Page 71 of 245 FirstFirst ... 2161666768697071727374757681121171 ... LastLast
Results 1,051 to 1,065 of 3668
  1. #1051
    Hi friend.
    Please send me a long coding abs.
    Thanks.
  2. #1052
    house
    Quote Originally Posted by vagva View Post
    HIV
    HOW YOU ARE NEW IN FORUM AND YOUR JOIN DATE IS MAY 2010 HOW ????????????? YOU MUST WRITE YOUR CAR BRAND , ANYWAY , ITS Scirocco
    HERE IS YOUR LONG CODING , IF I HELPED U PLEASE PRESS THANKS AND REP
    743B40F5492400132E0E02E5921A0042350000
    Well joined along time ago and never use the forum as i get by with good up to date equipment, a little grey matter & and local tech support in my area if that answers the question for you ?????????????? anyhow thank you for your reply i tried your code and tried 10 more like it by using 2 long coding calculators and got to the conclusion this abs unit won't except any code so off to main stealer its gone thanks again
  3. #1053
    VW Scirocco 2,0 TDI FWD 2008 year
    ESP MK60EC1 1K0907379AN
    S O L V E D .
  4. #1054
    Please help with long coding ABS/ESP
  5. #1055
    Mar 2011
    Quote Originally Posted by henryhenry View Post
    Hi I have a scoda 01/2013 type5L VIN= TMBKF75L6C6031760
    can anyone help with coding numer for ABS 1K0 907 379 BJ
    ESP MK60EC1 H31 0121
    I have lost coding it says Coding:00000000000000000000000000000000000000
    thank you
    Hello really could do with your help thanks.
    1. ABS part # 1K0 907 379 BJ
    2. Scoda Yeti Track YET
    3. VIN: TMBKF75L6C6031760
    3. RHD
    4.PETROL - Engine code = CBZB 1.2 TSI
    5.FWD
    6.FRONT ROTORS = 280mm, REAR ROTORS = 253mm
    7.NORMAL KEY START
    8.Transmission = automatic code = NBA Axle drive = 7A
    9. Has Traction Control
    10. Has Tyre Pressure Monitor
    If you need anymore info please advise
    Thank You
  6. #1056
    Mar 2011
    Hi I would appreciate your help here are the details you requested.
    1. ABS module part number = 1K0 907 379 BJ
    2. Exact model of the car = SCODA YETI
    3. Year of the car = 01/2013
    4. VIN = TMBKF75L6C6031760
    5. Left hand drive or right hand drive model = RIGHT HAND DRIVE
    6. Engine type (gas or diesel) and displacement. In some cases engine code might be useful. = GAS [PETROL] ENGINE CODE = CBZB 4cl 1.2 petrol engine
    7. 4Motion/4WD version or FWD = FRONT WHEEL DRIVE
    8. Provide front brake disc diameter, if known. Alternatively, you can provide PR numbers for brake system - they begin with numer "1". They can be located on the first page of service maintenance booklet OR under the trunk carpet. FRONT ROTOR= 280MM X 22MM 1ZF REAR = 235MM X 10MM 1KD
    9. Is there any start/stop ("eco"/"bluemotion"/etc) system installed in the car? = NO START STOP
    10. Is there any kind of TPMS? If yes, then what kind of TPMS - indirect ABS based (no sensors in each wheel) or direct system which uses sensors inside the wheels?
    NO TPMS HAS DIRECT ABS SYSTEM SENSORS IN EACH WHEEL
    11. Does the car have ASR/ESP off buttons? I CAN'T FIND BUTTON ON OR OFF BUT THERE IS A TRACTION CONTROL BUTTON ON / OFF
    12. "Hill hold" function. Does the car have one? Do you want it to be activated? HAS HILL HOLD /NO ACTIVATION PLEASE
  7. #1057
    Mar 2011
  8. #1058
    morfej's Avatar
    your coding: 41F5487D892633C31116106C0058821291CC8808000DCBF98F 00
    As u did not give much data ... it will be accepted but u need to fine tune it as well
  9. #1059
    Jul 2016
    Vilnius
    Henry, there's always a solution to a problem. You know what to do if you really need it
    * MK100
  10. #1060
    Jun 2016
    Hi, please help me with long coding. Skoda Octavia
    VIN: TMBGE61Z8A8009743
    Thx.
  11. #1061
    Mar 2018
    please help with the following
    MK60EC1
    VIN:TMBJS21Z0A8043957
    ABS MODEL: 1K0907379AH
    SKODA OKTAVIA III
    LONG CODE PLEASE
    THANKS
  12. #1062
    donkez's Avatar
    Mayo, Ireland
    hi, need help with long coding
    VW Touran
    WVGZZZ1TZBW020007
    abs 1KO907379AT
    GONE TO STEELER.... DONT WORRY ABOUT IT
  13. #1063
    DK Veteran ganker69's Avatar
    Apr 2013
    AUDI A3 FWD
    1KO907379CD ESP MK60EC1
    HW: 1K0907379AD
    1.9TDI BLS
    CRUISE CONTROL
    WAUZZZ8P29A036795
    TPMS
    LHD
  14. #1064
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by ganker69 View Post
    AUDI A3 FWD
    HW: 1K0907379AD
    1.9TDI BLS
    CRUISE CONTROL
    WAUZZZ8P29A036795
    TPMS
    LHD
    here is your Long Coding , dont forget Rep and THX
    1142401209250000881202ED901E0041390800
  15. The Following User Says Thank You to vagva For This Useful Post:
    ganker69 (13th March, 2018)
  16. #1065
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by yotaren View Post
    MK60EC1
    SKODA OKTAVIA III
    LONG CODE PLEASE
    THANKS
    113B201C092600FD881404E990200041340000
