Page 195 of 245 FirstFirst ... 95145185190191192193194195196197198199200205 ... LastLast
Results 2,911 to 2,925 of 3668
  1. #2911
    May 2014
    Hi. Can someone help.
    VW golf plus 1.9TDI BLS
    Change from Rhd to Lhd
    VCDS scan in ADD
  2. #2912
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by rafalgt View Post
    VCDS scan in ADD
    One of these should be your ABS long coding :
    134B000C092300FEC81300E7901C0000000000
    163B600D212300FE681306E7841C0080310000
    you maybe need to add or remove 00 from the end
  3. #2913
    Jul 2011
    I need help with long code abs /ESP Touran :
    year:2012 year
    transmition : DSG
    engine:1.6TDI
    WVGZZZ1TZDW030102
    ESP MK60EC1 H31 0152
    1K0 907 379 BL
    left hand drive, front-wheel drive
    Thanks in advance for help!
  4. #2914
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by DreamLand69 View Post
    year:2012 year
    transmition : DSG
    engine:1.6TDI
    WVGZZZ1TZDW030102
    1K0 907 379 BL
    10 years with ONLY 15 posts <<
    help others to get help
  5. The Following User Says Thank You to vagva For This Useful Post:
    DreamLand69 (31st March, 2021)
  6. #2915
    Jul 2011
    Quote Originally Posted by vagva View Post
    It's a shame. It's okay. Could someone help me? I'd be very grateful.
  7. #2916
    vagva's Avatar
    Apr 2016
    Here is your long coding :
    323B401609250EFA4C0C02E4901B7051310000
    You may be need to add or remove 00 from the end
  8. The Following 2 Users Say Thank You to vagva For This Useful Post:
    DreamLand69 (31st March, 2021), kusasusa (1st April, 2021)
  9. #2917
    Jul 2011
    Thank you very much, it worked perfectly.
  10. #2918
    Mar 2010
    Eu
    I need help with long code abs /ESP Golf V :
    year:2010 year
    transmition :manual gear box
    engine:BLS 1.9TDI
    WVWZZZ1KZ9M273103
    ESP MK60EC1 H45 0107
    1K0 907 379 AP
    Thanks in advance for help and regards.
  11. #2919
    Feb 2017
    Hello guys,
    I need some help with the long conding for ESP
    Golf 5 GT LHD 2.0TDI FWD manual
    WVWZZZ1KZ8W085705
    1k0 907 379 BJ
    312/282 brakes
    I tried to put the one below but it doesn't work and I can't figure it out. Any help it's apreciated.
    114B600C092A00FF881206E4901E0042002000
    Thank you in advance!
  12. #2920
    vagva's Avatar
    Apr 2016
    Quote Originally Posted by georgeMKO View Post
    Hello guys,
    WVWZZZ1KZ8W085705
    1k0 907 379 BJ
    312/282 brakes
    4 years and just 8 posts Only !!!!
    weird guys , Help others to get Help
  13. The Following User Says Thank You to vagva For This Useful Post:
    georgeMKO (3rd April, 2021)
  14. #2921
    Jan 2018
    Hi all can someone give me a help with long coding for abs esp pump.
    1K0907379AD
    ESP MK60EC1
    H35 0106
    WCS06314
    WAUZZZ8P99A102498
    Front discs 345 mm
    Rear 310 mm.
    Thanks in advance.
  15. #2922
    Feb 2017
    Quote Originally Posted by Bitlas View Post
    1K0907379AD
    ESP MK60EC1
    H35 0106
    WCS06314
    WAUZZZ8P99A102498
    Front discs 345 mm
    Rear 310 mm.
    Thanks in advance.
    Try 11428012092200FC880F01ED90210041000000
  16. #2923
    Feb 2017
    Quote Originally Posted by kusasusa View Post
    year:2010 year
    engine:BLS 1.9TDI
    WVWZZZ1KZ9M273103
    1K0 907 379 AP
    Try this: 114B400C092900FD880C02E4901C0041000000 or remove 00 if it's too long.
  17. #2924
    Jan 2018
    Hi thanks for you reply ok I will try tommorow and let you know.
  18. #2925
    Jan 2018
    Hi your code does not work.
