293031323334354080130 ... LastLast
Results 436 to 450 of 3668
  1. #436
    Griunvaldas's Avatar
    Aug 2010
    DC-DC
    Please help calculate long coding:
    VIN 3VWF17AT0GM638309
    Control Module Part Number: 1K0 907 379 CC HW: 1K0 907 379 CC
    Component and/or Version: ESP MK60EC1 H46 0175
    VW Beetle 1.8 TFSi US version AT no Auto Hold FWD
    Thank You
    Calculated myself.
    F14B4016492500028F0E02E49222004120100012
  2. #437
    Feb 2012
    work fine thanks
  3. #438
    Aug 2014
    Can you please help us with ABS Code for..
    VW Caddy 2012(2K) 2.0TDI
    Vin:WV1ZZZ2KZCX017298
    Manual transmission
    Thank you
  4. #439
    Jul 2016
    Vilnius
    Module part number?
    Start/stop system or not?
    * MK100
  5. #440
    Aug 2014
    SW: 1K0907379 BH
    HW: 1K0907379 BH
    NOT! Start/stop system
  6. #441
    Jul 2016
    Vilnius
    Try this one:
    423C200D09230301420D04ED9021C042300000
    * MK100
  7. The Following 2 Users Say Thank You to hid3 For This Useful Post:
    Afortunao (26th April, 2017), Tyson500 (3rd May, 2017)
  8. #442
    Sep 2016
    hello friend
    pls provide me Abs coding for vw vento right hand drive
    Hw no. 6R0 907 379 AQ
    vag no. 6R907379AQ
    ASAM Dataset EV-Brake1ABS90BOSCH
    ASAM Dataset Revision: 003017
    VIN no. WVWG13600DT073460
    REGARDS
  9. #443
    Apr 2017
    Help me please. I need the long coding for the ABS of a VW Jetta 2.5 SE model 2012
    Volkswagen Jetta 2.5 SE
    MFD 05/12
    Vin 3VWDX7AJ1CM410849
    Engine type: 2500 cc. 4 cyl. CBT 290513
    Left Hand Drive
    Brakes part number: 1K0907379BL
    Software Version: 0152
    Hardware version: H31
    Front Wheel Drive
    No ASR/ESP buttons
    No ECO/Bluemotion systems
    TPMS yes
    Automatic Transmition
    I don't know the brake disc diameter
    I appreciate your help with this problem- Thanks a lot
  10. #444
    Apr 2017
    I have the following problem:
    I was mounted on a SKODA OCTAVIA 2 1.9 tdi EU (manufactured 18.12.2006) a cluster of OCTAVIA 2 as of 14.03.2005 UK. The original cluster was minidot (EU) and the one I put is maxidot (UK).
    The big problem I have is that I can encode ABS ESP - I always get this error - 01044 incorrectly coded module control.
    I tried to compute different codes but I can not get rid of this error.
    Has anyone else hurt the problem?
    Is the problem due to the downgrade of the cluster?
    OCTAVIA 2 1.9 TDI
    Manual transmision
    With ESP Button
    Without TPMS
    VIN TMBCS61Z572038670
    ABS - 1K0907379AC
    Attached Thumbna
  11. #445
    Jul 2016
    Vilnius
    Quote Originally Posted by Edgar911 View Post
    MFD 05/12
    Left Hand Drive
    Front Wheel Drive
    No ASR/ESP buttons
    TPMS yes
    try this codding for the Jetta:
    B14B400C492300FA8D1302E892220041A71000
    * MK100
  12. #446
    Jul 2016
    Vilnius
    Quote Originally Posted by skypee View Post
    OCTAVIA 2 1.9 TDI
    Manual transmision
    With ESP Button
    Without TPMS
    ABS - 1K0907379AC
    Attached Thumbna
    1) So which cluster is now mounted on the car? The original one or replacement? Please use VCDS to grab the VIN which is shown in cluster (17 address)
    2) Do you happen to have the original coding of the ABS before starting to mess with clusters?
    * MK100
  13. #447
    Apr 2017
    Quote Originally Posted by hid3 View Post
    Thanks friend, this code was successfully accepted. But I have this problem now, I have the ABS light on and the dtc is 01309 "power steering control module(j500) - No signal / No communication" But this car hasn't electronic power steering module, it has a mechanic hydraulic pump with belt and just have the Steering position system. Can you please help me. Thanks a lot
  14. #448
    Edgar, add 20 value to byte 15, problem will dissaprear.
  15. The Following 2 Users Say Thank You to 1 6 D For This Useful Post:
    Afortunao (26th April, 2017), Edgar911 (24th April, 2017)
  16. #449
    Jul 2016
    Vilnius
    Quote Originally Posted by 1 6 D View Post
    Yeah, he's right. The correct coding should be like this:
    B14B400C492300FA8D1302E892220061A71000
    * MK100
  17. The Following User Says Thank You to hid3 For This Useful Post:
  18. #450
    Apr 2017
    Thanks to DigitalKaos and especially hid3 and 16D for your help. The coding is correct. I just have to do the ABS system function test to erase the code 01486. I really appreciate your valuable help. I will post again when the ABS light goes out.
    PD. Done, all the lights goes out. Once again thanks a lot.
