Please send me for my jetta 02.2006 1,6 16 v fsi
seal777 (3rd June, 2018)
hello
please im looking for abs long coding for vw touran 2014 1k0907379bm 1,6tdi cayc vin wvwzzz1tzfw029891
hi
thank you for your replay, but this coding not work .
I think that it have to be 20 bit coding for this abs
Looks like some leechers got refused
Wonder if I could be entitled for a coding![]()
* MK100;
Hi. Need help too. SuperB 2009
Please help calculate!
3T0 907 379 C
Chassis Number: TMBAB63T7A9014028
Engine code: CDA
Front brake disk 312
Rear 282
Have button esp off/parking assist/tyre pressure reset
Identification: TT1-000
Revision: 00H45001
Date: 26.07.09
Manufacturer number: 0304
Test stand number: 0383
Best regards!
Hi looking for long code for Skoda fabia Monte Carlo
2013
RHD
TMBFL25JXD3141807
6R0 907 379 AR
ABS 9.0
1.6 TDI
CAYC
Thanks very much
VIN: TMBFL25JXD3141807 License Plate: NA13 NAN
Mileage: 100490km-62441mi Repair Order:
Chassis Type: 5J-SK25 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56
VIN: TMBFL25JXD3141807 Mileage: 100490km-62441miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 LN HW: 03L 906 023 LK
Component: 1,6l R4 CR td H33 9972
Revision: --H33--- Serial number: 00000000000000
Coding: 00114016000500080000
Shop #: WSC 13765 031 00044
ASAM Dataset: EV_ECM16TDI02103L906023LN 003010
ROD: EV_ECM16TDI02103L906023LL.rod
VCID: 7DF5BE70ECB1BAAC4C-8028
No fault code found.
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 AR HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0001
Serial number: --------------
Coding: 000000000000000000000000000000000000
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 0E17E9BCD117B134A5-805A
3 Faults Found:
0887 - Control Module
C104A F0 [009] - Incorrect VIN
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 95
Mileage: 124375 km
Date: 2021.04.19
Time: 00:00:12
0897 - Coding Not Possible
U10BC 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 52
Mileage: 100498 km
Date: 2018.06.09
Time: 21:26:52
0883 - Control module not coded
U1013 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 52
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 5J0 820 045 D HW: 5J0 820 045 D
Component: Man AC H02 0202
Revision: 0004SH02
VCID: 2647B11C51A7D9747D-8072
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 M HW: 6R7 937 087 M
Component: PQ25 BCM H30 0555
Revision: -1------ Serial number: --------------
Coding: 3D980B3808FB2400922008002C2B08C00000400F6000000002 0010000000
Shop #: WSC 50413 001 1048576
VCID: 4E9729BC1997F134E5-801A
Subsystem 1 - Part No SW: 6R0 959 802 AN HW: 6R0 959 802 AN Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 006 5210
Serial number: --------------------
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 AL HW: 6R0 959 801 AL Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 5210
Coding: 020000
Subsystem 3 - Part No: 5J0 951 172
Component: DWA-Sensor H03 H03 1211
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 H05 1501
Subsystem 5 - Part No: 5J0 951 172
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagT2C H10 0020
Revision: -------- Serial number: 003GX01NJ41E
Coding: 003243
Shop #: WSC 13765 790 00044
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9F25ACEDFFDD14B9-801E
Crash sensor for side airbag: driver side:
Serial number: 3495RRB400C50FSSEOQR
Crash sensor for side airbag: front passenger side:
Serial number: 3505RRB400G50GQ299E7
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5J0 920 911 D HW: 5J0 920 911 D
Component: KOMBI H03 0306
Coding: 420A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_A04_SK25.rod
VCID: 295DBA2048B9F60C50-807C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R7 937 087 M
Component: GW-K-CAN TP20 H30 0555
Revision: -1------
Coding: 032300
VCID: 70EB9744A3E3C7C4D7-8024
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0306
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADF852C8D3F3D1499-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664586286
Coding: 010100
VCID: 2A5F452C45BFFD1459-807E
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 10110
Shop #: WSC 13765
VCID: 306B5744F76387C497-8064
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5J0 035 161 D HW: 5J0 035 161 D
Component: Radio-SWING 004 0003
Revision: -----07S Serial number: SKZ4Z2N1191462
Coding: 010004000006
VCID: 2341A80822952C5C1A-8076
1 Fault Found:
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 52
Mileage: 100498 km
Time Indication: 0
Date: 2018.06.09
Time: 21:15:40
End-------------------------(Elapsed Time: 02:32)--------------------------
ABS testing volunteers required.
If you have one of ABS modules with part number 1K0 907 379 BM/BS/CC in your car and you are willing to do some coding testing, please contact me.
We will be testing various ESP deactivation modes (ASR off, ESP off, ESP-sport mode, etc.).
Thank you.
* MK100;
i have the module with number 1k0907379bs for testing
hi i want abs coding for skoda rapid 2013
6R0614517BK
VIN : TMBAT6NH3E4012091
THX
