Page 66 of 245 FirstFirst ... 1656616263646566676869707176116166 ... LastLast
Results 976 to 990 of 3668
  1. #976
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by workas View Post
    Hi ,can i get ABS coding for this car .aThanks in avanse.
    Monday,29,January,2018,10:25:28:11935
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 18.1.0.2 (x64)
    Data version: 20180122 DS285.1
    www.Ross-Tech.com
    VIN: 3VW167AJ3HM283504 License Plate: JETTA 2016 USA
    Mileage: 11950km-7425mi Repair Order:
    Chassis Type: AJ-VW36 (7E0)
    Scan: 01 03 04 08 09 15 17 19 25 44 5F
    VIN: 3VW167AJ3HM283504 Mileage: 11950km-7425miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    5F-Information Electr. -- Status: OK 0000
    Address 01: Engine (J623-CZTA) Labels:. 04E-907-309-V1.clb
    Part No SW: 04E 906 023 AK HW: 04E 907 309 AP
    Component: R4 1.4l TFS H22 3670
    Revision: X5H22---
    Coding: 01110012232400000000
    Shop #: WSC 00066 790 00012
    ASAM Dataset: EV_ECM14TFS01104E906023AK 005003
    ROD: EV_ECM14TFS01104E906023AK_005.rod
    VCID: 69D2B89A88577D0D02-803C
    CAN Converter 01:
    7 Faults Found:
    4527 - Coolant Fan Control Circuit 1
    P0480 00 [040] - Electrical Malfunction
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 11947 km
    Date: 2018.01.24
    Time: 15:54:52
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: -7 °C
    Intake air temperature: -6 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 10.955 V
    Unlearning counter according OBD: 36
    18948 - Boost Pressure Regulation
    P0299 00 [101] - Control Range Not Reached
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 11948 km
    Date: 2018.01.25
    Time: 19:56:04
    Engine speed: 3294.50 /min
    Normed load value: 63.1 %
    Vehicle speed: 50 km/h
    Coolant temperature: 68 °C
    Intake air temperature: 11 °C
    Voltage terminal 30: 14.442 V
    Unlearning counter according OBD: 40
    Outside air temperature: 5 °C
    Absolute intake pressure: 126 kPa abs
    Engine torque: 180.9 Nm
    Fuel level: 17.00 l
    E-machine torque actual value: 0.0 Nm
    4238 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
    P2185 00 [040] - Signal too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 11947 km
    Date: 2018.01.24
    Time: 15:54:52
    Unlearning counter according OBD: 37
    Outside air temperature: 7 °C
    Absolute intake pressure: 100 kPa abs
    Engine torque: 0.0 Nm
    Fuel level: 22.00 l
    10203 - Random/Multiple Cylinder Misfire Detected
    P0300 00 [040] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 11947 km
    Date: 2018.01.24
    Time: 15:56:54
    Engine speed: 1370.00 /min
    Normed load value: 31.8 %
    Coolant temperature: -6 °C
    Intake air temperature: -5 °C
    Voltage terminal 30: 14.701 V
    Absolute intake pressure: 65 kPa abs
    Engine torque: 55.1 Nm
    Fuel level: 22.00 l
    10593 - Cylinder 3
    P0303 00 [040] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 11947 km
    Date: 2018.01.24
    Time: 15:57:33
    Absolute intake pressure: 43 kPa abs
    Engine torque: 29.4 Nm
    Fuel level: 22.00 l
    10594 - Cylinder 4
    P0304 00 [032] - Misfire Detected
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 11947 km
    Date: 2018.01.24
    Time: 17:56:04
    Engine speed: 839.50 /min
    Normed load value: 33.3 %
    Coolant temperature: 24 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 14.065 V
    Unlearning counter according OBD: 35
    Outside air temperature: -7 °C
    Absolute intake pressure: 50 kPa abs
    Engine torque: 53.3 Nm
    Fuel level: 22.00 l
    10592 - Cylinder 2
    P0302 00 [032] - Misfire Detected
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 11947 km
    Date: 2018.01.24
    Time: 17:55:11
    Engine speed: 1396.50 /min
    Normed load value: 28.2 %
    Coolant temperature: 0 °C
    Intake air temperature: -3 °C
    Absolute intake pressure: 58 kPa abs
    Engine torque: 42.3 Nm
    Fuel level: 22.00 l
    Readiness: 0010 0101
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
    Component: ESP MK60EC1 H46 0175
    Revision: 00H46001
    Coding: 0000000000000000000000000000000000000000
    Shop #: WSC 00066 000 00000
    VCID: 75EAE4EADCEFA9ED96-8020
    5 Faults Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 54
    Time Indication: 0
    Date: 2018.01.20
    Time: 00:17:32
    Freeze Frame:
    Count: 3
    Count: 0
    Count: 20992
    Count: 195
    Count: 42496
    Count: 0
    Count: 0
    Count: 0
    01279 - Longitudinal Acceleration Sensor (G251)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 54
    Mileage: 11947 km
    Time Indication: 0
    Date: 2018.01.20
    Time: 00:17:23
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 28672
    Count: 212
    Count: 42496
    Count: 0
    Count: 0
    Count: 0
    01435 - Brake Pressure Sensor 1 (G201)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 54
    Mileage: 11947 km
    Time Indication: 0
    Date: 2018.01.20
    Time: 00:17:23
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 28672
    Count: 279
    Count: 42496
    Count: 0
    Count: 0
    Count: 0
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 54
    Mileage: 11947 km
    Time Indication: 0
    Date: 2018.01.20
    Time: 00:17:23
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 28672
    Count: 270
    Count: 42496
    Count: 0
    Count: 0
    Count: 0
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 54
    Mileage: 11947 km
    Time Indication: 0
    Date: 2018.01.20
    Time: 00:17:23
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 28672
    Count: 291
    Count: 42496
    Count: 0
    Count: 0
    Count: 0
    Address 08: Auto HVAC Labels: 5C0-820-047.clb
    Part No SW: 5C0 820 047 CT HW: 5C0 820 047 CT
    Component: J301 Klimaanlage 0211
    Revision: 2001401S Serial number: 00000003617652
    VCID: 74ECD9EE1795B0E5A1-8020
    1 Fault Found:
    00229 - Refrigerant Pressure
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 101
    Time Indication: 0
    Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
    Part No SW: 7E0 937 189 A HW: 7E0 937 189
    Component: BCM PQ25 MMI3 H81 0744
    Revision: BA081001 Serial number: 91007316166682
    Coding: 7B994B1808AB0B0000392080240884D54BC6722E600151F0B0 0010032844
    VCID: 32601FF66D01FED573-8066
    Subsystem 1 - Part No SW: 6R0 959 801 DF HW: 6R0 959 801 DF Labels: 6R0-959-801.CLB
    Component: J386__TSG_FT 022 1467
    Serial number: 14102743161013023258
    Coding: 820000
    Subsystem 2 - Part No SW: 6R0 959 802 DJ HW: 6R0 959 802 DJ Labels: 6R0-959-802.CLB
    Component: J387__TSG_BT 022 1467
    Serial number: 14102742161017092127
    Coding: 820000
    Subsystem 3 - Part No SW: 6C0 959 442 G HW: 6C0 959 442 G
    Component: E221__MFL-TAT H06 0023
    Serial number: 2661622361402356BE1B
    Coding: 280000
    Subsystem 4 - Part No SW: 6R0 959 811 T HW: 6R0 959 811 T
    Component: J388__TSG_HL 022 1467
    Serial number: 14102745161014224459
    Coding: 000000
    Subsystem 5 - Part No SW: 6R0 959 812 T HW: 6R0 959 812 T
    Component: J389__TSG_HR 022 1467
    Serial number: 14102744161015141915
    Coding: 000000
    3 Faults Found:
    01800 - Light Switch (E1)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 94
    Mileage: 11947 km
    Time Indication: 0
    Date: 2018.01.24
    Time: 15:56:22
    02745 - Bulb for Daytime Running Light; Left
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 12
    Reset counter: 61
    Mileage: 11947 km
    Time Indication: 0
    Date: 2018.01.24
    Time: 15:56:24
    02746 - Bulb for Daytime Running Light; Right
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 12
    Reset counter: 61
    Mileage: 11947 km
    Time Indication: 0
    Date: 2018.01.24
    Time: 15:56:24
    Address 15: Airbags (J234) Labels:* 561-959-655.clb
    Part No SW: 561 959 655 HW: 561 959 655
    Component: AirbagVW11 008 0210
    Serial number: 003RXM0955U5
    Coding: 8CCCF000000000005000001AC20800000065
    ASAM Dataset: EV_AirbaVW11SMEVW411 001002
    ROD: EV_AirbaVW11SMEVW411.rod
    VCID: 63CEAAB26A7B275DC8-8036
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B
    Component: BF-Gewichtss. H13 0022
    Serial number: IBH0000000000060RDFL
    Coding: 303141
    Crash sensor for side airbag: driver side:
    Subsystem 2 - Part No SW: ----------- HW: 480 001 009 16
    Component: SideSensor_Df 001 0887
    Serial number: 357000000003AAFC5E1%
    Crash sensor for side airbag: front passenger side:
    Subsystem 3 - Part No SW: ----------- HW: 480 001 009 16
    Component: SideSensor_Pf 001 0887
    Serial number: 3580000000088AFC5E13
    Crash sensor for side airbag: rear: driver side:
    Subsystem 4 - Part No SW: ----------- HW: 480 021 209 16
    Component: SideSensor_Dr 000 0148
    Serial number: 3510001AD2280CB555A7
    Crash sensor for side airbag: rear: passenger side:
    Subsystem 5 - Part No SW: ----------- HW: 480 021 309 16
    Component: SideSensor_Pr 000 0148
    Serial number: 3520001A92319DB64430
    Crash sensor for front airbag: driver side:
    Subsystem 6 - Part No SW: ----------- HW: 480 020 110 16
    Component: FrontSensor_D 000 0189
    Serial number: 3550001AB2285326930W
    Crash sensor for front airbag: front passenger side:
    Subsystem 7 - Part No SW: ----------- HW: 480 020 110 16
    Component: FrontSensor_P 000 0189
    Serial number: 3560001AB2285323973.
    2 Faults Found:
    9438234 - Igniter for Front passenger's Head Curtain Airbag
    B1004 1A [137] - Resistance Too Low
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 11947 km
    Date: 2018.01.20
    Time: 00:18:00
    9438491 - Igniter for Driver head airbag
    B1005 1B [137] - Resistance Too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 11947 km
    Date: 2018.01.20
    Time: 00:18:00
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 5C6 920 956 A HW: 5C6 920 956 A
    Component: KOMBI H02 1104
    Serial number: 00000000000000
    Coding: 220A010000
    Shop #: WSC 00066 790 00320
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
    ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
    VCID: 2E580B867139DA3517-807A
    1 Fault Found:
    13654544 - Databus
    U1121 00 [008] - Missing Message
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 94
    Mileage: 11947 km
    Date: 2018.01.24
    Time: 00:50:32
    Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
    Part No SW: 7E0 909 901 HW: 7E0 937 189
    Component: GW-K-CAN TP20 H81 0744
    Revision: BA081001
    Coding: 102201
    VCID: 68D4BD9E9B5D44051D-803C
    No fault code found
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 R
    Component: EPS_ZFLS Kl. 304 3501
    Revision: 00H22000
    Shop #: WSC 02069 000 90108
    VCID: 397228DA70770D8DB2-806C
    1 Fault Found:
    03803 - Steering Angle Sensor for Steering Aid
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    check one of these 2 codes please :
    113B200D092A00FD881004E4901D0041B100
    143B600D212A00FD281006E4841D0040B100
  2. #977
    mikajna's Avatar
    Mar 2015
    Quote Originally Posted by hid3 View Post
    Yeah, sure. The Touran is MY2006. So it shouldn't be MK60EC1 module there unless someone retrofitted it.
    What do you think is older model, short code? I have few errors, angle sensor, brake pressure, coding error, and few errors more, which will check soon
  3. #978
    Jul 2016
    Vilnius
    Difficult to say. If you'd post the info which we need (link to thread in my signature), it would be much easier.
    * MK100
  4. #979
    mikajna's Avatar
    Mar 2015
    Sure I will, soon I will go to car again, car is not registred and cant drive...and will get all info from car
  5. #980
    hass42's Avatar
    Aug 2012
    USA
    Hello all I need help with this and unit
    I don't know what happened, but I need help please
    Sent from my Moto Z (2) using Tapatalk
  6. #981
    Oct 2013
    hi i need help with long coding please,,, i can pay you
    vin # WAUZZZ8P59A066079
    AUDI A3 1.8T 2008
  7. #982
    tsistvan's Avatar
    HUNGARY
    Hi, I need help for coding ABS 8.2 Skoda Fabia ll. 2010 I tryed lots of variant but not working ABS 6R0907379S engine cggb front disk 256 rar 200 drum vin # TNBJC25J1B3035611 I calculated coding 410124DB007000B7822B24E300D200400000 but not good. Thank you.....
  8. #983
    Need help! VIN: WVWZZZ1KZ9W064771 , Golf V , 2008, LHD, Breake disc diam. 280mm. Engine 20TDi (BKD)
    Thanks for help.
  9. The Following User Says Thank You to rakss For This Useful Post:
    tsistvan (6th February, 2018)
  10. #984
    tsistvan's Avatar
    HUNGARY
    Hi, Rakss try this 113b200d092800fe881204eb901a0042b000
  11. The Following User Says Thank You to tsistvan For This Useful Post:
    rakss (6th February, 2018)
  12. #985
    Feb 2016
    Lugansk, Ukraine
    Need help! VIN: 3VWLZ7AJ8BM359760, Jetta , 2014, USA , Engine 2.5i (CBUA)
    Lost long coding for MK60EC1
    Thanks for help.
  13. #986
    Quote Originally Posted by tsistvan View Post
    It's OK ! Thanks.
  14. #987
    hass42's Avatar
    Aug 2012
    USA
    Quote Originally Posted by hass42 View Post
    Do I need to supply different info?
    Really in a bit of a bind here.
  15. #988
    Jul 2016
    Vilnius
    What is the actual problem?
    Are you able to do a scan using VCDS?
    * MK100
  16. #989
    hass42's Avatar
    Aug 2012
    USA
    I was not, I am not with vehicle. I was going to have my apprentice program long coding, if someone here can help me get it.
  17. #990
    Hi, TSISTVAN. Try; 410124DB217000B7822B24E384D200401700
  18. The Following User Says Thank You to rakss For This Useful Post:
    hass42 (6th February, 2018)
