hey pls help me coding abs A3
Thursday,07,September,2017,14:36:34:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WAUZZZ8P79A056086 License Plate:
Mileage: 175800km-109237mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72
VIN: WAUZZZ8P79A056086 Mileage: 175800km-109237miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 EA HW: 03L 906 022 BQ
Component: R4 2,0L EDC G000SG 3612
Revision: 13H01--- Serial number: AUX7Z0H9FN60DZ
Coding: 0000172
Shop #: WSC 18432 807 674438
VCID: 68DFD2C65BB2F10208-803C
1 Fault Found:
049493 - No Communication with Instrument Cluster
U0155 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 175776 km
Time Indication: 0
Date: 2017.09.09
Time: 00:07:49
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Temperature: 31.5°C
Voltage: 12.54 V
Bin. Bits: 00000000
Torque: 126.0 Nm
Temperature: 54.0°C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 80093 222 69422
VCID: 75E18BB2DC001CEA83-8020
2 Faults Found:
01486 - System Function Test Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 175803 km
Time Indication: 0
Date: 2017.09.07
Time: 14:31:36
Freeze Frame:
Count: 3
Count: 2
Count: 4096
Count: 320
Count: 45056
Count: 65280
Count: 0
Count: 0
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Time Indication: 0
Date: 2017.09.07
Time: 14:31:41
Freeze Frame:
Count: 7
Count: 2
Count: 4096
Count: 195
Count: 44800
Count: 65280
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000490 Serial number: 8P0820043BG
Shop #: WSC 00000 000 00000
VCID: 72EBB0AE6D6E0BD2A6-8026
3 Faults Found:
01232 - A/C Compressor Regulator Valve (N280)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 8
Reset counter: 202
Mileage: 177608 km
Time Indication: 0
Date: 2017.04.24
Time: 18:20:56
Freeze Frame:
Load: 50.0 %
Current: 0.000 A
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 203
Mileage: 178042 km
Time Indication: 0
Date: 2017.04.26
Time: 20:18:55
Freeze Frame:
Temperature: 35.0°C
Voltage: 13.50 V
RPM: 750 /min
Load: 0.0 %
Load: 0.0 %
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 12
Reset counter: 224
Mileage: 178682 km
Time Indication: 0
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008990087
Coding: 11A82F8190141380EF00001C0000000000094E056401040100 A800000000
Shop #: WSC 06314 000 08192
VCID: 489F32463B72D10228-801C
Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
2 Faults Found:
00987 - Lamp for Brake Light; Left (M9)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 187
Mileage: 63552 km
Time Indication: 0
Date: 2015.10.10
Time: 00:11:00
Freeze Frame:
ON
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 175776 km
Time Indication: 0
Date: 2017.09.09
Time: 00:07:00
Freeze Frame:
ON
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303030364A55304C38503053
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 49993742E878280A37-801C
Crash sensor for side airbag: driver side:
Serial number: 3572DRB400007C48B19
Crash sensor for side airbag: front passenger side:
Serial number: 3582DRB400007C1D49E4
Crash sensor for side airbag: rear: driver side:
Serial number: 35128RB4000045C698CV
Crash sensor for side airbag: rear: passenger side:
Serial number: 35228RB400004637F1BN
Crash sensor for front airbag: driver side:
Serial number: 35547RB40000464582BK
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400004645839K
1 Fault Found:
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 226
Mileage: 175776 km
Date: 2017.09.09
Time: 00:07:49
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000041
Shop #: WSC 12345 123 12345
VCID: 78FF82860B12618298-802C
2 Faults Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective
01044 - Control Module Incorrectly Coded
000 - -
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 931 T HW: 8P0 920 931 T
Component: KOMBIINSTR. VDO H15 0820
Revision: D0H15004 Serial number: 2246H004006925
Coding: 0004128
Shop #: WSC 01286 386 08256
VCID: 44872676075AF562C4-8010
No fault code found.
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H-- 0202
Revision: H-- Serial number: 0000
Coding: E9827F060002022102
Shop #: WSC 56299 001 1048576
VCID: 35614BB25C805CEA43-8060
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 187
Mileage: 175803 km
Time Indication: 0
Date: 2017.09.07
Time: 14:32:55
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
VCID: 4385256A0254F25AFD-8016
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 9
Mileage: 0 km
Time Indication: 1
Veh. life cycle counter: 0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Status: 00001010
Fault Priority: 4
Fault Frequency: 2
Reset counter: 9
Mileage: 0 km
Time Indication: 1
Freeze Frame:
Ign. Timing: 4.5 °BTDC
Raw, Form. N/A: 000 000 000
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H15004 Serial number: AUX7Z0H9FN60DZ
Shop #: WSC 00137 211 56823
2 Faults Found:
16346 - Control Module - ROM Error
014 - Defective
01176 - Key
008 - Implausible Signal - Intermittent
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
Component: Tuer-SG H03 0060
Coding: 0004276
VCID: 428B206E1D4EFB52F6-8016
3 Faults Found:
00939 - Mirror Adjust Motor; Drivers Side (V149)
012 - Electrical Fault in Circuit - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
00109 - Left Mirror Turn Signal Lamp (L131)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 233 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5B68CE853E0312DE-807E
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 L
Component: KSG H11 0080
Coding: 1880202002186D098D0D4C8F0167
VCID: 45813B720C60CC6AD3-8010
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
Coding: 0004276
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 152 C HW: 8P0 035 152 C
Component: R Chorus2+ H20 0270
Revision: 00H20000 Serial number: AUZ1Z2H2534151
Coding: 0000221
VCID: 2B556DCA8AC41A1A25-807E
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 226
Mileage: 0 km
Time Indication: 0
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 41892F621848E04AEF-8014
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
End-------------------------(Elapsed Time: 02:03)--------------------------
