Page 8 of 245 FirstFirst ... 3456789101112131858108 ... LastLast
Results 106 to 120 of 3668
  1. #106
    Jul 2016
    Vilnius
    Quick Google search says this fault code might occur once Instruments cluster was tampered with. Usually this mean odo rollback.
    You can try this:
    • Check/Perform Instrument Cluster Service Interval Settings (Adaptation Channels 42, 43, 44, 45 and 49)
    Or, I think, you can use SRI reset funciton at the first VCDS page. I'd suggest going through several SRI resets (various regions, time/distance, longlife, etc) and then ending up with the desired one you want to use. Then try to see if the error is still there (try clearing it)
    * MK100
  2. #107
    smokey08's Avatar
    Essex, UK
    Poki123 try this:
    11504012492300FC881306E492210041B90C00
  3. #108
    Netherlands
    I just think that reason of no accepting coding maybe this:
    instrument clustar has been reflash from 8P0 920 892N (USA software) >> 8P0 920 931S (EU software) and during coding ABS pomp (USA software) there are some mismatches between each other.
    If I'll find some one with VAS online SVM tester I do this coding.
    Tomorrow I try coding with your string smokey08.
    I want to know how many elements of car I need to make coding "on table"...
    Gateway(19) Instrument(17) IMMO(25) of course ABS/ESP(03) everything connected with CAN and VCDS. What determinate ABS unit(03) to no accepting coding...
    impossible is nothing...
  4. #109
    Jul 2016
    Vilnius
    OMG what a coctail you have. Why was the Instruments software reflashed? I believe miles could be easily changed to km and Fahrenheit also converted to Celsius without an issue using just VCDS. Now seems you ended up with 'module defective' code. Obviously something went wrong during the reflash.
    What else is altered on the car? Is ECU software stock or some kind of reflash?
    * MK100
  5. #110
    Netherlands
    I told that I recive this car in this state with two instrument cluster on back seat and with bypass immo in orginal ecu. I have another instrument cluster without def. (without DTC) and with this coding ABS looks the same. I take this car after same people "electronics" say it's impossible to repair it. I don't belive in impossible
    All electric windows and slide roof not working when I start make this car.
    Now only ABS/ESP pomp needs to be coding rest of car works perfectly
  6. #111
    smokey08's Avatar
    Essex, UK
    If its NAR model then also try these:
    1150400F492300FC881306E492210041B90C00
    1150400F492300FC881306E492210041390C00
  7. The Following User Says Thank You to smokey08 For This Useful Post:
    poki123 (16th September, 2016)
  8. #112
    Netherlands
    Quote Originally Posted by smokey08 View Post
    no accepted
  9. #113
    Netherlands
    Poki123 try this:
    no accepted
  10. #114
    Aug 2013
    Hi Guys
    I have a golf 6 with ABS coding lost.Please could you help with coding? Details as follows:
    2012 VW Golf 6 1.6
    VIN: WVWZZZ1KZBW070446
    ENGINE:BFS
    RHD SOUTH AFRICAN model.
    Thanks in advance
  11. #115
    Jul 2016
    Vilnius
    Hello Magic,
    please try this coding:
    133B200D092900FA880F04E8901F0080310000
    No matter if it works or not, could you please provide the ABS unit's part number as seen in VCDS?
    Also, could you check your glove box and see if there is "SET" button? Or in the center console?
    If there is SET button, I could enable TPMS function which is quite useful.
    Also, is there a button in the center console with "slippery car" icon and "OFF" word?
    If there is, I could enable full ESP deactivation with the button, but again, this depends on your controller part number
    * MK100
  12. The Following User Says Thank You to hid3 For This Useful Post:
    magicworx (16th September, 2016)
  13. #116
    Netherlands
    I'm just waiting for coding online by Audi servis partner. I'll give a feedback from result of it.
  14. #117
    Aug 2013
    Thanx hid3 but coding not accepted.No set button in glove box but i do have "slippery car" icon.
    Part no. 1KO 907 379 AT as displayed by VCDS.
  15. #118
    Jul 2016
    Vilnius
    Seems that you got a bit older module in your MY2012 car.
    Could you please do a full autoscan? You can send it to me via PM.
    * MK100
  16. #119
    Aug 2013
    Thank You hid3.Will contact soonest.
  17. #120
    Netherlands
    online coding for A3 8P 2010 North America
    VIN: WAUKEAFMXAA112808
    11 50 60 0F 49 23 00 FC 88 13 06 E4 92 21 00 41 39 08 00
    Thanks for help.
  18. The Following User Says Thank You to poki123 For This Useful Post:
    smokey08 (16th September, 2016)
