Hi All,
I tried fix this Skoda, the story, some times ( random ) flashing the ABS and hand brake lights and give error code in ABS vacum sensor lower limit exceeded - intermittent I was changed the sensor (original )
but not good, I check all pipes by vacum mesure, and wires too all is good. Could someone make coding without vacum sensor ,
thank you, Istvan
so where is the fault code? The scan you have provided shows absolutely no faults.
* MK100;
jaca1232 (13th January, 2018)
sorry now was cleared, the fault only abs
What do you mean the fault only ABS? Could you please be more specific? I don't understand what the problem is..
* MK100;
this is fault in abs. sorry my english is not the best
hi i need long coding for abs
vw touran
2014
1.6 tdi
automatique gearbox
vin wvgzzz1tzfw000673
thank you
Hello need a long code for Audi a3 RHD. 1.6 petrol WAUZZZ8P39A021089
Išsiųsta naudojantis F8331 Tapatalk 4 Lt
Hi the coding for the abs on a audi a3 has erased.
Hi, please help with ABS long coding Audi A3 2010 tdi
Removed dash and lost codding on ABS, now all 000000000000000000
Please help ....... Can donate some , for working solution (its urgent for me)
You naughty boy, rolling back odometers is a crime in Lithuania
See PM.
* MK100;
try that one: 11424012092500FC881102E7901F0041390800
Hi, please help with ABS(1K0907379BJ) long coding WV Jetta 2.0TDI vin 3VWLL7AJ4BM035273
Dear,
I would like to thank you in advance for helping me.
I am looking for Audi A1 1.6 TDI SE ABS Long Code as the information as Follows:
Audi A1 1.6 TDI SE
Year 2011
ABS Moudle: 6R0 907 379 BB 001
6R0 907 379 AH 007
VIN: WAUZZZ8X1CB011890
Start & Stop Button: yes
ESP 8.2i Front H07c001
TPMS
RHD
Thursday,18,January,2018,11:33:18:53046
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
VIN: WAUZZZ8X1CB011890 License Plate: AUDI A1
Chassis Type: 8X (8U0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 KQ HW: 03L 906 023 KP
Component: 1,6L R4 CR td H63 8530
Revision: --H63--- Serial number:
Coding: 00114016030501080000
Shop #: WSC 00046 790 00000
ASAM Dataset: EV_ECM16TDI02103L906023KQ 003009
ROD: EV_ECM16TDI02103L906023KG.rod
VCID: 7F0B753BE6324AD9175-802A
2 Faults Found
7332 - Mass Air Flow Sensor (G70)
P0103 00 [165] - Signal too High
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 101243 km
Date: 2018.01.13
Time: 07:43:44
7196 - Function Restriction due to Faults in Other Modules
U1113 00 [101] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 101243 km
Date: 2018.01.13
Time: 07:43:44
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH
Component: ESP8.2i front H07 0001
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 00046 000 00000
VCID: 7F0B753BEA324AD9175-802A
3 Faults Found
03306 - Coding Not Valid
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 61
Mileage: 101411 km
Time Indication: 0
Date: 2018.01.13
Time: 06:40:56
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1209
Hex Value: 0x1495
Hex Value: 0x007C
Hex Value: 0x7F7F
Hex Value: 0x7F00
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 61
Mileage: 101411 km
Time Indication: 0
Date: 2018.01.13
Time: 06:40:56
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1211
Hex Value: 0x1495
Hex Value: 0x007C
Hex Value: 0x7F7F
Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 3
Reset counter: 61
Mileage: 101411 km
Time Indication: 0
Date: 2018.01.13
Time: 06:40:56
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12E1
Hex Value: 0x2095
Hex Value: 0x007C
Hex Value: 0x7F7F
Hex Value: 0x7F00
Address 08: Auto HVAC Labels: None
Part No SW: 8X0 820 045 HW: 8X0 820 045
Component: J255 Klima Manuell 0140
Revision: 0000707S Serial number: 03030005009074
VCID: 73E3A90B127A1EB963D-8026
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 8X0-907-063.clb
Part No SW: 8X0 907 063 F HW: 8X0 907 063 F
Component: BCM PQ35 B 110 0653
Revision: 00110 AD
Coding: 0E000A2CA805F100201841E00000005443836C0A00CF4122DC 0087830041
VCID: 3F8B353BAEB28AD9575-806A
Subsystem 1 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 15: Airbags (J234) Labels: 8X0-959-655.clb
Part No SW: 8X0 959 655 A HW: 8X0 959 655 A
Component: Airbag10.41 H04 0008
Revision: -------- Serial number: 003JJ002J3K%
Coding: 30314539303330303034554A305238583053
ASAM Dataset: EV_Airba1041BPAAU210 001015
ROD: EV_Airba1041BPAAU210.rod
VCID: 48992EE7F37CCD61E6F-801D
Crash sensor for side airbag; driver side:
Serial number: 3554VRB405D0I3GU7OTK
Crash sensor for side airbag; front passenger side:
Serial number: 3575HRB404P0INGS40E$
Crash sensor for front airbag; driver side:
Serial number: 3585HRB40570ISD468OL
Rear Impact Crash Sensor:
Serial number: 3515ZRB40670GR36FHP+
Address 16: Steering wheel (J527) Labels: 8X0-953-569.clb
Part No SW: 8X0 953 501 HW: 5K0 953 569 F
Component: LENKS.MODUL 014 0140
Revision: FF010016 Serial number: 20110620300092
Coding: 1180004000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 77FB9D1BCE0272995F5-8022
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 HW: 8U0 907 468
Component: GAT 5CAN 1LIN H10 0043
Revision: 1Q030021 Serial number: 2141Q11610826E
Coding: FB0F005A000100010153
VCID: 7F0B753BEE324AD9175-802A
Subsystem 1 - Part No SW: 8K0 915 181 H HW: 8K0 915 181 H
Component: J367-BDM H07 0171
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
1 Fault Found
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 4
Reset counter: 101
Mileage: 101406 km
Time Indication: 0
Date: 2018.01.02
Time: 02:20:38
Freeze Frame:
Bin. Bits: 11000
Voltage: 12.10 V
Count: 18
Address 25: Immobilizer (J334) Labels: Redir Fail!
Part No SW: 8X0 920 950 B HW: 8X0 920 950 B
Component: IMMO H02 0179
Serial number:
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
ROD: EV_Immo_UDS_VDD_AU10.rod
VCID: 3B73412BB2AA96F97BD-806E
Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
Part No SW: 8X0 959 793 B HW: 8X0 959 793 B
Component: TSG FA H09 0409
Revision: -------- Serial number: --------------
Coding: 011802200101000100
VCID: 4C9112F7EF042141C27-8019
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11251
Shop #: WSC 00046
VCID: 2F6B657BEAD27A59C75-807A
Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
Part No SW: 8X0 959 792 B HW: 8X0 959 792 B
Component: TSG BF H09 0409
VCID: 4B9311EBEA0A2679CBD-801E
Address 56: Radio (R) Labels: None
Part No SW: 8X0 035 180 D HW: 8X0 035 180 D
Component: RMC H51 0717
Serial number: AUZ4Z1L1173266
Coding: 01010000000011070002000003010000010000
VCID: 356757139C8E40898D9-8060
Subsystem 1 - Part No SW: 8X0 919 603 HW: 8X0 919 603
Component: DU6 Basic H42 0084
1 Fault Found
03454 - Functional Restriction due to Implausible Signal
Freeze Frame:
Fault Priority: 6
Fault Frequency: 23
Reset counter: 101
Mileage: 101411 km
Time Indication: 0
Date: 2018.01.16
Time: 02:34:34
Freeze Frame:
Voltage: 10.80 V
Bin. Bits: 00000000 00000100
End-------------------------(Elapsed Time: 02:52)--------------------------
Best Regards,
Waliduk
Hi...
These modules are mystery for me.
Try this code:
330448E9436E00B3CC2D12EBC2D100820F00
* MK100;
