Page 55 of 245 FirstFirst ... 545505152535455565758596065105155 ... LastLast
Results 811 to 825 of 3668
  1. #811
    Jul 2016
    Vilnius
    Hello mate,
    try this one:
    423C200D092A03FC420C04E8901AC051B5040020
    * MK100
  2. #812
    Usa
    HELLO
    please I need coding of this abs
    VIN: 3VWLL7AJ4DM249521
    No. pièce Log: 1K0 907 379 BL Mat: 1K0 907 379 BL
    Pièce: ESP MK60EC1 H31 0152
    Révision: 00H31001
    thank you
  3. #813
    Jul 2016
    Vilnius
    please provide more information:
    http://www.digital-kaos.co.uk/forums...=1#post2835479
    * MK100
  4. The Following User Says Thank You to hid3 For This Useful Post:
    sathicham (13th October, 2017)
  5. #814
    Quote Originally Posted by hid3 View Post
    Hello mate,
    try this one:
    hello not working
  6. #815
    Jul 2016
    Vilnius
    Is it simple Caddy or Caddy Maxi?
    What is the history of the car?
    Why was the original coding lost?
    * MK100
  7. #816
    Usa
    HELLO
    CAR: JETTA 2013
    Left hand drive
    DIESEL
    KEYLESSGO
    Révision: 00H31001
    thank you
  8. #817
    Jul 2016
    Vilnius
    This is coding for your US-spec Jetta:
    B14B400C492600038D1002E6921A0042A71000
    * MK100
  9. The Following User Says Thank You to hid3 For This Useful Post:
  10. #818
    Usa
    hello
    sir codage doesn't work
    VCDS
    Codage rejeté
    Erreur 31: Requête hors intervalle
  11. #819
    hello,
    It's Caddy, coding lost after change instrument cluster, now is come back to original instruments,
  12. #820
    Jul 2016
    Vilnius
    Quote Originally Posted by taraba123 View Post
    hello,
    Can you check what VIN is stored in the Instruments cluster?
    * MK100
  13. #821
    Jul 2016
    Vilnius
    Quote Originally Posted by sathicham View Post
    hello
    VCDS
    Codage rejeté
    What is the hhistory of the car?
    Have you made sure that WSC, Importert number and Stand numbers are not Zeroes in VCDS?
    * MK100
  14. #822
    Usa
    hello
    I changed the ecu motor and make immo off
    here is scan complet
    thank you
  15. #823
    Jul 2016
    Vilnius
    unable to open the archive
    * MK100
  16. #824
    Usa
    this what inside the archive
    Vendredi,13,Octobre,2017,06:02:45:36870
    Version VCDS: FRM 11.11.1
    Version données: 20120106
    Type chassis: 6N0
    Scanner: 01 02 03 05 08 09 15 17 19 25 2B 2E 44 56 77
    01-Moteur -- Etat: Défaut 1010
    02-Boite auto -- Etat: Défaut 1010
    03-Freins ABS -- Etat: Défaut 1010
    04-Angle de direction -- Etat: Erreur sporatique de communication 1000
    05-Autor. démarrage -- Etat: Défaut 0010
    08-Climatronic -- Etat: Défaut 0010
    09-Centrale Elec. -- Etat: Défaut 0010
    15-Airbags -- Etat: Défaut 1010
    17-Instruments -- Etat: Défaut 1010
    19-Gateway CAN -- Etat: Défaut 0010
    25-Anti-démarrage -- Etat: Défaut 1010
    2B-Verr. Col. Direct. -- Etat: Défaut 0010
    2E-Lect. multiméd. 3 -- Etat: Défaut 0010
    44-Direction assistée -- Etat: Défaut 1010
    56-Radio -- Etat: Défaut 0010
    77-Téléphone -- Etat: Défaut 0010
    Adresse 01: Moteur (CJA) Labels: Aucun
    No. pièce Log: 03L 906 019 HD Mat: 03L 907 309 AA
    Pièce: R4 2,0L EDC G000AG 8175
    Révision: 12H15--- No. de série:
    Codage: 0050078
    No. Atelier: WSC 00066 000 00000
    VCID: 74EC322317A00F8
    2 Codes défaut trouvés
    000115 - Détecteur de température extérieure (G17) -Signal trop fort
    P0073 - 000 -
    Capture:
    Etat du défaut: 01100000
    Priorité du défaut: 6
    Fréquence du défaut: 1
    Kilometrage: 68959 km
    Heure: 0
    Date: 2107.14.04
    Temps: 17:06:26
    Capture:
    Tr/min: 0 /min
    Vitesse: 0.0 km/h
    Tension: 12.16 V
    Température: 44.1°C
    Température: 33.3°C
    Température: 35.1°C
    Température: -90.0°C
    005784 - Lire la mém. des défauts de l´électronique de la colonne de direction
    P1698 - 000 -
    Capture:
    Heure: 0
    Date: 2107.14.04
    Temps: 00:22:31
    Capture:
    Tr/min: 0 /min
    Vitesse: 0.0 km/h
    Charge: 0.0 %
    Vitesse: 0.0 km/h
    (sans unité): 255.0
    (sans unité): 255.0
    Bits: 10000001
    Tests passés: 0 0 0 1 1
    Adresse 02: Boite auto Labels: Aucun
    No. pièce Log: 02E 300 058 M Mat: 02E 927 770 AL
    Pièce: GSG DSG AG6 512 3524
    Révision: 05551213 No. de série: 00001208020687
    Codage: 0000020
    No. Atelier: WSC 02069 000 90108
    VCID: 244C0263E7C0DF8
    3 Codes défaut trouvés
    18258 - Bus groupe motopropulseur Pas de message du calculateur moteur
    P1850 - 000 - - Intermittent
    Capture:
    Etat du défaut: 00100000
    Priorité du défaut: 0
    Compteur de RAZ: 40
    Heure: 0
    Date: 2107.14.03
    Temps: 00:12:11
    01196 - Bus de données moteur/boîte de vitesses
    004 - Aucun(e) signal / communication - Intermittent
    Capture:
    Etat du défaut: 00100100
    Compteur de RAZ: 40
    Heure: 0
    Date: 2107.14.03
    Temps: 00:12:11
    18270 - Bus groupe motopropulseur Pas de message du combiné d’instruments
    P1862 - 000 - - Intermittent
    Capture:
    Fréquence du défaut: 7
    Compteur de RAZ: 40
    Heure: 0
    Date: 2107.14.03
    Temps: 00:23:29
    Adresse 03: Freins ABS (J104) Labels: Aucun
    Révision: 00H31001
    Codage: 00000000000000000000000000000000000000
    VCID: 7DFA1707E4EA4E0
    03306 - Codage non valable
    000 - - - Intermittent
    Capture:
    Compteur de RAZ: 95
    Heure: 0
    Date: 2107.14.04
    Temps: 18:22:48
    Capture:
    Décompte: 3
    Décompte: 14
    Décompte: 20480
    Décompte: 4161
    Décompte: 43008
    Décompte: 0
    Décompte: 0
    Décompte: 0
    01042 - Calculateur non codé
    000 - -
    Capture:
    Priorité du défaut: 2
    Compteur de RAZ: 95
    Kilometrage: 1048575 km
    Heure: 0
    Date: 2107.14.04
    Temps: 00:58:47
    Capture:
    Décompte: 3
    Décompte: 0
    Décompte: 20992
    Décompte: 195
    Décompte: 42240
    Décompte: 0
    Décompte: 0
    Décompte: 0
    00778 - Transmetteur d´angle de braquage (G85)
    005 - Réglage de base / adaptation inexistant ou erroné
    Capture:
    Etat du défaut: 01100101
    Compteur de RAZ: 95
    Heure: 0
    Date: 2107.14.04
    Temps: 00:58:13
    Capture:
    Décompte: 3
    Décompte: 2
    Décompte: 20480
    Décompte: 295
    Décompte: 42496
    Décompte: 0
    Décompte: 0
    Décompte: 0
    Adresse 05: Autor. démarrage (J518) Labels: Aucun
    No. pièce Log: 5K0 959 434 B Mat: 5K0 959 434
    Pièce: VWKESSYPQ35GP 086 1101
    Révision: 00086000 No. de série: 0187108323
    Codage: 030C0C
    Jeu de données ASAM: EV_KESSYPQ35G A02013
    VCID: 346CF2239F204F8
    6 Codes défaut trouvés
    65794 - Fonctionnement limité
    U1400 00 [008] - par sous-tension
    Intermittent - Confirmé - Testé depuis RàZ mémoire
    Capture:
    Etat du défaut: 00000001
    Fréquence du défaut: 5
    Compteur de RAZ: 135
    Date: 2043.14.03
    Temps: 00:26:20
    65813 - Tension d'alimentation
    U1011 00 [008] - Tension trop faible
    Capture:
    Priorité du défaut: 4
    Fréquence du défaut: 10
    Kilometrage: 68958 km
    Date: 2040.14.22
    Temps: 13:35:56
    1052935 - Capteur d'effleur.poignée extérieure de porte; côté conducteur
    B116B 11 [008] - Court-circuit à la masse
    Capture:
    Compteur de RAZ: 134
    Date: 2041.14.00
    Temps: 00:01:01
    1053191 - Capteur d'effleur. poignée ext. porte; côté passager AV
    B116C 11 [008] - Court-circuit à la masse
    Capture:
    Date: 2041.14.09
    Temps: 00:00:00
    1053195 - Capteur d'effleur. poignée ext. porte; côté passager AV
    B116C 13 [008] - Circuit ouvert
    Capture:
    Fréquence du défaut: 2
    Kilometrage: 0 km
    Date: 2000.00.00
    Temps: 00:00:00
    1057547 - Antenne -1- ds l'habitacle pr autorisa. d'accès et de démarrage
    B1172 13 [008] - Circuit ouvert
    Capture:
    Fréquence du défaut: 4
    Date: 2041.14.09
    Temps: 00:15:33
    Adresse 08: Climatronic Labels: Aucun
    No. pièce Log: 5C0 820 047 BA Mat: 5C0 820 047 BA
    Pièce: J301 Klimaanlage 0204
    Révision: 2001012S No. de série: 00000001259847
    VCID: 60C44E73B358838
    7 Codes défaut trouvés
    01317 - Calculateur dans le porte-instruments (J285)
    013 - Lire la mémoire de défauts
    Capture:
    Etat du défaut: 01101101
    Compteur de RAZ: 94
    Heure: 0
    Date: 2105.14.00
    Temps: 00:00:33
    01314 - calculateur moteur
    Capture:
    Fréquence du défaut: 37
    Heure: 0
    Date: 2105.14.09
    Temps: 00:03:34
    Capture:
    Fréquence du défaut: 254
    Kilometrage: 0 km
    Heure: 0
    Date: 2105.14.09
    Temps: 00:15:04
    01316 - Calculateur de freins
    Capture:
    Fréquence du défaut: 13
    Heure: 0
    Date: 2105.14.09
    Temps: 00:05:16
    00819 - Transmetteur de haute pression (G65)
    009 - Rupture/court-circuit à la masse - Intermittent
    Capture:
    Etat du défaut: 00101001
    Heure: 0
    Date: 2105.14.09
    Temps: 00:07:02
    00446 - Limitation du fonctionnement due à une sous-tension
    002 - Limite inférieure non atteinte - Intermittent
    Capture:
    Etat du défaut: 00100010
    Heure: 0
    Date: 2107.14.03
    Temps: 07:40:14
    00532 - Tension d´alimentation
    Capture:
    Priorité du défaut: 3
    Heure: 0
    Date: 2107.14.03
    Temps: 07:40:14
    Adresse 09: Centrale Elec. (J519) Labels: Echec redir!
    No. pièce Log: 5C0 937 087 E Mat: 5C0 937 087 A
    Pièce: BCM25 JLB H3 H66 0256
    Révision: B2066001 No. de série: 04371308120785
    Codage: 73994B9A08230F0008382000240884C50082502E6000000030 A000000000
    VCID: 2F66FD4F7E066C0
    Sous-système 1 - No. pièce Log: 6R0 959 801 AF Mat: 6R0 959 801 AF
    Pièce: J386__TSG_FT 004 3465
    Codage: 820000
    Sous-système 2 - No. pièce Log: 6R0 959 802 AF Mat: 6R0 959 802 AF
    Pièce: J387__TSG_BT 004 3465
    Codage: 820000
    Sous-système 3 - No. pièce Log: 5K0 959 591 Mat: 5K0 959 591
    Pièce: J245 PS41.022 H10 0007
    Codage: 180000
    Sous-système 4 - No. pièce Log: 6R0 959 811 H Mat: 6R0 959 811 H
    Pièce: J388__TSG_HL 004 3464
    Codage: 800000
    Sous-système 5 - No. pièce Log: 6R0 959 812 H Mat: 6R0 959 812 H
    Pièce: J389__TSG_HR 004 3464
    Codage: 800000
    1 Code défaut trouvé
    01326 - Calculateur de volant multifonctions (J453)
    Capture:
    Etat du défaut: 01100100
    Compteur de RAZ: 95
    Heure: 0
    Date: 2107.14.04
    Temps: 00:22:32
    Adresse 15: Airbags (J234) Labels: Echec redir!
    No. pièce Log: 5C0 959 655 E Mat: 5C0 959 655 E
    Pièce: AirbagVW10G 014 0808
    No. de série: 003GTM08XXET
    Codage: 00003936
    Jeu de données ASAM: EV_AirbaVW10SMEVW360 A01023
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    Détection d'occupation du siège:
    Sous-système 1 - No. pièce Log: 5C6 959 339 B Mat: 5C6 959 339 B
    Pièce: BF-Gewichtss. H10 0046
    No. de série: 6940000Y120000LYKU0W
    Codage: 303042
    Capt. collis. pr sac gonfl. latéral; côté cond.:
    Sous-système 2 - No. pièce Log: 5K0 959 354 Mat: 5K0 959 354
    Pièce: S.Sens.Fahr.V H02 ----
    No. de série: 3572MSME6D714370ZZZY
    Capteur de collision pour sac gonflable latéral; côté passager:
    Sous-système 3 - No. pièce Log: 5K0 959 354 Mat: 5K0 959 354
    Pièce: S.Sens.Beif.V H02 ----
    No. de série: 3582MSME782E5274ZZZ0
    Capt. collis. pr sac gonfl. latéral AR; côté cond.:
    Sous-système 4 - No. pièce Log: 5K0 959 351 A Mat: 5K0 959 351 A
    Pièce: S.Sens.Fahr.H H02 ----
    No. de série: 3516KSME72162E1FZZZ.
    Capt. collis. pr sac gonfl. latéral AR; côté pass.:
    Sous-système 5 - No. pièce Log: 5K0 959 351 A Mat: 5K0 959 351 A
    Pièce: S.Sens.Beif.H H02 ----
    No. de série: 3526KSME611B2E1FZZZ+
    Capt. collis. pr sac gonfl. frontal; côté cond.:
    Sous-système 6 - No. pièce Log: 5K0 959 659 A Mat: 5K0 959 659 A
    Pièce: F.Sens.Fahr H02 ----
    No. de série: 3556LSME13174D17ZZZV
    Capt. collis. pr sac gonfl. frontal; côté pass. AV:
    Sous-système 7 - No. pièce Log: 5K0 959 659 A Mat: 5K0 959 659 A
    Pièce: F.Sens.Beif H02 ----
    No. de série: 3566LSME61054D17ZZZW
    9438747 - Détonateur de rétracteur de ceinture côté passager AV
    B1006 1B [137] - Résistance trop élevée
    Témoin allumé - Confirmé - Testé depuis RàZ mémoire
    Capture:
    Date: 2043.14.03
    Temps: 00:15:51
    9439003 - Détonateur de rétracteur de ceinture - côté passager avant
    B1007 1B [137] - Résistance trop élevée
    Capture:
    Date: 2043.14.03
    Temps: 00:15:51
    9442075 - Détonateur de limiteur d'effort de ceinture côté conducteur
    B1013 1B [137] - Résistance trop élevée
    Capture:
    Date: 2043.14.03
    Temps: 00:15:51
    9442331 - Détonateur de limiteur d'effort de ceinture côté passager avant
    B1014 1B [137] - Résistance trop élevée
    Capture:
    Date: 2043.14.03
    Temps: 00:15:51
    12670208 - Calculateur porte-instruments Aucune communication
    U0155 00 [008] - -
    Capture:
    Fréquence du défaut: 9
    Date: 2043.14.04
    Temps: 06:21:28
    12674816 - Appareil de commande d´antidémarrage
    U0167 00 [008] - Aucune communication
    Capture:
    Date: 2043.14.04
    Temps: 06:21:28
    Adresse 17: Instruments (J285) Labels: Echec redir!
    No. pièce Log: 5C6 920 852 A Mat: 5C6 920 852 A
    Pièce: KOMBI H06 0705
    No. de série: 00000000000000
    Codage: 370E00
    No. Atelier: WSC 00066 000 00122
    Jeu de données ASAM: EV_Kombi_UDS_VDD_RM09 A04716
    VCID: 2952135748E2020
    9453330 - Détecteur de température extérieure
    B103F 1B [009] - Résistance trop élevée
    Capture:
    Compteur de RAZ: 95
    Date: 2043.14.03
    Temps: 01:00:55
    Adresse 19: Gateway CAN (J533) Labels: FRM\6N0-909-901.lbl
    No. pièce Log: 6N0 909 901 Mat: 5C0 937 087 A
    Pièce: GW-K-CAN TP20 H66 0256
    Révision: B2066001
    Codage: 102200
    VCID: F0E4BE3323B8B38
    9 Codes défaut trouvés
    01312 - Bus groupe motopropulseur (GMP)
    Capture:
    Priorité du défaut: 1
    Heure: 0
    Date: 2105.14.16
    Temps: 02:00:30
    Capture:
    Fréquence du défaut: 49
    Heure: 0
    Date: 2105.14.09
    Temps: 00:03:38
    01315 - Calculateur de la boîte de vitesses
    Capture:
    Heure: 0
    Capture:
    Fréquence du défaut: 154
    Kilometrage: 0 km
    Heure: 0
    Date: 2105.14.09
    Temps: 00:17:43
    Capture:
    Heure: 0
    Capture:
    Heure: 0
    01321 - Calculateur d´airbag (J234)
    Capture:
    Fréquence du défaut: 250
    Heure: 0
    Date: 2105.14.09
    Temps: 00:14:57
    01309 - Calculateur d´aide au braquage (J500)
    Capture:
    Fréquence du défaut: 218
    Heure: 0
    00474 - Calculateur d´antidémarrage
    Capture:
    Fréquence du défaut: 64
    Heure: 0
    Adresse 25: Anti-démarrage (J334) Labels: Echec redir!
    No. pièce Log: 5K0 953 234 Mat: 5K0 953 234
    Pièce: IMMO H06 0705
    No. de série:
    Codage: 000007
    Jeu de données ASAM: EV_Immo_UDS_VDD_RM09 A03709
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    VCID: EAD0AC5B0D64498
    9456128 - Calculateur du moteur non autorisé
    B104A 00 [008] - -
    Capture:
    Fréquence du défaut: 52
    Date: 2043.14.03
    Temps: 00:11:25
    9456681 - Clé(s)
    B104C 29 [008] - Signal non plausible
    Capture:
    Date: 2043.14.04
    Temps: 00:00:44
    13762816 - Bus de données
    U1201 00 [008] - Absence de communication
    Capture:
    Date: 2041.14.16
    Temps: 02:00:29
    Adresse 2B: Verr. Col. Direct. (J764) Labels: Aucun
    No. pièce Log: 5K0 905 861 B Mat: 5K0 905 861 B
    Pièce: ELV-PQ35 H20 0240
    Révision: 00000000 No. de série: 12000216455004
    Codage: 4900000000000000
    No. Atelier: WSC 00066 790 50316
    Jeu de données ASAM: EV_ELVMarquMPVW36X A01001
    ROD: EV_ELVMarquMPVW36X.rod
    VCID: 2F66FD4F76066C0
    1049090 - Calculateur bloqué
    B2017 00 [008] - Défaut de signal
    Capture:
    Date: 2041.14.09
    Temps: 00:19:36
    13635840 - Tension d'alimentation
    Capture:
    Date: 2043.14.03
    Temps: 07:31:34
    13893632 - Fonctionnement limité
    Capture:
    Date: 2040.14.22
    Temps: 13:35:56
    1049345 - Bus CAN Confort (SAE: Bus moyenne vitesse)
    U0011 00 [008] - Performance
    Capture:
    Date: 2041.14.00
    Temps: 00:00:40
    12670208 - Fonctionnement limité en raison de l'absence de message
    U1111 00 [008] - -
    Capture:
    Fréquence du défaut: 229
    Kilometrage: 0 km
    Date: 2041.14.09
    Temps: 00:15:04
    12666370 - Fonctionnement limité en raison de l'absence de message
    U1111 00 [008] - -
    Capture:
    Date: 2041.14.09
    Temps: 00:17:59
    Adresse 2E: Lect. multiméd. 3 (J650) Labels: 5N0-035-342.lbl
    No. pièce Log: 5N0 035 342 F Mat: 5N0 035 342 F
    Pièce: SG EXT.PLAYER H18 0546
    Révision: A1001003 No. de série: 7663521210
    Codage: 010100
    VCID: 2A50EC5B45E4098
    4 Codes défaut trouvés
    Capture:
    Kilometrage: 0 km
    Heure: 0
    Capture:
    Heure: 0
    Capture:
    Fréquence du défaut: 34
    Heure: 0
    Date: 2105.14.09
    Temps: 00:13:36
    Capture:
    Fréquence du défaut: 12
    Heure: 0
    Date: 2105.14.09
    Temps: 00:10:44
    Adresse 44: Direction assistée Labels: Echec redir!
    No. pièce: 1K0 909 144 P
    Pièce: EPS_ZFLS Kl. 70 3305
    Révision: 00H22000
    VCID: 3776C52F4656A40
    Capture:
    Heure: 0
    Date: 2105.14.16
    Temps: 02:00:29
    Capture:
    Tension: 11.63 V
    DU
    Température: 33.0°C
    Tr/min: 1498 /min
    Vitesse: 8.0 km/h
    Vitesse: 50.0 km/h
    Décompte: 0
    Capture:
    Heure: 0
    Date: 2107.14.03
    Temps: 00:47:10
    Capture:
    Tension: 12.00 V
    DU
    Température: 29.0°C
    Tr/min: 1498 /min
    Vitesse: 0.0 km/h
    Vitesse: 0.0 km/h
    Décompte: 0
    Capture:
    Heure: 0
    Date: 2107.14.04
    Temps: 00:09:25
    Capture:
    Tension: 12.00 V
    DD
    Température: 31.0°C
    Tr/min: 0 /min
    Vitesse: 0.0 km/h
    Vitesse: 0.0 km/h
    Décompte: 0
    03803 - Transmetteur d'angle de braquage de l'assistance de direction
    005 - Réglage de base / adaptation inexistant ou erroné - Témoin allumé
    Capture:
    Etat du défaut: 11100101
    Heure: 0
    Capture:
    Volts batt.: 12.2 V
    PD
    Température: 25.0°C
    Décompte: 2
    Angle direction: 0.00°
    Décompte: 0
    Braq. pas ini
    Adresse 56: Radio (J503) Labels: Aucun
    No. pièce Log: 1K0 035 180 AF Mat: 1K0 035 180 AF
    Pièce: Radio Prem-8 H04 0008
    Révision: -----08S No. de série: VWZ4Z7M3379124
    Codage: 21000400020006
    VCID: 64CC426367409F8
    5 Codes défaut trouvés
    02635 - Tuner non validé / activé
    000 - -
    Capture:
    Priorité du défaut: 7
    Compteur de RAZ: 95
    Kilometrage: 53657 km
    Heure: 0
    Date: 2031.14.05
    Temps: 11:11:55
    Capture:
    Heure: 0
    Date: 2104.14.25
    Temps: 13:00:22
    02633 - Antenne pour Tuner satellite
    007 - Court-circuit à la masse - Intermittent
    Capture:
    Etat du défaut: 00100111
    Priorité du défaut: 5
    Heure: 0
    Date: 2105.14.09
    Temps: 00:08:58
    00625 - Signal de vitesse
    Capture:
    Heure: 0
    Date: 2105.14.09
    Temps: 00:17:58
    Capture:
    Fréquence du défaut: 11
    Heure: 0
    Date: 2105.14.16
    Temps: 02:00:29
    Adresse 77: Téléphone (J412) Labels: Aucun
    No. pièce Log: 7P6 035 730 K Mat: 7P6 035 730 K
    Pièce: TELEFON H15 3200
    Révision: 1B001001 No. de série: 00007663430565
    Codage: 0310040000010110
    No. Atelier: WSC 94759 999 83929
    Jeu de données ASAM: EV_UHVNA 002720
    ROD: EV_UHVNA_VW36.rod
    VCID: 3A70DC1BBD44B98
    U0155 00 [008] - -
    Capture:
    Date: 2041.14.16
    Temps: 02:00:29
    Capture:
    Date: 2043.14.03
    Temps: 07:40:28
    Capture:
    Date: 2043.14.03
    Temps: 07:40:28
    Fin ---------------------------------------------------------------------
  17. #825
    Jul 2016
    Vilnius
    Well, try this coding then:
    * MK100
  18. The Following User Says Thank You to hid3 For This Useful Post:
    sathicham (16th October, 2017)
