Page 64 of 245 FirstFirst ... 1454596061626364656667686974114164 ... LastLast
Results 946 to 960 of 3668
  1. #946
    Feb 2016
    Default Audi A1 1.6 TDI SE ABS Long Code
    Dear,
    I would like to thank you in advance for helping me.
    I am looking for Audi A1 1.6 TDI SE ABS Long Code as the information as Follows:
    Audi A1 1.6 TDI SE
    Year 2011
    ABS Moudle: 6R0 907 379 BB 001
    6R0 907 379 AH 007
    VIN: WAUZZZ8X1CB011890
    Start & Stop Button: yes
    ESP 8.2i Front H07c001
    TPMS
    RHD
    Thursday,18,January,2018,11:33:18:53046
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 14.10.2.0
    Data version: 20150311
    www.Ross-Tech.com
    VIN: WAUZZZ8X1CB011890 License Plate: AUDI A1
    Chassis Type: 8X (8U0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 KQ HW: 03L 906 023 KP
    Component: 1,6L R4 CR td H63 8530
    Revision: --H63--- Serial number:
    Coding: 00114016030501080000
    Shop #: WSC 00046 790 00000
    ASAM Dataset: EV_ECM16TDI02103L906023KQ 003009
    ROD: EV_ECM16TDI02103L906023KG.rod
    VCID: 7F0B753BE6324AD9175-802A
    2 Faults Found
    7332 - Mass Air Flow Sensor (G70)
    P0103 00 [165] - Signal too High
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 101243 km
    Date: 2018.01.13
    Time: 07:43:44
    7196 - Function Restriction due to Faults in Other Modules
    U1113 00 [101] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Mileage: 101243 km
    Date: 2018.01.13
    Time: 07:43:44
    Readiness: 1110 1000
    Address 03: ABS Brakes (J104) Labels: Redir Fail!
    Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH
    Component: ESP8.2i front H07 0001
    Revision: --------
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 00046 000 00000
    VCID: 7F0B753BEA324AD9175-802A
    3 Faults Found
    03306 - Coding Not Valid
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 61
    Mileage: 101411 km
    Time Indication: 0
    Date: 2018.01.13
    Time: 06:40:56
    Freeze Frame:
    Hex Value: 0x0007
    Hex Value: 0x0002
    Hex Value: 0x1209
    Hex Value: 0x1495
    Hex Value: 0x007C
    Hex Value: 0x7F7F
    Hex Value: 0x7F00
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 61
    Mileage: 101411 km
    Time Indication: 0
    Date: 2018.01.13
    Time: 06:40:56
    Freeze Frame:
    Hex Value: 0x0007
    Hex Value: 0x0002
    Hex Value: 0x1211
    Hex Value: 0x1495
    Hex Value: 0x007C
    Hex Value: 0x7F7F
    Hex Value: 0x7F00
    00493 - ESP-Sensor Unit (G419)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 61
    Mileage: 101411 km
    Time Indication: 0
    Date: 2018.01.13
    Time: 06:40:56
    Freeze Frame:
    Hex Value: 0x0007
    Hex Value: 0x0002
    Hex Value: 0x12E1
    Hex Value: 0x2095
    Hex Value: 0x007C
    Hex Value: 0x7F7F
    Hex Value: 0x7F00
    Address 08: Auto HVAC Labels: None
    Part No SW: 8X0 820 045 HW: 8X0 820 045
    Component: J255 Klima Manuell 0140
    Revision: 0000707S Serial number: 03030005009074
    VCID: 73E3A90B127A1EB963D-8026
    No fault code found.
    Address 09: Cent. Elect. (J519) Labels: 8X0-907-063.clb
    Part No SW: 8X0 907 063 F HW: 8X0 907 063 F
    Component: BCM PQ35 B 110 0653
    Revision: 00110 AD
    Coding: 0E000A2CA805F100201841E00000005443836C0A00CF4122DC 0087830041
    VCID: 3F8B353BAEB28AD9575-806A
    Subsystem 1 - Part No: 8X0 951 177
    Component: DWA-Sensor H0 H01 0020
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Address 15: Airbags (J234) Labels: 8X0-959-655.clb
    Part No SW: 8X0 959 655 A HW: 8X0 959 655 A
    Component: Airbag10.41 H04 0008
    Revision: -------- Serial number: 003JJ002J3K%
    Coding: 30314539303330303034554A305238583053
    ASAM Dataset: EV_Airba1041BPAAU210 001015
    ROD: EV_Airba1041BPAAU210.rod
    VCID: 48992EE7F37CCD61E6F-801D
    Crash sensor for side airbag; driver side:
    Serial number: 3554VRB405D0I3GU7OTK
    Crash sensor for side airbag; front passenger side:
    Serial number: 3575HRB404P0INGS40E$
    Crash sensor for front airbag; driver side:
    Serial number: 3585HRB40570ISD468OL
    Rear Impact Crash Sensor:
    Serial number: 3515ZRB40670GR36FHP+
    Address 16: Steering wheel (J527) Labels: 8X0-953-569.clb
    Part No SW: 8X0 953 501 HW: 5K0 953 569 F
    Component: LENKS.MODUL 014 0140
    Revision: FF010016 Serial number: 20110620300092
    Coding: 1180004000
    ASAM Dataset: EV_VW360SteerWheelUDS A03004
    ROD: EV_VW360SteerWheelUDS.rod
    VCID: 77FB9D1BCE0272995F5-8022
    Address 17: Instruments
    Cannot be reached
    Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
    Part No SW: 8U0 907 468 HW: 8U0 907 468
    Component: GAT 5CAN 1LIN H10 0043
    Revision: 1Q030021 Serial number: 2141Q11610826E
    Coding: FB0F005A000100010153
    VCID: 7F0B753BEE324AD9175-802A
    Subsystem 1 - Part No SW: 8K0 915 181 H HW: 8K0 915 181 H
    Component: J367-BDM H07 0171
    Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
    Component: J532_DCDCStab H17 0042
    1 Fault Found
    03041 - Energy Management Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 4
    Reset counter: 101
    Mileage: 101406 km
    Time Indication: 0
    Date: 2018.01.02
    Time: 02:20:38
    Freeze Frame:
    Bin. Bits: 11000
    Voltage: 12.10 V
    Count: 18
    Address 25: Immobilizer (J334) Labels: Redir Fail!
    Part No SW: 8X0 920 950 B HW: 8X0 920 950 B
    Component: IMMO H02 0179
    Serial number:
    Coding: 000002
    ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
    ROD: EV_Immo_UDS_VDD_AU10.rod
    VCID: 3B73412BB2AA96F97BD-806E
    Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
    Part No SW: 8X0 959 793 B HW: 8X0 959 793 B
    Component: TSG FA H09 0409
    Revision: -------- Serial number: --------------
    Coding: 011802200101000100
    VCID: 4C9112F7EF042141C27-8019
    Address 44: Steering Assist Labels: 6Q0-423-156.clb
    Part No: 6R0 423 156 B
    Component: LenkhilfeTRW V277
    Coding: 11251
    Shop #: WSC 00046
    VCID: 2F6B657BEAD27A59C75-807A
    Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
    Part No SW: 8X0 959 792 B HW: 8X0 959 792 B
    Component: TSG BF H09 0409
    VCID: 4B9311EBEA0A2679CBD-801E
    Address 56: Radio (R) Labels: None
    Part No SW: 8X0 035 180 D HW: 8X0 035 180 D
    Component: RMC H51 0717
    Serial number: AUZ4Z1L1173266
    Coding: 01010000000011070002000003010000010000
    VCID: 356757139C8E40898D9-8060
    Subsystem 1 - Part No SW: 8X0 919 603 HW: 8X0 919 603
    Component: DU6 Basic H42 0084
    1 Fault Found
    03454 - Functional Restriction due to Implausible Signal
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 23
    Reset counter: 101
    Mileage: 101411 km
    Time Indication: 0
    Date: 2018.01.16
    Time: 02:34:34
    Freeze Frame:
    Voltage: 10.80 V
    Bin. Bits: 00000000 00000100
    End-------------------------(Elapsed Time: 02:52)--------------------------
    Best Regards,
    Waliduk
  2. #947
    Jul 2016
    Vilnius
    Oh, I see the problem:
    Cannot be reached
    It seems that your Instruments cluster is not reachable? Why? You need to fix that first before coding ABS. Othervise, coding of the ABS is impossible, as it must communicate with Instrument cluster module.
    * MK100
  3. #948
    khalilo_de's Avatar
    Hi need coding abs unit mk60ec1
    Vw caddy
    Year 2012
    Engine : 1.6 tdi type CAYD
    Vin : WV2ZZZ2KZDX072423
    Left hand drive
    Gearbox : manual 5 speed
    Abs : MK60EC1 1K0 907 379 BL
    No tpms
    No star/stop
    Disk diameter should be standard
    Envoyé de mon SM-G955F en utilisant Tapatalk
  4. #949
    khalilo_de's Avatar
    Quote Originally Posted by khalilo_de View Post
    Vw caddy
    Year 2012
    Left hand drive
    No tpms
    No star/stop
    Problem solved
  5. #950
    Default vw cady long coding abs hlp
    need long coding abs ca
    vw cady
    year 2011
    engine 1.6 tdi
    left hand drive
    esp boton
    abs nr 1K0907379BH
    vin WV1ZZZ2KZCX088739
    THANKS
  6. #951
    Default i read full scan
    y,2018,11:04:56:62939
    VCDS Version: 12.12.0.0
    Data version: 20130910
    VIN: WV1ZZZ2KZCX088739 License Plate:
    Chassis Type: 2K (7N0)
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    Address 01: Engine (J623-CAYE) Labels: 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 PA HW: 03L 907 425 C
    Component: 1,6l R4 CR td H43 4989
    Revision: --H43--- Serial number: 00000000000000
    Coding: 00114014032400080000
    Shop #: WSC 35110 790 50316
    ASAM Dataset: EV_ECM16TDI02103L 003007
    ROD: N/A
    VCID: 74E73A5BDF4EF4BE80B-8021
    No ASAM data for: "EV_ECM16TDI02103L" (VW36 *)
    4 Faults Found:
    7286 - ROD - Unknown Error Code
    - 00 [101]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 140452 km
    Date: 2057.14.14
    Time: 02:33:00
    7332 - ROD - Unknown Error Code
    - 00 [173]
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 140452 km
    Date: 2057.14.14
    Time: 02:31:28
    6082 - ROD - Unknown Error Code
    - 00 [045]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 23
    Mileage: 140452 km
    Date: 2057.14.14
    Time: 02:31:28
    16856 - ROD - Unknown Error Code
    - 00 [173]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 140452 km
    Date: 2057.14.14
    Time: 02:31:28
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BH HW: 1K0 907 379 BH
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 00000000000000000000000000000000000000
    Shop #: WSC 35110 377 00142
    VCID: 79F90B6FF02C89D6D3D-802C
    7 Faults Found:
    00668 - Supply Voltage Terminal 30
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 1
    Fault Frequency: 3
    Reset counter: 174
    Mileage: 140097 km
    Time Indication: 0
    Freeze Frame:
    Count: 16391
    Count: 0
    Count: 4096
    Count: 129
    Count: 60416
    Count: 0
    Count: 512
    Count: 0
    00526 - Brake Light Switch-F
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 28
    Reset counter: 177
    Mileage: 139659 km
    Time Indication: 0
    Date: 2052.14.04
    Time: 22:47:52
    Freeze Frame:
    Count: 16391
    Count: 32768
    Count: 13056
    Count: 148
    Count: 49666
    Count: 0
    Count: 0
    Count: 0
    01435 - Brake Pressure Sensor 1 (G201)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 137
    Mileage: 139741 km
    Time Indication: 0
    Date: 2052.14.21
    Time: 00:20:03
    Freeze Frame:
    Count: 16391
    Count: 2
    Count: 4608
    Count: 274
    Count: 43776
    Count: 0
    Count: 0
    Count: 4352
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 90
    Mileage: 140097 km
    Time Indication: 0
    Freeze Frame:
    Count: 16391
    Count: 0
    Count: 4096
    Count: 195
    Count: 60416
    Count: 0
    Count: 512
    Count: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 90
    Mileage: 127961 km
    Time Indication: 0
    Date: 2008.14.21
    Time: 00:01:36
    Freeze Frame:
    Count: 16391
    Count: 2
    Count: 4608
    Count: 279
    Count: 39936
    Count: 0
    Count: 0
    Count: 0
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 90
    Mileage: 127961 km
    Time Indication: 0
    Date: 2008.14.21
    Time: 00:01:36
    Freeze Frame:
    Count: 16391
    Count: 2
    Count: 4608
    Count: 295
    Count: 39936
    Count: 0
    Count: 0
    Count: 0
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 90
    Mileage: 127961 km
    Time Indication: 0
    Date: 2008.14.21
    Time: 00:01:36
    Freeze Frame:
    Count: 16391
    Count: 2
    Count: 4608
    Count: 270
    Count: 39936
    Count: 0
    Count: 0
    Count: 0
    Address 08: Auto HVAC (J301) Labels: 7N0-907-426.clb
    Part No SW: 7N0 907 426 AT HW: 7N0 907 426 AT
    Component: AC Manuell H19 0304
    Revision: 00001016
    Coding: 0000004002
    ASAM Dataset: EV_ACManueBHBVW36X A01010
    ROD: EV_ACManueBHBVW36X_SE36.rod
    VCID: 8603F09339D2762E2EF-80D3
    4 Faults Found:
    9473810 - Motor for Temperature Flap
    B108F 12 [009] - Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 137
    Mileage: 140452 km
    Date: 2057.14.15
    Time: 04:45:52
    9477394 - Motor for Air Distribution Flap
    B109D 12 [009] - Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 137
    Mileage: 140452 km
    Date: 2057.14.15
    Time: 04:45:52
    9474578 - Motor for Recirculation Flap
    B1092 12 [009] - Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 137
    Mileage: 140452 km
    Date: 2057.14.15
    Time: 04:45:52
    9481748 - High Pressure Sensor
    B10AE 14 [009] - Open or Short to Ground
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 137
    Mileage: 140452 km
    Date: 2057.14.15
    Time: 04:45:52
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 085 R HW: 5K0 937 085 R
    Component: BCM PQ35 B+ 021 0064
    Revision: BB021001
    Coding: 411A583A80251A290880008290000064030172885202806064 8000000040
    VCID: 428BAC83DD7A0A0EC27-8017
    Subsystem 1 - Part No: 1T1 955 119 A Labels: 1KX-955-119.CLB
    Component: Wischer 22101 26 0512
    Coding: 009795
    4 Faults Found:
    00153 - Windshield Wiper Motor; Driver Side (V216)
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 177
    Mileage: 140452 km
    Time Indication: 0
    Date: 2057.14.15
    Time: 06:17:18
    Freeze Frame:
    Term 15 On
    Voltage: 9.25 V
    ON
    ON
    OFF
    OFF
    OFF
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 177
    Mileage: 140452 km
    Time Indication: 0
    Date: 2057.14.15
    Time: 06:16:53
    Freeze Frame:
    Term 15 On
    Voltage: 7.00 V
    ON
    OFF
    OFF
    OFF
    OFF
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 177
    Mileage: 140452 km
    Time Indication: 0
    Date: 2057.14.15
    Time: 06:20:30
    Freeze Frame:
    Term 15 On
    Voltage: 8.20 V
    ON
    OFF
    OFF
    OFF
    OFF
    01504 - Bulb for License-Plate Light (X)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 137
    Mileage: 140452 km
    Time Indication: 0
    Date: 2057.14.15
    Time: 06:01:34
    Freeze Frame:
    Term 15 On
    Voltage: 10.55 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
    Component: VW10Airbag024 H06 0013
    Revision: -------- Serial number: 003HL0097TTT
    Coding: 000000000000000000000000000000003234
    ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
    ROD: EV_AirbaVW10BPAVN750_VN35.rod
    VCID: 3561C75F94B4ADB6775-8060
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 1K5 953 507 M HW: 5K0 953 549
    Component: Lenks.Modul 008 0080
    Revision: -------- Serial number: 90440KL20008V
    Coding: 0080060000
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS.rod
    VCID: 3B75D167B2907BC6811-806E
    1 Fault Found:
    136194 - Supply voltage
    U1011 00 [008] - Voltage too Low
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 177
    Mileage: 140452 km
    Date: 2057.14.15
    Time: 06:19:27
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 2K0 920 865 E HW: 2K0 920 865 E
    Component: KOMBI H03 0606
    Coding: 180001
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
    ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
    VCID: 306FF64B6BD6889E243-8065
    1 Fault Found:
    13635840 - Supply voltage
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 177
    Mileage: 140452 km
    Date: 2057.14.15
    Time: 06:19:26
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 M HW: 1K0 907 951
    Component: J533 Gateway H42 1623
    Revision: H42 Serial number: 051211F2001014
    Coding: 357400
    VCID: 3A7BD463B5AA42CE9A7-806F
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 177
    Mileage: 140452 km
    Time Indication: 0
    Date: 2057.14.15
    Time: 06:20:22
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H03 0606
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
    ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
    VCID: EADBA4230D8AB24EAA7-80BF
    Address 42: Door Elect, Driver Labels: 1K0-959-793.lbl
    Part No: 1K0 959 793
    Component: Tuersteuergeraet 73 0159
    Coding: 0000000
    VCID: F6E38053813266AE3EF-80A3
    1 Fault Found:
    01811 - Supply Voltage for Door Controller; Drivers Side (J386)
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 N
    Component: EPS_ZFLS Kl. 140 3301
    Revision: 00H22000
    VCID: 3561C75F5CB4ADB6775-8060
    Address 52: Door Elect, Pass. Labels: 1K0-959-792.lbl
    Part No: 1K0 959 792
    Component: Tuersteuergeraet 02 0159
    Coding: 0000000
    VCID: F5E1875F9C346DB6375-80A0
    1 Fault Found:
    01812 - Supply Voltage for Door Controller; Pass. Side (J387)
    End ---------------------------------------------------------------------
  7. #952
    Jan 2017
    could you help me with my engine change from 1.4 TSI to 2.0 TSI from GTI in Scirocco MY 2010?
    I changed also the ABS Block, now the originale Block from the GTI is inside.
    1. ABS Module: 1K0 907 379 BE (ESP MK60 EC1)
    2. Scirocco 2.0 TSI
    3. Year: 2010
    4. WVWZZZ13ZBV008687
    5. Left Hand
    6. 2.0 TSI gas
    7. FWD
    8. 1.4 TSI and 2.0 TSI have the same as the GTI
    9. No Start/Stop
    10. No TPMS
    11. ESP Button
    12. No Hill Hold
    I thank you so much for your help, because everything is running except ABS/ESP...
    I have the ABS coding module from VCP, I think this is okay for coding, right?
  8. #953
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by gogoli View Post
    ROD: N/A
    4 Faults Found:
    - 00 [101]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 140452 km
    Date: 2057.14.14
    Time: 02:33:00
    - 00 [173]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 140452 km
    Date: 2057.14.14
    Time: 02:31:28
    - 00 [045]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 23
    Mileage: 140452 km
    Date: 2057.14.14
    Time: 02:31:28
    - 00 [173]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 140452 km
    Date: 2057.14.14
    Time: 02:31:28
    Revision: 00H31001
    7 Faults Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 3
    Reset counter: 174
    Mileage: 140097 km
    Time Indication: 0
    Freeze Frame:
    Count: 16391
    Count: 0
    Count: 4096
    Count: 129
    Count: 60416
    Count: 0
    Count: 512
    Count: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 28
    Reset counter: 177
    Mileage: 139659 km
    Time Indication: 0
    Date: 2052.14.04
    Time: 22:47:52
    Freeze Frame:
    Count: 16391
    Count: 32768
    Count: 13056
    Count: 148
    Count: 49666
    Count: 0
    Count: 0
    Count: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 137
    Mileage: 139741 km
    Time Indication: 0
    Date: 2052.14.21
    Time: 00:20:03
    Freeze Frame:
    Count: 16391
    Count: 2
    Count: 4608
    Count: 274
    Count: 43776
    Count: 0
    Count: 0
    Count: 4352
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 90
    Mileage: 140097 km
    Time Indication: 0
    Freeze Frame:
    Count: 16391
    Count: 0
    Count: 4096
    Count: 195
    Count: 60416
    Count: 0
    Count: 512
    Count: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 90
    Mileage: 127961 km
    Time Indication: 0
    Date: 2008.14.21
    Time: 00:01:36
    Freeze Frame:
    Count: 16391
    Count: 2
    Count: 4608
    Count: 279
    Count: 39936
    Count: 0
    Count: 0
    Count: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 90
    Mileage: 127961 km
    Time Indication: 0
    Date: 2008.14.21
    Time: 00:01:36
    Freeze Frame:
    Count: 16391
    Count: 2
    Count: 4608
    Count: 295
    Count: 39936
    Count: 0
    Count: 0
    Count: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 90
    Mileage: 127961 km
    Time Indication: 0
    Date: 2008.14.21
    Time: 00:01:36
    Freeze Frame:
    Count: 16391
    Count: 2
    Count: 4608
    Count: 270
    Count: 39936
    Count: 0
    Count: 0
    Count: 0
    Revision: 00001016
    Coding: 0000004002
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 137
    Mileage: 140452 km
    Date: 2057.14.15
    Time: 04:45:52
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 137
    Mileage: 140452 km
    Date: 2057.14.15
    Time: 04:45:52
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 137
    Mileage: 140452 km
    Date: 2057.14.15
    Time: 04:45:52
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 137
    Mileage: 140452 km
    Date: 2057.14.15
    Time: 04:45:52
    Revision: BB021001
    Coding: 009795
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 177
    Mileage: 140452 km
    Time Indication: 0
    Date: 2057.14.15
    Time: 06:17:18
    Freeze Frame:
    Term 15 On
    Voltage: 9.25 V
    ON
    ON
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 177
    Mileage: 140452 km
    Time Indication: 0
    Date: 2057.14.15
    Time: 06:16:53
    Freeze Frame:
    Term 15 On
    Voltage: 7.00 V
    ON
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 177
    Mileage: 140452 km
    Time Indication: 0
    Date: 2057.14.15
    Time: 06:20:30
    Freeze Frame:
    Term 15 On
    Voltage: 8.20 V
    ON
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 137
    Mileage: 140452 km
    Time Indication: 0
    Date: 2057.14.15
    Time: 06:01:34
    Freeze Frame:
    Term 15 On
    Voltage: 10.55 V
    ON
    ON
    OFF
    OFF
    OFF
    Coding: 0080060000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 177
    Mileage: 140452 km
    Date: 2057.14.15
    Time: 06:19:27
    Coding: 180001
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 177
    Mileage: 140452 km
    Date: 2057.14.15
    Time: 06:19:26
    Coding: 357400
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 177
    Mileage: 140452 km
    Time Indication: 0
    Date: 2057.14.15
    Time: 06:20:22
    Coding: 000000
    Coding: 0000000
    1 Fault Found:
    Revision: 00H22000
    Coding: 0000000
    1 Fault Found:
    Hi Mate
    did you read the Title of this Thread , ITS JUST FOR MK60
  9. #954
    Jul 2016
    Vilnius
    His is MK60EC1, so everything is alright...
    * MK100
  10. #955
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by Tabaluga View Post
    2. Scirocco 2.0 TSI
    3. Year: 2010
    5. Left Hand
    6. 2.0 TSI gas
    7. FWD
    9. No Start/Stop
    10. No TPMS
    11. ESP Button
    12. No Hill Hold
    Here is your Long Coding : 763B40F5492200026E1102EC92200092350000
    thank and Rep please
  11. #956
    Jun 2013
    Hallo i need long coding ABS
    Golf VI, 1.4mpi, 2009 motor CGGA
    ESP MK60EC1, 1K0 907 379 CD
    WVWZZZ1KZAW186896
    LHD
    front break 1ZF
    I thank you so much for Your help.
  12. #957
    Jun 2013
    I coded this
    143B200D212A0000281304ED841F00403000
    all ok but 2 error stayed
    03366 - vac sensor
    012 - electric error
    auto is MPI without vac sensor in servo
  13. #958
    vagva's Avatar
    Apr 2016
    vw cady
    year 2011
    engine 1.6 tdi
    left hand drive
    esp boton
    abs nr 1K0907379BH
    THANKS
    here is your Long Coding : 433C400D092A0302C21202E79022C081300000
    OR: 423C400D092A0302421202E79022C041300000
    if everything is OK just push Magic Buttons { thanks and Rep }
  14. #959
    Jan 2018
    Need long coding please
    2011
    Vw scirocco 1.4 tsi
    vin-wvwzzz13zbv001253
    cavd
    1k0-907 379AT
    RHD
  15. The Following User Says Thank You to Mrkeyz For This Useful Post:
    pawelm13 (25th January, 2018)
  16. #960
    Jan 2018
    hello
    20011
    audi a3 8p Sportback 1.4 92KW DSG
    1.4 TSI CAXC
    WAUZZZ8P3CA124388
    1K0907379BJ
    LHD
