The coding was accepted but I still get a fault code 00150 plausibility brake booster system.
can You help me with coding for abs mk60ec1 1k0907379bj
Skoda Superb 1.6 tdi 2011
vin TMBJJ73T5C9020485
FWD, TPMS, start stop button, LHD, ESP button
Thanks in advance
hello
can you help me golf 7 esp long coding (electronic brakes)
vin:WVWZZZAUZEW350986
PART N° VW/AUDI : 5Q0907379AB
SN: 60614000000BE0
thankyou
hello
can you help with abs coding for vw touran mk60ec1 1ko907379bm
vin:wvgzzz1tzfw029564
* MK100;
* MK100;
lbnsky (31st August, 2017)
Hello mate,
have some read here:
http://www.digital-kaos.co.uk/forums...=1#post2835479
* MK100;
hid3 so many thanks You saved my life it's work like charm
Hello hid3
I need your help with coding
A3 8P 2009 1.9TDI
1KD907739AD
WAUZZZ8P09A116340
RHD
FWD
standard suspension
no start stop
no tpms
Thank in advance and best regards
can You help me with coding for abs MK25A XT 7E0907379J.
Transpoter T5 2012 2,0L deisel
VIN WV1ZZZ7HZCH129198
LHD, ESP button
i have read coding from exactly the same car: 908764ad91a7099726a28978696610
then just changed 5 bytes of chassis and it was this: 908764ad91a6099e26a3897a696610
then it accept the code but i have 5 errors inside the unit:
01279 Longitudinal Acceleration Sensor -G251
Status : Permanent error
missing data or wrong setting/adaptation
01435 Brake pressure Sensor 1 -G201
01423 Transverse acceleration sensor -G200
00778 Steering angle sensor
defect
can u guide me what is the problem?
Is my coding correct?
if yes,how i can delete these errors
THANKS
AUTO CODING
* MK100;
* MK100;
i have adapt the Brake pressure Sensor 1 -G201 and Transverse acceleration sensor -G200, now these errors gone.
i have just 3 errors,2 about angle sensor that has problem becasue do not have value and is 0.
but the other error cannot be deleted and car do not have this sensor i think:
because i check vcds manuals and guide me to adapt it.in measuring blocks the field is blank and car doesnt have this unit [53 - Parking Brake].
what could be the problem?
W,R
AUTO CODING
THANKS IN ADVANCE FOR YOUR GUIDING
For steering angle sensor, you probably need to adapt it in 44-steering assit first. Then try doing the same in ABS.
As for Longitudinal Acceleration Sensor, leave it alone for now, firstly figure out the steering angle sensor.
Longitudinal Acceleration Sensor should NOT be related to Parking Brake module. If the parking Brake module is NOT present in the car, make sure to remove it from CAN gateway coding... G251 should adapt then too...
* MK100;
auto coding (4th September, 2017)
please for coding
VW TOURAN 2014 2.0TDI CFH DSG
BLUE MOTION
WVGZZZ1TZFW029564
1K0907379BM
LHD FWD
START STOP YES
TPMS ABS BASED
ASR BUTTON YES
HILL HOLD NO
PR:1AT 1NL 1GB 1KS 1JA
THANKS
