Page 57 of 245 FirstFirst ... 747525354555657585960616267107157 ... LastLast
Results 841 to 855 of 3668
  1. #841
    mobileworks's Avatar
    Buenos Aires
    I tested all but don't work any coding, only one 0000380, but if I change dash coding from USA use in milles.......???
    I from argentine need KM...
    THANKKK, SSS
  2. #842
    Jul 2016
    Vilnius
    So change the dash coding and give it a try
    * MK100
  3. #843
    Buenos Aires
    i will change dash coding ,and run ok , but this proble is, in my country is km!!!!"!!!!!
  4. #844
    Jul 2016
    Vilnius
    Sorry, I don't understand what the actual problem is. Also, whatever it is, I'll probably won't be able to assist as I have absolutely no information on Passat ABS module codings.
    * MK100
  5. #845
    kinketotua's Avatar
    Apr 2016
    Europe
    I need to coding A3 Abs if its posible, thanks
    AUDI A3
    YEAR 2008
    2.0TDI
    WAUZZZ8P29A045464
    1K0907379AD
    LHD FWD
    START STOP NO
    TPMS
    NO ASR BUTTON
    PR: 1AT (I think is these you need...)
  6. #846
    Jul 2016
    Vilnius
    Try this for the Audi:
    11424012092600FF880F02EA901D00422C00
    * MK100
  7. The Following User Says Thank You to hid3 For This Useful Post:
    kinketotua (22nd October, 2017)
  8. #847
    kinketotua's Avatar
    Apr 2016
    Europe
    Works fine!! perfect. thanks hid3
  9. #848
    Hi, please I need a abs coding. The car is:
    Volswagen
    Abs modul: ESP MK60EC1
    Model:Caddy
    Engine: 1.6 Diesel
    Year:2010
    Vin: WV2ZZZ2KZBX218612
    VAg number: 1K0907379BD
  10. #849
    Buenos Aires
    HI i post all information about my passat, produced for latin america (dash only in kilometer)
    VIN: WVWKB83C1AE139422 License Plate: JIM599
    Mileage: 103230km-64144mi Repair Order:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 25 36 42 44 46 52 53 55 56 62 72
    VIN: WVWKB83C1AE139422 Mileage: 103230km-64144miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
    Part No SW: 06J 906 026 FA HW: 06J 907 309
    Component: MED17.5 01 5843
    Revision: AAH16--- Serial number: VWZCZ000000000
    Coding: 0404000C1C070160
    Shop #: WSC 12345 123 45725
    VCID: 6E9003EF790CD93668-803A
    1 Fault Found:
    049493 - No Communication with Instrument Cluster
    U0155 - 000 - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 139645 km
    Time Indication: 0
    Date: 2012.03.11
    Time: 21:57:38
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 45.0°C
    Temperature: 30.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 11.684 V
    Readiness: 1110 0101
    Address 02: Auto Trans Labels: 02E-927-770.clb
    Part No SW: 02E 300 053 A HW: 02E 927 770 AL
    Component: GSG DSG AG6 511 2108
    Revision: 51112 Serial number: 00001003161726
    Coding: 0000020
    Shop #: WSC 05311 000 00000
    VCID: 1366721B32EE54DE27-8046
    No fault code found.
    Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
    Component: J104 C4 440 V2 0015
    Revision: --025--- Serial number: 00000705384087
    Coding: 0000000
    Shop #: WSC 05311 985 00006
    VCID: 628867DFBDD46D56FC-8036
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 35
    Time Indication: 0
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Voltage: 11.50 V
    Bin. Bits: 00011111
    Count: 149
    Hex Value: 0x0000
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
    Component: Climatronic H15 0709
    Revision: 00003001
    Coding: 0000000002
    Shop #: WSC 05311 115 00000
    ASAM Dataset: EV_Climatronic A01006
    ROD: EV_ClimaAutoBasis_VW36.rod
    VCID: 7EB033AFE16CA9B6F8-802A
    1 Fault Found:
    13701456 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 75
    Mileage: 139645 km
    Date: 2017.10.19
    Time: 21:57:38
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
    Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 00000003730763
    Coding: A7868F0700041A00470A00000F000000000B5D435C00012000 0000000000
    Shop #: WSC 05124 000 00000
    VCID: 3326D29B52AEB4DE47-8066
    Subsystem 1 - Part No: 3C1 955 419 B Labels: 1KX-955-119.CLB
    Component: Wischer 130310 006 0208
    Coding: 00046997
    Shop #: WSC 05124
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
    Component: J234__00H VW10 HI 1916
    Revision: 20013000 Serial number: 003E2P5D6EXT
    Coding: 0012360
    VCID: 44C4814707000366EE-8010
    Subsystem 1 - Serial number: 6332MTS638250630
    Subsystem 2 - Serial number: 6342MTS631920620
    Subsystem 3 - Serial number: 6351HTS6LI7T86KJ
    Subsystem 4 - Serial number: 6361HTS6BTCK69KJ
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
    Part No SW: 3C5 953 501 BG HW: 5K0 953 569 T
    Component: LENKS.MODUL 009 0122
    Revision: FF010035 Serial number: 20100318200588
    Coding: 0982270002
    ASAM Dataset: EV_VW360SteerWheelUDS A03002
    ROD: EV_VW360SteerWheelUDS.rod
    VCID: 6B960AFB821E2C1E4F-803E
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
    Labels: 3C8-959-537.CLB
    Component: E221__MFL-TK6 H06 0022
    Coding: E20000
    Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb
    Part No SW: 3C0 920 872 F HW: 3C0 920 872 F
    Component: KOMBI H03 0305
    Coding: 160F00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
    ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
    VCID: 281C35F75368C706E2-807C
    Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
    Part No SW: 3C0 907 530 Q HW: 3C0 907 951
    Component: J533 Gateway H13 0172
    Revision: H13 Serial number: 3620P10320027B
    Coding: FD81FF06000202001002
    Shop #: WSC 05314 000 00000
    VCID: 2F2EDEEBBE86903E23-807A
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 799 H HW: 3C0 959 799 H
    Component: IMMO 071 0383
    Revision: 00071000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 3E30F3AF69EC69B6B8-806A
    Subsystem 1 - Part No: 3C0 905 861 H
    Component: ELV 028 0380
    3C0905861H ELV 028 0380
    Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
    Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
    Component: Sitzverstellung 1101
    Revision: 00005000 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
    Part No SW: 3C0 959 701 A HW: 3C0 959 793 A
    Component: TUER-SG FT 002 0305
    Revision: 12101005 Serial number: 0000630638
    Coding: 0011FF
    ASAM Dataset: EV_DCU42BroseDriveSide A03004
    ROD: EV_DCU42BroseDriveSide.rod
    VCID: 26003BCF597CD176D0-8072
    Slave Driver:
    Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels:
    1K0-959-70X-GEN4.CLB
    Component: J388__TSG-HL 004 0402
    Serial number: 00000001349845
    Coding: 0000D0
    6 Faults Found:
    66048 - Motor for Front Window Regulator
    B11EC 54 [009] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 139529 km
    Date: 2017.09.28
    Time: 02:37:14
    68102 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 75
    Mileage: 139645 km
    Date: 2017.10.19
    Time: 21:57:38
    131584 - Motor for Rear Window Regulator
    B11EE 54 [009] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 139529 km
    Date: 2017.09.28
    Time: 02:37:14
    131842 - Switch for Rear Window Regulator
    B11F2 29 [009] - Signal Implausible
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 139529 km
    Date: 2017.09.28
    Time: 02:37:14
    132610 - Motors for Rear Central Locking
    B122C 01 [009] - Electrical Failure
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 139531 km
    Date: 2017.09.28
    Time: 00:01:26
    132866 - Switch for Rear Central Locking
    B122E 29 [009] - Signal Implausible
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 34
    Reset counter: 35
    Mileage: 139531 km
    Date: 2017.09.28
    Time: 00:01:27
    Address 44: Steering Assist Labels: 5N1-909-144.clb
    Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
    Component: J500__APA-BS KL.148 0703
    Revision: 1AH03726 Serial number: 00100750195501
    Coding: 0000258
    VCID: 3A38FFBF75C4459684-806E
    Address 46: Central Conv. Labels:. 3C0-959-799-46.clb
    Component: 01 KESSY PQ46 R 071 0231
    Coding: 01910A0001C60E76300494157000CF0E70780103242498
    Shop #: WSC 05311 000 08193
    Subsystem 1 - Part No: 1K8 951 605 A
    Component: LIN BACKUP HORN H11 9004
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    1 Fault Found:
    00183 - Interior Access/Start Authorization Antenna 1 (R138)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 4
    Fault Frequency: 4
    Reset counter: 35
    Mileage: 103233 km
    Time Indication: 0
    Date: 2012.03.11
    Time: 14:01:18
    Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
    Part No SW: 3C0 959 702 A HW: 3C0 959 792 A
    Component: TUER-SG BT 002 0305
    Revision: 14101005 Serial number: 0000000659
    Coding: 0011FE
    Shop #: WSC 05311 115 08193
    ASAM Dataset: EV_DCU52BrosePasseSide A03004
    ROD: EV_DCU52BrosePasseSide.rod
    VCID: 271E36CB5E76C87EEB-8072
    Slave Passenger:
    Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels:
    Component: J389__TSG-HR 004 0402
    Serial number: 00000001353550
    Coding: 0000D0
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 139529 km
    Date: 2017.09.28
    Time: 02:37:14
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 75
    Mileage: 139645 km
    Date: 2017.10.19
    Time: 21:57:38
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 139529 km
    Date: 2017.09.28
    Time: 02:37:15
    Address 53: Parking Brake Labels: 5N0-907-801.clb
    Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
    Component: J540 EPB3 VW-15417 0007
    Revision: 010 Serial number: 00000000213499
    Coding: 0000057
    VCID: 2C14C9E78F90EB2606-8078
    Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
    Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
    Component: AFS-Steuergeraet 0142
    Revision: 00H04000 Serial number:
    Coding: 2311361
    VCID: 3424D18757A0B3E65E-8060
    Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
    Component: AFS-Lst.-Modul l 0004
    Coding: 00000035
    Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
    Component: AFS-Lst.-Modul r 0004
    Coding: 00000035
    Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 5K0 035 190 HW: 5K0 035 190
    Component: Radio RCD510 040 0167
    Revision: 00000001 Serial number: VWZ1Z3K3018794
    Coding: 0500041004
    VCID: 628867DF7DD46D56FC-8036
    2 Faults Found:
    00856 - Radio Antenna
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 103233 km
    Time Indication: 0
    Date: 2012.03.11
    Time: 00:00:26
    00821 - Antenna 2 for Radio (R93)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 103233 km
    Time Indication: 0
    Date: 2012.03.11
    Time: 00:00:26
    End----(Elapsed Time: 01:29, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
    Address 01: DTCs cleared
    Address 08: DTCs cleared
    Address 56: DTCs cleared
    Address 46: DTCs clearedThursday,19,October,2017,15:42:17:39900
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 17.8.0.1 HEX-NET CB: 0.4401.4
    Data version: 20170721 DS276.2
    www.Ross-Tech.com
    Dealer/Shop Name: Vw & audi service
    Workshop Code: 985 05311 000006
    01-Engine -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    Coding: 0000020
    Coding: 0000000
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 35
    Time Indication: 0
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0000
    Voltage: 11.50 V
    Bin. Bits: 00011111
    Count: 149
    Hex Value: 0x0000
    Revision: 00003001
    Coding: 0000000002
    Coding: 00046997
    Shop #: WSC 05124
    Coding: 0012360
    Coding: 0982270002
    Coding: E20000
    Coding: 160F00
    Coding: 0011FF
    Slave Driver:
    Coding: 0000D0
    6 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 139529 km
    Date: 2017.09.28
    Time: 02:37:14
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 75
    Mileage: 139645 km
    Date: 2017.10.19
    Time: 21:57:38
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 139529 km
    Date: 2017.09.28
    Time: 02:37:14
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 139529 km
    Date: 2017.09.28
    Time: 02:37:14
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 139531 km
    Date: 2017.09.28
    Time: 00:01:26
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 34
    Reset counter: 35
    Mileage: 139531 km
    Date: 2017.09.28
    Time: 00:01:27
    Coding: 0000258
    Coding: 0011FE
    Slave Passenger:
    Coding: 0000D0
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 139529 km
    Date: 2017.09.28
    Time: 02:37:14
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 75
    Mileage: 139645 km
    Date: 2017.10.19
    Time: 21:57:38
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 139529 km
    Date: 2017.09.28
    Time: 02:37:15
    Coding: 0000057
    Coding: 2311361
    Coding: 00000035
    Coding: 00000035
    Coding: 0500041004
    2 Faults Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 103233 km
    Time Indication: 0
    Date: 2012.03.11
    Time: 15:40:18
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 103233 km
    Time Indication: 0
    Date: 2012.03.11
    Time: 15:40:18
    End----------(Elapsed Time: 01:28, VBatt start/end: 13.7V/13.6V)-----------
  11. #850
    Buenos Aires
    THANKS TO ALL, BUT TIME IS MONEY, MAKE SVM IN OFICIAL DEALER , 2 MINUTES AND RECODE ONLINE..
    SOLVED NOW!!
    if any people need help about specific car ,contact me !!
  12. #851
    Jul 2016
    Vilnius
    Would be nice if you would share the coding for that module. As we don't have any information for those, at least some information would be useful. Thanks.
    * MK100
  13. The Following User Says Thank You to hid3 For This Useful Post:
    serviclau (24th October, 2017)
  14. #852
    rafal's Avatar
    UK - PL
    Quote Originally Posted by serviclau View Post
    Volswagen
    Model:Caddy
    Engine: 1.6 Diesel
    Year:2010
    423C000D09230002001100E5901B0000000000
  15. The Following User Says Thank You to rafal For This Useful Post:
  16. #853
    It's ok.
    Thanks.
  17. #854
    Oct 2017
    Default Hiya
    Quote Originally Posted by vagva View Post
    I am really new to this Forum , So I can provide to member Long coding for ABS for VAG MK60
    Always send me VIN , you Must read it from 17- instrument
    and will send you long Coding Free
    Thanks to you All
    Hi are you still avaliable to help with long coding?
  18. #855
    Oct 2017
    If so could you help with this VSSZZZ1PZCR027992
