Page 44 of 245 FirstFirst ... 3439404142434445464748495494144 ... LastLast
Results 646 to 660 of 3668
  1. #646
    Jul 2017
    Hi, I've got a 2007 B6 VW Passat (LHD) that I've done an engine swap on ... and I need ABS coding. I've got about 1500 miles on the car since the swap, but can't get the ABS/ESP coded properly. ANY help would be greatly appreciated!
    In place of the original 2.0t FSI engine, I've installed a 2010 VW 2.5L 5-Cyl. engine. The VIN number in the following VCDS scan is from the ECU used (from a 2008 Golf 2.5L). The VIN number for the car itself, a 2007 VW Passat is: WVWLK73C97E009332.
    Because I couldn't code the original ABS Control Module to the 2008 Golf ECU ... I installed a Jetta ABS Control Module: MK60 - 1K0 907 379 AC.
    Here's the latest VCDS scan (I've also attached an image of the Passat PR Label in the trunk) ... If you need any other info, let me know ...
    Monday,17,July,2017,11:01:06:23114
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
    Data version: 20170320 DS267.7
    www.Ross-Tech.com
    VIN: WVWBA71K78W315062   License Plate:
    Mileage: 221120km-137397mi   Repair Order:
    Chassis Type: 1K (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 6D 72
    VIN: WVWBA71K78W315062   Mileage: 221120km-137397miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1C-Position Sensing -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (CBT)       Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 BJ    HW: 07K 906 032 Q
       Component: 2,5l R5/4V      G   1567
       Revision: 1NH01---    Serial number: VWX7Z0H33N97Z2
       Coding: 0000003
       Shop #: WSC 01279 785 00200
       VCID: 72BED2CB78AA85372BD-8026
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans        Labels: 09G-927-750.clb
       Part No SW: 09G 927 750 HJ    HW: 09G 927 750 CJ
       Component: AQ 250 6F           1068
       Revision: 00H38000    Serial number:
       Coding: 0000840
       Shop #: WSC 08114 444 84076
       VCID: 005A88034606A7A72D9-8054
    1 Fault Found:
    01316 - ABS Control Module
                004 - No Signal/Communication
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
       Component: ESP FRONT MK60      0101
       Revision: 00H11001
       Coding: 0021122
       Shop #: WSC 00066 000 00000
       VCID: 73B0D7CF07B08C3F20B-8026
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
                008 - Implausible Signal
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No: 1K0 820 047 EB
       Component: Climatic PQ35   090 0505
       Shop #: WSC 00000 000 00000
       VCID: 688AB0A34E767FE7859-803C
    1 Fault Found:
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
       Component: Bordnetz-SG     H46 1501
       Revision: 00H46000    Serial number: 00000005468122
       Coding: 008C0F0340041A00470A00000F00000000285D435C0000
       Shop #: WSC 05311 123 12345
       VCID: 372823DF5348201FDC3-8062
       Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer VW461  012  0503
       Coding: 00063445
       Shop #: WSC 05311
    Address 15: Airbags        Labels: 3C0-909-605.lbl
       Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
       Component: 0N AIRBAG VW8R  029 2521
       Revision: 10029000    Serial number: 003A3P2W7PWA
       Coding: 0012366
       Shop #: WSC 05311 000 08193
       VCID: 2E0606BBAC12E1D78F5-807A
       Subsystem 1 - Part No: 3C0 959 339 A
       Component: BF-Gewichtsens. 006 0002
       Subsystem 2 - Serial number: 00000000032EPS
       Subsystem 3 - Serial number: 0001.01.000000600000000000??63
       Subsystem 4 - Serial number: 000000??6332MSME0E716159E??63
       Subsystem 5 - Serial number: 16159E??6342MSME105B60746??63
       Subsystem 6 - Serial number: B60746??6351HTS64IKQTM627??63
       Subsystem 7 - Serial number: QTM627??6361HTS6TLLE15C3U??63
       Subsystem 8 - Serial number: E15C3U??63727TS63IK2T6C39??63
       Subsystem 9 - Serial number: 2T6C39??63827TS63IKEPNQ25?
       Subsystem 10 - Serial number: EPNQ25?
    Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
       Part No SW: 3C0 953 549 H    HW: 3C0 953 549 H
       Component: J0527               0015
       Revision: 00005000    Serial number: 3C9953507R
       Coding: 0102014
       Shop #: WSC 05311 000 00000
       VCID: 313C1DC7BD2CFE2F927-8064
    Address 17: Instruments        Labels: 3C0-920-xxx-17.lbl
       Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
       Component: KOMBIINSTRUMENT VD1 4240
       Revision: V0033000    Serial number: 00000000000000
       Coding: 0007205
       Shop #: WSC 01119 067 57207
       VCID: 333017CF4730CC3FE0B-8066
    Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
       Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
       Component: Gateway         007 0040
       Revision: 00007000    Serial number: 0700C0631304F6
       Coding: 3FFC0C0CD22002
       VCID: 211CED87EDCC4EAF027-8074
    Address 1C: Position Sensing        Labels: 1Kx-919-xxx-1C.lbl
       Part No SW: 3C0 919 965 A    HW: 3C0 919 965 A
       Component: Kompass         001 0002
       Revision: 00001000    Serial number: 1339817TQ3XP02
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
       Component:    IMMO         041 0364
       Revision: 00041000    Serial number: VWZCZ000000000
       Shop #: WSC 64713 001 1048576
       VCID: 2A0E0AAB90FA8DF753D-807E
       Subsystem 1 - Part No: 3C0 905 861 H
       Component:    ELV          028 0380
       3C0905861H     ELV          028 0380
    2 Faults Found:
    02823 - Requirements for Locking the Steering Column Lock not met
                000 -  -  - Intermittent
                 Freeze Frame:
                        Fault Status: 00110000
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 131
                        Mileage: 220933 km
                        Time Indication: 0
                        Date: 2017.07.13
                        Time: 15:29:13
    02827 - Wake-Up request via ESP
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 131
                        Mileage: 220933 km
                        Time Indication: 0
                        Date: 2017.07.13
                        Time: 15:29:14
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2801
       Coding: 0001205
       VCID: 36362EDB5442D917C75-8062
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V2.clb
       Part No: 1K1 909 144 K
       Component: EPS_ZFLS Kl.5   D06 1701
    Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
       Component:    KSG PQ46 RDK 041 0213
       Coding: 13900E88D1032E521804141FF00A0F0E083C00
       Subsystem 1 - Component:   Sounder n.mounted
       Subsystem 2 - Component:       NGS n.mounted
       Subsystem 3 - Component:      IRUE n.mounted
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
       Part No: 1K0 959 702 K
       Coding: 0001204
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 A    HW: 1K0 035 161 A
       Component: Radio DE2       012 0015
       Revision: 00012000    Serial number: VWZ4Z7F6117447
       Coding: 0040400
       VCID: 1D64D177D1B46A4F26F-8048
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
       Part No: 3C9 959 703 A
       Component: Tuer-SG         021 2507
       Coding: 0000144
    Address 6D: Trunk Elect.        Labels: None
       Part No SW: 3C9 827 383 B    HW: 3C9 827 383 C
       Component: J605  HECKDECKEL    0405
       Revision: 00H20001
       Shop #: WSC 23250 384 715754
       VCID: 303A18C3B626F7279D9-8064
       Subsystem 1 - Part No: 3C9 827 384 B
       Component: J756  HECKDECKEL    0405
       Subsystem 2 - Serial number: 0600H20001001C0055?
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
       Part No: 3C9 959 704 A
       Coding: 0000144
       VCID: 323E12CBB82AC537EBD-8066
    End----------(Elapsed Time: 01:11, VBatt start/end: 14.1V/14.1V)-----------
  2. #647
    Jul 2016
    Vilnius
    Quote Originally Posted by kenza287 View Post
    Hello
    I would need the coding abs for a golf 6 1.6tdi 2011
    I would like you auto scan to do the coding thank you
    VIN: WVWZZZ1KZBW165517
    Attachment 464777
    Adresse 03: Freins ABS (J104) Labels: 1K0-907-379-60EC1F.clb
    No. pi?ce Log: 1K0 907 379 BE Mat: 1K0 907 379 BE
    Pi?ce: ESP MK60EC1 H31 0108
    R?vision: 00H31001
    Codage: 00000000000000000000000000000000000000
    No. Atelier: WSC 01357 011 00200
    VCID: 76E3EEA5C12832F1C3-8022
    Adresse 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    No. pi?ce Log: 5K0 920 871 A Mat: 5K0 920 871 A
    Pi?ce: KOMBI H20 0420
    No. de s?rie: 00000000000000
    Codage: 170B01
    Jeu de donn?es ASAM: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
    VCID: 2C570CCD47E4382165-8078
    assuming it's LHD and without start-stop, try this:
    113B200D092800FF881004E590200041310000
    * MK100
  3. The Following User Says Thank You to hid3 For This Useful Post:
    kenza287 (21st July, 2017)
  4. #648
    Jul 2016
    Vilnius
    Quote Originally Posted by Geoffzie View Post
    I can see you have VCDS.
    Can you go to Instruments and check the VIN which is coded there? It should be somewhere in (Advanced) Measuring Blocks.
    Post that VIN here and I will try to prepare the coding.
    Also, to me it seems that you installed an incompatible module into your car...
    1) What was the original module's part numer?
    2) Are you able to borrow/buy/install a slightly different module, like one of these 1K0 907 379 AT, 1K0 907 379 BE, 1K0 907 379 BJ, 1K0 907 379 BL
    * MK100
  5. #649
    Jul 2016
    Vilnius
    Quote Originally Posted by s3man View Post
    I'm getting Error 31 with that code?
    please don't swap the clusters back and forth, just choose one you want to use on the car.
    Install the cluster the cluster into the car.
    Use the software to chech what VIN number is stored in the clsuter and post it here.
    Thanks.
    * MK100
  6. #650
    Feb 2013
    thank you for coding
    work good
    but my car have star and stop
    my star and stop is error in cluster
    send me please for wiht sart and stop
  7. #651
    The original cluster is back in the car but still won't accept the code. Still get error 31. Will I have to go to the dealers or is anyone able to help generate a code? Thanks
    1. ABS part no 1K0 907 379 AT
    2.Car:
    Audi A3 1.6 TDI
    3. Year 2010
    4. VIN in cluster:WAUZZZ8P8BA034846
    5. Right hand drive
    5. Diesel CAYC
    7. Front wheeldrive, Manual gearbox
    8. 1ZF 280mm
    9. start stop
    10.No TMPS
    11.Has Stop start off button and ASR? (Has picture of Car with Skid Marks )
    12.NO Hold Hill
    Quote Originally Posted by hid3 View Post
    Thanks.
  8. #652
    Jul 2017
    Hid3, I will try and check the VIN in the instrument cluster today, then post it here. Here's the original ABS Control Module number, and the fault code I was getting (I switched it because I could find no VW's that paired it with my 2.5L 2008 Golf ECU) ...
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
    Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
    Component: ESP 440 C2 H015 0004
    Revision: H015 Serial number: 0100005710
    Coding: 0046523
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 46
    Mileage: 219086 km
    Time Indication: 0
    Date: 2016.01.17
    Time: 10:42:58
    Yes, I could probably swap the ABS Control Module out with one of those you've listed (AT, BE, BJ, BL) ... would I have to switch out the entire ABS unit, or could I just switch out the ABS Control Module itself? Also, what would be the advantages of those units as opposed to what I have installed?
    By the way, I had the immobilized disabled by a company in Massachusetts, so the car would run (don't know if that makes any difference). I also have the TPMS disabled, Address 65 (no pressure sensors in my wheels) ... and would like to use the TPMS in the ABS Control Module if possible.
    Thanks for your help!
  9. #653
    Jul 2017
    hid3, I think I just answered my own question ... it looks (from eBay photos) like the 4 ABS units you listed (AT, BE, BJ, BL) are somewhat different, so I'd have to change the whole ABS unit (If there's no way to get coding for the existing unit).
  10. #654
    Jul 2016
    Vilnius
    work good
    Then this one should be fine:
    113B200D092800FF881004E590200051310000
    * MK100
  11. #655
    Jul 2016
    Vilnius
    Hold on, don't pull the trigger yet!
    I'll dig some more information on this THIS EVENING and will provide you the exact list of recommended ABS units.
    * MK100
  12. #656
    Jul 2016
    Vilnius
    2.Car:
    Audi A3 1.6 TDI
    3. Year 2010
    5. Right hand drive
    5. Diesel CAYC
    8. 1ZF 280mm
    9. start stop
    10.No TMPS
    12.NO Hold Hill
    Try this one:
    133B2012092500FEC81304E8901F0091300000
    * MK100
  13. #657
    Jul 2016
    Vilnius
    I think you need this module:
    3C0 614 109 AF.
    Unfortunately, I don't have any coding information for that module, so not even sure if it's possible to code that module with 2.5 engine... As Passats only had 2.0 and 3.6 engines installed.
    Alternatively, it's possible to try to install a module from B7 Passat (I think we can code it). However, I'm not sure if the wiring harness is identical. If not, then money will be wasted. That's why I can't recommend that. In this case, it's either hit or miss
    Passat is a bit different from Golf/Jetta/etc.
    It uses completely different modules. I believe the wiring harness is different too.
    * MK100
  14. #658
    Jul 2017
    hid3, yes that was the problem before ... I had to rewire the Golf ABS plug to adapt it to the Passat wiring (no easy job!). And would probably have to rewire it again ... if I had to change out ABS Module again.
    Here in the US, starting in 2012, the Passat WAS offered with the 2.5L engine (until 2014 I believe) ... but the 2012 VW Passat 2.5L ECU is completely different than my 2008 Golf 2.5L ECU (different plug type and pinouts). To install the Golf ECU, I had to rewire the Golf ECU Engine Plug to adapt it to the Passat chassis wiring (about 40 wires!).
    I really would like to get the ABS working on this car ... everything else seems to work.
  15. #659
    Jul 2016
    Vilnius
    What was the original ABS controller part number?
    What codings did you try on that?
    Did you have to rewire the ABS plug to swap the module or did it work out of the box?
    * MK100
  16. #660
    Jul 2017
    hello
    can you help me finding the abs long coding for the golf mk6 chassis num wvwzzz1kaw110089?
    regards.
