TMBBE61Z582205792
1K0907379AD
LHD
FWD MANUAL TRANSMISSION
ESP
NO TPMS
NO HHC
THANKS
TMBBE61Z582205792
1K0907379AD
LHD
ESP
NO TPMS
NO HHC
THANKS
BMM ENGINE
sorry
113B401C092200FF881202ED901B00423000
It worked, Right bytes
thanks again!
r4nd0mize (20th January, 2022)
Hello can u help me with this?
TMBBS61Z392043901
1K0907379AD
LHD
ESP
NO TPMS
NO HHC
bxe ENGINE CODE
danypk (1st February, 2022)
Hello, please help ABS / ESP replacement of the ABS pump, long coding needed.
Golf 5, 2008 oorsBKC 1.9 TDi
vin.WVWZZZ1KZ8W046508
1K0907379AC
ESP FRON
Software version0101
ECU 0023170
left hand drive
no TMPS
thank you
This is MK60 (short decimal coding), not MK60EC1.
Use this.
kikibol (22nd January, 2022)
Hello guys,
Would need your help with the code for MK60EC1. I have replaced the ABS unit and wasn't smart enough to copy the previous code i have only 00000 now.
Details about the car:
Skoda Octavia
2.0TDI CFHC
DSG Gearbox
No TPMS
LHD
VIN: TMBBE61Z9C8008615
Part no.: 1K0614517DD
Many thanks in advance
1K0614517DD is not a software part number. It is hw sw combination number or order part number or something but not sw part number.
I can only recommend (anyone) to post scans in a text file or at least the identification data as an extract from it a to avoid passing wrong information or causing irritation. It only ends up the people trying to help having more work and/or creating wrong coding.
Hi, sorry for confusion, the part no. 1K0614517DD i was meaning the code which is on the mounted ABS pump.
Yes, and therefore it is the part number for the pump that is mounted. But it needs the part number from the software that is running on the electronic control unit attached to the pump. It is the software that needs the coding, not the pump. So please provide software part number (and preferrable hw part number from the electronic). Both are part of identification in diagnostics (part of every full scan).
Please need your help me.
Needed coding long ABS module for
Skoda Octavia 2010
Engine 1.8 TSI
Trasmision automatic
VIN TMBBK6121A2044212
Thanks from Chile
Needs your help to help you.
I think your VIN is wrong. There is no octavia with "12" as identification in VIN. Guess typical case of not just simply provide a scan, but instead hand writing false informationBesides that, not enough information to recreate anyways
