Page 88 of 245 FirstFirst ... 3878838485868788899091929398138188 ... LastLast
Results 1,306 to 1,320 of 3668
  1. #1306
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by dyc View Post
    Hi, please help me with code for:
    1K0 907 379 AT
    Golf 6
    LHD 1.6 TDI
    WVWZZZ1KZBM646276
    one of these your long coding :
    113B400D09268000880D02EB901F0142350800
    133B200D09260000C80D04EB901F0091310000
    if my post was Useful , Press Thanks & Rep Buttons
  2. The Following User Says Thank You to vagva For This Useful Post:
    dyc (6th September, 2018)
  3. #1307
    andkl2810's Avatar
    Aug 2012
    SLAVA UKRAINI !!! HEROJAM SLAVA !!!!
    not correct code , 3VW2K7AJ3EM398499 . please check jetta ameryka 2.0 tsi LHR -1K0 907 379 BL
    A4 3B 40 F8 11 2B 00 02 25 0F 02 ED 88 22 00 40 21 10 0
    A13B20F8092B0002850F04ED9022004121100
    37 bit
    38 bit correct it
  4. #1308
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by andkl2810 View Post
    A43B40F8112B0002250F02ED8822004021100
    37 bit
    38 bit correct it
    test and report please
    143B600D212B0002280F06ED84220040B10000
    B14B440C492B08028D0F22ED92221061A70000
    A43B40F8112B0002250F02ED882200402110000
  5. The Following 2 Users Say Thank You to vagva For This Useful Post:
    andkl2810 (6th September, 2018), dyc (6th September, 2018)
  6. #1309
    grzyb26's Avatar
    Jan 2012
    543B4008092300002A1402E790220041300000
    Quote Originally Posted by vagva View Post
    one of these your Long coding :
    514B600A492300008A1406E792220041A10000
    563B6008092300006A1406E790220082340000
  7. #1310
    andkl2810's Avatar
    Aug 2012
    B14B440C492B08028D0F22ED92221061A70000 it correct code ! thanks you bro !
    1 error
    00150 - Plausibility Brake Booster System
    Booster System checked all good
    Possible Symptoms
    • Fault code appears after ABS controller was replaced
    • Coding is accepted, but is lost after a key cycle
    • Code clears, but comes right back
    wiki
  8. #1311
    dyc's Avatar
    first is not accepted and second string is ok but esp fault still active "wrong coding"
    car is basic without hill option
    Thanks are welcome !
  9. #1312
    Apr 2017
    PLEASEEEE vin is W V 2 Z Z Z 2 K Z C X 0 4 7 2 4 4 , 1K0 907 379 BS , left hand . THANK YOU VERY MUCH !!!
  10. #1313
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by hguritr View Post
    you should provide us more info
    car type ??
  11. #1314
    vagva's Avatar
    Apr 2016
    one of these Long coding should be your exact Long coding:
    433C400D09260301C20D02E8901DC091310000
    633C600D09260301C60D06E8901DC081300000
    423C400D09260301420D02E8901DC051310000
  12. #1315
    South Africa
    hi there dear members.
    hi there dear friend. hope all fine your side. is it possible to enter last 5 digits of vin into long coding for me please. a new pump were fitted with different vin nr. turned to all zeros. i will sent few different year model car which are exactly the same. i just need the vin to be changed. many thanks if you could assist. system is abs 9.0 keep well.
    this is the vin in the car now. (last 5 digits from this vin must be added into any of the long codings i supply. many thanks)
    AAVZZZ6RZFU047406
    this is the three exactly same vehicles. with different vin nrs.
    AAVZZZ6RZGU00105
    23DD2885492333C10914006E0057C41492CC90000005C90980 00
    AAVZZZ6RZFU065589
    23DD2885492633C3091C006A0053C41492CC90000005C90980 00
    AAVZZZ6RZGU042217
    23DD2885492733C20916006A0058C41492CC90000005C90980 00
  13. #1316
    South Africa
    no member can assist
  14. #1317
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by frikki View Post
    Here are yours :
    AAVZZZ6RZGU 00105
    23DD2885492233FA090C00E4001EC41492CC90000005C90980 00
    AAVZZZ6RZFU0 65589
    23DD2885492833FF091000EC0022C41492CC90000005C90980 00
    AAVZZZ6RZGU0 42217
    23DD2885492633FC090D00E500EBC41492CC90000005C90980 00
  15. The Following User Says Thank You to vagva For This Useful Post:
    frikki (9th September, 2018)
  16. #1318
    South Africa
    will test and report . many thanks
  17. #1319
    South Africa
    Here are yours :
    AAVZZZ6RZGU 00105
    AAVZZZ6RZFU0 65589
    AAVZZZ6RZGU0 42217
    all codings coding rejected dear friend. thanks for trying dear friend.
    i need this vin number last 5 digits to be put into the following coding dear friend.
    AAVZZZ6RZFU047406
  18. #1320
    South Africa
    please any member can change only 5 digits in long coding byte 5, 7, 9, 11 and 13.
    if i knew how to edit and encrypt vin into long coding i would have done it. cant find any decent instructions on internet to get job done.
