Hi ... can you help me to encode an ABS MK60 EC1 ????
Golf 1.4 tsi Engine CAXA VIN WVWZZZ1KZAP162676.
]Thanks.
]Thanks.
hi
i need abs coding on an audi a3 2010 1.8 petrol RHD
i added a full scan of the car made with vcds..
if someone could help..
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107 Revision: 00H30001
Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb Part No SW: 8P7 907 115 K HW: 8P0 907 115 Q
Component: 1.8l R4/4V TFSI 0020 Revision: AAH11--- Serial number: AUX7Z0I8FNU008
.... thanks!
Sent from my MI MAX 3 using Tapatalk
jomberykaso (19th October, 2019)
Hello friends
I want skoda yetti 2.0 rhd diesel long code
Thanks in advance
witam potrzebuje kodowania pomp abs
Skoda octavia 1.4 caxa 2011rok
TMBCJ61Z8B2120159
Ogarnięte zrobiłem to sam każdy Bit ręcznie krok po kroku ,....: rofl:
I need long coding for Vw golf V with abs MK60EC1.
VIN: WVWZZZ1KZ9W094384
1.4 TSI
1K0 907 379 CE
Left hand
I need long coding for VW GOLF VI Variant with ESP MK60EC1.
VIN: WVWZZZ1KZCM618807
N.I.V. AJ522V
1.6 TDI CAYC 77KW
1K0 907 379 BJ
Left hand
I need long coding
No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
VIN: WVGZZZ1TZDW056069
hello i need a long coding
cadi vin WV1ZZZ2KZEX149569
ESP MK60EC1
HW 1K0907379BM engine 1.6tdi
Right hand thanks
ESP MK60EC1
Right hand thanks
VW GOLF5 2009 ABS Long Coding Help Needed (MK60EC1)
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 76
77
VIN: WVWZZZ1KZ8W586784 Mileage: 88230km-54823miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Not registered 0011
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: 03C-906-032-BLG.lbl
Part No SW: 03C 906 032 AL HW: 03C 906 032 C
Component: MED17.5.1 6458
Revision: 96H07--- Serial number: VWXBZ0H0749695
Coding: 0000075
Shop #: WSC 00102 935 176006
VCID: 67D6A69C566EF37706-8032
2 Faults Found:
001299 - Incorrect Immobilizer Key
P0513 - 000 -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 88191 km
Time Indication: 0
Date: 2000.00.00
Time: 11:14:05
Freeze Frame:
RPM: 1506 /min
Load: 11.8 %
Speed: 0.0 km/h
Temperature: 80.0°C
Temperature: 44.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.065 V
008198 - Intake Manifold Flap; Bank 1
P2006 - 000 - Stuck Closed
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 88191 km
Time Indication: 0
Date: 2000.00.00
Time: 11:14:12
Freeze Frame:
RPM: 780 /min
Load: 19.6 %
Speed: 0.0 km/h
Temperature: 80.0°C
Temperature: 43.0°C
Voltage: 13.589 V
Readiness: 0010 0000
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 050 M HW: 02E 927 770 AL
Component: GSG DSG AG6 541 1460
Revision: 54104 Serial number: 00001707190983
Coding: 0000020
Shop #: WSC 04940 001 00001
VCID: 1C3CC970DFA8E0AF5B-8048
No fault code found.
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 43320 001 1048576
VCID: 77F6F6DCC6CE63F796-8022
6 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 0
Count: 12288
Count: 195
Count: 44032
Count: 0
Count: 0
Count: 512
00778 - Steering Angle Sensor (G85)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 0
Count: 12288
Count: 292
Count: 44032
Count: 0
Count: 0
Count: 512
01435 - Brake Pressure Sensor 1 (G201)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 0
Count: 12288
Count: 279
Count: 44032
Count: 0
Count: 0
Count: 512
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 0
Count: 12288
Count: 295
Count: 44032
Count: 0
Count: 0
Count: 512
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 0
Count: 12288
Count: 270
Count: 44032
Count: 0
Count: 0
Count: 512
00150 - Plausibility Brake Booster System
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 0
Count: 12288
Count: 398
Count: 44288
Count: 0
Count: 0
Count: 512
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 76E8FBD801C41AFF8D-8022
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008747657
Coding: E78F0F2700041500471400001400000000087F075C00010000 0000000000
Shop #: WSC 00000 785 00200
VCID: 336E02CC52364FD76A-8066
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 220708 021 0501
Coding: 00038805
Shop #: WSC 00000
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 200808 054 0402
Coding: 00217261
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 58 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0BS0C+
Coding: 0013624
Shop #: WSC 01357 011 00200
VCID: 6CDCD9B04F88D02F6B-8038
Subsystem 1 - Serial number: 6332MSME3E624924F
Subsystem 2 - Serial number: 6342MSME3E66334FQ
Subsystem 3 - Serial number: 6352QSME76004200$
Subsystem 4 - Serial number: 6362QSME786D3D61Z
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 051 0101
Coding: 0002122
Shop #: WSC 01392 785 00200
VCID: 78F4F5E00BD06C8F9F-802C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 874 A HW: 1K0 920 874 A
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0002000 Serial number: 00000000000000
Coding: 0007103
Shop #: WSC 13585 002 1048576
VCID: 2B5E1AAC8A06171722-807E
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 74519 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:18
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 220708F1000403
Coding: 6D817F0E4006020002
Shop #: WSC 27202 002 104857
VCID: 356A3CD45C4251E744-8060
3 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Date: 2000.00.00
Time: 11:12:15
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Date: 2000.00.00
Time: 11:12:15
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 88238 km
Time Indication: 0
Date: 2000.00.00
Time: 11:12:10
Address 25: Immobilizer
Cannot be reached
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1K0 959 701 AL HW: 1K0 959 701 AL
Component: Tuer-SG 006 1203
Coding: 0000182
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.070 H08 1901
Shop #: WSC 27202 002 1048576
2 Faults Found:
02546 - Steering Limit Stop
Freeze Frame:
Mileage: 88220 km
Temperature: 32.0°C
Voltage: 12.40 V
Voltage: 12.20 V
014 - Defective
Freeze Frame:
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 809002005103087F2D0484056008CF03E0FC00
VCID: 030E920C42163F57BA-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1K0 959 702 AL HW: 1K0 959 702 AL
Coding: 0000438
VCID: 79F2F0E430DA7587E0-802C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74ECC1D017B808EFB3-8020
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1305
Coding: 0000144
Shop #: WSC 01392 785 1012552
VCID: 387435E04B50AC8F5F-806C
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
VCID: 397230E4705AB587A0-806C
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 22 Einparkhilfe 0101
VCID: 2D5A14B4B41219273C-8078
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 HW: 1K8 035 730
Component: Telefon H06 3100
Revision: 00006000 Serial number: 20387920025966
Coding: 012100
Shop #: WSC 01316 785 00200
VCID: 66C8AB989164EA7F3D-8032
2 Faults Found:
03426 - Left Audio Channel
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Date: 2000.00.00
Time: 11:12:12
Zadleer (30th January, 2021)
