Page 136 of 245 FirstFirst ... 3686126131132133134135136137138139140141146186236 ... LastLast
Results 2,026 to 2,040 of 3668
  1. #2026
    Oct 2019
    Default Long coding ABS MK60 EC1
    Hi ... can you help me to encode an ABS MK60 EC1 ????
    Golf 1.4 tsi Engine CAXA VIN WVWZZZ1KZAP162676.
    ]Thanks.
  2. #2027
    Apr 2016
    uk
    hi
    i need abs coding on an audi a3 2010 1.8 petrol RHD
    i added a full scan of the car made with vcds..
    if someone could help..
  3. #2028
    Apr 2016
    uk
    Quote Originally Posted by comizelu View Post
    hi
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
    Component: ESP MK60EC1 H30 0107 Revision: 00H30001
    Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb Part No SW: 8P7 907 115 K HW: 8P0 907 115 Q
    Component: 1.8l R4/4V TFSI 0020 Revision: AAH11--- Serial number: AUX7Z0I8FNU008
    .... thanks!
    Sent from my MI MAX 3 using Tapatalk
  4. The Following User Says Thank You to comizelu For This Useful Post:
    jomberykaso (19th October, 2019)
  5. #2029
    Jul 2011
    Default Skoda yetti 2.0
    Hello friends
    I want skoda yetti 2.0 rhd diesel long code
    Thanks in advance
  6. #2030
    Jan 2018
    witam potrzebuje kodowania pomp abs
    Skoda octavia 1.4 caxa 2011rok
    TMBCJ61Z8B2120159
  7. #2031
    Jan 2018
    Ogarnięte zrobiłem to sam każdy Bit ręcznie krok po kroku ,....: rofl:
  8. #2032
    Jun 2017
    I need long coding for Vw golf V with abs MK60EC1.
    VIN: WVWZZZ1KZ9W094384
    1.4 TSI
    1K0 907 379 CE
    Left hand
  9. #2033
    May 2018
    I need long coding for VW GOLF VI Variant with ESP MK60EC1.
    VIN: WVWZZZ1KZCM618807
    N.I.V. AJ522V
    1.6 TDI CAYC 77KW
    1K0 907 379 BJ
    Left hand
  10. #2034
    Jun 2016
    I need long coding
    No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
    Component: ESP MK60EC1 H31 0152
    VIN: WVGZZZ1TZDW056069
  11. #2035
    Jun 2016
  12. #2036
    Jun 2016
    Jan 2019
    hello i need a long coding
    cadi vin WV1ZZZ2KZEX149569
    ESP MK60EC1
    HW 1K0907379BM engine 1.6tdi
    Right hand thanks
  14. #2038
    Jan 2019
    ESP MK60EC1
    Right hand thanks
  15. #2039
    Jun 2017
    VW GOLF5 2009 ABS Long Coding Help Needed (MK60EC1)
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 76
    77
    VIN: WVWZZZ1KZ8W586784 Mileage: 88230km-54823miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: Not registered 0011
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Cannot be reached 1100
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: Malfunction 0010
    Address 01: Engine Labels: 03C-906-032-BLG.lbl
    Part No SW: 03C 906 032 AL HW: 03C 906 032 C
    Component: MED17.5.1 6458
    Revision: 96H07--- Serial number: VWXBZ0H0749695
    Coding: 0000075
    Shop #: WSC 00102 935 176006
    VCID: 67D6A69C566EF37706-8032
    2 Faults Found:
    001299 - Incorrect Immobilizer Key
    P0513 - 000 -
    Freeze Frame:
    Fault Status: 01110000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 88191 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:14:05
    Freeze Frame:
    RPM: 1506 /min
    Load: 11.8 %
    Speed: 0.0 km/h
    Temperature: 80.0°C
    Temperature: 44.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 12.065 V
    008198 - Intake Manifold Flap; Bank 1
    P2006 - 000 - Stuck Closed
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 88191 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:14:12
    Freeze Frame:
    RPM: 780 /min
    Load: 19.6 %
    Speed: 0.0 km/h
    Temperature: 80.0°C
    Temperature: 43.0°C
    Voltage: 13.589 V
    Readiness: 0010 0000
    Address 02: Auto Trans Labels: 02E-927-770.clb
    Part No SW: 02E 300 050 M HW: 02E 927 770 AL
    Component: GSG DSG AG6 541 1460
    Revision: 54104 Serial number: 00001707190983
    Coding: 0000020
    Shop #: WSC 04940 001 00001
    VCID: 1C3CC970DFA8E0AF5B-8048
    No fault code found.
    Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 CE HW: 1K0 907 379 AE
    Component: ESP MK60EC1 H35 0120
    Revision: 00H35001
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 43320 001 1048576
    VCID: 77F6F6DCC6CE63F796-8022
    6 Faults Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 6
    Mileage: 88238 km
    Time Indication: 0
    Freeze Frame:
    Count: 16391
    Count: 0
    Count: 12288
    Count: 195
    Count: 44032
    Count: 0
    Count: 0
    Count: 512
    00778 - Steering Angle Sensor (G85)
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 6
    Mileage: 88238 km
    Time Indication: 0
    Freeze Frame:
    Count: 16391
    Count: 0
    Count: 12288
    Count: 292
    Count: 44032
    Count: 0
    Count: 0
    Count: 512
    01435 - Brake Pressure Sensor 1 (G201)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 6
    Mileage: 88238 km
    Time Indication: 0
    Freeze Frame:
    Count: 16391
    Count: 0
    Count: 12288
    Count: 279
    Count: 44032
    Count: 0
    Count: 0
    Count: 512
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 6
    Mileage: 88238 km
    Time Indication: 0
    Freeze Frame:
    Count: 16391
    Count: 0
    Count: 12288
    Count: 295
    Count: 44032
    Count: 0
    Count: 0
    Count: 512
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 6
    Mileage: 88238 km
    Time Indication: 0
    Freeze Frame:
    Count: 16391
    Count: 0
    Count: 12288
    Count: 270
    Count: 44032
    Count: 0
    Count: 0
    Count: 512
    00150 - Plausibility Brake Booster System
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 6
    Mileage: 88238 km
    Time Indication: 0
    Freeze Frame:
    Count: 16391
    Count: 0
    Count: 12288
    Count: 398
    Count: 44288
    Count: 0
    Count: 0
    Count: 512
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
    Component: Climatic PQ35 142 1111
    Revision: 00142031 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 76E8FBD801C41AFF8D-8022
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
    Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 00000008747657
    Coding: E78F0F2700041500471400001400000000087F075C00010000 0000000000
    Shop #: WSC 00000 785 00200
    VCID: 336E02CC52364FD76A-8066
    Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 220708 021 0501
    Coding: 00038805
    Shop #: WSC 00000
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 200808 054 0402
    Coding: 00217261
    Shop #: WSC 00000
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
    Component: 58 AIRBAG VW8R 034 8000
    Revision: 05034000 Serial number: 003B6D0BS0C+
    Coding: 0013624
    Shop #: WSC 01357 011 00200
    VCID: 6CDCD9B04F88D02F6B-8038
    Subsystem 1 - Serial number: 6332MSME3E624924F
    Subsystem 2 - Serial number: 6342MSME3E66334FQ
    Subsystem 3 - Serial number: 6352QSME76004200$
    Subsystem 4 - Serial number: 6362QSME786D3D61Z
    1 Fault Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    013 - Check DTC Memory - MIL ON
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
    Component: J0527 051 0101
    Coding: 0002122
    Shop #: WSC 01392 785 00200
    VCID: 78F4F5E00BD06C8F9F-802C
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K0 920 874 A HW: 1K0 920 874 A
    Component: KOMBIINSTRUMENT VDD 2416
    Revision: V0002000 Serial number: 00000000000000
    Coding: 0007103
    Shop #: WSC 13585 002 1048576
    VCID: 2B5E1AAC8A06171722-807E
    1 Fault Found:
    00003 - Control Module
    014 - Defective
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 74519 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:01:18
    Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533 Gateway H07 0062
    Revision: H07 01 Serial number: 220708F1000403
    Coding: 6D817F0E4006020002
    Shop #: WSC 27202 002 104857
    VCID: 356A3CD45C4251E744-8060
    3 Faults Found:
    01300 - Control Module for Navigation with CD-Rom (J401)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 6
    Mileage: 88238 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:12:15
    01304 - Radio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 6
    Mileage: 88238 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:12:15
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 88238 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:12:10
    Address 25: Immobilizer
    Cannot be reached
    Address 37: Navigation
    Cannot be reached
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
    Part No SW: 1K0 959 701 AL HW: 1K0 959 701 AL
    Component: Tuer-SG 006 1203
    Coding: 0000182
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
    Part No: 1K1 909 144 M
    Component: EPS_ZFLS Kl.070 H08 1901
    Shop #: WSC 27202 002 1048576
    2 Faults Found:
    02546 - Steering Limit Stop
    Freeze Frame:
    Mileage: 88220 km
    Temperature: 32.0°C
    Voltage: 12.40 V
    Voltage: 12.20 V
    014 - Defective
    Freeze Frame:
    Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0204
    Revision: 00020000 Serial number: 00000000000000
    Coding: 809002005103087F2D0484056008CF03E0FC00
    VCID: 030E920C42163F57BA-8056
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
    Part No SW: 1K0 959 702 AL HW: 1K0 959 702 AL
    Coding: 0000438
    VCID: 79F2F0E430DA7587E0-802C
    Address 55: Headlight Range Labels: 1T0-907-357.lbl
    Part No: 1T0 907 357
    Component: Dynamische LWR 0003
    Coding: 0000003
    VCID: 74ECC1D017B808EFB3-8020
    Address 56: Radio
    Cannot be reached
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
    Component: Tuer-SG 006 1305
    Coding: 0000144
    Shop #: WSC 01392 785 1012552
    VCID: 387435E04B50AC8F5F-806C
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
    Coding: 0000144
    VCID: 397230E4705AB587A0-806C
    Address 76: Park Assist Labels: 1K0-919-283.lbl
    Part No: 1K0 919 283 A
    Component: 22 Einparkhilfe 0101
    VCID: 2D5A14B4B41219273C-8078
    Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
    Part No SW: 1K8 035 730 HW: 1K8 035 730
    Component: Telefon H06 3100
    Revision: 00006000 Serial number: 20387920025966
    Coding: 012100
    Shop #: WSC 01316 785 00200
    VCID: 66C8AB989164EA7F3D-8032
    2 Faults Found:
    03426 - Left Audio Channel
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 6
    Mileage: 88238 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:12:12
  16. #2040
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by kawagatto View Post
    ]Thanks.
    Here is your Long coding :
    113B200D092800FC881104EB901F0040350000
    Please Press Thanks and Rep
  17. The Following User Says Thank You to vagva For This Useful Post:
    Zadleer (30th January, 2021)
