Page 175 of 245 FirstFirst ... 75125165170171172173174175176177178179180185225 ... LastLast
Results 2,611 to 2,625 of 3668
  1. #2611
    macako6's Avatar
    Mar 2015
    Quote Originally Posted by hiperkey View Post
    hello friends I need long code for my abs of seat altea year 2012 vin: VSSZZZ5PZCR034713
    It was erased when the instrument cluster was removed to replace the screen
    greetings and thanks
    Device identification:
    Nśmero de VAG SW: 1K0907379BJ 0121
    Nśmero de VAG HW: 1K0907379BJ H31
    System description: ESP MK60EC1
    Workshop (Part/Imp/Supp): 00000/0000/04941
    Vehicle information:
    Codificación: 00000000000000000000000000000000000000
    FAZIT identification:
    FAZIT Identification: TT1-012 16.04.12 0301 017B
    Production Change Number: 00H31001
    Workshop System Name (J-number): J104
    Flash information:
    Programming APPLICATION attempts: 0
    Programming APPLICATION successfull: 0
    Flash status: OK
    check this code :
    213F0012092500FE841200E5901C0000000000
  2. #2612
    macako6's Avatar
    Mar 2015
    Quote Originally Posted by skodagod View Post
    Hello,
    I am struggling and tired to find long code for my ABS module. Here are the data from VCDS
    Car : VW GolF MKV 1.9TDI
    VIN:WVWZZZ1KZ9W129874
    Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0120
    Revision: 00H35001
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 09550 758 180955
    VCID: 76E9BB1AC1C734FFBB-8022
    5 Faults Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 210152 km
    Time Indication: 0
    Freeze Frame:
    Count: 7
    Count: 3
    Count: 12288
    Count: 195
    Count: 41984
    Count: 0
    Count: 0
    Count: 0
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 210152 km
    Time Indication: 0
    Freeze Frame:
    Count: 7
    Count: 3
    Count: 12288
    Count: 143
    Count: 41984
    Count: 0
    Count: 0
    Count: 0
    01435 - Brake Pressure Sensor 1 (G201)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 210152 km
    Time Indication: 0
    Freeze Frame:
    Count: 7
    Count: 3
    Count: 12288
    Count: 279
    Count: 41984
    Count: 0
    Count: 0
    Count: 0
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 210152 km
    Time Indication: 0
    Freeze Frame:
    Count: 7
    Count: 3
    Count: 12288
    Count: 295
    Count: 41984
    Count: 0
    Count: 0
    Count: 0
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 210152 km
    Time Indication: 0
    Freeze Frame:
    Count: 7
    Count: 3
    Count: 12288
    Count: 270
    Count: 41984
    Count: 0
    Count: 0
    Count: 0
    Could anyone help to find the code please .. I wait for your reply.. Thanks
    You may still need it
    114B000C09240003881300EB901D0000000000
  3. #2613
    Oct 2017
    ESPAŃA
    HOLA , no acepta el codigo
  4. #2614
    Sep 2020
    Poland
    VIN: WVWZZZ1KZAM036977 Numer rejestracyjny:
    Typ podwozia: 1K-VW36 (1K0)
    Skanowanie: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 69 72
    VIN: WVWZZZ1KZAM036977 Przebieg: 157450km
    01-Silnik -- Stan: Usterka 1010
    03-ABS/hamulce -- Stan: Usterka 1010
    04-Kąt skrętu kierow. -- Stan: OK 0000
    08-Klimatyzacja -- Stan: Usterka 0010
    09-Centr.zesp.elektr. -- Stan: Usterka 0010
    10-Asyst.park./kierow. -- Stan: Usterka 0010
    15-Airbag -- Stan: OK 0000
    16-Koło kierownicy -- Stan: OK 0000
    17-Zest.wskaźników -- Stan: Usterka 0010
    19-CAN Gateway -- Stan: Usterka 0010
    25-Immobiliser -- Stan: OK 0000
    37-Nawigacja -- Stan: Niezarejestrowany 0011
    42-Elektr.drzwi kier. -- Stan: OK 0000
    44-Wsp.kierownicy -- Stan: Usterka 0010
    46-Moduł komfortu -- Stan: OK 0000
    52-Elektr.drzwi pas. -- Stan: Usterka 0010
    56-Radio -- Stan: Nie może być osiągnięty 1100
    62-Drzwi tylne lewe -- Stan: OK 0000
    69-Przyczepa -- Stan: OK 0000
    72-Drzwi tylne prawe -- Stan: OK 0000
    Adres 01: Silnik (CAX) Plik etykiet: 03C-906-022-CAX.clb
    Oznaczenie elementu SW: 03C 906 022 AK HW: 03C 906 022 J
    Komponent: MED17.5.20 G 5369
    Weryfikacja: D5H07--- Numer seryjny:
    Kodowanie: 0000072
    Kod serwisu: WSC 66565 257 00032
    VCID: 65C10493AC61CF6735-8030
    3 - ilość znalezionych błędów. Oto one:
    006439 - Przekaźnik dodatkowej pompy płynu chłodzącego (J496)
    P1927 - 000 - przerwa - Sporadyczny
    Ramka zamrożona:
    Stan błędu: 00100000
    Priorytet błędu: 0
    Częstość błędu: 1
    Wew.licznik błędów: 255
    Wskaźnik czasu: 0
    Data: 2047.15.31
    Czas: 31:63:63
    Ramka zamrożona:
    Obroty silnika: 0 /min
    Obciążenie: 0.0 %
    Prędkość: 0.0 km/h
    Temperatura: 33.0*C
    Temperatura: 18.0*C
    Ciśnienie rzecz.: 1020.0 mbar
    Napięcie: 11.938 V
    049441 - Brak komunikacji ze sterownikiem systemu ABS
    U0121 - 000 - - Sporadyczny
    Ramka zamrożona:
    Priorytet błędu: 0
    Częstość błędu: 1
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.08
    Czas: 00:37:57
    Ramka zamrożona:
    Obciążenie: 0.0 %
    Prędkość: 0.0 km/h
    Temperatura: 36.0*C
    Temperatura: 20.0*C
    Napięcie: 11.811 V
    001393 - Przełącznik świateł hamowania (F)
    P0571 - 000 - usterka w obwodzie
    Ramka zamrożona:
    Stan błędu: 01110000
    Priorytet błędu: 0
    Częstość błędu: 1
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.08
    Czas: 23:32:10
    Ramka zamrożona:
    Obciążenie: 0.0 %
    Prędkość: 0.0 km/h
    Temperatura: 14.0*C
    Temperatura: 18.0*C
    Napięcie: 11.303 V
    Kody gotowości: 0000 0000
    Adres 03: ABS/hamulce (-----) Plik etykiet:. 1K0-907-379-60EC1F.clb
    Oznaczenie elementu SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Komponent: ESP MK60EC1 H35 0106
    Weryfikacja: 00H35001
    Kodowanie: 000000000000000000000000000000000000
    Kod serwisu: WSC 06314 000 00000
    VCID: 74E769D7D7BB26EFB2-8020
    6 - ilość znalezionych błędów. Oto one:
    00778 - Czujnik kąta skrętu kierownicy (G85)
    003 - Usterka mechaniczna
    Ramka zamrożona:
    Stan błędu: 01100011
    Priorytet błędu: 2
    Częstość błędu: 1
    Wew.licznik błędów: 125
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.08
    Czas: 23:28:24
    Ramka zamrożona:
    Zliczanie: 7
    Zliczanie: 0
    Zliczanie: 12288
    Zliczanie: 288
    Zliczanie: 42496
    Zliczanie: 65280
    Zliczanie: 0
    Zliczanie: 0
    01435 - Czujnik 1 ciśnienia w układzie hamulcowym (G201)
    005 - Brak lub niepoprawne nastawy podstawowe / adaptacja
    Ramka zamrożona:
    Stan błędu: 01100101
    Priorytet błędu: 2
    Częstość błędu: 1
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.08
    Czas: 23:27:46
    Ramka zamrożona:
    Zliczanie: 3
    Zliczanie: 0
    Zliczanie: 12288
    Zliczanie: 279
    Zliczanie: 42496
    Zliczanie: 65280
    Zliczanie: 0
    Zliczanie: 0
    Ramka zamrożona:
    Priorytet błędu: 2
    Częstość błędu: 1
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.08
    Czas: 23:27:46
    Ramka zamrożona:
    Zliczanie: 3
    Zliczanie: 0
    Zliczanie: 12288
    Zliczanie: 295
    Zliczanie: 42496
    Zliczanie: 65280
    Zliczanie: 0
    Zliczanie: 0
    01423 - Czujnik przyspieszenia poprzecznego (G200)
    Ramka zamrożona:
    Priorytet błędu: 2
    Częstość błędu: 1
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.08
    Czas: 23:27:46
    Ramka zamrożona:
    Zliczanie: 3
    Zliczanie: 0
    Zliczanie: 12288
    Zliczanie: 270
    Zliczanie: 42496
    Zliczanie: 65280
    Zliczanie: 0
    Zliczanie: 0
    00003 - Sterownik
    Ramka zamrożona:
    Priorytet błędu: 1
    Częstość błędu: 1
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.09
    Czas: 00:44:19
    Ramka zamrożona:
    Zliczanie: 3
    Zliczanie: 0
    Zliczanie: 12288
    Zliczanie: 143
    Zliczanie: 42496
    Zliczanie: 0
    Zliczanie: 0
    Zliczanie: 0
    01042 - Sterownik niezakodowany
    000 - -
    Ramka zamrożona:
    Stan błędu: 01100000
    Priorytet błędu: 2
    Częstość błędu: 1
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.08
    Czas: 23:28:24
    Ramka zamrożona:
    Zliczanie: 7
    Zliczanie: 0
    Zliczanie: 12288
    Zliczanie: 195
    Zliczanie: 42496
    Zliczanie: 65280
    Zliczanie: 0
    Zliczanie: 0
    Adres 08: Klimatyzacja (J255) Plik etykiet:| 5K0-907-044.clb
    Oznaczenie elementu SW: 5K0 907 044 BD HW: 5K0 907 044 BD
    Komponent: Climatronic H14 0608
    Weryfikacja: 00003001
    Kod serwisu: WSC 00066 000 00185
    Zbiór danych ASAM: EV_Climatronic A01001
    ROD: EV_ClimaAutoBasis_VW36.rod
    VCID: 6ED37BBFB1970C3F44-803A
    2 - ilość znalezionych błędów. Oto one:
    13701376 - Ograniczenie działania z powodu braku informacji
    U1111 00 [008] - -
    [Nowa funkcja - rozszerzone informacje o kodach błędów (protokół UDS) - jest dostępna wyłącznie przy użyciu najnowszych interfejsów, oferowanych na VCDS.pl.]
    Sporadyczny - Potwierdzony - Testowany od skasowania kodów błędów
    Ramka zamrożona:
    Stan błędu: 00000001
    Priorytet błędu: 6
    Częstość błędu: 1
    Wew.licznik błędów: 165
    Przebieg: 157456 km
    Data: 2020.09.16
    Czas: 23:50:23
    13701392 - Ograniczenie działania z powodu braku informacji
    U1111 00 [008] - -
    Ramka zamrożona:
    Priorytet błędu: 6
    Częstość błędu: 1
    Przebieg: 157456 km
    Data: 2020.09.17
    Czas: 00:37:57
    Adres 09: Centr.zesp.elektr. (J519) Plik etykiet:. AKP\1K0-937-08x-09.clb
    Oznaczenie elementu SW: 5K0 937 086 HW: 5K0 937 086
    Komponent: BCM PQ35 M 008 0019
    Weryfikacja: BC008001
    Kodowanie: 40000A3A982D02E040000080400001200300008870008D605C C000000000
    Kod serwisu: WSC 00066 000 00000
    VCID: 71E960C3A8A913C759-8024
    Podsystem 1 - Oznaczenie elementu: 1K1 955 119 E Plik etykiet: 1KX-955-119.CLB
    Komponent: Wischer 18090 21 0501
    Kodowanie: 009795
    01314 - Sterownik silnika
    004 - Brak sygnału / brak komunikacji - Sporadyczny
    Ramka zamrożona:
    Stan błędu: 00100100
    Priorytet błędu: 6
    Częstość błędu: 1
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.07
    Czas: 23:50:25
    Ramka zamrożona:
    zacisk 15 ZAŁ
    Napięcie: 12.05 V
    ON
    ON
    OFF
    OFF
    OFF
    01316 - Sterownik ABS
    Ramka zamrożona:
    Priorytet błędu: 6
    Częstość błędu: 1
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.08
    Czas: 00:37:58
    Ramka zamrożona:
    zacisk 15 ZAŁ
    Napięcie: 12.00 V
    ON
    ON
    OFF
    OFF
    OFF
    Adres 10: Asyst.park./kierow. (J446) Plik etykiet:. 3C8-919-475.clb
    Oznaczenie elementu SW: 1K9 919 475 HW: 1K9 919 475
    Komponent: PARKHILFE 8K H07 0001
    Weryfikacja: -------- Numer seryjny: 90340919001871
    Kodowanie: 100001
    VCID: 78FF5DE7CBD3428F9E-802C
    Znaleziono 1 błąd:
    Ramka zamrożona:
    Priorytet błędu: 6
    Częstość błędu: 1
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.08
    Czas: 00:37:57
    Ramka zamrożona:
    Temperatura: 16.0*C
    Adres 15: Airbag Plik etykiet: 1K0-909-605.lbl
    Oznaczenie elementu SW: 1K0 909 605 T HW: 1K0 909 605 T
    Komponent: 2J AIRBAG VW8 020 2300
    Weryfikacja: 05020000 Numer seryjny: 0038PD2ESE3O
    Kodowanie: 0012874
    VCID: 3D718CF36471A7A78D-8068
    Podsystem 1 - Numer seryjny: 6332MSME49450E2BK
    Podsystem 2 - Numer seryjny: 6342MSME4944210B7
    Podsystem 3 - Numer seryjny: 6351HSME1D2724130
    Podsystem 4 - Numer seryjny: 6361HSME1D27050D9
    Nie znaleziono błędów.
    Adres 16: Koło kierownicy Plik etykiet: 1K0-953-549-MY9.lbl
    Oznaczenie elementu SW: 1K0 953 549 CP HW: 1K0 953 549 CP
    Komponent: J0527 053 0111
    Kodowanie: 0000033
    VCID: 020B3F0F5D0F185FB0-8056
    Adres 17: Zest.wskaźników (J285) Plik etykiet:| 5K0-920-xxx-17.clb-SRI1
    Oznaczenie elementu SW: 5M0 920 860 A HW: 5M0 920 860 A
    Komponent: KOMBI H08 0020
    Weryfikacja: V0008011 Numer seryjny:
    Kodowanie: 170D00
    Kod serwisu: WSC 00066 123 00146
    Zbiór danych ASAM: EV_KombiUDSMM9RM10 A04010
    ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
    VCID: 2C57B1B7470B3E2F2A-8078
    12648448 - Ograniczenie działania z powodu braku informacji
    U1111 00 [008] - -
    Ramka zamrożona:
    Priorytet błędu: 6
    Częstość błędu: 1
    Przebieg: 157456 km
    Data: 2020.09.16
    Czas: 23:50:20
    12656896 - Ograniczenie działania z powodu braku informacji
    U1111 00 [008] - -
    Ramka zamrożona:
    Priorytet błędu: 6
    Częstość błędu: 1
    Przebieg: 157456 km
    Data: 2020.09.17
    Czas: 00:37:56
    Adres 19: CAN Gateway Plik etykiet:. AKP\1K0-907-530-V4.clb
    Oznaczenie elementu SW: 1K0 907 530 AA HW: 1K0 907 951
    Komponent: J533 Gateway H07 0081
    Weryfikacja: H07 01 Numer seryjny: 210709F1001731
    Kodowanie: E9A07F46000202001002
    Kod serwisu: WSC 65535 000 00000
    VCID: 66C3039F5167C47F3C-8032
    5 - ilość znalezionych błędów. Oto one:
    Ramka zamrożona:
    Stan błędu: 00110100
    Priorytet błędu: 2
    Częstość błędu: 1
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.07
    Czas: 23:50:22
    Ramka zamrożona:
    Priorytet błędu: 2
    Częstość błędu: 1
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.08
    Czas: 00:37:58
    00469 - Magistrala danych inforozrywki (Infotainment) w jednoprzewodowym trybie pracy
    012 - usterka elektryczna w obwodzie - Sporadyczny
    Ramka zamrożona:
    Stan błędu: 00101100
    Priorytet błędu: 3
    Częstość błędu: 2
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.09
    Czas: 00:00:03
    01304 - Radio
    Ramka zamrożona:
    Stan błędu: 01100100
    Priorytet błędu: 2
    Częstość błędu: 1
    Wew.licznik błędów: 106
    Przebieg: 156678 km
    Wskaźnik czasu: 0
    Data: 2015.01.01
    Czas: 02:17:22
    01044 - Sterownik zakodowany nieprawidłowo
    000 - -
    Ramka zamrożona:
    Priorytet błędu: 1
    Częstość błędu: 124
    Przebieg: 156678 km
    Wskaźnik czasu: 0
    Data: 2015.01.01
    Czas: 02:17:18
    Adres 25: Immobiliser (J334) Plik etykiet:. 5K0-920-xxx-25.clb
    Komponent: IMMO H08 0020
    Kod serwisu: WSC 00000 000 00000
    Zbiór danych ASAM: EV_ImmoUDSMM9RM10 A01010
    ROD: EV_ImmoUDSMM9RM10_VW12.rod
    Adres 37: Nawigacja
    Adres 42: Elektr.drzwi kier. Plik etykiet:. AKP\1K0-959-701-MAX3.clb
    Oznaczenie elementu SW: 1K0 959 701 AE HW: 1K0 959 793 P
    Komponent: J386 TUER-SG FT 1519
    Weryfikacja: 71009005 Numer seryjny: 00000879698819
    Kodowanie: 0000180
    VCID: 71E960C368A913C759-8024
    Adres 44: Wsp.kierownicy Plik etykiet: 1K0-909-14x-GEN3.clb
    Oznaczenie elementu: 1K0 909 144 H
    Komponent: EPS_ZFLS Kl. 68 2901
    Weryfikacja: 00H17000
    Kod serwisu: WSC 02069 000 90108
    VCID: 2F6DA6BBBE1D45370F-807A
    Ramka zamrożona:
    Priorytet błędu: 3
    Częstość błędu: 1
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.07
    Czas: 23:50:23
    Ramka zamrożona:
    Napięcie: 12.13 V
    DU
    Temperatura: 18.0*C
    Obroty silnika: 1498 /min
    Prędkość: 0.0 km/h
    Prędkość: 0.0 km/h
    Zliczanie: 0
    Ramka zamrożona:
    Priorytet błędu: 3
    Częstość błędu: 1
    Przebieg: 157456 km
    Wskaźnik czasu: 0
    Data: 2015.02.08
    Czas: 00:37:57
    Ramka zamrożona:
    Napięcie: 12.00 V
    DD
    Temperatura: 21.0*C
    Prędkość: 0.0 km/h
    Prędkość: 0.0 km/h
    Zliczanie: 0
    03803 - Czujnik kąta skrętu układu wspomagania kierowania
    000 - - - MIL zapalona
    Ramka zamrożona:
    Stan błędu: 11100000
    Priorytet błędu: 2
    Częstość błędu: 1
    Wskaźnik czasu: 0
    Ramka zamrożona:
    Nap.akumulatora: 11.9 V
    PD
    Temperatura: 18.0*C
    Zliczanie: 2
    Kąt skrętu: 0.00*
    Zliczanie: 0
    cz.kąt.br.ini
    Adres 52: Elektr.drzwi pas. Plik etykiet:. AKP\1K0-959-702-MAX3.clb
    Oznaczenie elementu SW: 1K0 959 702 AE HW: 1K0 959 792 P
    Komponent: J387 TUER-SG BT 1519
    Weryfikacja: 71009005 Numer seryjny: 00000645798901
    Kodowanie: 0000436
    VCID: 72EB6FCF6DAF28DFA0-8026
    Znaleziono 1 błąd:
    00110 - Żarówka kierunkowskazu w lusterku po stronie pasażera (L132)
    Ramka zamrożona:
    Priorytet błędu: 5
    Częstość błędu: 84
    Przebieg: 156678 km
    Wskaźnik czasu: 0
    Data: 2015.01.01
    Czas: 03:50:14
    Adres 56: Radio
    Adres 62: Drzwi tylne lewe Plik etykiet:. AKP\1K0-959-703-GEN3.clb
    Oznaczenie elementu SW: 1K0 959 703 AG HW: 1K0 959 795 R
    Komponent: J388 TUER-SG HL 1401
    Weryfikacja: 11006001 Numer seryjny: 00000004217496
    Kodowanie: 0000144
    VCID: 75E154D31CC13FE785-8020
    Adres 69: Przyczepa Plik etykiet: RETROFIT69.lbl
    Oznaczenie elementu SW: 5F0 05V 010 1 HW: 5F0 05V 010 1
    Komponent: TOWBARMODULE ECS 0010
    Kodowanie: 0000001
    VCID: 285F4DA79BF3120FCE-807C
    Adres 72: Drzwi tylne prawe Plik etykiet:. AKP\1K0-959-704-GEN3.clb
    Oznaczenie elementu SW: 1K0 959 704 AG HW: 1K0 959 794 R
    Komponent: J389 TUER-SG HR 1401
    Weryfikacja: 11006001 Numer seryjny: 00000004215806
    Kodowanie: 0000144
    VCID: 76E353DF01C734FF8C-8022
    can someone please help me with codeing of this abs MK60 EC1 in VW jetta 1.4tsi i have forgotten to save this codeing .
  5. #2615
    Sep 2020
    Poland
    Hi I changed my whole ABS module and forggoten to read the coding from the previous module could somebody help me with the coding
    Car: Jetta 1.4 tsi 2009r. Left hand drive
    vIN: WVWZZZ1KZAM036977 (there was one Z missing in the VIN from VCDS dunno why)
    Chassis type: 1K-VW36 (1K0)
    Scanning: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 69 72
    VIN: WVWZZZ1KZAM036977 Runway: 157450km
    01-Motor -- Status: Fault 1010
    03-ABS/brakes -- Status: Fault 1010
    04 Steering angle. -- Status: OK 0000
    08-Air conditioning -- Status: Fault 0010
    09-Centr.zesp.elektr. -- Status: Fault 0010
    10-Asyst.park./directors. -- Status: Fault 0010
    15-Airbag -- Status: OK 0000
    16- Steering wheel -- Status: OK 0000
    17-Zest.indicators -- Status: Fault 0010
    19-CAN Gateway -- Status: Fault 0010
    25-Immobiliser -- Status: OK 0000
    37-Navigation -- State: Unregistered 0011
    42-Elektr. directional door. -- Status: OK 0000
    44-Wsp.kiergyz - Status: Fault 0010
    46-Comfort Module -- Status: OK 0000
    52-Elektr.door belt. -- Status: Fault 0010
    56-Radio -- Status: Cannot reach 1100
    62-Left rear door -- Status: OK 0000
    69 Trailer -- Status: OK 0000
    72-Rear door right -- Status: OK 0000
    Address 01: Engine (CAX) Label file: 03C-906-022-CAX.clb
    Element designation SW: 03C 906 022 AK HW: 03C 906 022 J
    Component: MED17.5.20 G 5369
    Verification: D5H07--- Serial number:
    Coding: 0000072
    Service code: WSC 66565 257 00032
    3 - number of errors found. Here they are:
    006439 - Relay for additional coolant pump (J496)
    P1927 - 000 - interruption - Occasional
    Frozen frame:
    Error state: 00100000
    Priority of the error: 0
    Error rate: 1
    Wew.error counter: 255
    Time index: 0
    Date: 2047.15.31
    Time: 31:63:63
    Frame is frozen:
    Motor speed: 0 /min
    Load capacity: 0.0 %
    Speed: 0.0 km/h
    Temperature: 33.0*C
    Temperature: 18.0*C
    The pressure of the thing: 1020.0 mbar
    Tension: 11.938 V
    049441 - No communication with the ABS controller
    U0121 - 000 - - - Occasional
    Frozen frame:
    Error rate: 1
    Instructions: 157456 km
    Time index: 0
    Date: 2015.02.08
    Time: 00:37:57
    Frozen frame:
    Engine speed: 0 /min
    Speed: 0.0 km/h
    Temperature: 36.0*C
    Temperature: 20.0*C
    Tension: 11.811 V
    001393 - Brake light switch (F)
    P0571 - 000 - circuit failure
    Frozen frame:
    Error state: 01110000
    Error rate: 1
    Time index: 0
    Date: 2015.02.08
    Time: 23:32:10
    Frame is frozen:
    Speed: 0.0 km/h
    Temperature: 14.0*C
    Temperature: 18.0*C
    Tension: 11.303 V
    Readiness codes: 0000 0000
    Address 03: ABS/brakes (-----) Label file:. 1K0-907-379-60EC1F.clb
    Element designation SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0106
    Verification: 00H35001
    Service code: WSC 06314 000 00000
    6 - number of errors found. Here they are:
    00778 - Steering angle sensor (G85)
    003 - Mechanical failure
    Frozen frame:
    Error state: 01100011
    Priority of the error: 2
    Error rate: 1
    Wew.error counter: 125
    Time index: 0
    Date: 2015.02.08
    Time: 23:28:24
    Frame is frozen:
    Counting: 7
    Counting: 0
    Counting: 12288
    Calculation: 288
    Calculation: 42496
    Calculation: 65280
    Counting: 0
    Counting: 0
    01435 - Brake system pressure sensor 1 (G201)
    005 - No or incorrect basic settings / adaptation
    Frozen frame:
    Error state: 01100101
    Error rate: 1
    Time index: 0
    Date: 2015.02.08
    Time: 23:27:46
    Frame is frozen:
    Counting: 3
    Counting: 0
    Counting: 12288
    Calculation: 279
    Calculation: 42496
    Calculation: 65280
    Counting: 0
    Counting: 0
    Frozen frame:
    Error rate: 1
    Time index: 0
    Date: 2015.02.08
    Time: 23:27:46
    Frame is frozen:
    Counting: 3
    Counting: 0
    Counting: 12288
    Counting: 295
    Calculation: 42496
    Calculation: 65280
    Counting: 0
    Counting: 0
    01423 - Transverse acceleration sensor (G200)
    Frozen frame:
    Error rate: 1
    Time index: 0
    Date: 2015.02.08
    Time: 23:27:46
    Frame is frozen:
    Counting: 3
    Counting: 0
    Counting: 12288
    Counting: 270
    Calculation: 42496
    Calculation: 65280
    Counting: 0
    Counting: 0
    00003 - Controller
    Frozen frame:
    Priority of the error: 1
    Error rate: 1
    Time index: 0
    Date: 2015.02.09
    Time: 00:44:19
    Frozen frame:
    Counting: 3
    Counting: 0
    Counting: 12288
    Calculation: 143
    Calculation: 42496
  6. #2616
    Sep 2020
    Can somebody help with long coding for:
    Audi A3
    2009
    1.9BLS
    105BHP
    WAUZZZ8P3AA000747
    1K0907379AN ESP MK60EC1 H450107
  7. #2617
    Nov 2009
    South Africa
    Default jetta 6 abs mk6ec1
    hi guys. please assist in abs long coding for jetta 6. pr numbers i sent. new vin last 5 digits is 07873. customer replaced ecu and other cluster. thanks. keep well.
  8. #2618
    Sep 2020
    Hi can anyone help me I’m after my abs/esp long code please
    1k0907379an
    has esp button no tpms
    Wauzzz8p49a097355
    1.9 bls RHD manual
    Last edited by Egapnerrad; 27th September, 2020 at 05:34 PM. Reason: Forgot to enter something
  9. #2619
    Feb 2018
    Egapnerrad
    check code :
    11422012092B0001880E04E9901E00403800
  10. #2620
    Sep 2020
    Default Thanks
    Hi thanks so much code has gone in but now esp light is on could this be another fault? Thanks
  11. #2621
    Dec 2010
    hy all!
    Please Help ! I need ABS Long coding seat ibiza 2012 ess1.4 Manual gearbox
    VIN: VSSZZZ6JZDR084691
    6r0907379ab
    Regards
  12. #2622
    Senior Member MOUTRO's Avatar
    Nov 2009
    Greece
    Hi.can anyone help with long coding for VW Caddy
    vin WV1ZZZ2KZEX041026
    abs/esp MK60EC1 1K0907379BL
  13. #2623
    macako6's Avatar
    Mar 2015
    Quote Originally Posted by MOUTRO View Post
    423C000D092600FB420B00E6901F0000000000
  14. The Following User Says Thank You to macako6 For This Useful Post:
    MOUTRO (1st October, 2020)
  15. #2624
    Nov 2009
    Greece
    Quote Originally Posted by macako6 View Post
    but still having 01044 code and 01279
    do you have anther long code
  16. #2625
    macako6's Avatar
    Mar 2015
    this is correct
    423C400D092600FB420B02E6901F0062300000
  17. The Following User Says Thank You to macako6 For This Useful Post:
