Page 4 of 245 FirstFirst 1234567891454104 ... LastLast
Results 46 to 60 of 3668
  1. #46
    Jul 2016
    Vilnius
    Quote Originally Posted by amrif View Post
    hello,
    GOLF 1.9TDI
    LHD W V W ZZZ1KZ9W030527
    THX
    Hello amrif,
    try this coding:
    113B200D092500FA881004E690200041310000
  2. The Following User Says Thank You to hid3 For This Useful Post:
    slawentiy (29th September, 2017)
  3. #47
    Nov 2015
    Windsor UK
    hi mate I am also fresh here and have a big problem with my golf mk5 2008 need to long coding for abs esp
    mk60 ec1
    1k0907379ad
    vin no wvwzzz1kz9w126047
    if you could help would be great
  4. #48
    Nov 2015
    Windsor UK
    mk60 ec1
    1k0907379ad
    thanks in advance
  5. #49
    Jul 2016
    Vilnius
    Hello Speed,
    assuming yours is LHD and 1.9 TDI too, try this coding:
    113B200C09240000880B04E890200041310000
    Let me know if:
    -yours is RHD
    -The engine is not 1.9 TDI
    -your golf is 4motion version
    -if you know brake system PR numers (should be in your service booklet or under the trunk carpet and should begin with "1", e.g. 1KZ, 1ZF, 1KD, etc...)
    In that case I could provide a coding which would be more accurate to your car.
  6. #50
    Jul 2016
    Vilnius
    For everyone, posting coding requests - be sure to include as much inforamtion as you have about the car.
    This is what's required:
    1. ABS module part number (the part number which is labelled on the ECU part, not the motor part number)
    2. VIN
    3. Exact model of the car
    4. Left hand drive (LHD) or right hand drive (RHD) model
    5. Engine type (gas or diesel), power output and displacement. Engine code can be provided instead if known.
    6. 4Motion/4WD version or FWD
    7. Is there any start/stop ("eco"/"bluemotion"/etc) system installed in the car?
    8. Is there any kind of TPMS? If yes, then what kind of TPMS - indirect ABS based (no sensors in each wheel) or direct system which uses sensors inside the wheels?
    9. Does the car have ASR/ESP off buttons (in the center console)?
    10. "Hill hold" function. Do you want it to be activated if possible?
    If you provide all the information requested, then you can expect a fully correct coding which would be the same as it would be coded in the factory. All the information is important if you want to have a fully and in-time working ESP system.
    Instead of all of the above you may just provide full car's autoscan and indicate if it's LHD or RHD model. That should be sufficient.
    Once you get a coding, please note the important points:
    (1) you will need to code the module and adapt all the related sensors in one ingition cycle. Otherwise, the coding will revert back to zeroes;
    (2) I strongly suggest doing the adaptations of the sensors on ideally flat surface. Also, when adapting steering wheel sensor, be sure to center the steering wheel very preceisely. If it'll end up slightly off-center, it will cause car pulling to a side.
    If it is your lucky day, you might get a coding offered with a "gift" - full ESP deactivation possibility. Once you have successfully coded the module and adapted all the sensors, you can try to fully deactivate ESP: press and hold the ESP-off button in the center console for around 5 seconds. Watch your dashboard, it should somehow inform you that ESP is not fully off.
    So you got a coding, everything works OK and you're happy but you feel that a simple 'Thanks' is not enough? Then PM me, I'll give you the details...
  7. The Following 2 Users Say Thank You to hid3 For This Useful Post:
    Afortunao (30th October, 2018), piedepesante (4th April, 2018)
  8. #51
    Nov 2015
    Windsor UK
    hello mate
    thanks for your replay and sorry I did not provide all details
    so car is vw golf MK 5 also 5 doors hatchback year 2008 1.4 petrol BUD engine right hand drive version
    FWD
    VIN WVWZZZ1KZ9W126047
    PR no and coding you sent i will check in the morning then replay
    thanks in advance
  9. #52
    Jul 2016
    Vilnius
    Oh, so it's RHD... You missed that part, that's why it's so important to provide as much information as possible.
    Anyway, here's your coding for RHD:
    133B200C09240000880B04E890200080300000
    You can try and code it tomorrow morning. I doubt the 1.4 engine powered Golf will have non-standard/bigger brakes. So I'm 98% sure this coding is the right fit.
    * MK100
  10. #53
    Nov 2015
    Windsor UK
    yes this is standard car
    I will check it tomorrow and let know
  11. #54
    Nov 2015
    Windsor UK
    hi again
    so I`ve checked it and ecu did not accept this coding, however there is 36 digits "0" not 38 so I removed last 2 digits (from coding I received ) also no luck every time fault
    if I tried put 38 fault was VCDS has detected a change in coding langth. are you sure you want to continue
    after removed last 2 digits
    coding rejected error 31 request out of range
    any idea I`ll get mad
  12. #55
    Jul 2016
    Vilnius
    Alright, try these ones and report back:
    1. 1342400C09240000C80B02E8902000803800
    2. 133B200C09240000C80B04E890200080E800
    3. 133B200C09240000C80B04E8902000803000
    * MK100
  13. The Following 2 Users Say Thank You to hid3 For This Useful Post:
    kamolsfss (6th October, 2019)
  14. #56
    Nov 2015
    Windsor UK
    hi there
    still nothing
    coding rejected I do not know every single part comes from this car, even if I could find similar golf form 08 but very difficult
  15. #57
    Jul 2016
    Vilnius
    Are you sure you have specified the VIN correctly?
    Can you confirm the very same VIn is coded into the ECU and the Cluster/IMMO?
    Could you please provide full autoscan to me in PM?
    * MK100
  16. #58
    Nov 2015
    Windsor UK
    ok no problem I will do
  17. #59
    Jul 2016
    Vilnius
    Here you go additional codings to try:
    133B200D09240000880B04E8902000803000
    163B600D09240000680B06E8902000813400
    163B200D09240000680B04E8902000803000
    163B200C09240000680B04E8902000803000
    When trying each of the above coding, if it does not accept it, try adding two zeroes to the end.
    * MK100
  18. The Following 2 Users Say Thank You to hid3 For This Useful Post:
    samranisimo (30th January, 2017), SPEED133 (27th August, 2016)
  19. #60
    Nov 2015
    Windsor UK
    hi again and thanks second coding has been accepted and everything looks fine
    take care and good weekend
