Page 6 of 245 FirstFirst 12345678910111656106 ... LastLast
Results 76 to 90 of 3668
  1. #76
    Jul 2016
    Vilnius
    Hello marcin,
    please try the following coding (assuming your car ir LHD):
    113B200D092A00FA881304EA901E0041310000
    * MK100
  2. The Following User Says Thank You to hid3 For This Useful Post:
    marcin7091 (12th September, 2016)
  3. #77
    Mar 2016
    Tanks Coding working.. Now I have error: 00003 end 01044
  4. #78
    Jul 2016
    Vilnius
    Can you please provide full autoscan of the car in question (send it to PM).
    Thanks.
    * MK100
  5. The Following User Says Thank You to hid3 For This Useful Post:
    kamolsfss (6th October, 2019)
  6. #79
    Netherlands
    I need help in coding ABS unit:
    Audi A3 8P 2010
    2.0 TFSI (CBF)
    VIN: WAUKEAFMXAA112808
    autoscan from VCDS:
    impossible is nothing...
  7. The Following User Says Thank You to poki123 For This Useful Post:
  8. #80
    Jul 2016
    Vilnius
    please try this coding:
    11424012092300FC881302E490210041390800
    * MK100
  9. #81
    Netherlands
    Hello
    coding no accepted.
    Error 31 Requested out of range
    in attachment sticker with car configuration.
  10. #82
    Jul 2016
    Vilnius
    Hm...
    How about this one?
    11426012092300FC881306E490210041390000
    * MK100
  11. #83
    Netherlands
    Quote Originally Posted by hid3 View Post
    Hm...
    How about this one?
    coding not accepted
    this car was imported from USA
  12. #84
    Netherlands
    any another idea ...
  13. #85
    Jul 2016
    Vilnius
    Yeah, I see it's from USA.
    Any background on the story? What has happened to the original coding? Maybe the module was replaced?
    Meanwhile please try this:
    1142600F092300FC881306E490210041390000
    * MK100
  14. #86
    Netherlands
    Background is that I take this car without instrument claster and immo bypass in engine ECU
    sombody was here before me Every thin is done excl. ABS coding
  15. #87
    Jul 2016
    Vilnius
    Sorry, I've just edited my original message and you replied...
    Please try this coding:
    * MK100
  16. #88
    Jul 2016
    Vilnius
    Also, you're telling that the ECU is altered, the instrument cluster was missing. Could you please look up the VIN number in the blocks (Engine, Instruments, etc). Should be somewhere available among Measuring Blocks. It might be that the ECU and/or cluster might belong to different car and different VIN might be coded there
    * MK100
  17. #89
    Jul 2016
    Vilnius
    Sorry for repeated numerous posts but some hint here: if you are using VCDS, go to "Advanced ID" function and check VIN there. Check for both, Engine and Instruments. Check every digit and letter. Make sure everything matches. If it doesn't, post the recorded VIN(s) in those blocks.
    * MK100
  18. #90
    Netherlands
    every think looks good:
